Масла Red Line
Официальный сайт: http://www.redlineoil.com/
15304 - Red Line 5W-30 Motor Oil, 0.946L
15305 - Red Line 5W-30 Motor Oil,  3.8L
15306 - Red Line 5W-30 Motor Oil, 19L
12304 - Red Line Euro-Series 5W-30 Motor Oil, 0.946L
15404 - Red Line 5W-40 Motor Oil 0.946L
15405 - Red Line 5W-40 Motor Oil 3.8L
15406 - Red Line 5W-40 Motor Oil 19L
12404 - Red Line Euro-Series 5W-40, 0.946L
11804 - Red Line Syntetic Oil 0W-20, 0.946L
11805 - Red Line Syntetic Oil 0W-20, 3.8L
11114 - Red Line Syntetic Oil 0W-30, 0.946L
11115 - Red Line Syntetic Oil 0W-30, 3.8L
11116 - Red Line Syntetic Oil 0W-30, 19L
11104 - Red Line Syntetic Oil 0W-40, 0.946L
11105 - Red Line Syntetic Oil 0W-40, 3.8L
11106 - Red Line Syntetic Oil 0W-40, 19L
15204 - Red Line Syntetic Oil 5W-20, 0.946L
15205 - Red Line Syntetic Oil 5W-20, 3.8L
15206 - Red Line Syntetic Oil 5W-20, 19L
11604 - Red Line Syntetic Oil 5W-50, 0.946L
11605 - Red Line Syntetic Oil 5W-50, 3.8L
11304 - Red Line 10W-30 Motor Oil, 0.946L
11305 - Red Line 10W-30 Motor Oil, 3.8L
11306 - Red Line 10W-30 Motor Oil, 19L
11404 - Red Line 10W-40 Motor Oil, 0.946L
11405 - Red Line 10W-40 Motor Oil, 3.8L
11406 - Red Line 10W-40 Motor Oil, 19L
11504 - Red Line 15W-50 Motor Oil, 0.946L
11505 - Red Line 15W-50 Motor Oil, 3.8L
11506 - Red Line 15W-50 Motor Oil, 19L
12504 - Red Line 20W-50 Motor Oil, 0.946L
12505 - Red Line 20W-50 Motor Oil, 3.8L
12506 - Red Line 20W-50 Motor Oil, 19L
21404 - Red Line 15W-40 Diesel Oil, 0.946L
21405 - Red Line 15W-40 Diesel Oil, 3.8L
21406 - Red Line 15W-40 Diesel Oil, 19L
11704 - Red Line 10W-60 Motor Oil, 0.946L
11705 - Red Line 10W-60 Motor Oil, 3.8L
11706 - Red Line 10W-60 Motor Oil, 19L
Любительские тесты на замерзание:
-29С Сравнение масел 0W-40, Redline, Shell, Neste, Yacco, Addinol, Petronas, Lukoil Genesis 2016-2017 год
-32C Сравнение масел 0W-40, Redline, Shell, Neste, Yacco, Addinol, Petronas, Lukoil 2016-2017 год
Без запроса в головной офис дату производства не расшифровать
Red Line Motor Oil 0W-40 API SN + Анилиновая точка
RedLine Motor Oil 5W-30 API SN + Анилиновая точка
Redline Motor Oil WT40 Polaris Lab
RedLine Euro Series 5W-30 корейская лаборатория
Red Line Euro Series 5W-30 Polaris Laboratories
Red Line High Performance 0W-20 Polaris Laboratories
Red Line Euro-Series 5W-30 2022
RedLine Professional-Series 5W-20 Motor Oil
Redline 20W-50 Motorcycle
Redline 0W-20
Redline 5W-20
Redline 5W-30
Redline 5W-40
Redline 0W-40
Redline Euro Series 5W-30
Redline Professional Series 5W-30 TD
Redline 10W-40 Motorcycle Oil
Redline Professional Series Motor Oil 5W-40
RedLine DCTF Dual Clutch Transmission Fluid лаборатория OelCheck
Redline MT-85 75W-85 GL-4 Gear Oil
Redline 75W-90 GL-5 Gear Oil
RedLine 75W-90 GL-5 Polaris Laboratory
Redline ATF DCTF
Redline D6 ATF
Redline 5W-40 SN (2022-23) отработка Mercedes SLC43 после 3737 км (144 мч)
Red Line Motor Oil 5W-30 отработка на BMW X6 после 7012км
RedLine Professional-Series 5W-30 TD EURO отработка на VW Tuareg после 4684 км
Red Line 5W-30 Motor Oil отработка на BMW X6 после 7185км
RedLine 0W-40 отработка на BMW Е90 325i после 12 410 км
Redline Euro-Series 5W-30 Motor Oil отработка на Range Rover Evoque 2.2 после 9133км
Redline Oil 0W-30 отработка на Range Rover Evoque 2.2 после 8500км
Red Line 5W-20 отработка на Mitsubishi Outlander XL после 7800 км
Red Line 0W-30 Motor Oil отработка на Mercedes ML166 350CDI после 10900км
RedLine High Performance 10W-40 отработка на Porsche Cayenne S 4.8 (958.1) после 9000км
Red Line 5W-30 Motor Oil отработка на BMW X6 после 6807 км
Red Line Professional Series 5W-30 TD Motor Oil отработка на Ниссан Патфайндер (V9X) после 6069 км (172 м.ч.)
Red Line Euro-Series 5W-30 Motor Oil отработка на Ниссан Патфайндер (V9X) после 11652 км
Red Line Euro Series 5W-30 на Ниссан Патфайндер(V9X) после 7100 км
Red Line 5W-40 отработка на Mercedes Benz GL500 после 6300км
Red Line 5W-20 отработка на KIA RIO III после 4500км
Red Line 0W-20 отработка на Mitsubishi Outlander XL после 4000 км
Red Line 5W-40 отработка на Mercedes A45AMG 3346 км
Red Line 10W-60 отработка на Audi RS6 после 6500 км.
Red Line Euro Series 5W-30 отработка на AUDI A1 после 9606км
22.12.2021 в 14:50, FlameRat сказал:
До конца какого года? Текущего 2021? 2022,2023…
5w30 нигде нет
Доброго времени суток ! Не было , причину указали . Ёрничить можно сколько угодно , но больше всего заинтересованы в наличие мы сами . Поэтому делаем всё что возможно .
Масло в наличие на центральном складе , доступно у дилеров в зависимости от удаленности .
27.04.2021 в 10:34, moryacek сказал:
Добрый день, не нашёл в теме... Интересует 5W50 на базе эстеров для спортивного мотора, что посоветуете?
28.04.2021 в 18:36, Redline_moscow сказал:
Доброго дня! 5W50 High Perfomance.
Артикулы для заказа: 11604 - 0,95л. 11605 - 3,8л.
@Redline_moscowподскажите, пожалуйста, какой сейчас процент эстеров в этом масле?
масло опять поменялось
https://www.redlineoil.com/Content/files/tech/0W20_MO_PROD_INFO_2023.pdf
Здравствуйте. Подскажите, существует ли RED LINE 5W30 A5/B5? Что-то не наблюдаю такого.
39 минут назад, soso сказал:
У них как и у Амса, все допуски на одной канистре :)
1 час назад, soso сказал:
A5/B5 они вязкостью 5W20 закрывают.
30.04.2023 в 21:25, soso сказал:
Доброго времени суток . 0W30 в линейки High - Performance
14 минут назад, Арбуэ сказал:
Там рецептуру изменили
https://www.redlineoil.com/0w30-motor-oil
Нулёвка с КВ40 60 сСт. Прикольная, густая. И Dexos1 gen3 подвезли.
On 12/24/2021 at 6:16 PM, Вадим_69 said:
MentalMonday думаю, да. 10 тыс. - предел...
А 5W-30 этой же серии не пробовали? Авто по-другому "побежит"... И HTHS=3.7 достаточно.
Сегодняшний ответ Red Line на вопрос им о наличии у них лимита в моточасах. Вопрос затрагивал серию High Performance.
We suggest following the OEM recommendations for oil drain intervals. Although we state some of our product can have extended drain intervals, a common practice would be every 3000 to 5000 miles along with a filter change and or change oil annually.  Under severe conditions you always consider shorting the drain interval. One way in determining how well oils hold up under certain conditions would be to an oil analysis. This process can help determine the life of the oil after milage is met,  to determine if less or more frequent changes are needed.
Although we are confident that our products will meet and or exceed OEM recommendations, it always best to follow normal maintenance schedule and recommendations.
Анализы рекомендуют)
Изменено пользователем ThetaN
Раньше катал на LM, делал анализ, была выроботка никеля (22), меди (11). После перехода на RedLine никел упал до (0), медь до (5). Покозания мне нравятся.
Может кто может ответить на такой вопрос. При LM дизеля было (1,6), а при RedLine сейчас (5,5), увеличилось. Страшно ли это? От куда он? Полный анализ могу предоставить для информации или нужд oil-club.ru
Изменено пользователем twixti
Кто-нибудь пробовал заливать RedLine DCTF в dq381/dl382? Поделитесь отзывом, как работает коробка на этом масле
Изменено пользователем mparty
Не обычный вопрос: сейчас в дороге и с собой нет бутылки данного масла. Машина попросила долить, что посоветуете долить из стороннего масла, что бы 1000км проехать спокойно? Двигатель BMW n63b44 4.4l.
P.S. из того что вижу на заправках всякие ZIC, масло от Газпромнефть, что продается на заправках Танеко.
Изменено пользователем FlameRat
Любое вообще доливайте 5w40, не до выбора сейчас... Газпромнефть Лукойл нормально. Ничего не будет, докатаете интервал и сольете как обычно Редлайн.
2 часа назад, torcon сказал:
Залил в итоге ZIC X9 LS 5w30 с допуском BMW LL-04 надеюсь vhvi и pao базы подружатся
