Масла Red Line
Официальный сайт: http://www.redlineoil.com/
15304 - Red Line 5W-30 Motor Oil, 0.946L
15305 - Red Line 5W-30 Motor Oil,  3.8L
15306 - Red Line 5W-30 Motor Oil, 19L
12304 - Red Line Euro-Series 5W-30 Motor Oil, 0.946L
15404 - Red Line 5W-40 Motor Oil 0.946L
15405 - Red Line 5W-40 Motor Oil 3.8L
15406 - Red Line 5W-40 Motor Oil 19L
12404 - Red Line Euro-Series 5W-40, 0.946L
11804 - Red Line Syntetic Oil 0W-20, 0.946L
11805 - Red Line Syntetic Oil 0W-20, 3.8L
11114 - Red Line Syntetic Oil 0W-30, 0.946L
11115 - Red Line Syntetic Oil 0W-30, 3.8L
11116 - Red Line Syntetic Oil 0W-30, 19L
11104 - Red Line Syntetic Oil 0W-40, 0.946L
11105 - Red Line Syntetic Oil 0W-40, 3.8L
11106 - Red Line Syntetic Oil 0W-40, 19L
15204 - Red Line Syntetic Oil 5W-20, 0.946L
15205 - Red Line Syntetic Oil 5W-20, 3.8L
15206 - Red Line Syntetic Oil 5W-20, 19L
11604 - Red Line Syntetic Oil 5W-50, 0.946L
11605 - Red Line Syntetic Oil 5W-50, 3.8L
11304 - Red Line 10W-30 Motor Oil, 0.946L
11305 - Red Line 10W-30 Motor Oil, 3.8L
11306 - Red Line 10W-30 Motor Oil, 19L
11404 - Red Line 10W-40 Motor Oil, 0.946L
11405 - Red Line 10W-40 Motor Oil, 3.8L
11406 - Red Line 10W-40 Motor Oil, 19L
11504 - Red Line 15W-50 Motor Oil, 0.946L
11505 - Red Line 15W-50 Motor Oil, 3.8L
11506 - Red Line 15W-50 Motor Oil, 19L
12504 - Red Line 20W-50 Motor Oil, 0.946L
12505 - Red Line 20W-50 Motor Oil, 3.8L
12506 - Red Line 20W-50 Motor Oil, 19L
21404 - Red Line 15W-40 Diesel Oil, 0.946L
21405 - Red Line 15W-40 Diesel Oil, 3.8L
21406 - Red Line 15W-40 Diesel Oil, 19L
11704 - Red Line 10W-60 Motor Oil, 0.946L
11705 - Red Line 10W-60 Motor Oil, 3.8L
11706 - Red Line 10W-60 Motor Oil, 19L
Любительские тесты на замерзание:
-29С Сравнение масел 0W-40, Redline, Shell, Neste, Yacco, Addinol, Petronas, Lukoil Genesis 2016-2017 год
-32C Сравнение масел 0W-40, Redline, Shell, Neste, Yacco, Addinol, Petronas, Lukoil 2016-2017 год
Без запроса в головной офис дату производства не расшифровать
Red Line Motor Oil 0W-40 API SN + Анилиновая точка
RedLine Motor Oil 5W-30 API SN + Анилиновая точка
Redline Motor Oil WT40 Polaris Lab
RedLine Euro Series 5W-30 корейская лаборатория
Red Line Euro Series 5W-30 Polaris Laboratories
Red Line High Performance 0W-20 Polaris Laboratories
Red Line Euro-Series 5W-30 2022
RedLine Professional-Series 5W-20 Motor Oil
Redline 20W-50 Motorcycle
Redline 0W-20
Redline 5W-20
Redline 5W-30
Redline 5W-40
Redline 0W-40
Redline Euro Series 5W-30
Redline Professional Series 5W-30 TD
Redline 10W-40 Motorcycle Oil
Redline Professional Series Motor Oil 5W-40
RedLine DCTF Dual Clutch Transmission Fluid лаборатория OelCheck
Redline MT-85 75W-85 GL-4 Gear Oil
Redline 75W-90 GL-5 Gear Oil
RedLine 75W-90 GL-5 Polaris Laboratory
Redline ATF DCTF
Redline D6 ATF
Redline 5W-40 SN (2022-23) отработка Mercedes SLC43 после 3737 км (144 мч)
Red Line Motor Oil 5W-30 отработка на BMW X6 после 7012км
RedLine Professional-Series 5W-30 TD EURO отработка на VW Tuareg после 4684 км
Red Line 5W-30 Motor Oil отработка на BMW X6 после 7185км
RedLine 0W-40 отработка на BMW Е90 325i после 12 410 км
Redline Euro-Series 5W-30 Motor Oil отработка на Range Rover Evoque 2.2 после 9133км
Redline Oil 0W-30 отработка на Range Rover Evoque 2.2 после 8500км
Red Line 5W-20 отработка на Mitsubishi Outlander XL после 7800 км
Red Line 0W-30 Motor Oil отработка на Mercedes ML166 350CDI после 10900км
RedLine High Performance 10W-40 отработка на Porsche Cayenne S 4.8 (958.1) после 9000км
Red Line 5W-30 Motor Oil отработка на BMW X6 после 6807 км
Red Line Professional Series 5W-30 TD Motor Oil отработка на Ниссан Патфайндер (V9X) после 6069 км (172 м.ч.)
Red Line Euro-Series 5W-30 Motor Oil отработка на Ниссан Патфайндер (V9X) после 11652 км
Red Line Euro Series 5W-30 на Ниссан Патфайндер(V9X) после 7100 км
Red Line 5W-40 отработка на Mercedes Benz GL500 после 6300км
Red Line 5W-20 отработка на KIA RIO III после 4500км
Red Line 0W-20 отработка на Mitsubishi Outlander XL после 4000 км
Red Line 5W-40 отработка на Mercedes A45AMG 3346 км
Red Line 10W-60 отработка на Audi RS6 после 6500 км.
Red Line Euro Series 5W-30 отработка на AUDI A1 после 9606км
Евро Серия, для меня то же, что и все остальное на прилавке...примерно/близко можно подобрать похожее из других марок за более гуманный ценник.
встречный вопрос, чем плох/хорош для моего двигателя RedLine 5W-30 HP?
Изменено пользователем Foreman_A
Может что- то почитать надо?
интересно что ж вы пойдете и выберите на прилавке похожее и с гуманной ценой?
5 часов назад, Foreman_A сказал:
Согласен..., можно взять и чуть поскромнее, но намного бюджетней. Да и хватит с меня экспериментов с малозольниками, особенно перед летними путешествиями, где можно солярки хапнуть палёной... Если заправляться на проверенных заправках, тут конечно без проблем...
3 часа назад, Booster сказал:
Интересно, чей это тут ответ... ?
11 часов назад, JEEPер сказал:
И?
там об одном, здесь о другом. Но если так нравится, пусть будет)))
В 17.04.2018 в 06:05, Foreman_A сказал:
Тем что это масла на эстеровой основе и с низким содержанием золы, что как нельзя лучше отражается на клапанах EGR, сажевых фильтрах и нейтрализаторах. Почему для вас масло на эстерах такое же как и все остальные на прилавке нам не очень понятно.
на золу не смотрю, моющие и нейтрализующие добавки+присадки молибден.... вроде выше писал о доработках двигателя.
В 18 апреля 2018 г. в 14:14, Foreman_A сказал:
Что такое базовое масло и чем они отличаются надеюсь понимаете. Смотреть на все вместе надо.
оценить подходит или нет можно только анализом, особенно если хочется ну очень точно подобрать масло.
чип разным бывает, но при этом ЕГР и экология на месте, так что и на золу надо смотреть. А так можно залить Идемитсу Зепро дизель, тот который не DL))))
9 часов назад, Booster сказал:
Если клапан ЕГР закрыт программно и сажевый удален, то так зольность/отложения влияют на работоспособность данных приблуд? Может Вы про выпускные клапана двигателя имеете ввиду?
13 часов назад, Foreman_A сказал:
Я не могу тогда понять что написано здесь:
Цель одна, из всех танцев с бубнами, это продлить жизнь двигателю, т.к. EGR+сажевый+перепрошивка мозгов.
они на месте или они где?
хотя... вам виднее что лить
8 часов назад, Booster сказал:
Я тоже не понял, что он имел в виду..., думал на месте всё, а человек полнозольник льёт...
Прошу прощения, если кого в блудняк ввел.
На моей машине программно закрыт ЕГР, удален сажевый, перепрошит мозг/контроллер
Старая гвардия умирает, но не сдается@:)
Доброго времени суток всем присутствующим! Продублируем тут информацию, на всякий случай. К сожалению по независящим от нас причинам, отправить на анализ 5W30TD Professional-Series удалось только сегодня (23.05.2018). Как только анализ будет готов, мы тут же переправим его уважаемому Torcon, для публикация его на форуме в соответствующим разделе. Просим извинения за доставленные неудобства и надеемся на понимание.
   Так же напоминаем, что Professional-Series доступна к приобретению, как у наших дилеров, так и через агрегаторов запасных частей.
Изменено пользователем Redline_moscow
На официальном сайте выложены новые MSDS (SDS) от 11.05.2018 на линейку High Performance Motor Oil (все вязкости).
Выгружаю SDS для истории, т.к. потом при обновлении ссылки на оф.сайт в большинстве не работают, тяжело сравнить с тем что было ранее.
Red Line® High Performance Motor Oil - SDS.pdf (дата документа 11.05.2018) - Synthetic Lubricant Base Oil (VARIOUS) <90%
И на остальные моторные масла
Red Line® Euro Series Full Synthetic SAE 5W-30 - SDS.pdf (дата документа 02.07.2015)
Red Line® Euro Series Full Synthetic SAE 5W-40 - SDS.pdf (дата документа 02.07.2015)
Red Line® Professional Series Turbo Diesel Motor Oil SAE 5W-30 - SDS.pdf (дата документа 12.03.2018)
Red Line® Professional Series Motor Oil SAE 5W-40 - SDS.pdf (дата документа 26.03.2018)
P.S. Для сравнения SDS на High Performance Motor Oil от 29.04.2015 г.
Red Line® High Performance Motor Oil - SDS.pdf - ПАО (1-Dodecene, Homopolymer, Hydrogenated 151006-63-2) - 25 - 60%
