TotalEnergies - антифризы
Total GLACELF PLUS EVO Si-P-OAT
1 lt conc. 230153
GLACELF-PLUS-EVO_TDS.pdf
Тotal GLACELF СARTECH P-OAT
1 lt conc. 229956
5 lt conc. 229955
totalenergies-glacelf-cartech-en-tds.pdf
Total COOLELF NEOTECH OAT
1 lt conc. 229950
1 lt ready-to-use. 230173
5 lt ready-to-use 230172
COOLELF-NEOTECH-1.pdf
Для сравнения TDS на Arteco Freecor LPC (P-OAT), Freecor BMC (Si-P-OAT), XLC (OAT),
Freecor_LPC_English.pdf
Freecor_BMC_English.pdf
Freecor_XLC_English.pdf
Изменено пользователем yorker
1 час назад, SL1 сказал:
Посмотрите, tds в теме есть.
По резине у нормальных антифризов проблем нет.
Забыл.смотрел по коррозии норм.вот с резинками как.хотя думаю должно быть нормально.
В июле 2025 Bardahl анонсировала:
XCL EVO 9 -40°C: new benchmark for coolants
Quote
Bardahl, the acknowledged expert in engine maintenance and protection solutions, is extending its range of high-performance coolants with XCL EVO 9 -40°C. Designed to meet the most stringent requirements of modern engines, this innovative fluid fully complies with the specifications of EURO 6 engines, while remaining compatible with EURO 5 and EURO 4 standards.
XCL EVO 9 -40°C features an extended thermal operating range from -56°C to +120°C, guaranteeing optimum protection whatever the climatic conditions or constraints of use. Its advanced formulation provides enhanced corrosion protection for light metals and alloys, while offering exceptional resistance to overheating, particularly in the most demanding professional environments.
It has been specifically designed to meet the specifications of leading manufacturers such as Volvo (Bus, Penta, Trucks, Construction - VCS-2 standard), Renault, Claas, Caterpillar and Daimler (DTFR29C110 standard).
TDS пока нет, но судя по описанию Freecor FTC/TotalEnergies Neotech/Miss Diesel  :D  активно продолжает продвигаться на рынок.
Bardahl XCL EVO 7 похоже аналогично ребренд Freecor BMC/TotalEnergies Evo Plus.
XCL EVO 7 -37C_tds.pdf
On 8/20/2018 at 1:13 PM, SerV said:
Чем он тогда отличается от A-110 и что такое "LP-OAT"?
оба антифриза идут по классу P-OAT (Phosphated Organic Additive Technology).
но есть мысль что LPC (Coolstream JPN в нашей интерпретации, пока что как рабочее название) в подклассе является LP-OAT (Low-Phosphated Organic Additive Technology) разница между 2-мя антифризами сугубо в хим. составе (больше даже в органической части - наборе карбоксилатов)
yorker Опять чехарда. Надо отличать нитриты NO2 от нитратов NO3. Первые в колбасу кладут, а вторыми овощи удобряют:)
SL1 Да, Serv неправильно процитировал требование Toyota, там non-nitrite.
18.11.2025 в 00:32, Klimson71 сказал:
Заказал себе 7 литров концентрата P-OAT, дата производства 11.24, срок годности 3 года
А у вас не осталось тары? Интересно подробнее про срок годности. На озоне продавец пишет что срок 5 лет..
ProstoLeo
Quote
Freecor® LPC can be stored for minimum 3 years in unopened containers without any effect on the product quality or performance. It is strongly recommended to use new and not recycled containers.
Пришёл антифриз GLACELF CARTECH P-OAT, заказывал на WB у белорусов. Дата 6.03.2024. Вес литрушек с концентратом 1208-1218 г. при плотности 1120.
5 минут назад, Вадим_69 сказал:
при плотности 1120
Чем меряли?
2 часа назад, Вадим_69 сказал:
 Дата 6.03.2024.
А какой срок годности на канистре указан?
28 минут назад, ProstoLeo сказал:
Не указан...
SL1 там тоже смотрел - циферки на дату никак не похожи...
Типа как здесь:
И ещё что интересно, на контрэтикетке русский язык отсутствует. В отличие от этого поста.
