Масла Hitatsu
Официальный сайт: https://hitatsu.ru/
Каталог продукции: https://hitatsu.ru/product-category/motor-oil/
0W20H11            Hitatsu 0W-20 Zero Line Series API SP/CF, ACEA C5 – 1л
0W20H14            Hitatsu 0W-20 Zero Line Series API SP/CF, ACEA C5 – 4л
0W30H11            Hitatsu 0W-30 Zero Line Series API SP/RC, ACEA С3 – 1л
0W30H14            Hitatsu 0W-30 Zero Line Series API SP/RC, ACEA С3 – 4л
5W30H11            Hitatsu 5W-30 Asia Extra Series API SP, ILSAC GF-6A – 1л
5W30H14            Hitatsu 5W-30 Asia Extra Series API SP, ILSAC GF-6A – 4л
5W30H21            Hitatsu 5W-30 Diesel & Petrol DPF Series API SN, ACEA C3-16 – 1л
5W30H24            Hitatsu 5W-30 Diesel & Petrol DPF Series API SN, ACEA C3-16 – 4л
5W30H31            Hitatsu 5W-30 Europe & Asia Top Series API SL/CF, ACEA A5/B5 – 1л
5W30H34            Hitatsu 5W-30 Europe & Asia Top Series API SL/CF, ACEA A5/B5 – 4л
5W30H41            Hitatsu 5W-30 Europe Premium Series API SL/CF, ACEA A3/B4-16 – 1л
5W30H44            Hitatsu 5W-30 Europe Premium Series API SL/CF, ACEA A3/B4-16 – 4л
5W40H11            Hitatsu 5W-40 Europe Premium Series API SN/CF, ACEA A3/B4-16 – 1л
5W40H14            Hitatsu 5W-40 Europe Premium Series API SN/CF, ACEA A3/B4-16 – 4л
5W40H21            Hitatsu 5W-40 Diesel & Petrol DPF Series API SP, ACEA C3 – 1л
5W40H24            Hitatsu 5W-40 Diesel & Petrol DPF Series API SP, ACEA C3 – 4л
10W40H11          Hitatsu 10W-40 Europe Premium Series API SN/CF, ACEA A3/B4 – 1л
10W40H14          Hitatsu 10W-40 Europe Premium Series API SN/CF, ACEA A3/B4 – 4л
75W80H11          Hitatsu 75W-80 API GL-4 – 1л
75W85H11          Hitatsu 75W-85 API GL-4/GL-4+ – 1л
75W90H11          Hitatsu 75W-90 API GL-4/GL-5 – 1л
80W90H11          Hitatsu 80W-90 API GL-5 – 1л
ATFCVT1             Hitatsu CVT MULTI – 1л
ATFCVT4             Hitatsu CVT MULTI – 4л
ATFDEX1             Hitatsu ATF DEXRON VI – 1л
ATFDEX4             Hitatsu ATF DEXRON VI – 4л
ATFMUL1            Hitatsu ATF Multivehicle – 1л
ATFMUL4            Hitatsu ATF Multivehicle – 4л
ATFWS1               Hitatsu ATF TYPE WS – 1л
ATFWS4               Hitatsu ATF TYPE WS – 4л
Лабораторные анализы - Свежие – VOA
Hitatsu 5W-30 Diesel & Petrol DPF Series 2026
Hitatsu 5W-30 Asia Extra Series API SP, ILSAC GF-6A + Shear Stability Test *
Hitatsu 5W-40 Diesel & Petrol DPF Series API SP ACEA С3
Hitatsu 0W-20 Zero Line Series API SP ACEA С5 + Shear Stability Test
Hitatsu 0W-30 Zero Line Series API SP ACEA С3
Hitatsu 5W-40 Europe Premium Series API SN ACEA A3/B4
Hitatsu ATF ULV
Hitatsu PSF/CHF Multi ULV
Hitatsu HLDX LV+
Hitatsu CVT MULTI
Hitatsu DCT/DSG MULTI LV
Hitatsu 75W-90 API GL-4 / GL-5 / MT-1
Лабораторные анализы - Отработка – UOA
Hitatsu 5W-30 Asia Extra Series отработка на Chery Tiggo 7 Stage 2 после 6050 км
Hitatsu 5W-30 Europe & Asia Top Series SL/CF A5/B5 отработка на Nissan Sunny после 6443км
Hitatsu 0W-20 Zero Line Series API SP/CF ACEA C5 отработка на Geely Coolray после 9875км
Hitatsu 0W-30 Zero Line Series API SP, ACEA C3 отработка на Toyota RAV4 после 8548 км
Изготовитель ООО Юнит групп?
Друзья, хотелось также в сообщении отметить вопрос цены на продукцию Hitatsu.
Обсуждение: дорогой или дешевый конкретный товар - предлагаю проводить вместе с результатами испытаний УРЦ, которые вот-вот появятся.
Но что хочется заметить.
Все из нас смотрят цену на популярных маркетплейсах, справедливо полагая, что она там будет минимальной.
Да, действительно (если не брать в расчет контрафакт, который там часто бывает) цены там бывают дешевле чем в магазинах. Но это достигается за счет того, что маркетплейсы снижают ее за свой счет.
Для покупателя это же хорошо! Но в результате компании, которые подсели на «иглу агрегатора» становятся заложниками и, когда халява проходит - вынуждены потом уже играть по жестким правилам маркетплейсов. В результате страдает ассортимент и качество товара, а потребитель потом получает цену выше. Далеко за примерами ходить не надо, вспомните историю с агрегаторами такси.
Поэтому хочу отметить, что продукция Hitatsu будет иметь максимально одинаковую (насколько это возможно) стоимость, независимо от того, продается она в автомагазине или в интернет агрегаторе.
08.05.2024 в 18:00, denis.platonov сказал:
Да
Моторные масла  из Японии что ли ?
Сомневаюсь .
13 часов назад, Hitatsu сказал:
Для покупателя это же хорошо! ...
Для покупателей на этом всё. Достаточно.
Все остальное вот это:
 Но ...
- плач Ярославны. Проблемы индейцев шерифа не волнует. Не можете вы, придут другие.
On 5/8/2024 at 6:00 PM, denis.platonov said:
ООО Юнит групп
Это где? Санкт-Петербург? А то я и у нас в Обнинске Юнит-Груп нашел)) На днях зайдет баллончик мовиля этого бренда, химия делается там же, где и масла?
2 часа назад, Dr_Brewer сказал:
Я имел ввиду Питерский Юнит.
Про индивидуальную канистру моторного масла
Задача каждого продукта: соответствовать ожиданиям потребителя (в нашем случае требованиям к моторным маслам) и быть индивидуальным.
Индивидуальность можно достигать внутренним превосходством продукта и внешним отличием. В маслах Hitatsu используются все возможности.
И казалось, что может быть проще – сделай свою канистру и выделяйся на фоне конкурентов. Но не все так просто.
Сейчас и далее речь пойдет о пластиковых ПНД (HDPE High Density Polyethylene) канистрах.
Сложности:
1. Проектирование. Нельзя просто так взять и спроектировать канистру). Нужно учитывать множество факторов: от прочностных характеристик, до соответствия заводским линиям налива продукции, а также удобства логистики и размещения в торговых точках.
2. Изготовление. Отдельный процесс требующий постоянной настройки и индивидуальной отладки.
3. Экономика продукта. Окупается индивидуальная канистра в течение пары-тройки лет. И соответственно, горизонт планирования производства и реализации продукта соответствующий.
Вот и выходит, что если производитель работает с полным циклом производства, контролируя и внося индивидуальность в каждый этап – то просто вынужден разрабатывать индивидуальную упаковку.
А если он планирует выпускать посредственный продукт, то вкладывать интеллектуальные, временные и финансовые средства – нет необходимости. Поэтому достаточно много брендов масла используют максимально распространённую тару.
Лидер здесь, конечно, пластиковая канистра масла Toyota и Nissan. Ее используют максимально часто. Затем располагаются копии канистр именитых брендов Shell, Mobil и т.д. Как правило, речь идет или о прямом копировании упаковки или слегка измененной таре (цвет канистры, форма крышки, грани).
Ну и понято, что компании, которые борются за внимание потребителя, хотят выделиться и работают с продуктом на длительную перспективу – имеют индивидуальную упаковку. У них, как правило, все в порядке с внешним и внутренним содержанием.
Конечно у данного правила есть исключения, которые лишь подтверждают правило.
Но в большинстве, масла в индивидуальной таре имеют качественный состав внутри.
В качестве послесловия.
Наглядный пример. Канистра Hitatsu, которая имеет достаточно прочные углы и толстые стенки.
При падении с высоты, канистра конечно замялась, но не треснула в углу и не потекла.
3 часа назад, Hitatsu сказал:
Hitatsu Доброго дня, в каталогах организации одноразовая посуда, скатерти, перчатки и иной бытовой продукт, но такого продукта как моторное масло - нет.
Legion777 bagi, grass
За что Вы рушите мой мир
Что же теперь выбирать из химии:cray:
3 часа назад, Legion777 сказал:
2 часа назад, Legion777 сказал:
Legion777 Здравствуйте!
Вы действительно считаете, что компания которая:
1. Производит масла на рецептурах Infineum (тут) и Lubrizol (скоро анализ)
2. Имеет индивидуальную канистру, которая запатентована в Федеральной Службе по Интеллектуальной Собственности (РОСПАТЕНТ)
3. Вкладывает ресурсы в цивилизованный сбыт товара
не имеет ОКВЭД - Производство смазочных материалов?
Это что, шутка такая?
Вы серьезно считаете, что загуглив схожее название и открыв ПЕРВУЮ ссылку в гугле - попадете на сайт производителя?:)
Лучше посетите официальный сайт hitatsu.ru
Найдете много полезной информации:)
32 минуты назад, MuxauJI сказал:
MuxauJI Спокойствие, только спокойствие!
Мир не рушится!) Атланты Хитацу не дадут ему упасть!)
Hitatsu Мне хочется узнать про ООО "Юнит Груп", которое позиционируется как производитель  автомобильных моторных масел, а не её отделение, либо сторонний производитель/упаковщик и т.п.
И гугл эту информацию предоставил, а не я её выдумал.
