Масла SRS
Официальный сайт: http://www.srs-oil.com/home-en.html
Русскоязычный сайт: http://srs-oil.ru
Список продукции: http://www.srs-oil.com/products.html
Спойлер
11000 - SRS ViVA 1 Ecosynth SAE 0W-40 1L
10262 - SRS ViVA 1 Ecosynth SAE 0W-40 4L
10195 - SRS ViVA 1 Ecosynth SAE 0W-40 200L
SRS ViVA 1 ecosynth SAE 0W-40 1л Артикул: 4033885000090
SRS ViVA 1 ecosynth SAE 0W-40 4лАртикул: 4033885000854
SRS ViVA 1 SAE 10W-40 1лАртикул: 4033885000168
SRS ViVA 1 SAE 10W-40 4лАртикул: 4033885000182
SRS ViVA 1 SLV plus SAE 5W-30 1лАртикул: 4033885000526
SRS ViVA 1 SLV plus SAE 5W-30 4лАртикул: 4033885000847
SRS ViVA 1 special F plus SAE 5W-30 1лАртикул: 4033885001189
SRS ViVA 1 special F plus SAE 5W-30 4лАртикул: 4033885001394
SRS ViVA 1 special F plus SAE 5W-30 5лАртикул: 4033885001400
SRS ViVA 1 special LMS SAE 5W-30 1лАртикул: 4033885001370
SRS ViVA 1 special LMS SAE 5W-30 4лАртикул: 4033885001011
SRS Viva 1 synthracing SAE 5W-50 1лАртикул: 4033885000489
SRS Viva 1 synthracing SAE 5W-50 4лАртикул: 4033885000861
SRS ViVA 1 topsynthalpha LA SAE 5W-30 1лАртикул: 4033885000533
SRS ViVA 1 topsynthalpha LA SAE 5W-30 4лАртикул: 4033885000540
SRS ViVA 1 topsynth SAE 5W-40 1лАртикул: 4033885000441
SRS ViVA 1 topsynth SAE 5W-40 4лАртикул: 4033885000458
7945 - SRS Viva 1 Topsynth Alpha LS 5W-40 1L
7944 - SRS Viva 1 Topsynth Alpha LS 5W-40 4L
7943 -  SRS Viva 1 Topsynth Alpha LS 5W-40 5L
7940 -  SRS Viva 1 Topsynth Alpha LS 5W-40 208L
SRS Cargolub TFG 10W-40 E4
SRS VIVA Special LMS 5W-30
SRS ViVA 1 Ecosynth Plus 0W-40
SRS ViVA 1 Synth Racing 5W-50
SRS Cargolub TLS Plus 5W-30
SRS Viva1 Topsynth Alpha LA 5W-30
SRS Viva1 Special MS 5W-30
SRS Viva1 SLV Plus 5W-30
SRS Viva1 Topsynth 5W-40
SRS Viva1 Ecosynth 0W-40
SRS VIVA 1 Topsynth 5W-40
SRS VIVA 1 topsynth Plus 5W-40 бочковое
SRS Viva1 10W-40
SRS Viva1 Longlife 5W-30
SRS VIVA 1 alpha LS 5W-40 C3
SRS Special F Eco 5W-20
SRS Getriebefluid 5 L 75W-90 API GL-4+
SRS Wiolin ATF VI
SRS Viva 1 SLV Top 5W-30 отработка на BMW 1 Series F20 после 7 648 км
SRS ViVA 1 synth racing 5W-50 отработка на Nissan GT-R после 5000км
SRS Cargolub TLS PLUS 5W-30 отработка на IVECO двиг CURSOR 13 после 18000км
SRS Ecosynth 0W-40 отработка на Infiniti EX35 после 8500км
SRS VIVA 1 topsynth SAE 5W40 API SN отработка на Citroen Berlingo NEW B9 после 7000км
SRS VIVA1 Longlife 5W30 отработка на Citroen Berlingo после 5000 км
SRS Viva1 SLV Plus 5w-30 отработка Audi Q7 2015 4M после 7500км
SRS ViVA 1 Topsynth Alpha LA 5W-30 отработка Audi A4 после 6011 км
SRS VIVA 1 Topsynth Plus 5W-40 отработка на Citroen Berlingo после 5000 км.
SRS ViVA 1 ecosynth 0w-40 отработка на Kia cerato Koup после 9500км.
SRS ViVA 1 Topsynth Alpha LA 5W-30 отработка Audi A5 3.2 TFSI после 5000 км
SRS ViVA 1 special F eco 5w-20 отработка на Kia cerato Koup после 7900км
Отлично!  И Вам спасибо!
С допусками форда есть ещё special F plus, но его анализа здесь тоже нет.
Так у меня же мазда. Или двигатель форд у меня?
Изменено пользователем BigFan
Мазда-Форд давно женаты,как Рено-Ниссан и др.@BigFan, попробуй в свой мотор SRS VIVA1 Special LMS 5W30 С1 С2 A5/B5,много таких машин у нас на этом масле,все работают нормально.
Понял. Спасибо!
Понял. Спасибо!
В общем залил это масло. Двигатель работает тише, но за 400 км сожрал 2мм уровня. Писец, такого даже на мобиле до 3000 км не было!
Понял. Спасибо!
Залил альфу ла
Может ошибки измерения или недолива?
На горячую - на холодную, авто чуть под наклоном стоит и т.п.
Нет. Проверка масла на одном и том же месте на подземной парковке, после отстоя примерно часов 9 - 12. :(
@BigFan, такое бывает при смене марки масла,угорает несливаемый остаток,позднее должно прекратиться,не паникуй.
Понял. Спасибо за информацию. Паники то нет, просто с таким впервые сталкиваюсь. Вот и консультируюсь с знающими людьми. Просто если вдруг масло не подходит, то его необходимо срочно заменить. В общем пока буду наблюдать как и чего. Но на этом масле двигатель работает реально тише.
Приветствую! Ещё минус 1мм. :(
Сколько проехал с момента заливки и сколько долил?
Проехал 850км. С отметки максимум минус 3мм. Не доливал ещё. Очень похоже, что расход идёт когда в движении примерно на скорости км 80 давишь резко педаль газа в пол и двиг уходит в максимальные обороты.
Дыма не видно из трубы?
