Масла SRS
Официальный сайт: http://www.srs-oil.com/home-en.html
Русскоязычный сайт: http://srs-oil.ru
Список продукции: http://www.srs-oil.com/products.html
Спойлер
11000 - SRS ViVA 1 Ecosynth SAE 0W-40 1L
10262 - SRS ViVA 1 Ecosynth SAE 0W-40 4L
10195 - SRS ViVA 1 Ecosynth SAE 0W-40 200L
SRS ViVA 1 ecosynth SAE 0W-40 1л Артикул: 4033885000090
SRS ViVA 1 ecosynth SAE 0W-40 4лАртикул: 4033885000854
SRS ViVA 1 SAE 10W-40 1лАртикул: 4033885000168
SRS ViVA 1 SAE 10W-40 4лАртикул: 4033885000182
SRS ViVA 1 SLV plus SAE 5W-30 1лАртикул: 4033885000526
SRS ViVA 1 SLV plus SAE 5W-30 4лАртикул: 4033885000847
SRS ViVA 1 special F plus SAE 5W-30 1лАртикул: 4033885001189
SRS ViVA 1 special F plus SAE 5W-30 4лАртикул: 4033885001394
SRS ViVA 1 special F plus SAE 5W-30 5лАртикул: 4033885001400
SRS ViVA 1 special LMS SAE 5W-30 1лАртикул: 4033885001370
SRS ViVA 1 special LMS SAE 5W-30 4лАртикул: 4033885001011
SRS Viva 1 synthracing SAE 5W-50 1лАртикул: 4033885000489
SRS Viva 1 synthracing SAE 5W-50 4лАртикул: 4033885000861
SRS ViVA 1 topsynthalpha LA SAE 5W-30 1лАртикул: 4033885000533
SRS ViVA 1 topsynthalpha LA SAE 5W-30 4лАртикул: 4033885000540
SRS ViVA 1 topsynth SAE 5W-40 1лАртикул: 4033885000441
SRS ViVA 1 topsynth SAE 5W-40 4лАртикул: 4033885000458
7945 - SRS Viva 1 Topsynth Alpha LS 5W-40 1L
7944 - SRS Viva 1 Topsynth Alpha LS 5W-40 4L
7943 -  SRS Viva 1 Topsynth Alpha LS 5W-40 5L
7940 -  SRS Viva 1 Topsynth Alpha LS 5W-40 208L
SRS Cargolub TFG 10W-40 E4
SRS VIVA Special LMS 5W-30
SRS ViVA 1 Ecosynth Plus 0W-40
SRS ViVA 1 Synth Racing 5W-50
SRS Cargolub TLS Plus 5W-30
SRS Viva1 Topsynth Alpha LA 5W-30
SRS Viva1 Special MS 5W-30
SRS Viva1 SLV Plus 5W-30
SRS Viva1 Topsynth 5W-40
SRS Viva1 Ecosynth 0W-40
SRS VIVA 1 Topsynth 5W-40
SRS VIVA 1 topsynth Plus 5W-40 бочковое
SRS Viva1 10W-40
SRS Viva1 Longlife 5W-30
SRS VIVA 1 alpha LS 5W-40 C3
SRS Special F Eco 5W-20
SRS Getriebefluid 5 L 75W-90 API GL-4+
SRS Wiolin ATF VI
SRS Viva 1 SLV Top 5W-30 отработка на BMW 1 Series F20 после 7 648 км
SRS ViVA 1 synth racing 5W-50 отработка на Nissan GT-R после 5000км
SRS Cargolub TLS PLUS 5W-30 отработка на IVECO двиг CURSOR 13 после 18000км
SRS Ecosynth 0W-40 отработка на Infiniti EX35 после 8500км
SRS VIVA 1 topsynth SAE 5W40 API SN отработка на Citroen Berlingo NEW B9 после 7000км
SRS VIVA1 Longlife 5W30 отработка на Citroen Berlingo после 5000 км
SRS Viva1 SLV Plus 5w-30 отработка Audi Q7 2015 4M после 7500км
SRS ViVA 1 Topsynth Alpha LA 5W-30 отработка Audi A4 после 6011 км
SRS VIVA 1 Topsynth Plus 5W-40 отработка на Citroen Berlingo после 5000 км.
SRS ViVA 1 ecosynth 0w-40 отработка на Kia cerato Koup после 9500км.
SRS ViVA 1 Topsynth Alpha LA 5W-30 отработка Audi A5 3.2 TFSI после 5000 км
SRS ViVA 1 special F eco 5w-20 отработка на Kia cerato Koup после 7900км
SRS VIVA 1 topsynth alpha LA откатал на нем 7500км мотор засрался, появились сгустки масла под заливной горловиной
Оффтоп
это что-то новенькое ))
На турбомоторах VAG (1.8 TSI, 1.9 TDI) у друзей ничего не зас.рало, а тут на тебе...
Оффтоп
На офф сайте GM нет допуска дексос2 к этому маслу, брал у офф дилера этого масла
Если и так, то не удивлен.
О каком офф сайте GM с перечнем масел/изготовителей dexos идет речь?
http://www.centerforqa.com/gm/dexos2-brands
об этом видимо :)
Я догадывался... Только это (Center for Quality Assurance (CQA)) не офф сайте GM!
факт остается фактом, умерло это масло даже в простом движке
@Tim222,а что до альфы было залито?
Motul Specific dexos2 5W30
Как правильно менять масло SRS в двигателе Ситроен Берлинго http://www.youtube.com/watch?v=0gcsEGJa1EE
Поменял масло,залил SRS VIVA 1 Longlife 5W30 A3/B4 из бочки.Думаю к весне нужно посмотреть "здоровье" двигателя по отработке,да и свежего анализ сделаем.Желающие на анализ свежего,милости просим.
Штукарь подкину, напомни только, мое второе имя амнезия :)))
Обязательно,но это весной.
Товарищу mikong был принципиален допуск sn на масле 5w-40, он писал, что все 5w-40 просмотрел на сайте, так вот он есть же на другом продукте http://www.srs-oil.com/coRED/_data/pdf/SRS_ViVA_1_topsynth_alpha_LA_5W-40_.pdf
