30 ноября 200718 г Закреплён Масла BP Официальный сайт: http://www.bp.com/en_gb/lubricants/united-kingdom.html Артикульные коды для заказа в интернет магазинах: 119368 / 15805A Visco 7000 0W-40 1L 119369 / 15805B Visco 7000 0W-40 4L 117528 / 15804F Visco 7000 0W-40 60L 117386 / 15804E Visco 7000 0W-40 208L 14F697 / 15571C Visco 5000 5W-30 1L 14F69B / 15571D Visco 5000 5W-30 4L 14F69C / 15570F Visco 5000 5W-30 60L 14EE20 / 15571A Visco 5000 5W-30 208L 114496 / 15805F Visco 5000 5W-40 1L 114502 / 15806A Visco 5000 5W-40 4L 108963 / 15805E Visco 5000 5W-40 60L 108959 / 15805D Visco 5000 5W-40 208L 14DF28 / 15870C Visco 3000 Diesel 10W-40 1L 14DF29 / 15870D Visco 3000 Diesel 10W-40 4L 119777 / 15870B Visco 3000 Diesel 10W-40 60L 119634 / 15870A Visco 3000 Diesel 10W-40 208L 14F6E7 / 157F38 Visco 3000 A3/B4 10W-40 1L 14F6E4 / 157F36 Visco 3000 A3/B4 10W-40 4L 14F6E2 / 157F35 Visco 3000 A3/B4 10W-40 20L 14F6E6 / 157F37 Visco 3000 A3/B4 10W-40 60L 14F6E1 / 157F34 Visco 3000 A3/B4 10W-40 208L 14FA23 / 156DA8 Visco 2000 A3/B3 15W-40 1L 14FA26 / 156DAA Visco 2000 A3/B3 15W-40 5L 14FA20 Visco 2000 A3/B3 15W-40 60L 14FA1D / 156DA6 Visco 2000 A3/B3 15W-40 208L 15267A / 1550F9 Vanellus Max 5W-30 208L 15267C / 1550F6 Vanellus Max 5W-30 20L 15267D / 1550F3 Vanellus Max 5W-30 5L 1525F6 / 1552B1 Vanellus Max Eco 10W-40 208L 1525F7 / 1552B0 Vanellus Max Eco 10W-40 20L 1527F6 / 1553CE Vanellus Max 10W-40 208L 1527F8 / 1553CD Vanellus Max 10W-40 20L 1527FB Vanellus Max 10W-40 5L 1525F0 / 1554FF Vanellus Multi A 10W-40 208L 1525EF / 1554FD Vanellus Multi A 10W-40 20L 1525F2 / 1554FA Vanellus Multi A 10W-40 5L 1525EB / 1552EB Vanellus Multi A 15W-40 208L 1525EA / 1552DB Vanellus Multi A 15W-40 20L 14E2AF Vanellus Multigrade 15W-40 208L 14E2B0 Vanellus Multigrade 15W-40 20L 15282A / 15552B Vanellus Multi 15W-40 208L 15282B / 15551C Vanellus Multi 15W-40 20L 15260C / 15549E Vanellus Mono 10W 208L 15269D / 154FE2 Vanellus Mono 30 208L 14342B Autran DX III 1L 1434A7 Autran DX III 20L 107042 Autran DX III 208L 14340E Autran MBX 1L 116163 / 15646C Autran MBX 20L 107068 Autran MBX 208L 119040 Autran MM-SP III 20L 119041 Autran MM-SP III 208L 117141 Autran 4 10 208L 114801 Autran 4 30 208L 14340A Energear SGX 75W-90 1L 116282 Energear SGX 75W-90 20L 108549 Energear SGX 75W-90 208L 14340D / 1557FC Energear HT 75W-90 1L 152B37 / 1557FD Energear HT 75W-90 20L 112212 / 1557FE Energear HT 75W-90 208L 14342A Energear HT 80W-90 1L 116204 Energear HT 80W-90 20L 107544 Energear HT 80W-90 208L 112224 Energear HT 85W-140 208L 1433FC / 15573C Energear EP 80W-90 1L 116100 / 15573B Energear EP 80W-90 20L 107481 / 15573A Energear EP 80W-90 208L 14973D / 15554C Energear EP 80W 208L 14340C Energear Limslip 90 1L 110198 / 1557F8 Energear Limslip 90 208L 1433FE / 155D2A Energear Hypo 80W-90 1L 116106 / 155D1A Energear Hypo 80W-90 20L 107520 / 155D1C Energear Hypo 80W-90 208L 107527 Energear Hypo 85W-140 208L 116107 Energear Hypo 85W-140 20L 107534 / 1556ED Energear Hypo 90 208L 116108 Energear Hypo 90 20L 119622 / 1556F7 Energear SHX-M 75W-90 208L 119624 / 1556FA Energear SHX-M 75W-90 20L 14B5E2 / 154FC7 Energear SHX-LS 75W-90 208L 109101 Energrease ZS 00 15KG 109107 Energrease ZS 00 50KG 135603 Brake Fluid DOT 4 0.5L Лабораторные анализы - Свежие - VOA oil-club.ru BP Visco 7000 0W-40 CleanGuard свежее BP Visco 5000 5W-40 свежее BP VISCO 3000 10W-40 свежее Лабораторные анализы - Отработки - UOA oil-club.ru BP Visco 7000 0W-40 LL-04 C3 отработка на BMW 525D после 10100км BP Visco 7000 0W-40 отработка на Fiat Linea после 7000км BP Visco 7000 0W-40 C3 отработка + Liqui Moly Oil Additive на Mitsubishi Outlander XL после 4500км BP Visco 5000 5W-40 на Лада Калина (Учебка) после 12000км и 1200м.ч BP Visco 7000 0W-40 LL-04 C3 отработка на VW Tiguan после 8300км
19 ноября 201214 г что скажите - потянет ли ВР 7000 на дизельный мотор 2.2 ланд ровер фрилендер? хватит ли ТВН? - всё остальное у этого масла на отлично как я понял как думаете потянет ТВН 7 с копейками дизель? А зачем покупать простой 7000??? есть ведь спецально для дизеля Visco 7000 Turbo Diesel API CF; ACEA B3/B4; VW 505.00 (01/97); MB 229.1; BMW Longlife-01 Физико-химические характеристики: Плотность при 15 оС, г/м3 0.843 Вязкость при 40 оС, сСт 73.6 Вязкость при 100 оС, сСт 12.9 Индекс вязкости 177 Температура вспышки в закрытом тигле, оC 236 Температура застывания, оС -66 Щелочное число(TBN), мг КОН/г 10,6 Вязкость при температуре 150 оС и скорости сдвига 106 c-1 (HTHS), сП 3,6
19 ноября 201214 г А зачем покупать простой 7000??? есть ведь спецально для дизеля Visco 7000 Turbo Diesel API CF; ACEA B3/B4; VW 505.00 (01/97); MB 229.1; BMW Longlife-01 Физико-химические характеристики: Плотность при 15 оС, г/м3 0.843 Вязкость при 40 оС, сСт 73.6 Вязкость при 100 оС, сСт 12.9 Индекс вязкости 177 Температура вспышки в закрытом тигле, оC 236 Температура застывания, оС -66 Щелочное число(TBN), мг КОН/г 10,6 Вязкость при температуре 150 оС и скорости сдвига 106 c-1 (HTHS), сП 3,6 давно ли масла стали подбирать по названию ?
19 ноября 201214 г причем тут название? или надо было блеснуть? человек хочет залить просто Visco 7000 в дизельное авто, значит универсальные допуски его устраивают, волнует только щелочное, а есть спец продукт Visco 7000 Turbo Diesel с соответствующей спецификацией которую если не заметил я выложил... кому не подходит по допускам -есть другие темы... тема за бренд ВР.... Изменено 19 ноября 201214 г пользователем Nordman
19 ноября 201214 г есть спец продукт Visco 7000 Turbo Diesel что то мне подсказывает,что если приписать к этому "спецпродукту" недостающее А3 - то получится "обычное" масло...
19 ноября 201214 г А зачем покупать простой 7000??? есть ведь спецально для дизеля Visco 7000 Turbo Diesel API CF; ACEA B3/B4; VW 505.00 (01/97); MB 229.1; BMW Longlife-01 Физико-химические характеристики: Плотность при 15 оС, г/м3 0.843 Вязкость при 40 оС, сСт 73.6 Вязкость при 100 оС, сСт 12.9 Индекс вязкости 177 Температура вспышки в закрытом тигле, оC 236 Температура застывания, оС -66 Щелочное число(TBN), мг КОН/г 10,6 Вязкость при температуре 150 оС и скорости сдвига 106 c-1 (HTHS), сП 3,6 Так тогда получается,что это масло можно лить и в бензиновый мотор тем,кто боится низкого щелочного числа в обычном Виско 7000? И если они стоят одинаково,то зачем тогда вообще нужно обычное Виско 7000? Изменено 19 ноября 201214 г пользователем Fallcon
19 ноября 201214 г Так тогда получается,что это масло можно лить и в бензиновый мотор тем,кто боится низкого щелочного числи в обычном Виско 7000? И если они стоят одинаково,то зачем тогда вообще нужно обычное Виско 7000? потому что в обычном 7000 допуски 229.51, LL-04
9 декабря 201213 г откатал уже тыщщи 2.5, масло заметно потемнело, отложений в горловине не заметил, но зима еще впереди
10 декабря 201213 г У меня на РАВ4 2AZ-FE Виско 7000 активно кушается, по крайней мере прошлой зимой доливал литрушку. Перед морозами опять залил это масло, т.к. прошлая зима показало что с этим маслом мой двигатель всегда заводится, даже без автопрогрева....
14 декабря 201213 г Сегодня приобрел для замены в свое турбоведерко Bp вместо откатавшего свое GM. И вот что обнаружил У нас в Республике Беларусь все импортеры обязаны указывать параметры масел, и вот что было указано по Bp visco 7000 0W-40 - плотность при 15 градусах – 0,838 г/см3 - вязкость при 40 градусах – 75,7 сСт - вязкость при 100 градусах – 12,8 сСт - индекс вязкости – 171 - температура вспышки в закрытом тигле (РМСС) – 224 градуса - температура застывания – 60 градусов
17 декабря 201213 г за 200км жесткого городского цикла 7000-ик резко потемнел :( щупа не видно На холодную или на горячую?
