Масла SRS
Масла SRS
Официальный сайт: http://www.srs-oil.com/home-en.html
Русскоязычный сайт: http://srs-oil.ru
Список продукции: http://www.srs-oil.com/products.html
Спойлер
11000 - SRS ViVA 1 Ecosynth SAE 0W-40 1L
10262 - SRS ViVA 1 Ecosynth SAE 0W-40 4L
10195 - SRS ViVA 1 Ecosynth SAE 0W-40 200L
SRS ViVA 1 ecosynth SAE 0W-40 1л Артикул: 4033885000090
SRS ViVA 1 ecosynth SAE 0W-40 4лАртикул: 4033885000854
SRS ViVA 1 SAE 10W-40 1лАртикул: 4033885000168
SRS ViVA 1 SAE 10W-40 4лАртикул: 4033885000182
SRS ViVA 1 SLV plus SAE 5W-30 1лАртикул: 4033885000526
SRS ViVA 1 SLV plus SAE 5W-30 4лАртикул: 4033885000847
SRS ViVA 1 special F plus SAE 5W-30 1лАртикул: 4033885001189
SRS ViVA 1 special F plus SAE 5W-30 4лАртикул: 4033885001394
SRS ViVA 1 special F plus SAE 5W-30 5лАртикул: 4033885001400
SRS ViVA 1 special LMS SAE 5W-30 1лАртикул: 4033885001370
SRS ViVA 1 special LMS SAE 5W-30 4лАртикул: 4033885001011
SRS Viva 1 synthracing SAE 5W-50 1лАртикул: 4033885000489
SRS Viva 1 synthracing SAE 5W-50 4лАртикул: 4033885000861
SRS ViVA 1 topsynthalpha LA SAE 5W-30 1лАртикул: 4033885000533
SRS ViVA 1 topsynthalpha LA SAE 5W-30 4лАртикул: 4033885000540
SRS ViVA 1 topsynth SAE 5W-40 1лАртикул: 4033885000441
SRS ViVA 1 topsynth SAE 5W-40 4лАртикул: 4033885000458
7945 - SRS Viva 1 Topsynth Alpha LS 5W-40 1L
7944 - SRS Viva 1 Topsynth Alpha LS 5W-40 4L
7943 -  SRS Viva 1 Topsynth Alpha LS 5W-40 5L
7940 -  SRS Viva 1 Topsynth Alpha LS 5W-40 208L
SRS Cargolub TFG 10W-40 E4
SRS VIVA Special LMS 5W-30
SRS ViVA 1 Ecosynth Plus 0W-40
SRS ViVA 1 Synth Racing 5W-50
SRS Cargolub TLS Plus 5W-30
SRS Viva1 Topsynth Alpha LA 5W-30
SRS Viva1 Special MS 5W-30
SRS Viva1 SLV Plus 5W-30
SRS Viva1 Topsynth 5W-40
SRS Viva1 Ecosynth 0W-40
SRS VIVA 1 Topsynth 5W-40
SRS VIVA 1 topsynth Plus 5W-40 бочковое
SRS Viva1 10W-40
SRS Viva1 Longlife 5W-30
SRS VIVA 1 alpha LS 5W-40 C3
SRS Special F Eco 5W-20
SRS Getriebefluid 5 L 75W-90 API GL-4+
SRS Wiolin ATF VI
SRS Viva 1 SLV Top 5W-30 отработка на BMW 1 Series F20 после 7 648 км
SRS ViVA 1 synth racing 5W-50 отработка на Nissan GT-R после 5000км
SRS Cargolub TLS PLUS 5W-30 отработка на IVECO двиг CURSOR 13 после 18000км
SRS Ecosynth 0W-40 отработка на Infiniti EX35 после 8500км
SRS VIVA 1 topsynth SAE 5W40 API SN отработка на Citroen Berlingo NEW B9 после 7000км
SRS VIVA1 Longlife 5W30 отработка на Citroen Berlingo после 5000 км
SRS Viva1 SLV Plus 5w-30 отработка Audi Q7 2015 4M после 7500км
SRS ViVA 1 Topsynth Alpha LA 5W-30 отработка Audi A4 после 6011 км
SRS VIVA 1 Topsynth Plus 5W-40 отработка на Citroen Berlingo после 5000 км.
SRS ViVA 1 ecosynth 0w-40 отработка на Kia cerato Koup после 9500км.
SRS ViVA 1 Topsynth Alpha LA 5W-30 отработка Audi A5 3.2 TFSI после 5000 км
SRS ViVA 1 special F eco 5w-20 отработка на Kia cerato Koup после 7900км
@Piphagore, я понял. если руководствоваться этим, то все верно говоришь. А я за 7 лет стажа так и не понял, что нужно, чтобы масло мне понравилось. Если цена хорошая (особенно по акции) и допуски есть, то я готов взять любое масло. Мне оно может понравиться по запаху, цвету, вкусу... :crazy: , но причем тут я? Главное, чтобы движку оно нравилось: угар, раскрутка, звук работы. А я ни на Калине, ни на Джетте разницы между маслами не заметил. Может, мне медведь на ухо наступил? :unknw:
Завод в Зальцбергене перерабатывает не нефть, а газойль российский. Стыдно не знать такого представителю. И только первую группу производят и только низковязкую. Даже брайтсток покупают.
Откуда такая информация?Ссылки давайте,а не просто бла-бла.
Заливал это масло (SRS Viva1 Topsynth Alpha LA 5W-30) при переходе от Мобила супер ФЕ 5 30 на Мобил 1 нью лайф 5 30. Проехал 2т.км-слил черное как будто тысяч 10 проехал. Думаю,что моющие способности у него очень хороши, но мне дексос1 нужен.
название масла
Википедиа и переводчик тебе в помощь! http://de.wikipedia.org/wiki/Raffinerie_Salzbergen
Die Raffinerie in Salzbergen ist eine Spezialraffinerie, deren Haupttätigkeit in der Produktion von chemisch-pharmazeutischen Spezialitäten besteht. Das bedeutet, man kauft die Rückstände der großen Raffinerien, die die leichten Bestandteile – Benzin, Diesel und Kerosin – aus dem Erdöl herauslöst haben und produziert aus diesen schweren Bestandteilen diverse rohölbasierte Spezialitäten, die in vielen Produkten des täglichen Lebens weiterverarbeitet werden. Dazu gehören unter anderem folgende Hauptgruppen
Изменено пользователем ServiceMan
@ServiceMan,я эти ссылки запостил выше,только в переводе,посмотри обе внимательно.Ну и что это по твоему означает,что это блэндер,обычный розливщик,или это все-таки нефтеперерабатывающий завод с производством смазочных материалов?Не пойму что ты мне хочешь объяснить.Тогда посмотри здесь http://srs-oil.ru/,там есть фильм про завод,где все объясняется.
Изменено пользователем kep
Ребят, где в ЦФО можно посмотреть ценник на эти масла и купить, если устроит?
г. Липецк, ул. Сырская 46 Б
Клубни, у кого-нибудь имеется желание сделать анализ дизельного SRS Cargolub TLS SAE 5W-30?
К тому же, у кого-нибудь имеется 0,5-1 л. данного масла для анализа?
Я готов помочь финансово. В том числе купить масло.
Добавлю без проблем.
сколько SRS 10W40 стоит?
Розничая за 4л примерно 1500=,плюс-минус.
В таком случае, пжст, раздобудьте литр данного масла для анализа и в последующем отправьте в лабу.
По приходу в лабу начнем сборы, как говорится, кто сколько сможет ))
