Масла RedLine
Масла Red Line
Официальный сайт: http://www.redlineoil.com/
15304 - Red Line 5W-30 Motor Oil, 0.946L
15305 - Red Line 5W-30 Motor Oil,  3.8L
15306 - Red Line 5W-30 Motor Oil, 19L
12304 - Red Line Euro-Series 5W-30 Motor Oil, 0.946L
15404 - Red Line 5W-40 Motor Oil 0.946L
15405 - Red Line 5W-40 Motor Oil 3.8L
15406 - Red Line 5W-40 Motor Oil 19L
12404 - Red Line Euro-Series 5W-40, 0.946L
11804 - Red Line Syntetic Oil 0W-20, 0.946L
11805 - Red Line Syntetic Oil 0W-20, 3.8L
11114 - Red Line Syntetic Oil 0W-30, 0.946L
11115 - Red Line Syntetic Oil 0W-30, 3.8L
11116 - Red Line Syntetic Oil 0W-30, 19L
11104 - Red Line Syntetic Oil 0W-40, 0.946L
11105 - Red Line Syntetic Oil 0W-40, 3.8L
11106 - Red Line Syntetic Oil 0W-40, 19L
15204 - Red Line Syntetic Oil 5W-20, 0.946L
15205 - Red Line Syntetic Oil 5W-20, 3.8L
15206 - Red Line Syntetic Oil 5W-20, 19L
11604 - Red Line Syntetic Oil 5W-50, 0.946L
11605 - Red Line Syntetic Oil 5W-50, 3.8L
11304 - Red Line 10W-30 Motor Oil, 0.946L
11305 - Red Line 10W-30 Motor Oil, 3.8L
11306 - Red Line 10W-30 Motor Oil, 19L
11404 - Red Line 10W-40 Motor Oil, 0.946L
11405 - Red Line 10W-40 Motor Oil, 3.8L
11406 - Red Line 10W-40 Motor Oil, 19L
11504 - Red Line 15W-50 Motor Oil, 0.946L
11505 - Red Line 15W-50 Motor Oil, 3.8L
11506 - Red Line 15W-50 Motor Oil, 19L
12504 - Red Line 20W-50 Motor Oil, 0.946L
12505 - Red Line 20W-50 Motor Oil, 3.8L
12506 - Red Line 20W-50 Motor Oil, 19L
21404 - Red Line 15W-40 Diesel Oil, 0.946L
21405 - Red Line 15W-40 Diesel Oil, 3.8L
21406 - Red Line 15W-40 Diesel Oil, 19L
11704 - Red Line 10W-60 Motor Oil, 0.946L
11705 - Red Line 10W-60 Motor Oil, 3.8L
11706 - Red Line 10W-60 Motor Oil, 19L
Любительские тесты на замерзание:
-29С Сравнение масел 0W-40, Redline, Shell, Neste, Yacco, Addinol, Petronas, Lukoil Genesis 2016-2017 год
-32C Сравнение масел 0W-40, Redline, Shell, Neste, Yacco, Addinol, Petronas, Lukoil 2016-2017 год
Расшифровка даты производства масла
Red Line Euro Series 5W-30 Polaris Laboratories
Red Line High Performance 0W-20 Polaris Laboratories
Red Line Euro-Series 5W-30 2022
RedLine Professional-Series 5W-20 Motor Oil
Redline 20W-50 Motorcycle
Redline 0W-20
Redline 5W-20
Redline 5W-30
Redline 5W-40
Redline 0W-40
Redline Euro Series 5W-30
Redline Professional Series 5W-30 TD
Redline 10W-40 Motorcycle Oil
Redline Professional Series Motor Oil 5W-40
RedLine DCTF Dual Clutch Transmission Fluid лаборатория OelCheck
Redline MT-85 75W-85 GL-4 Gear Oil
Redline 75W-90 GL-5 Gear Oil
RedLine 75W-90 GL-5 Polaris Laboratory
Redline ATF DCTF
Redline D6 ATF
Redline 5W-40 SN (2022-23) отработка Mercedes SLC43 после 3737 км (144 мч)
Red Line Motor Oil 5W-30 отработка на BMW X6 после 7012км
RedLine Professional-Series 5W-30 TD EURO отработка на VW Tuareg после 4684 км
Red Line 5W-30 Motor Oil отработка на BMW X6 после 7185км
RedLine 0W-40 отработка на BMW Е90 325i после 12 410 км
Redline Euro-Series 5W-30 Motor Oil отработка на Range Rover Evoque 2.2 после 9133км
Redline Oil 0W-30 отработка на Range Rover Evoque 2.2 после 8500км
Red Line 5W-20 отработка на Mitsubishi Outlander XL после 7800 км
Red Line 0W-30 Motor Oil отработка на Mercedes ML166 350CDI после 10900км
RedLine High Performance 10W-40 отработка на Porsche Cayenne S 4.8 (958.1) после 9000км
Red Line 5W-30 Motor Oil отработка на BMW X6 после 6807 км
Red Line Professional Series 5W-30 TD Motor Oil отработка на Ниссан Патфайндер (V9X) после 6069 км (172 м.ч.)
Red Line Euro-Series 5W-30 Motor Oil отработка на Ниссан Патфайндер (V9X) после 11652 км
Red Line Euro Series 5W-30 на Ниссан Патфайндер(V9X) после 7100 км
Red Line 5W-40 отработка на Mercedes Benz GL500 после 6300км
Red Line 5W-20 отработка на KIA RIO III после 4500км
Red Line 0W-20 отработка на Mitsubishi Outlander XL после 4000 км
Red Line 5W-40 отработка на Mercedes A45AMG 3346 км
Red Line 10W-60 отработка на Audi RS6 после 6500 км.
Red Line Euro Series 5W-30 отработка на AUDI A1 после 9606км
В 26.07.2018 в 22:37, JEEPер сказал:
Да у меня 229.5, там много чего подходит, но в мануале настоятельно рекомендуют 5w30 в независимости от пробега...
Как так? У тебя ж тоже VM?  Разве не написано в мануале "Для автомобилей, не оборудованных фильтром твердых частиц
(DPF), необходимо использовать синтетическое моторное
масло 0W40 ESP, соответствующее требованиям стандарта
DaimlerChrysler Material Standard MS10725"?
Да и раньше ты вроде как лил именно 0W-40, Extreme там, Amsoil.:unknw:
2 минуты назад, garrett сказал:
масло 0W40 ESP
У меня допуск по МВ, Крайслер тут вообще не при чём... А под 229.5 вязкость от 0W30 до 5W40...
Залил сегодня рэдлайн. Масло красивое, похоже на кленовый сироп!
Первое впечатление, - машина просто выскочила из гаража на холостых. Далее по ходу тянула повеселее родного МБ 229.51. Компрессия деиствително лучше: крутит легче, тянет лучше. Проехал около 200 км, не скажу, что бы тише работало, но и не громче. Расход топлива без изменений.
Проехал чуть более 1000 км на масле, расход топлива стал немного меньше, 0.2л/100км как минимум.
Помните я пару страниц назад писал про Редлайн зимой?  Так вот начало тогда потряхивать двигатель в мороз на холодную, потом наступило тепло, сменил на Мобил 1 ФС 5в30, отъездил на нем 9000, поехал в Крым и там зацокотел гидрик. Поменяли на Тотал 9000 5в40, цокотение не исчезло, после была залита ликви моли промывка гидриков (думал дотянуть до Киева , чтобы там не менять, дороже). В итоге через три дня цокотений пропала тяга, заглох, завёлся, двигатель троит дико, еле накатом вниз приехал домой, а на след день отвез машину эвакуатором с Алупки в Симфер к знакомым. Вскрытие показало: рассыпалась новая иридиевая свеча Денсо (в цилиндр не попало, повезло, просто болталось там все в ней). В общем, поменяли все 16 гидриков и свечи.
Вот у меня загадка, связано ли как-то свеча и гидрик или это дикое совпадение? Могло ли Редлайн зимой увалить гидрик или вряд-ли? Гидр был именно пробит, изношен. Пробег был 192 тыщ
Изменено пользователем nVidia
nVidia  после 9000 пробега на масле (интересно сколько ещё М/Ч?) ты ещё в Крым поехал... :Laie_60B: Уж RedLine тут точно не виноват...
9000 - это уже с Крымом.  Основной пробег на этом масле - это две поездки в Крым по 2000 км, также поездка в Харьков и другие города. Т.е. город трасса примерно 60 трасса, 40 город.
Но даже если это был бы только город, то всё остальные водители катают вообще по 10-15 тыщ, а я первый раз за все время наездил по трассе 9, а не 4-5 как обычно ! При этом Мобил ФС имеет просто дикое щелочное число. И да, гидрик уже начал цокотеть потихоньку на холодную после редлайна, но я думал это глушак где-то с мусором внутри. Потом начало на горячую.
Ото лишь бы похлопать, поугорать...
nVidia ну как написал, так и ответил... А ты Мобил точно не палёнку хапнул? Но я думаю тут вообще масла не при чём...
Это может быть, но брал в довольно серьезном магазе База Автозвука. Это тут довольно доверительный Магаз, хотя и читал уже недавно, что там может быть подделка. Хз , не понятно,  но я все же думаю, что это норм Магаз
On 8/27/2018 at 10:52 PM, mi4 said:
Может пора на пробег посмотреть 192 тк, а не на масло
Для гидриков это как раз замена
26.08.2018 в 15:33, JEEPер сказал:
Одно точноон хапнул свечи - палёнку. Про Denso уже не раз слышал...
Это вообще совпадение какое-то. Мог бы ездить и цокотеть месяц еще
Можете смеяться, но я его лью в перемешку с другими маслами. Просто оно есть и надо во что то его вылить... да, бывает и такое. :-)))
Только не бейте сильно https://www.drive2.ru/l/509468884286308550/
Изменено пользователем M4RAY
