Масла Red Line
Официальный сайт: http://www.redlineoil.com/
15304 - Red Line 5W-30 Motor Oil, 0.946L
15305 - Red Line 5W-30 Motor Oil,  3.8L
15306 - Red Line 5W-30 Motor Oil, 19L
12304 - Red Line Euro-Series 5W-30 Motor Oil, 0.946L
15404 - Red Line 5W-40 Motor Oil 0.946L
15405 - Red Line 5W-40 Motor Oil 3.8L
15406 - Red Line 5W-40 Motor Oil 19L
12404 - Red Line Euro-Series 5W-40, 0.946L
11804 - Red Line Syntetic Oil 0W-20, 0.946L
11805 - Red Line Syntetic Oil 0W-20, 3.8L
11114 - Red Line Syntetic Oil 0W-30, 0.946L
11115 - Red Line Syntetic Oil 0W-30, 3.8L
11116 - Red Line Syntetic Oil 0W-30, 19L
11104 - Red Line Syntetic Oil 0W-40, 0.946L
11105 - Red Line Syntetic Oil 0W-40, 3.8L
11106 - Red Line Syntetic Oil 0W-40, 19L
15204 - Red Line Syntetic Oil 5W-20, 0.946L
15205 - Red Line Syntetic Oil 5W-20, 3.8L
15206 - Red Line Syntetic Oil 5W-20, 19L
11604 - Red Line Syntetic Oil 5W-50, 0.946L
11605 - Red Line Syntetic Oil 5W-50, 3.8L
11304 - Red Line 10W-30 Motor Oil, 0.946L
11305 - Red Line 10W-30 Motor Oil, 3.8L
11306 - Red Line 10W-30 Motor Oil, 19L
11404 - Red Line 10W-40 Motor Oil, 0.946L
11405 - Red Line 10W-40 Motor Oil, 3.8L
11406 - Red Line 10W-40 Motor Oil, 19L
11504 - Red Line 15W-50 Motor Oil, 0.946L
11505 - Red Line 15W-50 Motor Oil, 3.8L
11506 - Red Line 15W-50 Motor Oil, 19L
12504 - Red Line 20W-50 Motor Oil, 0.946L
12505 - Red Line 20W-50 Motor Oil, 3.8L
12506 - Red Line 20W-50 Motor Oil, 19L
21404 - Red Line 15W-40 Diesel Oil, 0.946L
21405 - Red Line 15W-40 Diesel Oil, 3.8L
21406 - Red Line 15W-40 Diesel Oil, 19L
11704 - Red Line 10W-60 Motor Oil, 0.946L
11705 - Red Line 10W-60 Motor Oil, 3.8L
11706 - Red Line 10W-60 Motor Oil, 19L
Любительские тесты на замерзание:
-29С Сравнение масел 0W-40, Redline, Shell, Neste, Yacco, Addinol, Petronas, Lukoil Genesis 2016-2017 год
-32C Сравнение масел 0W-40, Redline, Shell, Neste, Yacco, Addinol, Petronas, Lukoil 2016-2017 год
Без запроса в головной офис дату производства не расшифровать
Red Line Motor Oil 0W-40 API SN + Анилиновая точка
RedLine Motor Oil 5W-30 API SN + Анилиновая точка
Redline Motor Oil WT40 Polaris Lab
RedLine Euro Series 5W-30 корейская лаборатория
Red Line Euro Series 5W-30 Polaris Laboratories
Red Line High Performance 0W-20 Polaris Laboratories
Red Line Euro-Series 5W-30 2022
RedLine Professional-Series 5W-20 Motor Oil
Redline 20W-50 Motorcycle
Redline 0W-20
Redline 5W-20
Redline 5W-30
Redline 5W-40
Redline 0W-40
Redline Euro Series 5W-30
Redline Professional Series 5W-30 TD
Redline 10W-40 Motorcycle Oil
Redline Professional Series Motor Oil 5W-40
RedLine DCTF Dual Clutch Transmission Fluid лаборатория OelCheck
Redline MT-85 75W-85 GL-4 Gear Oil
Redline 75W-90 GL-5 Gear Oil
RedLine 75W-90 GL-5 Polaris Laboratory
Redline ATF DCTF
Redline D6 ATF
Redline 5W-40 SN (2022-23) отработка Mercedes SLC43 после 3737 км (144 мч)
Red Line Motor Oil 5W-30 отработка на BMW X6 после 7012км
RedLine Professional-Series 5W-30 TD EURO отработка на VW Tuareg после 4684 км
Red Line 5W-30 Motor Oil отработка на BMW X6 после 7185км
RedLine 0W-40 отработка на BMW Е90 325i после 12 410 км
Redline Euro-Series 5W-30 Motor Oil отработка на Range Rover Evoque 2.2 после 9133км
Redline Oil 0W-30 отработка на Range Rover Evoque 2.2 после 8500км
Red Line 5W-20 отработка на Mitsubishi Outlander XL после 7800 км
Red Line 0W-30 Motor Oil отработка на Mercedes ML166 350CDI после 10900км
RedLine High Performance 10W-40 отработка на Porsche Cayenne S 4.8 (958.1) после 9000км
Red Line 5W-30 Motor Oil отработка на BMW X6 после 6807 км
Red Line Professional Series 5W-30 TD Motor Oil отработка на Ниссан Патфайндер (V9X) после 6069 км (172 м.ч.)
Red Line Euro-Series 5W-30 Motor Oil отработка на Ниссан Патфайндер (V9X) после 11652 км
Red Line Euro Series 5W-30 на Ниссан Патфайндер(V9X) после 7100 км
Red Line 5W-40 отработка на Mercedes Benz GL500 после 6300км
Red Line 5W-20 отработка на KIA RIO III после 4500км
Red Line 0W-20 отработка на Mitsubishi Outlander XL после 4000 км
Red Line 5W-40 отработка на Mercedes A45AMG 3346 км
Red Line 10W-60 отработка на Audi RS6 после 6500 км.
Red Line Euro Series 5W-30 отработка на AUDI A1 после 9606км
ошибка какая то
ошибка какая то
А как вам это (один из последних постов):
I find this interesting. This is the second or third UOA on Red Line where the TBN came out literally at 0.0. Yet, everything else looks fine.
Т.е. это уже второй или третий анализ с нулевым TBN. Однако всё ОК :unknw:
Хотя не мудрено, с такими то перепробегами...
@Вадим_69, видимо не зря на канистре красного флажки нарисованы...залил-вжарил-слил, а не поехал по пенсионерски 10 тыс миль.
А в параллельной теме Денни настаивал на TBN>=TAN ...
p.s. Кстати, а какой TBN у реформулированных гражданских REDLINE?
Скоро узнаем ;) 5w20 уже в лабе!
0w20 буду тестить зимой...
P.S. На битоге фигурировали числа 9.8 и 8.8 соответственно
У Атомик вообще то ещё 5W-20 ещё нереформулированный, а вот 0W-20 уже новый.
p.s. Так и не пойму никак, какого чёрта Redline не соблюдают общепринятые нормы и настойчиво пишут 0W20 вместо 0W-20, почему пишут CCS Viscosity, Poise, @*C 55@-35 вместо 5500 при -35 и т.д.
А откуда такая инфа? И как узнать по коду на квартах?
Если это так, то хорошо :) 0w20 по всем параметрам лучше реформулированный, а вот 5w20 наоборот...
Надо же как-то подчеркивать свою исключительность (бутиковость) ;)
А вообще, пофиг как пишут, главное, чтоб параметры реального масла этому соответствовали. И неплохо бы допуски настоящие иметь (а не соответствия)...
Redline - отличное по качеству масло.
И я не знаю ни одного другого негоночного легкового масла, у которого было бы цинка и фосфора в разумных размерах API SL около 1200ppm (разве что Comma XTECH, но оно мне не совсем понравилось),плюс молибден и бор.
Но вот откровенно отталкивает интервал OCI 5000 миль (7000км), далее которого(судя по многим анализам на Битоге) не выполняется условие TBN>1, при этом условие TBN=TAN достигается гораздо раньше.
Получается, что нормализованная (к распространённым 10000км) цена кварты масла стоит не менее 1000 рублей, что запредельно.
Для сравнения: полная синтетика Pennzoil Ultra стоит в два раза дешевле, а полная синтетика ConocoPhilips - в 4 раза дешевле.
Хочу перейти на RedLine 5w-20 с оригинального хондовского 0w-20. Подскажите, их вообше можно смешивать?
Изменено пользователем plkhn
Если доливать, то лучше не надо. Очень разные масла по базе и по пакету. При замене на редлайн промывки тоже не надо! Просто откатать сперва укороченный интервал (3-4 тыс.). Потом можно и на 5-7 тыс.
Я имел ввиду, что родное хондовское всеравно полностью не сольеться и смешается с редлайном. :rolleyes:
Т.е. у него "потолок" тыщ. 7 при замене?
ну так есть смысл тогда перейти на RedLine 0w-20
какой?
какой?
попробовать что-то новое :rolleyes:
Такой потолок у многих масел. Все зависит от качества топлива и режима эксплуатации. Если бензин Евро5 и в основном трасса, то можно и 10 тыс. Зимой в городе более 5 тыс. не советую. Анализы на битоге показывают, что у этого масла быстро проседает щелочное, и при перепробеге очень сильно растёт износ по цветмету, особенно меди (кислая среда в двиге, чему, возможно, способствуют соединения молибдена)...
