Масла Hyundai / KIA OEM
05200-00140 - Hyundai Kia Eco Premium Diesel C2 0W-30 1L
05200-00640 - Hyundai Kia Eco Premium Diesel C2 0W-30 6L
05100-00171 - Hyundai Mega Turbo Syn 0W-30 API SN, ACEA C2 1L
05100-00471 - Hyundai Mega Turbo Syn 0W-30 API SN, ACEA C2 4L
05100-00161 - Hyundai New Premium Gasoline Engine Oil 0W-20 API SN ACEA C2 1L
05100-00461 - Hyundai New Premium Gasoline Engine Oil 0W-20 API SN ACEA C2 4L
05200-00110 - HYUNDAI CLASSIC GOLD DIESEL 10W-30 1L
05200-00410 - HYUNDAI CLASSIC GOLD DIESEL 10W-30 4L
05200-484A0 - HYUNDAI COMMERCIAL DIESEL 10W-40 4L
05200-00120 - HYUNDAI PREMIUM DPF DIESEL 5W-30 1L
05100-00121 - HYUNDAI PREMIUM GASOLINE 5W-20 1L
05100-00421 - HYUNDAI PREMIUM GASOLINE 5W-20 4L
05100-00151 - HYUNDAI PREMIUM LF GASOLINE 5W-20 1L
05100-00451 - HYUNDAI PREMIUM LF GASOLINE 5W-20 4L
05200-00411 - HYUNDAI PREMIUM LS DIESEL 5W-30 4L
05200-00111 - HYUNDAI PREMIUM LS DIESEL 5W-30 1L
05200-00100 - HYUNDAI PREMIUM PC DIESEL 10W-30 1L
05200-00400 - HYUNDAI PREMIUM PC DIESEL 10W-30 4L
05100-00110 - HYUNDAI SUPER EXTRA GASOLINE 5W-30 1L
05100-00410 - HYUNDAI SUPER EXTRA GASOLINE 5W-30 4L
05100-00141 - HYUNDAI TURBO SYN 5W-30 1L
05100-00441 - HYUNDAI TURBO SYN 5W-30 4L
05200-00610 - HYUNDAI CLASSIC GOLD DIESEL 10W-30 6L
05200-486A0 - HYUNDAI COMMERCIAL DIESEL 10W-40 6L
05100-00121 HYUNDAI PREMIUM GASOLINE 5W-20 SL/GF-3 1L
05100-00321 HYUNDAI PREMIUM GASOLINE 5W-20 SL/GF-3 3L
Перевод кем произведено оригинальное масло:
Hyundai/KIA Premium DPF Diesel Engine Oil 5W30 ACEA-C3 0520000620 Cравнение 2 образцов
Hyundai Turbo Syn Gasoline Engine Oil 5W-30 Сравние 3 образцов
Hyundai N Performance Engine Oil 0W-30 корейская лаборатория
Hyundai-Kia Turbo Syn Gasoline Engine Oil 5W-30
Hyundai-Kia Premium LF Gasoline Engine Oil 5W-20
Hyundai-Kia Premium LF Gasoline 5W-20 2024 Мичанг
Hyundai-Kia New Premium Plus 0W-20 (анализ с корейского форума)
Hyundai Turbo Syn 5W-30 05100-00441 new
Kia Mega Turbo Syn 0W-30 API SN, ACEA C2 05100-00171
Hyundai New Premium Gasoline Engine Oil 0W-20 API SN ACEA C2 05100-00161
Hyundai-Kia Turbo Syn 5W-30 05100-00441
Hyundai Kia Ecо Premium Diesel 0W-30
Hyundai 05100-00451 (05100-00151) Premium LF Gasoline 5w-20
Hyundai Premium Gasoline Engine Oil 5W-20
Hyundai-Kia Premuim DPF Diesel 5W-30 ACEA C3
Hyundai Kia Premium LS Diesel 5W-30 05200-00111
Hyundai Turbo Syn 5W-30 отработка на Kia Sportage после 9781км
KIA Mega Turbo Syn 0W-30 отработка на Mitsubishi Outlander XL после 8000 км
Kia Mega Turbo Syn 0W-30 API SN, ACEA C2 отработка на Mitsubishi Montero Sport после 7000-7300км
KIA Mega Turbo Syn 0W-30 отработка на Kia Rio после 2745км
KIA Mega Turbo Syn 0W-30 отработка на Toyota Land Сruiser Prado после 5646км
KIA Mega Turbo Syn 0W-30 ACEA C2 API SN отработка на KIA ceed CD после 6023км
Hyundai New Premium Gasoline Engine Oil 0W-20 API SN ACEA C2 0W-20 отработка на Hyundai Creta после 0-200-4200км
Hyundai Premium LF Gasoline 5w-20 отработка на Hyundai Creta после 7 000 км
Hyundai Premium LF Gasoline 5w-20 отработка на Hyundai Solaris после 5500 км.
Hyundai Kia Premium LS Diesel 5W-30 отработка на KIA Sorento после 5520 км.
Hyundai 20 05100-00451 Premium LF Gasoline 5W-20 отработка на KIA Rio после 6345 км.
я бы не был так категоричен.
Как минимум для ниссана тоталь льет в оем канистры - и это не секрет
Так я про хендаевскую тару, но хотя если один из поставщиков масла для хендаевской ОЕМ тары, входит в группу Тоталя, то считай это он и есть) а вообще, у ОД, при прохождении ТО, вроде как уже Тоталь льют (хотя дилер чаще всего, льет вообще многие масла, не обращая на рекомендации и договоры) и с завода под Питером тоже идет Тоталь в Солярисы и Рио
почему xteer не имеет кода-номера детали как это есть у Hyundai Turbo SYN Gasoline Engine Oil SAE 5W/30 и HYUNDAI Premium LF Gasoline SAE 5W-20 SM/GF-4
Данное масло, уже идет под другим брендом считай, но тоже от Хендэ...на том же Экзисте, в каталоге по маслам, ищите бренд Xteer (свои коды есть и у них) + в обсуждениях про него есть тема.
Изменено пользователем Ecstasy85
Номера есть. Посмотрите у них на сайте.
Смотрел. Нет никаких номеров на канистре
Как пример...Xteer 1041006 Масло моторное синтетическое "Heavy Ultra Duty 10W-40", 4л...1300 руб.
Это не артикул детали автомобиля. Если внести этот номер в каталог запчастей то ничего не отобразится.
Hyundai Turbo SYN Gasoline Engine Oil SAE 5W/30 и HYUNDAI Premium LF Gasoline SAE 5W-20 SM/GF-4 а у этих масел есть каталожные номера
Я в Автодоке пишу 1041006 и мне выдает данное масло, что еще то нужно?))) :db:
Обычный артикул, код, наименование считай)
Поисковик автодока, экзиста и т.д...по сути и работает по данным номерным артикулам .
Считается что TOTAL QUARTZ ENERGY 9000 HKS G310 5W-30 это тоже самое что Hyundai turbo syn 5w30. Тогда какой завод все таки разливает масла тотал?
В производителях масла Hyundai/Kia числятся:
SK Lubricants — это ZIK
GS Galtex — это KIXX
S-Oil — это Dragon SSU
미창 — это Michang тот же Eneos
S-oil и Total - совместное предприятие, на канистрах HKS написано Made in Korea. Я покупал Турбосин разлива S-oil.
Заморозил HYUNDAI-KIA 0510000451 Premium LF Gasoline SAE 5W-20 при разных температурах, оно должно быть такого цвета и мутнеть? Производитель Michang.
При -32
При -20
@Etti, продублировал в теме заморозок - http://www.oil-club.ru/forum/topic/21632-lyubitelskie-testy-na-zamerzanie-zima-2015-2016/
А для полусинтетики 5-30 нет TDS? Кто льет интересно? ZIC A?
я конечно хз,что такое трехядерный молибден
Порядковый номер химического элемента в периодической системе химических элементов – 42. у молибдена на электронных уровнях находится 42 электрона, а в ядре должно находится также 42 протона.
http://www.chemiemania.ru/chemies-2230-1.html
Потому что Hyundai Motors и Hyundai Oilbank - это разные компании, соот-но масла Xteer никакого отношения к автомобилям Hyundai не имеют. Поэтому и партнамбера в стиле запчастей Hyundai/Kia у них не будет никогда.
@Etti, много парафинов скристализовалось, это может быть как подделка так и норма. Так не скажешь. Анализ нужен.
