Масла Red Line
Официальный сайт: http://www.redlineoil.com/
15304 - Red Line 5W-30 Motor Oil, 0.946L
15305 - Red Line 5W-30 Motor Oil,  3.8L
15306 - Red Line 5W-30 Motor Oil, 19L
12304 - Red Line Euro-Series 5W-30 Motor Oil, 0.946L
15404 - Red Line 5W-40 Motor Oil 0.946L
15405 - Red Line 5W-40 Motor Oil 3.8L
15406 - Red Line 5W-40 Motor Oil 19L
12404 - Red Line Euro-Series 5W-40, 0.946L
11804 - Red Line Syntetic Oil 0W-20, 0.946L
11805 - Red Line Syntetic Oil 0W-20, 3.8L
11114 - Red Line Syntetic Oil 0W-30, 0.946L
11115 - Red Line Syntetic Oil 0W-30, 3.8L
11116 - Red Line Syntetic Oil 0W-30, 19L
11104 - Red Line Syntetic Oil 0W-40, 0.946L
11105 - Red Line Syntetic Oil 0W-40, 3.8L
11106 - Red Line Syntetic Oil 0W-40, 19L
15204 - Red Line Syntetic Oil 5W-20, 0.946L
15205 - Red Line Syntetic Oil 5W-20, 3.8L
15206 - Red Line Syntetic Oil 5W-20, 19L
11604 - Red Line Syntetic Oil 5W-50, 0.946L
11605 - Red Line Syntetic Oil 5W-50, 3.8L
11304 - Red Line 10W-30 Motor Oil, 0.946L
11305 - Red Line 10W-30 Motor Oil, 3.8L
11306 - Red Line 10W-30 Motor Oil, 19L
11404 - Red Line 10W-40 Motor Oil, 0.946L
11405 - Red Line 10W-40 Motor Oil, 3.8L
11406 - Red Line 10W-40 Motor Oil, 19L
11504 - Red Line 15W-50 Motor Oil, 0.946L
11505 - Red Line 15W-50 Motor Oil, 3.8L
11506 - Red Line 15W-50 Motor Oil, 19L
12504 - Red Line 20W-50 Motor Oil, 0.946L
12505 - Red Line 20W-50 Motor Oil, 3.8L
12506 - Red Line 20W-50 Motor Oil, 19L
21404 - Red Line 15W-40 Diesel Oil, 0.946L
21405 - Red Line 15W-40 Diesel Oil, 3.8L
21406 - Red Line 15W-40 Diesel Oil, 19L
11704 - Red Line 10W-60 Motor Oil, 0.946L
11705 - Red Line 10W-60 Motor Oil, 3.8L
11706 - Red Line 10W-60 Motor Oil, 19L
Любительские тесты на замерзание:
-29С Сравнение масел 0W-40, Redline, Shell, Neste, Yacco, Addinol, Petronas, Lukoil Genesis 2016-2017 год
-32C Сравнение масел 0W-40, Redline, Shell, Neste, Yacco, Addinol, Petronas, Lukoil 2016-2017 год
Без запроса в головной офис дату производства не расшифровать
Red Line Motor Oil 0W-40 API SN + Анилиновая точка
RedLine Motor Oil 5W-30 API SN + Анилиновая точка
Redline Motor Oil WT40 Polaris Lab
RedLine Euro Series 5W-30 корейская лаборатория
Red Line Euro Series 5W-30 Polaris Laboratories
Red Line High Performance 0W-20 Polaris Laboratories
Red Line Euro-Series 5W-30 2022
RedLine Professional-Series 5W-20 Motor Oil
Redline 20W-50 Motorcycle
Redline 0W-20
Redline 5W-20
Redline 5W-30
Redline 5W-40
Redline 0W-40
Redline Euro Series 5W-30
Redline Professional Series 5W-30 TD
Redline 10W-40 Motorcycle Oil
Redline Professional Series Motor Oil 5W-40
RedLine DCTF Dual Clutch Transmission Fluid лаборатория OelCheck
Redline MT-85 75W-85 GL-4 Gear Oil
Redline 75W-90 GL-5 Gear Oil
RedLine 75W-90 GL-5 Polaris Laboratory
Redline ATF DCTF
Redline D6 ATF
Redline 5W-40 SN (2022-23) отработка Mercedes SLC43 после 3737 км (144 мч)
Red Line Motor Oil 5W-30 отработка на BMW X6 после 7012км
RedLine Professional-Series 5W-30 TD EURO отработка на VW Tuareg после 4684 км
Red Line 5W-30 Motor Oil отработка на BMW X6 после 7185км
RedLine 0W-40 отработка на BMW Е90 325i после 12 410 км
Redline Euro-Series 5W-30 Motor Oil отработка на Range Rover Evoque 2.2 после 9133км
Redline Oil 0W-30 отработка на Range Rover Evoque 2.2 после 8500км
Red Line 5W-20 отработка на Mitsubishi Outlander XL после 7800 км
Red Line 0W-30 Motor Oil отработка на Mercedes ML166 350CDI после 10900км
RedLine High Performance 10W-40 отработка на Porsche Cayenne S 4.8 (958.1) после 9000км
Red Line 5W-30 Motor Oil отработка на BMW X6 после 6807 км
Red Line Professional Series 5W-30 TD Motor Oil отработка на Ниссан Патфайндер (V9X) после 6069 км (172 м.ч.)
Red Line Euro-Series 5W-30 Motor Oil отработка на Ниссан Патфайндер (V9X) после 11652 км
Red Line Euro Series 5W-30 на Ниссан Патфайндер(V9X) после 7100 км
Red Line 5W-40 отработка на Mercedes Benz GL500 после 6300км
Red Line 5W-20 отработка на KIA RIO III после 4500км
Red Line 0W-20 отработка на Mitsubishi Outlander XL после 4000 км
Red Line 5W-40 отработка на Mercedes A45AMG 3346 км
Red Line 10W-60 отработка на Audi RS6 после 6500 км.
Red Line Euro Series 5W-30 отработка на AUDI A1 после 9606км
Брал в штатах, шло 3 недели по почте.
По шуму тут интересно, сразу после залива шум вырос при резком нажатии педали газа, но надо сказать , что до него было залит Motul 300v 5w30, а он по гуще
Однако после остановки на 2.5 часа и дальнешего запуска шум при резком подъеме оборотов в движении исчез, посмотрим как будет далее
Спасибо за инфу. Значит наша таможня даёт добро на пересылку масел :good:
Да, вопросов не задают!
Много сомнительных моментов, типа:
- Because Red Line synthetic oils don’t break down like other mineral and
synthetic oils, drain times are extended considerably. For a standard petrol
motor vehicle, a recommended oil change of 5,000kms can increase to
30,000kms.
- Using Red Line Synthetics reduces wear by a factor off up to four (4) times
over other brand mineral and ‘synthetic’ oils, hence the ‘proven to outperform’
label.
Требует подтверждения последовательными анализами на одном и том же моторе
в реальных условях эксплуатации. Особенно про интервалы 30 000 км.
Valvoline, например, дает гарантию (в США) на пробег 300 000 миль (500 000 км) при условии замены масла
каждые 3-4т.миль.
Не уверен, что RedLine даст гарантию на пробег 500 000 км при условии замены масла раз в 30 000 км :D
PS
По-этому крайне интересно получить анализы отработок в реальных условиях эксплуатации.
Сам тоже на RL посматриваю :) Цена отпугивает (даже если почтой из США).
Как бы не оказалось что это "просто масло"...
Изменено пользователем GVA
Так чудес-то они не обещают, а так посмотрим, может и отработку сольем и на анализ
Для фордовского Дюратека выбор из четырёх масел Redline http://redline-oil.ru/tech/motor-oil-product-data.pdf :
0w-20
0W-30
Первое отпадает по причине слишком низкой вязкости (8.2 при 100 и HTHS 2.7 - не хочется получать двойной износ), четвёртое масло не имеет смысла в связи с вполне достаточной вязкостью масла 5W-20 (9.1 !!!).
Остаются:
1) 5W-20 (минимум загустителей, вязкость 9.1, HTHS=3.3, но при -20 пусковой износ будет немалым...) и
2) 0W-30 (загустителей больше, вязкость 10.9, HTHS=3.2, но при -20 износ будет минимальным)
Вот и непонятно, что больше повлияет на износ: большее количество загустителя в 0W-30 (и чуть худшая смазка на трассе) или большая вязкость при пуске -20 (ниже редко бывает в Москве) 5W-20.
p.s. Хотя и пишет изготовитель в описании масла про "natural multigrade property", но не верится в отсутствие загустителя (достаточно сравнить 0W-30, 5W-30, 10W-30) ...
Изменено пользователем Izb
Вот и непонятно, что больше повлияет на износ: большее количество загустителяв 0W-30 или большая вязкость при -30 5W-20.
Полагаю для атмосферника кол-во загустителя не является критичным.
Сделать анализ на том и другом :)
@Izb,
Нулевку надо брать
@Izb, а чего ты проще не подойдешь к вопросу, возьми каждого залей да сделай лаб анализ.
У меня в будущем мысль максимально снизить расход топлива путем 0W20 и мониторинга -чем мне это грозит на старом двигателе с и без тоо крупными с завода зазорами.
@Izb,
Нулевку надо брать
Аргументируйте.
Вообще говоря, тогда уж на FUCHS 0W-20 стоит смотреть, у которого больший HTHS 2.95, но там неизвестность с:
- минусами бесцинового пакета присадок,
- да и информация про эстеры лишь предположительная (в описании говорится лишь про PAO базу). Знают в представительстве Фукса, но не скажут.
- отсутствию молибдена (хотя слова про некий модификатор трения в описании есть) - а именно молибден традиционно уменьшает шумность масла.
Я вот тоже так думал снизить расход на нестаром двигателе, не вышло :( . В ближайшее время буду менять на 0w30.
Но это Motul (HTHS=2.69), а RedLine 5w20 вроде очень заманчиво выглядит :rolleyes:
P.S. Нигде в описаниях не нашёл щелочное и зольность :unknw:
@Izb,
Тут и так понятно. Зима есть зима, нулевка в морозы за -30 на прогревах лучше. Индекс вязкости 183 против 145, наверника пакет присадок более мощный, более устойчивое и синтетичное масло. Главное в крайности не бросаться, при - 20 никакой разницы в пусковом износе не будет. Разница будет когда в -30 и ниже 5ка начнет застывать. Какие еще аргументы надо, не знаю)
Если при -20 разницы не будет, зачем излишний загуститель, больший Noack и потенциально худшие смазывающие свойства? Так что не всё так просто.
Да не, все это в теории, какие там худшие свойства) Уверен что все это компенсируется так или иначе, базой или присадками. Кому как, по мне 0-30 больше подходит для суровых Российских условий эксплуатации, тем более зимних.
