Масла Areol
Официальный сайт:  http://www.areollub.com/
Нарвался на просторах интернета на такое вот масло под названием Areol, производится типа в Нидерландах.
каталог http://armtek.by/wp-content/uploads/2017/10/Katalog-masel-AREOL.pdf
продвигается белорусским Armtek
5W30AR015 - Areol Max Protect F 5W-30 1L
5W30AR016 - Areol Max Protect F 5W-30 4L
5W30AR017 - Areol Max Protect F 5W-30 5L
5W30AR044 - Areol Max Protect F 5W-30 20L
5W30AR045 - Areol Max Protect F 5W-30 60L
5W30AR046 - Areol Max Protect F 5W-30 205L
5W40AR011 - Areol Max Protect 5W-40 1L
5W40AR010 - Areol Max Protect 5W-40 4L
5W40AR009 - Areol Max Protect 5W-40 5L
5W40AR038 - Areol Max Protect 5W-40 20L
5W40AR039 - Areol Max Protect 5W-40 60L
5W40AR040 - Areol Max Protect 5W-40 205L
10W40AR002 - Areol Max Protect 10W-40 1L
10W40AR003 - Areol Max Protect 10W-40 4L
10W40AR001 - Areol Max Protect 10W-40 5L
10W40AR032 - Areol Max Protect 10W-40 20L
10W40AR033 - Areol Max Protect 10W-40 60L
10W40AR034 - Areol Max Protect 10W-40 205L
5W40AR060 - Areol Eco Protect 5W-40 1L
5W40AR061 - Areol Eco Protect 5W-40 4L
5W40AR062 - Areol Eco Protect 5W-40 5L
5W40AR063 - Areol Eco Protect 5W-40 20L
5W40AR064 - Areol Eco Protect 5W-40 60L
5W40AR065 - Areol Eco Protect 5W-40 205L
5W30AR018 - Areol Eco Protect 5W-30 1L
5W30AR019 - Areol Eco Protect 5W-30 4L
5W30AR020 - Areol Eco Protect 5W-30 5L
5W30AR047 - Areol Eco Protect 5W-30 20L
5W30AR048 - Areol Eco Protect 5W-30 60L
5W30AR049 - Areol Eco Protect 5W-30 205L
0W20AR068 - Areol Eco Energy DX1 0W-20 5L
0W20AR067 - Areol Eco Energy DX1 0W-20 4L
0W20AR066 - Areol Eco Energy DX1 0W-20 1L
0W30AR057 - Max Protect 0W-30 1L ACEA A3/B4
0W30AR058 - Max Protect 0W-30 4L ACEA A3/B4
0W30AR059 - Max Protect 0W-30 5L ACEA A3/B4
5W30AR074 - Areol ECO Energy DX1 5W-30 5L
5W30AR073 - Areol ECO Energy DX1 5W-30 4L
5W30AR072 - Areol ECO Energy DX1 5W-30 1L
5W30AR006 AREOL ECO Protect Z 5W-30 (5L) масло моторное! синт.\ ACEA C3, API SN, MB 229.51/229.52, VW 502.00
5W30AR007 AREOL ECO Protect Z 5W-30 (1L) масло моторное! синт.\ ACEA C3, API SN, MB 229.51/229.52, VW 502.00
5W30AR008 AREOL ECO Protect Z 5W-30 (4L) масло моторное! синт.\ ACEA C3, API SN, MB 229.51/229.52, VW 502.00
5W30AR012 AREOL Max Protect LL 5W-30 (1L) масло моторное! синт.\ ACEA A3/B4, API SN/CF, MB 229.3/226.5
5W30AR013 AREOL Max Protect LL 5W-30 (4L) масло моторное! синт.\ ACEA A3/B4, API SN/CF, MB 229.3/226.5
5W30AR014 AREOL Max Protect LL 5W-30 (5L) масло моторное! синт.\ ACEA A3/B4, API SN/CF, MB 229.3/226.5
5W30AR018 AREOL ECO Protect 5W-30 (1L) масло моторное! синт.\ ACEA C3, API SN, VW 504.00/507.00, MB 229.51
5W30AR019 AREOL ECO Protect 5W-30 (4L) масло моторное! синт.\ ACEA C3, API SN, VW 504.00/507.00, MB 229.51
5W30AR020 AREOL ECO Protect 5W-30 (5L) масло моторное! синт.\ ACEA C3, API SN, VW 504.00/507.00, MB 229.51
Грузовая Программа:
10W40AR004 AREOL Trans Truck 10W-40 (20L) масло моторное! полусинт.\ ACEA A3/B4/E7, API CI-4/SL, MB 228.3/229.1
10W40AR005 AREOL Trans Truck 10W-40 (205L) масло моторное! полусинт.\ACEA A3/B4/E7, API CI-4/SL, MB 228.3/229.1
10W40AR025 AREOL Trans Truck ECO 10W-40 (20L) масло моторное! синт.\ACEA E6/E7, API CI-4, Volvo VDS-3,MAN M3477
10W40AR026 AREOL Trans Truck ECO 10W-40 (205L) масло моторное! синт.\ACEA E6/E7, API CI-4,Volvo VDS-3,MAN M3477
Areol Trans Truck ECO 10W-40
Areol Max Protect F 5W-30 API SL
Areol Eco Energy DX1 5W-30 API SP
Areol Max Protect 5W-40 API SN
Areol Trans Truck 10W-40 API CI-4
Areol Max Protect 0W-30
Areol Eco Protect C2 5W-30
Areol Eco Energy DX1 0W-20 API SP
Areol Eco Protect 5W-30 2022
Areol EcoProtect 5W-30 канистра март 2018 года
Areol Max Protect LL 5W-30
Areol Eco Energy DX1 0W-20  отработка на Toyota Rav4 после 9300км
6 часов назад, IvanRND сказал:
пока что моторка, про трансмиссию не в курсе.
Канистры хде, давай фоты:D
torcon первое тестилось 0-20, ещё в 2019г, а 0-30 уже в 2020г.
7 минут назад, Евген48 сказал:
В личку, а то холивар будет.
IvanRND да харэ, кидай тут, глянем чё в турке заказывают.
03.02.2022 в 15:22, Hanval Rus сказал:
Тоесть вы ездили, морщились  проверяя уровень 8000 км без доливки?.... Пока недожгли масло в конец? ... Или ... Капельную пробу делали  ?  Масло  нюхали   ?    Из трубы дым валит  ? Двс диагностику   кто делал? И как давно?   Какой общий хоть пробег на маслах?  Какой авто  и какое конкретно масло - масло маслянное?)))
Р. С  не поверите  вы наверное 20 человек  в этом месяце  но в разных маслах, ветках,    всё отзывы как под копирку -ни о чем... У вас обострение?
Или будет подробный рассказ?
Ничего удивительного в том, что у человека масло сожрало на этой таче. Это же вольксваген моторы 1,4 до 2015 года эти вообще склонны к жору масла, и не первый раз об этом слышу. У меня в эксплуатации Джетта 5 с мотором 1,6 bse, который так же по заводу склонен к жору. Что и я и др. пользователи (она у нас рабочая тача) туда не лили - и крон оилы и коммы и лотосы и ени и чемпиоилы показатель один - забыл проверить уровень и подлить вовремя, получай масленку на табло. На моем моторе тенденция одна, ездишь спокойно -  литрушку полторы на 10 тык. заливаешь, крутишь мотор, гоняешь на трасе 120-130+ плюс 30-50 гр. на сотню. И с чем я только не эксперементировал и с вязкостью и с допусками - абсолютно ничего, всё +/- одинаково.
Возможно не в масле и дело, просто частный случай у человека. Хотя я не первый раз слышу о том, что у народа жрет оно на движках.
Маде ин Голландия. Производитель Германия. Штрих код Германия.
по адресу, указанному на этикетке 33729 bielefeld bronninghauser str 33, вообще нет производства. навряд ли на складах мебели и магазине шин производят масло.
На нугл картах все видно:
https://www.google.com/maps/place/Brönninghauser+Str.+33,+33729+Bielefeld,+Германия/@52.0406043,8.6348997,20.75z/data=!4m6!3m5!1s0x47ba3e1ebb34693d:0xbaeaf68c4eb07d70!8m2!3d52.0406!4d8.6348601!16s%2Fg%2F11c25g_mjp?entry=ttu
Это нормально?
peasedata все верно, это легенда что бы "пипл хавал". Но если смотреть в корень, масло заказывается на серьезном заводе, производящим масла для полевропы De Oliebron Голандия. По анализам, если опять же смотреть в корень, рецептуры и пакеты присадок правильные, масла качественные. Были косяки с вязкостью, но не критичные для мотора. :) Схема эта среди наших коммерсантов не новая, ее кто только не повторяет, NGN так делал масла например и вполне качественные. Aimol, Novus, Heck, да их много таких было...
23.11.2023 в 15:49, torcon сказал:
Для меня было новостью что Аимол так плотно сидит в В2В сегменте поставляя гидравлические масла.
интернет великая "Помойка", и если копнуть, про "Нидерландское" - на выходе скорее всего только фантик, а конфетка Белорусская... имхо.
Все что стоит знать про немецко-нидерландское...
Он же "Андрей Ильинец, директор департамента закупок ГК ARMTEK ",
https://armtek.by/nagrazhdenie-luchshego-postavshhika-2017-goda-gk-armtek/,
https://www.drive2.ru/o/b/555926274216821066/,
https://ru.areollub.com/kontaktnyye-i-registratsionnyye-dannyye-kompanii/,
https://areollub.com/where-can-i-buy/,
На фотографии: Андрей ИЛЬИНЕЦ, директор по закупкам ГК Армтек, Евгений ЛАТЫШЕВ, менеджер по продажам Delphi Samara, Александр КОНОПЛЕВ, генеральный директор Delphi Samara, Вадим ГРИНКЕВИЧ, генеральный директор ГК Армтек/ https://www.drive2.ru/o/b/555926274216821066/
Контактные и регистрационные данные компании
Данные в соответствии с § 5 Закона Германии об электронных средствах массовой информации (TMG)
Texco FZE
Управляющий директор: Андрей Ильинец
Адрес электронной почты: info@texco.ae
Тел. +971 4 885 0522
Запись в реестре: регистрация в Торговом реестре
Местонахождение суда, ведущего торговый реестр: Dubai
№ регистрации: 13965389
И что в этом такого?
Масла с Нидерландского заводика по 2000-2500 руб. за канистру на маркетплейсах — это очень неплохо, независимо от того, как маскируются (если они вообще это делали) наши соседи.
ничего, кроме того что брендом "Areol" владеет руководитель армтека... Все масла 5W30 и "холоднее" под жестким запретом на ввоз к нам!, ввозить через буржуйскую границу сотни тонн масла это прям невидимка какая то..., скорее всего под красивой этикеткой обыкновенная куриная попка, а внутри "брендированное" белорусское масло. ина че нам бы давно гордо показали контрактные доки на  выпуск этого масла оем производителем... а их похоже до сих пор нет...
Есть мнение, что Areol льют в Турции...
3 часа назад, fvms.ru сказал:
из Европы под жестким запретом прямого ввоза ВСЕ вязкости и виды моторных масел.
И для всех уже с года так 2015 не секрет, что AREOL, STELLOX, ZENPARTS(с 2020 года бренд), EDCON, WEZER, CHEMIPRO, FURO - бренды, которыми владеет армтек.
2 часа назад, IvanRND сказал:
Попробую запросить сертификат и паспорт качества на какой либо продукт от армтека.
11 минут назад, Sn00pY сказал:
Но возят же как-то.
Вон товарищ Северянин постоянно реализует нечастые бренды из Европы, а тут еще и собственный российский четырехбуквенный бренд европейского разлива (они или их партнеры) запустили.
