Масла Taif
Официальный сайт: http://taif-lubricants.ru/index.html
TAIF Allegro 0w-20 API SP, ILSAC GF-6 1л - 211001
TAIF Allegro 0w-20 4л - 211002
TAIF Allegro 0w-20 20л - 211003
TAIF Allegro 0w-20 205л - 21104
TAIF Allegro 5w-20 API SP, ILSAC GF-6 1л - 211005
TAIF Allegro 5w-20 4л - 211006
TAIF Allegro 5w-20 20л - 211007
TAIF Allegro 5w-20 205л - 211008
TAIF Allegro 5w-30 API SP, ILSAC GF-6 1л - 211009
TAIF Allegro 5w-30 4л - 211010
TAIF Allegro 5w-30 20л - 211011
TAIF Allegro 5w-30 205л - 211012
TAIF Tanto 0w-20 API SN, ILSAC GF-5 1л - 211033
TAIF Tanto 0w-20 4л - 211034
TAIF Tanto 0w-20 20л - 211035
TAIF Tanto 0w-20 205л - 211036
TAIF Tanto 10w-30 API SN, ILSAC GF-5 1л - 211045
TAIF Tanto 10w-30 4л - 211046
TAIF Tanto 10w-30 20 - 211047
TAIF Tanto 10w-30 205 - 211048
TAIF Tanto 5w-20 API SN, ILSAC GF-5 1л - 211037
TAIF Tanto 5w-20 4л - 211038
TAIF Tanto 5w-20 20л - 211039
TAIF Tanto 5w-20 205л - 211040
TAIF Tanto 5w-30 1л - 211041
TAIF Tanto 5w-30 4л - 211042
TAIF Tanto 5w-30 20л - 211043
TAIF Tanto 5w-30 205л - 211044
TAIF Vite 5w-30 ACEA C3, API SN, VW 504 00/507 00, MB 229.51 1л - 211013
TAIF Vite 5w-30 4л - 211014
TAIF Vite 5w-30 20л - 211015
TAIF Vite 5w-30 205л - 211016
TAIF Etude 5w-40 API SL/CF 1л - 211069
TAIF Etude 5w-40 4л - 211070
TAIF Etude 5w-40 20л - 21071
TAIF Etude 5w-40 205л - 211072
TAIF Etude 10w-40 SL/CF 1л - 211073
TAIF Etude 10w-40 4л - 211074
TAIF Etude 10w-40 20л - 211075
TAIF Etude 10w-40 205л - 211076
TAIF Vivace 5w-40 API SN/CF, MB 229.5 1л - 211025
TAIF Vivace 5w-40 4л - 211026
TAIF Vivace 5w-40 20л - 211027
TAIF Vivace 5w-40 205л - 211028
TAIF Vivace 0w-40 API SN/CF 1л - 211021
TAIF Vivace 0w-40 4л - 211022
TAIF Vivace 0w-40 20л - 211023
TAIF Vivace 0w-40 205л - 211024
Taif Vite C3 5W-30 2025
Taif Forte 5W-30 A5/B5 2024
Taif Vivace 5W-40 API SN 2024
Taif Allegro 5W-30 API SP 2023
Taif Vivace 0W-40 API SN 2023
Taif Tanto 0W-20 API SN
Taif Tirata 10W-40
Taif Vite C3 5W-30
Taif Allegro 0W-20 API SP
Taif Tirata 10W-40 свежее Shear Stability Test and HTHS
Taif Shift CVTF
Taif Shift PAO 75W-90 API GL-4/5
Лабораторные анализы - Отработки - UOA
Taif Allegro 5W-30 отработка на Mazda CX-5 после 7500км
В теме присутствует официальный представитель TAIF Lubricants. Если у Вас есть какие то вопросы по маслам Taif, вы можете их задать @taif_lubricants. Прошу любить и жаловать :)
1 час назад, Роман 73 сказал:
Хрен с ним, уже залил, уже катаю...это супермасло))))
Судя по низкому сдвигу должно быть экономичным и заметно резвее чем другие, но это меня и смущает - тоже купил танту 5w-30 думаю на следующую зиму его залить, так как зимой не те температуры и нагрузки как летом.
Какого года у вас масло?
3 часа назад, akadama сказал:
У меня масло произведено в октябре 2022года.
Но я его специально залил сейчас, а не в зиму, т.к зимой будет сильное разжижение топливом, при холодных прогревах и вязкость масла ещё больше уменьшится.
Пока проехал, конечно, очень мало и только по городу (на трассу ещё не выходил), но пока всё нравится - мотор запускается и потом работает очень тихо на этом масле, вообще без посторонних звуков, можно сказать - шепчет и динамика у авто тоже хорошая, видно, что потери на трение минимальны :lol: Все-таки это маловязкое и энергосберегающие масло, как позиционирует его сам производитель.
Насчёт расхода бенза на нём - посмотрим потом, как покатаю хотя бы пару-тройку тысяч на нём
47 минут назад, Роман 73 сказал:
Вы паспорт выкладывали недавно, я туда смотрю - вязкость при 100°=8,43 то что надо, но вот HTHS=2,7 это мало, хотелось бы 2,8-2,9 купил бы ведро и ездил бы круглый год и зимой и летом MVR и CCS как у многих нулевок хотя это пятерка. Вобщем неоднозначное масло буду ждать от вас тут в теме наблюдений по мере пробега может оно и ничего.
 Обратите внимание, что на банках старой расцветки (коричнево-оранжевой) имеется бублик API Service, а на банках нового дизайна (черного) бублик отсутствует.  Вот и ответ про китай-пакет.
Вот allegro 2.93 HTHS 5W-20. Я на таком круглый год езжу.
23.10.2022 №1294 (п.22210103) TAIF ALLEGRO 5W-20 (4л).pdf
17.09.2026 в 12:57, Taimer81 сказал:
Написал на почту в Taif, они подтвердили что информация о содержании в масле Taif Allegro 0W-20 ПАО 70-75% достоверна.
Ну вот последние наши два анализа Taif.
https://www.oil-club.ru/forum/topic/92882-taif-forte-5w-30-a5b5-svezhee-2024/
NOACK 11,5%, вспышка 227С у 5W-30, пик 722 ИК спектра 1.15 на подменной кувете, реально 1,06 - какое нафиг ПАО 70%? :)
https://www.oil-club.ru/forum/topic/93468-taif-vite-c3-5w-30-svezhee-2025/
Вот здесь NOACK получше 7,6%, вспышка 235С, но пик 1.17 на подменной кувете - реально то есть 1.08.
Я конечно не знаю, может и ошибаюсь. (осторожничаю с громкими заявами всегда), но мое видение такое. Для экономической целесообразности эти масла в основном на гидрокрекинге VHVI + ПАО 20% + эфиров ДОТФ 5-10% (с эфирами, я прям сильно блуждаю в процентовке, потому что больше ДОТФ никто не использует, не с чем сравнить.)
Езжу на Танто 5-20, 22го года) без нареканий,мотор шепчет! На замену взял Аллегро 5-20, 22го года 4+1
Отличия думаю не замечу!
Запросил паспорта для taif allegro 5w-20, то что сейчас получил при заказе с завода на Озоне.
28.11.2023 № 1845 (п.23715403) ALLEGRO 5W-20 (1 л.).pdf 10.12.2023 № 1920 (п.23716003) ALLEGRO 5W-20 (4 л.).pdf
Изменено пользователем Latest_Jedi
1 час назад, Latest_Jedi сказал:
28.11.2023 № 1845 (п.23715403) ALLEGRO 5W-20 (1 л.).pdf 408 \u041a\u0431 · 6 скачиваний 10.12.2023 № 1920 (п.23716003) ALLEGRO 5W-20 (4 л.).pdf 404 \u041a\u0431 · 8 скачиваний
Однако показатели ттх слегка гуляют в разных партиях хотя между замесами всего то 3 недели согласно датам выпуска.
Посмотрел два паспорта - я не могу согласится с тем что параметры гуляют. Там все одинаково, если смотреть не с точки зрения равности цифр, а с учетом погрешности и нормальной разницы замеса партии. Это одинаковые масла.
13 минут назад, torcon сказал:
 странно повела себя сульфатная зола - 0.71 и 1.1 это огромная разница. в полтора раза переложили пакета? тогда как минимум щелочное должно уползти, а оно на месте
OldBenz а вот этого я не заметил - думаю это ошибка в паспорте, на одном пакете нельзя сделать такой разбег в золе, да и масло не того стандарта что бы быть 1.1% зольностью.
Заполняющий пинал балду, или по-татарски "тырай тибу" :)
torcon Согласен, тоже о головотяпстве подумал. Просто вот она цена этим паспортам, а мы тут на их основе какие-то выводы делаем
50 минут назад, OldBenz сказал:
И не только зола, там даже плотность разная как такое может быть?
Щелочное 6 и зола 1,1%, где-то тут обманывают)
