Масла Hitatsu
Официальный сайт: https://hitatsu.ru/
Каталог продукции: https://hitatsu.ru/product-category/motor-oil/
0W20H11            Hitatsu 0W-20 Zero Line Series API SP/CF, ACEA C5 – 1л
0W20H14            Hitatsu 0W-20 Zero Line Series API SP/CF, ACEA C5 – 4л
0W30H11            Hitatsu 0W-30 Zero Line Series API SP/RC, ACEA С3 – 1л
0W30H14            Hitatsu 0W-30 Zero Line Series API SP/RC, ACEA С3 – 4л
5W30H11            Hitatsu 5W-30 Asia Extra Series API SP, ILSAC GF-6A – 1л
5W30H14            Hitatsu 5W-30 Asia Extra Series API SP, ILSAC GF-6A – 4л
5W30H21            Hitatsu 5W-30 Diesel & Petrol DPF Series API SN, ACEA C3-16 – 1л
5W30H24            Hitatsu 5W-30 Diesel & Petrol DPF Series API SN, ACEA C3-16 – 4л
5W30H31            Hitatsu 5W-30 Europe & Asia Top Series API SL/CF, ACEA A5/B5 – 1л
5W30H34            Hitatsu 5W-30 Europe & Asia Top Series API SL/CF, ACEA A5/B5 – 4л
5W30H41            Hitatsu 5W-30 Europe Premium Series API SL/CF, ACEA A3/B4-16 – 1л
5W30H44            Hitatsu 5W-30 Europe Premium Series API SL/CF, ACEA A3/B4-16 – 4л
5W40H11            Hitatsu 5W-40 Europe Premium Series API SN/CF, ACEA A3/B4-16 – 1л
5W40H14            Hitatsu 5W-40 Europe Premium Series API SN/CF, ACEA A3/B4-16 – 4л
5W40H21            Hitatsu 5W-40 Diesel & Petrol DPF Series API SP, ACEA C3 – 1л
5W40H24            Hitatsu 5W-40 Diesel & Petrol DPF Series API SP, ACEA C3 – 4л
10W40H11          Hitatsu 10W-40 Europe Premium Series API SN/CF, ACEA A3/B4 – 1л
10W40H14          Hitatsu 10W-40 Europe Premium Series API SN/CF, ACEA A3/B4 – 4л
75W80H11          Hitatsu 75W-80 API GL-4 – 1л
75W85H11          Hitatsu 75W-85 API GL-4/GL-4+ – 1л
75W90H11          Hitatsu 75W-90 API GL-4/GL-5 – 1л
80W90H11          Hitatsu 80W-90 API GL-5 – 1л
ATFCVT1             Hitatsu CVT MULTI – 1л
ATFCVT4             Hitatsu CVT MULTI – 4л
ATFDEX1             Hitatsu ATF DEXRON VI – 1л
ATFDEX4             Hitatsu ATF DEXRON VI – 4л
ATFMUL1            Hitatsu ATF Multivehicle – 1л
ATFMUL4            Hitatsu ATF Multivehicle – 4л
ATFWS1               Hitatsu ATF TYPE WS – 1л
ATFWS4               Hitatsu ATF TYPE WS – 4л
Лабораторные анализы - Свежие – VOA
Hitatsu 5W-30 Diesel & Petrol DPF Series 2026
Hitatsu 5W-30 Asia Extra Series API SP, ILSAC GF-6A + Shear Stability Test *
Hitatsu 5W-40 Diesel & Petrol DPF Series API SP ACEA С3
Hitatsu 0W-20 Zero Line Series API SP ACEA С5 + Shear Stability Test
Hitatsu 0W-30 Zero Line Series API SP ACEA С3
Hitatsu 5W-40 Europe Premium Series API SN ACEA A3/B4
Hitatsu ATF ULV
Hitatsu PSF/CHF Multi ULV
Hitatsu HLDX LV+
Hitatsu CVT MULTI
Hitatsu DCT/DSG MULTI LV
Hitatsu 75W-90 API GL-4 / GL-5 / MT-1
Лабораторные анализы - Отработка – UOA
Hitatsu 5W-30 Asia Extra Series отработка на Chery Tiggo 7 Stage 2 после 6050 км
Hitatsu 5W-30 Europe & Asia Top Series SL/CF A5/B5 отработка на Nissan Sunny после 6443км
Hitatsu 0W-20 Zero Line Series API SP/CF ACEA C5 отработка на Geely Coolray после 9875км
Hitatsu 0W-30 Zero Line Series API SP, ACEA C3 отработка на Toyota RAV4 после 8548 км
torcon а меня какая фраза тригернула? :)
Друзья! Позвольте в рамках ликбеза, в самых общих чертах, описать области, которые охватывает своей работой производитель моторного масла.
Глобально все начинается с юридических аспектов и регистрации соответствующих патентных прав.
Затем идет огромная работа по маркетингу продукта: компоненты, базовые масла, присадки.
Ведется разработка упаковки, которая помимо привлекательности должна обеспечивать необходимые прочностные, технологические и транспортировочные характеристики.
Все разработки там, где это возможно, патентуются соответствующим образом для защиты авторских прав.
Далее идет огромная репутационная работа, для подтверждения бескомпромиссно постоянного качества.
Так, бренд Hitatsu выгодно отличится тем, что все масла Hitatsu застрахованы страховым полисом ответственности производителя в независимой страховой компании в ходящей в топ 10 страховых и имеющей рейтинг ruA+. Страховая компания готова работать только с надежным производителем, который исключает любые риски.
Сам производственный процесс начинается с непростой работы по логистике базовых масел и оригинальных пакетов Infineum, Afton, Lubrizol.
После многочисленных входных контролей, компоненты доставляются на завод, где происходит процесс варки масел.
После 100% выходного контроля каждой партии, обеспечивается упаковка, хранение и дистрибуция продукции.
Весь этот комплекс работ обеспечивает производитель. Только тогда он может по-настоящему им являться.
Это если ну очень кратко рассказывать.
Поэтому на каждой банке Hitatsu с гордостью написан производитель.
Примерно по такому же принципу указан производитель (который пользуется множеством подрядчиков) такого продукта, как iPhone:)
Hitatsu а паспорт качества на приобретенный продукт Вы за 2 месяца так и не удосужились прислать.
Мало "производить",нужно ещё и быть открытыми к клиентам...
Изменено пользователем bvv83
15 минут назад, Hitatsu сказал:
То есть это вы всё сами достаёте и привозите на завод upec?
И это тоже вы и ваши люди делают самолично, непосредственно на производстве?
Изменено пользователем kit72
Все перечеркивает этот закос под Японию. Масла у вас качественные - спору нет.
5 минут назад, bvv83 сказал:
Прошу прощения, видимо пропустилось ваше сообщение. Вышлю в ближайшее время
1 час назад, Hitatsu сказал:
Какая, в  ...опу, гордость с х.з. каким узкоглазым названием?! Ну нахрена эта дребедень с "японскими" наименованиями?!
8 часов назад, Hitatsu сказал:
После 100% выходного контроля каждой партии...
Прям 100%? Например HTHS у каждой партии моторных масел проверяете?
7 часов назад, Владимир09 сказал:
Чо бочку катишь. Это масло самурая !!! -)
28.12.2024 в 00:02, IvanRND сказал:
Прям 100%. На входе когда ЖД цистерну подвозят к трубопроводам, проверяют базовые масла - они тоже могут гулять качеством. После блендинга, проверяют что намешали, перед заливкой по таре. Я видел как они проверяют, ходил по лабе. Приборами она напичкана, приборы дублируются, HTHS вот не помню точно, есть у них или нет. Скорее всего есть.
4 часа назад, torcon сказал:
Тут с ВИНКами периодически проблемы по качеству, а здесь прям с уверенностью в 100%....хорошо, если будет так. Но опыт подсказывает, что не всегда так радужно, как кажется.
IvanRND ты спросил про 100% контроль каждой партии. Я ответил. Лаба есть, я по ней ходил, видел приборы... Проверяется перед замесом база, и после - перед розливом в тару. Такое многим мелким брендам, что тут боготворят фан группы - не снилось... Даже просто ЖД ветка к заводу...
В качестве аргумента. Ты был свидетелем как последние несколько лет, мы тестировали их продукцию под разными брендами. Неужели не заметил, что мешают они точно? Не рецептурные хитрости с китайскими присадками. А именно косяки блендинга были? :)
Пересмотрел фото, нет HTHS у них на тот момент не было. Говорили, что закупили якобы и идут некоторые нужные приборы, втом числе и HTHS. (сейчас наверное уже пришли...).
На момент моего присутствия было это: Кто знает, тот знает... 2/3 вырезала безопасность :)
IMG_20241229_232725_458.jpgIMG_20241229_232724_643.jpgIMG_20241229_232724_758.jpgIMG_20241229_232724_607.jpgIMG_20241229_232724_954.jpgIMG_20241229_232714_832.jpgIMG_20241229_232714_375.jpgIMG_20241229_232714_731.jpgIMG_20241229_232704_108.jpgIMG_20241229_232703_901.jpgIMG_20241229_232703_710.jpgIMG_20241229_232703_272.jpgIMG_20241229_232703_878.jpg
3 часа назад, torcon сказал:
В качестве аргумента. Ты был свидетелем как последние несколько лет мы тестировали их продукцию под разными брендами. Неужели не заметил, что мешают они точно? Не рецептурные хитрости с китайскими присадками. А именно косяки блендинга были? :)
Контроль партии, это когда уже выпустили - разлили в тару и только потом проверили по всем статьям(что там разлили). Вот это называю 100%.
Вот тебе один из моих примеров: масло одного из ВИНКов, свежее моторное из бочек разных партий с разницей даты производства в несколько месяцев. Для производителя было откровением данные предоставленные результаты.
И эти ребята помощней Обнинска во всех отношениях, если говорим о производстве, разработке и мощностях в целом.
"Такое вам по телевизору не покажут".
Screenshot_2024-12-30-00-23-25-18_a27b88515698e5a58d06d430da63049d.thumb.jpg.e7912ef5e12f8ee76ebc1fb0183579dc.jpgScreenshot_2024-12-30-00-22-39-03_a27b88515698e5a58d06d430da63049d.thumb.jpg.bf86bed47a0160f66f4787bf3360ffce.jpgScreenshot_2024-12-30-00-21-51-95_a27b88515698e5a58d06d430da63049d.thumb.jpg.a6e0ac25b1ee6cad6cb8b6a644911176.jpg
Когда сотни тонн масла проходят через руки, побольше инфы собирается о "100% контроле партий"
IvanRND я тебе только что вопрос задал. Ты видел последние пять лет наши анализы, продукции этого завода, под разными брендами. Контроль партии прямо из розницы, были косяки? :)
Перед розливом в тару есть контроль лабой. Что бы не разлить в канистры что попало. Есть ли после розлива анализ партии? Так наверное, как у всех заводов, по умолчанию есть. Иначе как ты паспорта партии выдавать будешь, под номером и датой? Хотя если честно я ХЗ - этот момент не знаю.
Когда мониторишь реальными анализами весь рынок страны, прямо с полок розницы, независимой лабой, а не лабой завода, и не рассматривая по паспортам, которые у многих как попало и отличаются от реальных характеристик продукта - нормально инфы собирается. Представление имеем :)
