TotalEnergies - антифризы
Total GLACELF PLUS EVO Si-P-OAT
1 lt conc. 230153
GLACELF-PLUS-EVO_TDS.pdf
Тotal GLACELF СARTECH P-OAT
1 lt conc. 229956
5 lt conc. 229955
totalenergies-glacelf-cartech-en-tds.pdf
Total COOLELF NEOTECH OAT
1 lt conc. 229950
1 lt ready-to-use. 230173
5 lt ready-to-use 230172
COOLELF-NEOTECH-1.pdf
Для сравнения TDS на Arteco Freecor LPC (P-OAT), Freecor BMC (Si-P-OAT), XLC (OAT),
Freecor_LPC_English.pdf
Freecor_BMC_English.pdf
Freecor_XLC_English.pdf
Изменено пользователем yorker
TDS на Freecor LPC 2016 года:
freecor_lpc_english_v0 2016.pdf
+TDS Coolelf Cartech -37°C
totalenergies-coolelf-cartech-tds.pdf
Интересные цитаты из ASTM D1384 Standard Test Method for Corrosion Test for Engine Coolants in Glassware (ASTM D3360), во многом обьясняющие странные результаты испытаний по методике ГОСТ 28084-89 (в т.ч. крайне упрощенная версия от лабораторий) и их спорную интерпретацию:
Quote
4.1 This test method will generally distinguish between coolants that are definitely deleterious from the corrosion standpoint and those that are suitable for further evaluation. However, the results of this test method cannot stand alone as evidence of satisfactory corrosion inhibition. The actual service value of an engine coolant formulation can be determined only by more comprehensive bench, dynamometer, and field tests.
10.1.10 Because cleaning methods and materials may vary among laboratories, occasionally determine cleaning losses obtained by a particular operator on an untested set of triplicate metal specimens. Deduct the average cleaning losses from gross weight differences to determine actual corrosion losses.
11.2 Report the average corrected metal weight change for triplicate tests on each engine coolant solution. A single weight change that appears completely out of line should be dealt with as described in Practice E 178.
12.1 As indicated in 1.1, this test method is intended only as a rough screening tool. Corrosion tests of this type are inherently lacking in precision and bias, and specific weight change values for metal specimens cannot be interpreted closely. For information on significance of tests and interpretation of results, reference should be made to Appendix X1.A statistical analysis of the data in Appendix X1 is in progress.
X1.2 Significance
X1.2.1 Users of the corrosion test in glassware should understand thoroughly its purpose and limitations. The opening paragraphs of the test method state clearly that this is a screening procedure for evaluating the effects of antifreeze solutions on metal specimens under controlled laboratory conditions. The test method is generally capable of distinguishing between coolants that are definitely deficient from the corrosion standpoint and those that are worthy of further evaluation. Results from this test are not sufficient evidence of satisfactory corrosion inhibition because service conditions cannot be simulated adequately.
X1.2.2 Because of the simplicity of the test, it is only expected to evaluate corrosion inhibition and not other important properties of an engine coolant such as foaming, rust loosening, heat transfer, dye stability, and noncorrosive service life. In more complex test methods using simulated service units or engine dynamometers, it is possible to combine the determination of several basic properties into one procedure. However, only in vehicle tests can the coolant product be subjected to the actual conditions encountered in service.
X1.2.3 Members of this committee have always agreed that a three-phase program is necessary to determine the suitability of a coolant for actual service. This would include screening in glassware tests, testing in engine dynamometers or laboratory equipment capable of service simulation, and evaluation in cars on the highway. Thus, the corrosion test in glassware is considered to be only the first step in the evaluation of a coolant.
X1.2.4 The corrosion test in glassware is not intended to evaluate inhibitor life, but only the corrosion inhibition qualiies of new, unused products. Tests on used solutions that have been drained from cooling systems have little significance because of service contamination effects and the fact that important inhibitor constituents may remain behind on the metal surfaces of the cooling system
X1.3 Interpretation of Results
X1.3.1 Duplicate runs of laboratory corrosion tests may give widely different results because of the difficulty in controlling test variables as well as variations in specimen composition, grain structure, and surface finish. It is for this reason that tests should be run in triplicate, and the results from each metal should be averaged to obtain a significant value. Two tables are presented to indicate the repeatability and reproducibility of results obtained by this procedure. These results are taken from the data obtained by the study group that ran the cooperative tests. Two coolants with different inhibitive qualities were used.
astm-standard-d1384.pdf
28084-89.pdf
Перевод от GT:
Quote
Стандартный метод испытаний для
Испытания на коррозию охлаждающих жидкостей для двигателей в стеклянной посуде
4.1 Данный метод испытаний, как правило, позволяет различать охлаждающие жидкости, которые однозначно вредны с точки зрения коррозии, и те, которые подходят для дальнейшей оценки. Однако результаты данного метода испытаний не могут служить единственным доказательством удовлетворительного ингибирования коррозии. Фактическая эксплуатационная ценность состава охлаждающей жидкости для двигателя может быть определена только с помощью более всесторонних стендовых, динамометрических и полевых испытаний.
10.1.10 Поскольку методы и материалы очистки могут различаться в разных лабораториях, иногда следует определять потери при очистке, полученные конкретным оператором на неиспытанном наборе из трех образцов металла. Вычтите средние потери при очистке из разницы в общем весе, чтобы определить фактические потери от коррозии.
11.2 Сообщите среднее скорректированное изменение веса металла для трехкратных испытаний каждого раствора охлаждающей жидкости для двигателя. Единичное изменение веса, которое кажется совершенно не соответствующим норме, следует рассматривать в соответствии с Практической методикой E 178.
12.1 Как указано в 1.1, данный метод испытаний предназначен только в качестве приблизительного инструмента скрининга. Коррозионные испытания этого типа по своей природе неточны и содержат погрешности, а значения изменения удельного веса металлических образцов не могут быть точно интерпретированы. Для получения информации о значимости испытаний и интерпретации результатов следует обратиться к Приложению X1. Статистический анализ данных в Приложении X1 находится в процессе.
X1.2 Значимость
X1.2.1 Пользователи коррозионного испытания стеклянной посуды должны досконально понимать его цель и ограничения. В первых абзацах метода испытания четко указано, что это процедура скрининга для оценки воздействия растворов антифриза на металлические образцы в контролируемых лабораторных условиях. Метод испытания, как правило, позволяет различать охлаждающие жидкости, которые явно неэффективны с точки зрения коррозионной стойкости, и те, которые заслуживают дальнейшего изучения. Результаты этого испытания не являются достаточным доказательством удовлетворительного ингибирования коррозии, поскольку условия эксплуатации не могут быть адекватно смоделированы.
X1.2.2 Ввиду простоты теста, предполагается, что он оценивает только ингибирование коррозии, а не другие важные свойства охлаждающей жидкости двигателя, такие как пенообразование, разрыхление ржавчины, теплопередача, стабильность красителей и срок службы в некоррозионных условиях. В более сложных методах испытаний с использованием имитаторов условий эксплуатации или динамометров для двигателей можно объединить определение нескольких основных свойств в одну процедуру. Однако только при испытаниях на транспортных средствах охлаждающая жидкость может быть подвергнута реальным условиям эксплуатации.
X1.2.3 Члены этого комитета всегда сходились во мнении, что для определения пригодности охлаждающей жидкости к реальной эксплуатации необходима трехэтапная программа. Она включает в себя скрининг в стеклянной посуде, испытания на динамометрах для двигателей или лабораторном оборудовании, способном имитировать условия эксплуатации, и оценку в автомобилях на дорогах общего пользования. Таким образом, испытание на коррозию в стеклянной посуде считается лишь первым этапом оценки охлаждающей жидкости.
X1.2.4 Испытание на коррозию стеклянной посуды не предназначено для оценки срока службы ингибитора, а лишь для оценки антикоррозионных свойств новых, неиспользованных изделий. Испытания использованных растворов, слитых из систем охлаждения, имеют мало значения из-за воздействия загрязнения в процессе эксплуатации и того факта, что важные компоненты ингибитора могут оставаться на металлических поверхностях системы охлаждения.
X1.3 Интерпретация результатов
X1.3.1 Повторные лабораторные испытания на коррозию могут давать значительно различающиеся результаты из-за сложности контроля переменных испытаний, а также из-за вариаций в составе образцов, структуре зерна и качестве поверхности. Именно поэтому испытания следует проводить в трех повторениях, а результаты для каждого металла следует усреднять для получения значимого значения. Представлены две таблицы, указывающие на повторяемость и воспроизводимость результатов, полученных с помощью этой процедуры. Эти результаты взяты из данных, полученных исследовательской группой, проводившей совместные испытания. Использовались два охлаждающих вещества с различными ингибирующими свойствами.
TotalEnergies обновила tds на Neotech (Freecor FTC) 12/2025, количество официальных одобрений увеличилось, как и рекомендаций. Glacelf - концентрат, Coolelf - раствор.
TDS_TOTALENERGIES_GLACELF-NEOTECH_25.pdf
TDS_TOTALENERGIES_COOLELF-NEOTECH_25.pdf
В линейке антифризов Bardahl обнаружились три клона (ребренда) TotalEnergies/Arteco NV:
XCL EVO 6 - Freecor QRC - TotalEnergies Si-OAT
XCL Universal - Freecor XLC - TotalEnergies Auto Supra
XCL Evo 8 - Freecor LPC - TotalEnergies Cartech
У Motul пока засветился только Frecor BMC - TotalEnergies Evo Plus
Bardahl XCL EVO 8_en_tds.pdf
Bardahl XCL EVO 6_en_tds.pdf
Bardahl XCL UNIVERSAL_en_tds.pdf
Bardahl XCL G12 G12+ -37_en_tds.pdf
auto_cool_expert_ultra_en_fr_motul.pdf
https://english.bardahl.fr/en-us/products/automotive/coolants
yorker Здравствуйте, с таким набором официальной технической документации, собранной Вами, делать какие-либо самобытные независимые лабораторные анализы не имеет практического смысла, если только с целью развеять скуку, высказывая здесь, на сайте, своё же самобытное мнение.
Искренне благодарю Вас.
15.01.2026 в 22:25, yorker сказал:
TDS_TOTALENERGIES_GLACELF-NEOTECH_25.pdf 762 \u041a\u0431 · 13 скачиваний
TDS_TOTALENERGIES_COOLELF-NEOTECH_25.pdf 766 \u041a\u0431 · 5 скачиваний
Скажите, чем отличаются Freecor XLC от Freecor FTC, оба карбоксилаты и вроде все одинаково или просто FTC последователь XLC ?
Тотал Авто Супра это XLC, Неотеч последователь Авто Супра но уже FTC, cильно эти антифризы отличаются ?
Изменено пользователем 192
192 Карбоксилатный антифриз (ОАТ) это очень упрощенно, так же как и фосфатник (P-OAT), разных рецептур может быть неограниченное количество. P-OAT, Si-OAT, Si-P-OAT фактически тоже карбоксилатники, просто усиленные фосфатами и силикатами (упрощенно).
Chevron Havoline Xtended Life Coolant это хоть и легенда, но старая рецептура, которая тем не менее все еще флагман у Arteco.
Freecor XLC это Havoline XLC, только без 2-EHA.
Auto Supra - Havoline XLC
Auto Supra 2F - Freecor XLC
Соот-но логично что Arteco решила сделать замену (наследника) Шевроновской рецептуры, более современную и доработанную, допуски у FTC прибавляются т.е. Arteco его продвигает у автопроизводителей, правда пока это в основном тяжелые, коммерческие дизеля, которые требуют чистого OAT судя по всему.
Точной разности рецептур нам вряд ли кто раскроет, поэтому немного спекуляций. Плюс не забываем что у Артеко был еще успешный NRC/NRB, возможно что то и оттуда взяли в FTC.
уже 9 официальных одобрений, что то вроде Мисс Дизель выходит :D:
https://www.arteco-coolants.com/en/oem-approval-list?product=497
Fuchs FRICOFIN LD так же похоже очередной ребренд Freecor FTC. FRICOFIN AV - LPC, FRICOFIN LL - XLC
https://www.arteco-coolants.com/en/innovation/knowledge-hub/why-zitrec-ec-doesnt-contain-2ethylhexanoic-acid-and-why-that-matters
Quote
В индустрии охлаждающих жидкостей точность и ясность имеют первостепенное значение. Одним из соединений, недавно привлекших внимание, является 2-этилгексановая кислота (2-EHA). Ее иногда ошибочно называют 2-этилгексилакрилатом, что является совершенно другим веществом. Хотя названия могут звучать похоже, такая неправильная идентификация может привести к путанице в отношении состава продукта, безопасности и соответствия нормативным требованиям. В Arteco мы сделали осознанный выбор: ZITREC® EC не содержит 2-EHA. Вот почему.
Понимание роли 2-ЭГК в охлаждающих жидкостях 2-EHA — это карбоновая кислота, обычно используемая в охлаждающих жидкостях в качестве ингибитора коррозии. Ее основная функция заключается в защите поверхностей железа и алюминия от коррозии путем адсорбции на начальных очагах коррозии, образуя барьер, предотвращающий дальнейшее разрушение под действием коррозионных агентов. Это особенно важно в условиях высоких температур, где деградация металла может поставить под угрозу целостность системы. Ее совместимость с различными материалами двигателей и термическая стабильность сделали ее популярным выбором в прошлом. Фактически, компания Arteco ранее владела патентами на технологии, содержащие 2-этилгексановую кислоту (2-EHA), признавая её эффективность в защите от коррозии.
Однако нормативно-правовая база изменилась. Классификация и влияние на регулирование 2-этилгексановая кислота (2-EHA) претерпела значительную переклассификацию в соответствии с 18-й адаптацией к техническому прогрессу (ATP) Регламента о классификации, маркировке и упаковке (CLP) в Европейском Союзе. Ранее она классифицировалась как репродуктивный токсикант категории 2 (H361d – предположительно вреден для нерожденного ребенка), теперь же она классифицируется как репродуктивный токсикант категории 1B с предупреждением об опасности H360D – «может нанести вред нерожденному ребенку». Это изменение отражает переход от статуса предполагаемого репродуктивного токсиканта к подтвержденному, и оно сопровождается более строгим порогом концентрации: вещества, содержащие ≥ 0,3% 2-EHA или её солей, теперь должны иметь эту классификацию. Новый лимит действует с 1 декабря 2023 года.
Важно отметить, что эта классификация применяется исключительно к Европейскому Союзу (ЕС). В других регионах могут действовать иные нормативные рамки и пороговые значения для маркировки и классификации. Для обеспечения соответствия требованиям и безопасности продукции, составы должны либо полностью исключить 2-EHA, либо снизить его концентрацию ниже нормативного порога.
В Arteco мы выбрали путь полного исключения, гарантируя, что ZITREC® EC остается безопасным и соответствующим нормативным требованиям решением. Наш альтернативный подход Удаление 2-EHA не означает компромисса в отношении производительности. Мы выявили органические ингибиторы коррозии, которые соответствуют или превосходят защитные свойства 2-EHA без связанных с этим рисков для здоровья. Эти альтернативы интегрированы в состав ZITREC® EC, обеспечивая надежную защиту систем охлаждения при сохранении соответствия меняющимся нормативным требованиям. Наши внутренние испытания показывают, что ZITREC® EC сохраняет превосходную стабильность pH, совместимость и коррозионную стойкость в широком диапазоне применений.
yorker  Спасибо за разъяснения, как говорится чем дальше в лес, тем больше дров, более менее стало все понятно ! :drinks:
192 У них на Neotech есть еще один тезис:
Quote
Superior oxidation and pH stability at high temperatures, resulting in limited amount of glycol degradation acids
Которое они подкрепляют результатами по ASTM D7820:
12 минут назад, yorker сказал:
Да, классный антифриз, заказал себе такой, спасибо за разъяснения !!!:)
Одного не могу понять, зачем после Глагеола rx тип D стали переходить на Глагеол rx тип E, ведь он P OAT, перешли бы на Неотеч, думаю это намного лучше и безопаснее !?:pardon:
Я для себя решил после rx тип D перейти на Неотеч !
19.12.2025 в 18:25, Vadim D сказал:
Доброго дня. Подскажите, как Тotal GLACELF СARTECH Р-ОАТ подружится с силиконовыми шлангами?
Есть пару штук в системе(
А как он насчёт резины.уплотнителей и прокладок в СО mitsubishi?коррозии метала и кавитации
Изменено пользователем KPECT
3 часа назад, KPECT сказал:
коррозии метала
Посмотрите, tds в теме есть.
По резине у нормальных антифризов проблем нет.
