Масла Eurol ОБЩАЯ
Масла Eurol
Генеральный сайт: http://www.eurol.com/en/oil_products/product_advisor/2
Адрес завода: Energiestraat 12 7442 DA Nijverdal
Панорамные фотографии завода:
Вид на завод со спутника
Видео:
E1000764L - EUROL FLUENCE DXS 5W-30 4L
E1000761L - EUROL FLUENCE DXS 5W-30 1L
E1000691L - Eurol Fluence FE 5W-30 1L
E1000695L - Eurol Fluence FE 5W-30 5L
E10006960L - Eurol Fluence FE 5W-30 60L
E100069210L - Eurol Fluence FE 5W-30 210L
E1000621L - EUROL SYNTENCE 5W-30 1L
E1000624L - EUROL SYNTENCE 5W-30 4L
E1000625L - EUROL SYNTENCE 5W-30 5L
E1000651L - EUROL FORTENCE 5W-30 1L
E1000655L - EUROL FORTENCE 5W-30 5L
V172085638 - EUROL SUPER LITE ARCTIC 5W-30 1L
E1000094L - EUROL SUPER LITE ARCTIC 5W-30  4L
E1000091L - Eurol Super Lite Arctic 5W-30 1L
E1000671L - EUROL SYNERGY 0W-30 1L
E1000675L - EUROL SYNERGY 0W-30 5L
E1000641L - EUROL SYNERGY 0W-40 1L
E1000645L - EUROL SYNERGY 0W-40 5L
E1000911L - EUROL SUPER LITE 5W-30 1L
E1000914L - EUROL SUPER LITE 5W-30 4L
E10009120L - EUROL SUPER LITE 5W-30 20L
E100091210L - EUROL SUPER LITE 5W-30 210L
E1000921L - EUROL SUPER LITE 5W-40 1L
E1000924L - EUROL SUPER LITE 5W-40 4L
E10009220L - EUROL SUPER LITE 5W-40 20L
E100092210L - EUROL SUPER LITE 5W-40 210L
E1000931L - EUROL SUPER LITE 5W-50 1L
E1000934L - EUROL SUPER LITE 5W-50 4L
E100093210L - EUROL SUPER LITE 5W-50 210L
E1000851L - EUROL TURBO DI 5W-40 1L
E1000854L - EUROL TURBO DI 5W-40 4L
E10008520L - EUROL TURBO DI 5W-40 20L
E1000611L - EUROL MAXENCE RC 10W-60 1L
E1000614L - EUROL MAXENCE RC 10W-60 4L
E1001281L - EUROL EVOLENCE 0W-20 1L
E1001285L - EUROL EVOLENCE 0W-20 5L
E1001311L - EUROL EVOLENCE 5W-30 1L
E1001315L - EUROL EVOLENCE 5W-30 5L
E1000511L - EUROL SYNTO-V 5W-30 1L
E1000514L - EUROL SYNTO-V 5W-30 4L
E1000941L - EUROL TURBOSYN 10W-40 1L
E1000944L - EUROL TURBOSYN 10W-40 4L
E10009420L - EUROL TURBOSYN 10W-40 20L
E100094210L - EUROL TURBOSYN 10W-40 210L
E1000391L - EUROL TURBOSYN 15W-50 1L
E1000394L - EUROL TURBOSYN 15W-50 4L
E100039210L - EUROL TURBOSYN 15W-50 210L
E1100761L - EUROL FULTRASYN 75W-90 GL3/4/5 (ESTER+PAO, -51°C)
E1100751L - EUROL TRANSYN 75W-90 GL 4/5 1L
E1100755L - EUROL TRANSYN 75W-90 GL 4/5 5L
E11007520L - EUROL TRANSYN 75W-90 GL 4/5 20L
E110075210L - EUROL TRANSYN 75W-90 GL 4/5 210L
E1106301L - EUROL HPG SAE 80W-90 GL5 1L
E1106305L - EUROL HPG SAE 80W-90 GL5 5L
E11063020L - EUROL HPG SAE 80W-90 GL5 5L 20L
E110630210L - EUROL HPG SAE 80W-90 GL5 210L
E1106051L - EUROL MPG EP SAE 80W-90 GL4 1L
E1106054L - EUROL MPG EP SAE 80W-90 GL4 4L
E11060520L - EUROL MPG EP SAE 80W-90 GL4 20L
E110605210L - EUROL MPG EP SAE 80W-90 GL4 210L
E1136611L - EUROL ATF 1100 1L
E1136571L - EUROL ATF 6100 1L
E1136531L - EUROL ATF 6700 1L
E1136535L - EUROL ATF 6700 5L
E11365320L - EUROL ATF 6700 20L
E1136581L - EUROL ATF 7100 1L
E1136591L - EUROL ATF III F 1L
E1136595L - EUROL ATF III F 5L
E11365920L - EUROL ATF III F 20L
E1136501L - EUROL ATF II D 1L
E1136504L - EUROL ATF II D 4L
E11365020L - EUROL ATF II D 20L
E113650210L - EUROL ATF II D 210L
E1136631L - EUROL CVT 1304 1L
E801400500ML - EUROL BRAKEFLUID DOT 4 0.5L
E8014001L - EUROL BRAKEFLUID DOT 4 1L
E901304400G - EUROL BLUE STAR GREASE EP 2 0.4kg
E90130415KG - EUROL BLUE STAR GREASE EP 2 15kg
E901030400G - EUROL UNIVERSAL LITHIUM GREASE EP 2 0.4kg
E90103020KG - EUROL UNIVERSAL LITHIUM GREASE EP 2 20kg
E901070400G - EUROL MOLYBDENUM DISULPHIDE MOS2 GREASE 0.4kg
E90107020KG - EUROL MOLYBDENUM DISULPHIDE MOS2 GREASE 20kg
E90101020KG - EUROL LITHIUM GREASE EP 00 - 20kg
E5041451L - EUROL COOLANT GLX -36°C 1L
E5041455L - EUROL COOLANT GLX -36°C 5L
E50414520L - EUROL COOLANT GLX -36°C 20L
E504145210L - EUROL COOLANT GLX -36°C 210L
E5041051L - EUROL COOLANT BS -36°C 1L
E5041055L - EUROL COOLANT BS -36°C 5L
E50410520L - EUROL COOLANT BS -36°C 20L
E504105210L - EUROL COOLANT BS -36°C 210L
E5031521L - EUROL ANTIFREEZE GLX concentrate 1L
E5031525L - EUROL ANTIFREEZE GLX concentrate 5L
E50315220L - EUROL ANTIFREEZE GLX concentrate 20L
E50315260L - EUROL ANTIFREEZE GLX concentrate 60L
E503152210L - EUROL ANTIFREEZE GLX concentrate 210L
E5041051L - EUROL ANTIFREEZE BS 6580 concentrate 1L
E5041055L - EUROL ANTIFREEZE BS 6580 concentrate 5L
E50410520L - EUROL ANTIFREEZE BS 6580 concentrate 20L
E50315060L - EUROL ANTIFREEZE BS 6580 concentrate 60L
E504105210L - EUROL ANTIFREEZE BS 6580 concentrate 210L
E116001250ML - EUROL AIRCO OIL PAG 46 250ml
E116002250ML - EUROL AIRCO OIL PAG 100 250ml
E701445500ML - EUROL SUPER BRAKE CLEANER SPRAY (cпрей обезжириватель) 500ml
E701310400ML - EUROL CHAIN SPRAY PTFE (спрей-смазка для цепей) 400ml
E701300400ML - EUROL PENETRATING OIL SPRAY (разблокирующий спрей-смазка) 400ml
E701320400ML - EUROL SILICONE SPRAY (силиконовый спрей-смазка) 400ml
E401701250ML - EUROL RADIATOR SEALER (присадка для остановки течи радиатора) 250ml
E701420400ML - EUROL WHITE GREASE SPRAY with PTFE (спрей смазка на литиевой основе) 400ml
E601440600ML - EUROL HANDCLEANER WHITESTAR (мыло для рук) 600ml
E60144045L - EUROL HANDCLEANER WHITESTAR (мыло для рук) 4.5L
E1000701L - EUROL SPORTBIKE 10W-40 FULLSY (синтетическое) 1L
E1000971L - EUROL MOTORCYCLE 10W-40 (полусинтетическое) 1L
E1000974L - EUROL MOTORCYCLE 10W-40 (полусинтетическое) 4L
E1000111L - EUROL SPORT TOURING 10W-40 (минеральное) 1L
E1284331L - EUROL SUPER 2T FORMAX (синтетическое) 1L
E1284281L - EUROL TTX PROSCOOT (полусинтетическое) 1L
E1284001L - EUROL SX SPORT TWO STROKE (минеральное) 1L
E125400600ML - EUROL LAWN MOWER OIL SAE 30 (газонокосилки) 600ml
E1254001L - - EUROL LAWN MOWER OIL SAE 30 (газонокосилки) 1L
E1254501L - EUROL CHAINSAW OIL AK (масло для цепей) 1L
E1001441L - EUROL NAUTIC LINE 10W40 FCW 1L
E1284301L - EUROL NAUTIC LINE SUPER 2T OUTBOARD TCW-III 1L
E10871020L - EUROL HYKROL HLP ISO-VG 32 20L
E108710210L - EUROL HYKROL HLP ISO-VG 32 210L
E10880020L - EUROL HYKROL VHLP ISO-VG 32 20L
E108800210L - EUROL HYKROL VHLP ISO-VG 32 210L
E10881020L - EUROL HYKROL VHLP ISO-VG 46 20L
E108810210L - EUROL HYKROL VHLP ISO-VG 46 210L
E10011320L - EUROL FUSION 10W-40 20L
E100113210L - EUROL FUSION 10W-40 210L
EUROL артикульные коды.xlsx
Eurol Evolence 0W-20 Dexos1 (Gen2) (анализ июль 2019)
Eurol Syndura 5W-40 API SN
Eurol Syntence 5W-30
Eurol Maxence RC 10W-60
Eurol Super Lite 5W-40
Eurol Turbo DI 5W-40
Eurol Fluence DXS 5W-30
Eurol Turbosyn 10W-40
Eurol Synergy 0W-40
Eurol Synergy 0W-30
Eurol Super Lite 5W-30
Eurol Evolence 5W-30 API SN
Eurol Evolence 0W-20 API SN
Eurol Fortence 5W-30
Eurol MTF 75W-80 API GL-5
Eurol Transfluid STF
Eurol ATF 6700
Eurol MTF FE 75W-85
Eurol MTF FE 75W-85 API GL-5 NEW 2023
Eurol Fultrasyn 75W-90
Eurol Evolence 5W-30 API SP отработка на Kia Rio 3 после 4914 км
Eurol Fortence 5W-30 отработка на Land Rover Freelander 2 после 6500км
Eurol Super Lite Arctic 5W-30 отработка на Nissan Qashqai после 7500км
Eurol Fortence 5W-30 отработка на Kia Ceed после 7200км
Eurol Super Lite 5W-40 отработка на Infifnity QX56 после 9800км.
Eurol Super Lite 5w40 отработка на Mitsubishi Pajero Sport после 6000 км.
Eurol Super Lite 5W-30 отработка на Mitsubishi Pajero после 7200 км.
Eurol Super Lite 5W30 отработка на Skoda Yeti после 5981 км.
Eurol Fluence DXS 5W-30 на Skoda Yeti после 5297 км.
Eurol Synergy 0W-30 отработка на Mitsubishi Lancer X после 6500 км.
Eurol Syntence 5W-30 отработка на Skoda Yeti после 4855км
Eurol Super Lite 5W-40 отработка на VW Bora после 8419 км.
Eurol Super Lite 5W-50 отработка на Renault Duster после 5084 км.
Eurol Super Lite 5W-30 отработка на Renault Logan после 8000 км.
Eurol Super Lite 5W-30 отработка на VW Touareg после 12900 км.
Eurol Super Lite Arctic 5W-30 + NGN Nord 5W-30 отработка на Toyota Landcruiser Prado после 7500 км.
Eurol Fortence 5W-30 отработка на Mitsubishi Pajero 4 после 7500 км.
Eurol Synergy 0W-40 отработка на Lada Kalina после 8000 км.
Eurol Super Lite Arctic 5W-30 отработка на Nissan Almera New после 13680 км.
Eurol Turbo DI 5-40 отработка на Nissan Pathfinder после 9653км - 241м.ч.
Eurol Evolence 0W-20 + присадка Eurol Engine Oil Treat на Hyundai Creta после 6350 км
Отчеты форумчан по маслам Eurol:
Eurol Syntence 5W30
Eurol Synergy 0w-40
Eurol Super Lite Arctic 5w-30
Eurol Super Lite Arctic 5W-30/NGN Nord 5W-30 на Toyota Prado 1GR-FE 4.0
Eurol Synergy 0w-30
А крышку ОТКРУТИТЬ у еврола легко ? Возможно ?
Как достается пистон сделано классно...
Мне кажется вы сами не понимаете что пишите...
Свиат - это импортер коммы. Вы же в теме еврола.
Еврол у нас с Европы импортирует AD, а так же еще возят с России, берут у представительства.
Короче, лично я не улавливаю что вы хотите сказать, спросить, уточнить, какое масло вы заливаете... Советую успокоиться, и написать доступным языком.
точняк, этикета свиат была на комме, на евроле была ад...
но факт что 4 литра еврола просто сгорело.
А комма не горит ?
Напишите точные марки масел, сравним основные характеристики... Лично мне очень с трудом верится ...
Хотя взял с вашей фотки
Комма полусинтетика, еврол синтетика. Основное отличие это температура вспышки...
Советовал бы проверить внутрянку мотора, систему рециркуляции... Потому что если оно и угорело, то только из за какой те неисправности...
Сказанное ИМХО
на комме проехал только 124км по трассе с скоростью 90-110, уровень пока не упал)
С внутрянкой всё в порядке, в том году ездил зимой на ардека 5в40, даже не подливал, как и лукойл 10в40, а тут ушло в ноль.
Eurol Turbosyn 10W-40 свежее за анализ спасибо дистрибьютору Eurol "Стиль Авто" и Eurol-shop.ru
Вывод: Традиционная европейская полусинтетика - на лето хороший вариант. Из плюсов - высокая термостабильность масла при высоких температурах, масло должно иметь малый расход на угар
так а почему на канистре пишется что синтетика и как вышло что это масло у меня полностью ушло на угар? учитывая что двигатель исправен.
Все на высшем уровне. Посмотрите внимательно на фото, вроде видно, что там по 4 точечных спайки идут с каждой стороны. И также у самой крышки по периметру много таких :up:
Тогда вы просто выбрали масло не для своего двигателя... Или...
Ну, да, защита отличная )))
мне тоже кажется что это масло не для дизеля. всегда настораживали масла SL/CF, за что лукой и нравился, исключительно турбодизель CF полусинтетика 10w40, тем более мой 1.9D из ряда горячих двигателей, где зимой на ХХ включается вторая скорость вентилятора в -20, про печку на скорости вообще молчу.
что по канистре, то горловина там такая как на фото, как у крон ойл, а вот у коммы как у лукойла, обычная пробка, аж обидно как то)
Думается мне , еврол для современных дизелей, а у вас классический тракторный мотор. Может и сыграло это роль, но я пока сам лично такое не испытаю на 200% уверен не буду.
Кстати, залейте следующий раз Fuchs titan MC и отпишитесь. Вот на 250% что должно быть классно, потому что у друга такого же плана мотор он за 15000 доливает 200гр, можно сказать что и не доливает. А машина работает в доставке то в городе то межгород. набеги у нее 15000 за 2 месяца...
ОК ?
ну 124 км пробег на комме эт еще НЕ_показатель!, а потому советую быть предельно внимательным и почаще контролировать уровень...прежде чем пенять на еврол (т.к. вполне может оказаться понапрасну...мож он все же убег :db: )
Изменено пользователем kam69
ОК ?
на фукс титан гт1 про флекс 5в30 ездил на шевроле что в профиле и на мицубиси л200, претензий нет, на орлен ойл шевроле работает громче.
а сам пока поезжу на комме, нам так сказать промыться двиглу, может быть на тысячах 2-3 поменяю, или в конце зимы.
масло я обычно менял на 5000 примерно, а тут за эти 5 еврол ушел почти весь, завтра скажу сколько слитого масла в ведре с учетом тех залитых 2.7
ну 124 км пробег на комме эт еще НЕ_показатель!, а потому советую быть предельно внимательным и почаще контролировать уровень...прежде чем пенять на еврол (т.к. вполне может оказаться понапрасну...мож он все же убег  )
ну я эту машину знаю, ипусь с ней 2 года, чужие руки в ней не бывают, и как то не был готов к тому что хваленый еврол которым торгует мой знакомый и который себе 2 раза лил мой друг, будет хуже лукойла, на котором с 2007 года езжу на разных машинах.
так что ждем результатов жора от коммы, а после нее традиционно зальем лукойл.
Eurol Super Lite 5W-30 :up:  Прокатился 400 км. по трассе в агрессивном режиме. По приезду проверил уровень :)  дал турбо ёжику выпить всего рюмку :DD
Спасибо. Изучаю, приглядываюсь.
Не пойму одного факта - в тех. документации пишут, что масло доступно в объёмах 1,5,60 и 210 л.
Это написано внизу тех.паспорта
А на сайте в ЕМЕХ есть в продаже и 4 л упаковка
Как так???
Варианты упаковки 1, 5, 60, 210 - это стандартные варианты завода. Но при этом завод может фасовать и в другие типы тары, 4, 10, 20, 200 и т.д.
В частности Eurol Syntence 5W-30 можно купить как в 4 литровой канистре, так и в 5 литровой (Eurol-shop).
В частности Eurol Syntence 5W-30 можно курить как в 4 литровой канистре, так и в 5 литровой (Eurol-shop).
Спасибо. Разобрался
А почему этого масла нет в последнем списке erwin?
вероятная причина лил летом, ездил в отпуск, высокие обороты больше угар.
вторая причина не пошло масло, бывает такое... менять значит на другое.
Присматриваюсь к Eurol Syntence 5W-30 (ACEA C3 504/507) в свою старуху, понравились мне масла этого стандарта - очень мало угарают...
