Масла Eurol ОБЩАЯ
Масла Eurol
Генеральный сайт: http://www.eurol.com/en/oil_products/product_advisor/2
Адрес завода: Energiestraat 12 7442 DA Nijverdal
Панорамные фотографии завода:
Вид на завод со спутника
Видео:
E1000764L - EUROL FLUENCE DXS 5W-30 4L
E1000761L - EUROL FLUENCE DXS 5W-30 1L
E1000691L - Eurol Fluence FE 5W-30 1L
E1000695L - Eurol Fluence FE 5W-30 5L
E10006960L - Eurol Fluence FE 5W-30 60L
E100069210L - Eurol Fluence FE 5W-30 210L
E1000621L - EUROL SYNTENCE 5W-30 1L
E1000624L - EUROL SYNTENCE 5W-30 4L
E1000625L - EUROL SYNTENCE 5W-30 5L
E1000651L - EUROL FORTENCE 5W-30 1L
E1000655L - EUROL FORTENCE 5W-30 5L
V172085638 - EUROL SUPER LITE ARCTIC 5W-30 1L
E1000094L - EUROL SUPER LITE ARCTIC 5W-30  4L
E1000091L - Eurol Super Lite Arctic 5W-30 1L
E1000671L - EUROL SYNERGY 0W-30 1L
E1000675L - EUROL SYNERGY 0W-30 5L
E1000641L - EUROL SYNERGY 0W-40 1L
E1000645L - EUROL SYNERGY 0W-40 5L
E1000911L - EUROL SUPER LITE 5W-30 1L
E1000914L - EUROL SUPER LITE 5W-30 4L
E10009120L - EUROL SUPER LITE 5W-30 20L
E100091210L - EUROL SUPER LITE 5W-30 210L
E1000921L - EUROL SUPER LITE 5W-40 1L
E1000924L - EUROL SUPER LITE 5W-40 4L
E10009220L - EUROL SUPER LITE 5W-40 20L
E100092210L - EUROL SUPER LITE 5W-40 210L
E1000931L - EUROL SUPER LITE 5W-50 1L
E1000934L - EUROL SUPER LITE 5W-50 4L
E100093210L - EUROL SUPER LITE 5W-50 210L
E1000851L - EUROL TURBO DI 5W-40 1L
E1000854L - EUROL TURBO DI 5W-40 4L
E10008520L - EUROL TURBO DI 5W-40 20L
E1000611L - EUROL MAXENCE RC 10W-60 1L
E1000614L - EUROL MAXENCE RC 10W-60 4L
E1001281L - EUROL EVOLENCE 0W-20 1L
E1001285L - EUROL EVOLENCE 0W-20 5L
E1001311L - EUROL EVOLENCE 5W-30 1L
E1001315L - EUROL EVOLENCE 5W-30 5L
E1000511L - EUROL SYNTO-V 5W-30 1L
E1000514L - EUROL SYNTO-V 5W-30 4L
E1000941L - EUROL TURBOSYN 10W-40 1L
E1000944L - EUROL TURBOSYN 10W-40 4L
E10009420L - EUROL TURBOSYN 10W-40 20L
E100094210L - EUROL TURBOSYN 10W-40 210L
E1000391L - EUROL TURBOSYN 15W-50 1L
E1000394L - EUROL TURBOSYN 15W-50 4L
E100039210L - EUROL TURBOSYN 15W-50 210L
E1100761L - EUROL FULTRASYN 75W-90 GL3/4/5 (ESTER+PAO, -51°C)
E1100751L - EUROL TRANSYN 75W-90 GL 4/5 1L
E1100755L - EUROL TRANSYN 75W-90 GL 4/5 5L
E11007520L - EUROL TRANSYN 75W-90 GL 4/5 20L
E110075210L - EUROL TRANSYN 75W-90 GL 4/5 210L
E1106301L - EUROL HPG SAE 80W-90 GL5 1L
E1106305L - EUROL HPG SAE 80W-90 GL5 5L
E11063020L - EUROL HPG SAE 80W-90 GL5 5L 20L
E110630210L - EUROL HPG SAE 80W-90 GL5 210L
E1106051L - EUROL MPG EP SAE 80W-90 GL4 1L
E1106054L - EUROL MPG EP SAE 80W-90 GL4 4L
E11060520L - EUROL MPG EP SAE 80W-90 GL4 20L
E110605210L - EUROL MPG EP SAE 80W-90 GL4 210L
E1136611L - EUROL ATF 1100 1L
E1136571L - EUROL ATF 6100 1L
E1136531L - EUROL ATF 6700 1L
E1136535L - EUROL ATF 6700 5L
E11365320L - EUROL ATF 6700 20L
E1136581L - EUROL ATF 7100 1L
E1136591L - EUROL ATF III F 1L
E1136595L - EUROL ATF III F 5L
E11365920L - EUROL ATF III F 20L
E1136501L - EUROL ATF II D 1L
E1136504L - EUROL ATF II D 4L
E11365020L - EUROL ATF II D 20L
E113650210L - EUROL ATF II D 210L
E1136631L - EUROL CVT 1304 1L
E801400500ML - EUROL BRAKEFLUID DOT 4 0.5L
E8014001L - EUROL BRAKEFLUID DOT 4 1L
E901304400G - EUROL BLUE STAR GREASE EP 2 0.4kg
E90130415KG - EUROL BLUE STAR GREASE EP 2 15kg
E901030400G - EUROL UNIVERSAL LITHIUM GREASE EP 2 0.4kg
E90103020KG - EUROL UNIVERSAL LITHIUM GREASE EP 2 20kg
E901070400G - EUROL MOLYBDENUM DISULPHIDE MOS2 GREASE 0.4kg
E90107020KG - EUROL MOLYBDENUM DISULPHIDE MOS2 GREASE 20kg
E90101020KG - EUROL LITHIUM GREASE EP 00 - 20kg
E5041451L - EUROL COOLANT GLX -36°C 1L
E5041455L - EUROL COOLANT GLX -36°C 5L
E50414520L - EUROL COOLANT GLX -36°C 20L
E504145210L - EUROL COOLANT GLX -36°C 210L
E5041051L - EUROL COOLANT BS -36°C 1L
E5041055L - EUROL COOLANT BS -36°C 5L
E50410520L - EUROL COOLANT BS -36°C 20L
E504105210L - EUROL COOLANT BS -36°C 210L
E5031521L - EUROL ANTIFREEZE GLX concentrate 1L
E5031525L - EUROL ANTIFREEZE GLX concentrate 5L
E50315220L - EUROL ANTIFREEZE GLX concentrate 20L
E50315260L - EUROL ANTIFREEZE GLX concentrate 60L
E503152210L - EUROL ANTIFREEZE GLX concentrate 210L
E5041051L - EUROL ANTIFREEZE BS 6580 concentrate 1L
E5041055L - EUROL ANTIFREEZE BS 6580 concentrate 5L
E50410520L - EUROL ANTIFREEZE BS 6580 concentrate 20L
E50315060L - EUROL ANTIFREEZE BS 6580 concentrate 60L
E504105210L - EUROL ANTIFREEZE BS 6580 concentrate 210L
E116001250ML - EUROL AIRCO OIL PAG 46 250ml
E116002250ML - EUROL AIRCO OIL PAG 100 250ml
E701445500ML - EUROL SUPER BRAKE CLEANER SPRAY (cпрей обезжириватель) 500ml
E701310400ML - EUROL CHAIN SPRAY PTFE (спрей-смазка для цепей) 400ml
E701300400ML - EUROL PENETRATING OIL SPRAY (разблокирующий спрей-смазка) 400ml
E701320400ML - EUROL SILICONE SPRAY (силиконовый спрей-смазка) 400ml
E401701250ML - EUROL RADIATOR SEALER (присадка для остановки течи радиатора) 250ml
E701420400ML - EUROL WHITE GREASE SPRAY with PTFE (спрей смазка на литиевой основе) 400ml
E601440600ML - EUROL HANDCLEANER WHITESTAR (мыло для рук) 600ml
E60144045L - EUROL HANDCLEANER WHITESTAR (мыло для рук) 4.5L
E1000701L - EUROL SPORTBIKE 10W-40 FULLSY (синтетическое) 1L
E1000971L - EUROL MOTORCYCLE 10W-40 (полусинтетическое) 1L
E1000974L - EUROL MOTORCYCLE 10W-40 (полусинтетическое) 4L
E1000111L - EUROL SPORT TOURING 10W-40 (минеральное) 1L
E1284331L - EUROL SUPER 2T FORMAX (синтетическое) 1L
E1284281L - EUROL TTX PROSCOOT (полусинтетическое) 1L
E1284001L - EUROL SX SPORT TWO STROKE (минеральное) 1L
E125400600ML - EUROL LAWN MOWER OIL SAE 30 (газонокосилки) 600ml
E1254001L - - EUROL LAWN MOWER OIL SAE 30 (газонокосилки) 1L
E1254501L - EUROL CHAINSAW OIL AK (масло для цепей) 1L
E1001441L - EUROL NAUTIC LINE 10W40 FCW 1L
E1284301L - EUROL NAUTIC LINE SUPER 2T OUTBOARD TCW-III 1L
E10871020L - EUROL HYKROL HLP ISO-VG 32 20L
E108710210L - EUROL HYKROL HLP ISO-VG 32 210L
E10880020L - EUROL HYKROL VHLP ISO-VG 32 20L
E108800210L - EUROL HYKROL VHLP ISO-VG 32 210L
E10881020L - EUROL HYKROL VHLP ISO-VG 46 20L
E108810210L - EUROL HYKROL VHLP ISO-VG 46 210L
E10011320L - EUROL FUSION 10W-40 20L
E100113210L - EUROL FUSION 10W-40 210L
EUROL артикульные коды.xlsx
Eurol Evolence 0W-20 Dexos1 (Gen2) (анализ июль 2019)
Eurol Syndura 5W-40 API SN
Eurol Syntence 5W-30
Eurol Maxence RC 10W-60
Eurol Super Lite 5W-40
Eurol Turbo DI 5W-40
Eurol Fluence DXS 5W-30
Eurol Turbosyn 10W-40
Eurol Synergy 0W-40
Eurol Synergy 0W-30
Eurol Super Lite 5W-30
Eurol Evolence 5W-30 API SN
Eurol Evolence 0W-20 API SN
Eurol Fortence 5W-30
Eurol MTF 75W-80 API GL-5
Eurol Transfluid STF
Eurol ATF 6700
Eurol MTF FE 75W-85
Eurol MTF FE 75W-85 API GL-5 NEW 2023
Eurol Fultrasyn 75W-90
Eurol Evolence 5W-30 API SP отработка на Kia Rio 3 после 4914 км
Eurol Fortence 5W-30 отработка на Land Rover Freelander 2 после 6500км
Eurol Super Lite Arctic 5W-30 отработка на Nissan Qashqai после 7500км
Eurol Fortence 5W-30 отработка на Kia Ceed после 7200км
Eurol Super Lite 5W-40 отработка на Infifnity QX56 после 9800км.
Eurol Super Lite 5w40 отработка на Mitsubishi Pajero Sport после 6000 км.
Eurol Super Lite 5W-30 отработка на Mitsubishi Pajero после 7200 км.
Eurol Super Lite 5W30 отработка на Skoda Yeti после 5981 км.
Eurol Fluence DXS 5W-30 на Skoda Yeti после 5297 км.
Eurol Synergy 0W-30 отработка на Mitsubishi Lancer X после 6500 км.
Eurol Syntence 5W-30 отработка на Skoda Yeti после 4855км
Eurol Super Lite 5W-40 отработка на VW Bora после 8419 км.
Eurol Super Lite 5W-50 отработка на Renault Duster после 5084 км.
Eurol Super Lite 5W-30 отработка на Renault Logan после 8000 км.
Eurol Super Lite 5W-30 отработка на VW Touareg после 12900 км.
Eurol Super Lite Arctic 5W-30 + NGN Nord 5W-30 отработка на Toyota Landcruiser Prado после 7500 км.
Eurol Fortence 5W-30 отработка на Mitsubishi Pajero 4 после 7500 км.
Eurol Synergy 0W-40 отработка на Lada Kalina после 8000 км.
Eurol Super Lite Arctic 5W-30 отработка на Nissan Almera New после 13680 км.
Eurol Turbo DI 5-40 отработка на Nissan Pathfinder после 9653км - 241м.ч.
Eurol Evolence 0W-20 + присадка Eurol Engine Oil Treat на Hyundai Creta после 6350 км
Отчеты форумчан по маслам Eurol:
Eurol Syntence 5W30
Eurol Synergy 0w-40
Eurol Super Lite Arctic 5w-30
Eurol Super Lite Arctic 5W-30/NGN Nord 5W-30 на Toyota Prado 1GR-FE 4.0
Eurol Synergy 0w-30
Вот это и печалит :( , что точность смешивания у производителя гульнула, уж от Еврол, меньше всего ждали такого. Но думаю, представитель уже скинул производителю анализы линейки Super Lite, и те учтут  это :drinks:
Никто никуда не отпишется, голландцы будут отвечать в стиле "Это не является браковочным показателем - и в стандарт ACEA A3/B4 и MB 229.3 масло по зольности проходит с запасом" покажут такую же табличку что я выше и по факту они будут правы :D
Вот пример когда присадок не доложили
http://www.oil-club.ru/forum/topic/14870-ravenol-vst-5w-40-svezhee/
видите какое щелочное? Должно быть не менее 10.
это так же сходится и по остальным параметрам.
цинка фосфора посмотрите сколько - маловато слегка
кальция так же чуть меньше, чем обычно у таких масел.
Ну это так для опыта,как выглядит "переложили пакет присадок" и как выглядит "не доложили пакет присадок". Что бы вы умели различать :)
Eurol Syntence оно же NGN EMERALD ?
А можно какое то объяснение почему на газу надо перевести машину на масла 504/507 ?
машина по паспорту просит 502/505
Изменено пользователем oil_find
Вчера залил в Аута 3 литра 2006 года, Super Lite 5w-30 (25.08.2015), крутится двиг легко, как будто это ни фига не АСЕА А3, мягко, работает тихо :up:
Изменено пользователем Mikhalev28
Вся переписка гладкая как стекло.Все прекрасно и хорошо.Но кто-нибудь скажет почему масло стоит так дешево??????
Потому что еще нет активного маркетинга, ждите будут вливать деньги будет вам цена
Может мне кто ответит,
На сколько в РФ Eurol дешевле тоталя.
Например 9000 quartz vs super lite
Long life vs synergy
Просто не понимаю, почему говорят что народ прям дешевый, в РБ он дороже тоталя на пару у.е.
Добрался до компьютера, столько же и в Москве стоит, поэтому не понимаю что нашли Вы в нем дешевого.
Другое дело что оно и хорошее. Хорошая вещь дешевой быть не может
@Zeke, отпишись потом, когда зальёшь - впечатления и прочее, хоть и в этой теме - всё хочу знакомому на Х3 это масло "сосватать", писал об этом
Оффтоп
Итак. Залил на днях. Проехал 300 км. Что могу сказать. Пока устраивает. Сначала думал что эффект плацебо или самовнушение, но уже не первый раз замечаю что при пуске двигателя на холодную после стоянки в несколько дней пропал один надоедливый звучок (некое грохотание в первые 30 секунд запуска). Заливалось после промывки LM и вместо паспортных 6,7 у меня залилось под 7 литров. Можно не много придраться к канистре NGN,масло густоватое и льется достаточно долго. Плюс масло собирается в ручке канистры и канистру приходится ворочать в разные стороны чтобы все масло стекло. Да и еще,открыть ее тоже не легко получилось. Первую канистру когда начал тянуть за ушки чтобы вытащить носик,чуть пальцы себе не порезал,воткнул отвертку и вытащил. Со второй другой момент. Вытащился носик легко,а вот потянув за кольцо внутри носика оторвались ушки,пришлось ножичком вырезать Буду пробовать делать капельные тесты и смотреть за расходом масла
допуски все теже
Не все
Нет только 505.01 изза которого цена в турбо ди выше
нет LL-04
А суть проста - таже очнова с меньшим пакетом присадок для уменьшения зольности изза катов и сажевиков. Отсюда и износ двига выше и замена чаще
зольности ?
мне всегда казалось серы, масло типо без серы практически...
п.с. а да, все верно зольности, серы и зольности это еще более экологический класс масел... а потом все удивляются почему моторы ТЮТЮ... раньше 300 тыс было норма, а сейчас 200 уже много... а одна из причин что ездят на масле по 15.000, так ладно масло было бы тоже как раньше, так современное урезанное масло в лучшем случаи 10.000 выдержит...
