Масла Areol
Официальный сайт:  http://www.areollub.com/
Нарвался на просторах интернета на такое вот масло под названием Areol, производится типа в Нидерландах.
каталог http://armtek.by/wp-content/uploads/2017/10/Katalog-masel-AREOL.pdf
продвигается белорусским Armtek
5W30AR015 - Areol Max Protect F 5W-30 1L
5W30AR016 - Areol Max Protect F 5W-30 4L
5W30AR017 - Areol Max Protect F 5W-30 5L
5W30AR044 - Areol Max Protect F 5W-30 20L
5W30AR045 - Areol Max Protect F 5W-30 60L
5W30AR046 - Areol Max Protect F 5W-30 205L
5W40AR011 - Areol Max Protect 5W-40 1L
5W40AR010 - Areol Max Protect 5W-40 4L
5W40AR009 - Areol Max Protect 5W-40 5L
5W40AR038 - Areol Max Protect 5W-40 20L
5W40AR039 - Areol Max Protect 5W-40 60L
5W40AR040 - Areol Max Protect 5W-40 205L
10W40AR002 - Areol Max Protect 10W-40 1L
10W40AR003 - Areol Max Protect 10W-40 4L
10W40AR001 - Areol Max Protect 10W-40 5L
10W40AR032 - Areol Max Protect 10W-40 20L
10W40AR033 - Areol Max Protect 10W-40 60L
10W40AR034 - Areol Max Protect 10W-40 205L
5W40AR060 - Areol Eco Protect 5W-40 1L
5W40AR061 - Areol Eco Protect 5W-40 4L
5W40AR062 - Areol Eco Protect 5W-40 5L
5W40AR063 - Areol Eco Protect 5W-40 20L
5W40AR064 - Areol Eco Protect 5W-40 60L
5W40AR065 - Areol Eco Protect 5W-40 205L
5W30AR018 - Areol Eco Protect 5W-30 1L
5W30AR019 - Areol Eco Protect 5W-30 4L
5W30AR020 - Areol Eco Protect 5W-30 5L
5W30AR047 - Areol Eco Protect 5W-30 20L
5W30AR048 - Areol Eco Protect 5W-30 60L
5W30AR049 - Areol Eco Protect 5W-30 205L
0W20AR068 - Areol Eco Energy DX1 0W-20 5L
0W20AR067 - Areol Eco Energy DX1 0W-20 4L
0W20AR066 - Areol Eco Energy DX1 0W-20 1L
0W30AR057 - Max Protect 0W-30 1L ACEA A3/B4
0W30AR058 - Max Protect 0W-30 4L ACEA A3/B4
0W30AR059 - Max Protect 0W-30 5L ACEA A3/B4
5W30AR074 - Areol ECO Energy DX1 5W-30 5L
5W30AR073 - Areol ECO Energy DX1 5W-30 4L
5W30AR072 - Areol ECO Energy DX1 5W-30 1L
5W30AR006 AREOL ECO Protect Z 5W-30 (5L) масло моторное! синт.\ ACEA C3, API SN, MB 229.51/229.52, VW 502.00
5W30AR007 AREOL ECO Protect Z 5W-30 (1L) масло моторное! синт.\ ACEA C3, API SN, MB 229.51/229.52, VW 502.00
5W30AR008 AREOL ECO Protect Z 5W-30 (4L) масло моторное! синт.\ ACEA C3, API SN, MB 229.51/229.52, VW 502.00
5W30AR012 AREOL Max Protect LL 5W-30 (1L) масло моторное! синт.\ ACEA A3/B4, API SN/CF, MB 229.3/226.5
5W30AR013 AREOL Max Protect LL 5W-30 (4L) масло моторное! синт.\ ACEA A3/B4, API SN/CF, MB 229.3/226.5
5W30AR014 AREOL Max Protect LL 5W-30 (5L) масло моторное! синт.\ ACEA A3/B4, API SN/CF, MB 229.3/226.5
5W30AR018 AREOL ECO Protect 5W-30 (1L) масло моторное! синт.\ ACEA C3, API SN, VW 504.00/507.00, MB 229.51
5W30AR019 AREOL ECO Protect 5W-30 (4L) масло моторное! синт.\ ACEA C3, API SN, VW 504.00/507.00, MB 229.51
5W30AR020 AREOL ECO Protect 5W-30 (5L) масло моторное! синт.\ ACEA C3, API SN, VW 504.00/507.00, MB 229.51
Грузовая Программа:
10W40AR004 AREOL Trans Truck 10W-40 (20L) масло моторное! полусинт.\ ACEA A3/B4/E7, API CI-4/SL, MB 228.3/229.1
10W40AR005 AREOL Trans Truck 10W-40 (205L) масло моторное! полусинт.\ACEA A3/B4/E7, API CI-4/SL, MB 228.3/229.1
10W40AR025 AREOL Trans Truck ECO 10W-40 (20L) масло моторное! синт.\ACEA E6/E7, API CI-4, Volvo VDS-3,MAN M3477
10W40AR026 AREOL Trans Truck ECO 10W-40 (205L) масло моторное! синт.\ACEA E6/E7, API CI-4,Volvo VDS-3,MAN M3477
Areol Trans Truck ECO 10W-40
Areol Max Protect F 5W-30 API SL
Areol Eco Energy DX1 5W-30 API SP
Areol Max Protect 5W-40 API SN
Areol Trans Truck 10W-40 API CI-4
Areol Max Protect 0W-30
Areol Eco Protect C2 5W-30
Areol Eco Energy DX1 0W-20 API SP
Areol Eco Protect 5W-30 2022
Areol EcoProtect 5W-30 канистра март 2018 года
Areol Max Protect LL 5W-30
Areol Eco Energy DX1 0W-20  отработка на Toyota Rav4 после 9300км
Канистра действительно классная, но она не только у Вас  ;)
я кстати узнал ваши канистры)))
Жижка и у меня начала биться. 1374 р. за 5 литров 5-30 синтетики А3/В4 - по моему вкусно. Бьётся в (моём) местном инет-магазе (которы работает с адео-про)...
Я скажем уже могу его заказать,но пока не вижу никакого смысла (манагер армтековский меня пока ещё никак не заинтересовал выставить его у себя и начать продвижение)))))))).
А как бы Ваш менеджер мог Вас заинтересовать?) При каких условиях Вы бы согласились выставить его у себя, ну и начать продвижение?)  :)
А у кого еще такая есть?
Экстрим
Экстрим
Экстрим меняет завод производителя, и теперь такая канистра только у нас!)
наверное завтра закажу и залью) вдруг тихое)
Заказал? Залил? Какие впечатления?
ну сегодня все же ограничили польским Orlen Oil, но вот скоро мне в двух авто менять масло...в общем думаю.
в общем купил, залил, AREOL Max Protect 5W-40, в гольф 4 1.4бензин 1998г, авто в одних руках около 6 лет, пол заливной крышкой едва не уголь. на авто езжу не я. если на след замену приедет, буду смотреть в заливнуху, может чего отмыло, а что залито было до не спрашивал, но последняя замена была больше 10 тыс, так типа обычно 8, но как так загадить движок я не знаю.
если что есть общее фото заливки масла в двиг.
Залил я себе тоже 5w40, до этого прежний хозяин заливал bp visco 10w40, под клапонной крышкой было очень грязно, да и когда сливал старое масло оно было уж больно светлым(не моет, подумал я). После того как залил Areol проехал 2 тыс. - масло несколько потемнело, что не может не радовать, клаппанную крышку не поднимал, при замене обязательно проверю...
Изменено пользователем Maloy_x84
А масла на ПАО синтетике какие нибудь линейке есть? :) Развития вам!
Спасибо! Мы стараемся!
Кстати, сегодня в лабораторию в Екатеринбурге были сданы два масла на свежий анализ, теперь ждём 5 рабочих дней.
В данный момент масла производятся из 3+ группы. С не урезанным пакетом присадок.
Масла на ПАО конечно планируются, но по срокам даже примерно не смогу сориентировать.
вот бы 5w50 A3B4 сделали...льют его сейчас не в спортивные тачки а в те где есть масложор, или просто чел вжаривает на чипе.
