30 ноября 200718 г Закреплён Масла BP Официальный сайт: http://www.bp.com/en_gb/lubricants/united-kingdom.html Артикульные коды для заказа в интернет магазинах: 119368 / 15805A Visco 7000 0W-40 1L 119369 / 15805B Visco 7000 0W-40 4L 117528 / 15804F Visco 7000 0W-40 60L 117386 / 15804E Visco 7000 0W-40 208L 14F697 / 15571C Visco 5000 5W-30 1L 14F69B / 15571D Visco 5000 5W-30 4L 14F69C / 15570F Visco 5000 5W-30 60L 14EE20 / 15571A Visco 5000 5W-30 208L 114496 / 15805F Visco 5000 5W-40 1L 114502 / 15806A Visco 5000 5W-40 4L 108963 / 15805E Visco 5000 5W-40 60L 108959 / 15805D Visco 5000 5W-40 208L 14DF28 / 15870C Visco 3000 Diesel 10W-40 1L 14DF29 / 15870D Visco 3000 Diesel 10W-40 4L 119777 / 15870B Visco 3000 Diesel 10W-40 60L 119634 / 15870A Visco 3000 Diesel 10W-40 208L 14F6E7 / 157F38 Visco 3000 A3/B4 10W-40 1L 14F6E4 / 157F36 Visco 3000 A3/B4 10W-40 4L 14F6E2 / 157F35 Visco 3000 A3/B4 10W-40 20L 14F6E6 / 157F37 Visco 3000 A3/B4 10W-40 60L 14F6E1 / 157F34 Visco 3000 A3/B4 10W-40 208L 14FA23 / 156DA8 Visco 2000 A3/B3 15W-40 1L 14FA26 / 156DAA Visco 2000 A3/B3 15W-40 5L 14FA20 Visco 2000 A3/B3 15W-40 60L 14FA1D / 156DA6 Visco 2000 A3/B3 15W-40 208L 15267A / 1550F9 Vanellus Max 5W-30 208L 15267C / 1550F6 Vanellus Max 5W-30 20L 15267D / 1550F3 Vanellus Max 5W-30 5L 1525F6 / 1552B1 Vanellus Max Eco 10W-40 208L 1525F7 / 1552B0 Vanellus Max Eco 10W-40 20L 1527F6 / 1553CE Vanellus Max 10W-40 208L 1527F8 / 1553CD Vanellus Max 10W-40 20L 1527FB Vanellus Max 10W-40 5L 1525F0 / 1554FF Vanellus Multi A 10W-40 208L 1525EF / 1554FD Vanellus Multi A 10W-40 20L 1525F2 / 1554FA Vanellus Multi A 10W-40 5L 1525EB / 1552EB Vanellus Multi A 15W-40 208L 1525EA / 1552DB Vanellus Multi A 15W-40 20L 14E2AF Vanellus Multigrade 15W-40 208L 14E2B0 Vanellus Multigrade 15W-40 20L 15282A / 15552B Vanellus Multi 15W-40 208L 15282B / 15551C Vanellus Multi 15W-40 20L 15260C / 15549E Vanellus Mono 10W 208L 15269D / 154FE2 Vanellus Mono 30 208L 14342B Autran DX III 1L 1434A7 Autran DX III 20L 107042 Autran DX III 208L 14340E Autran MBX 1L 116163 / 15646C Autran MBX 20L 107068 Autran MBX 208L 119040 Autran MM-SP III 20L 119041 Autran MM-SP III 208L 117141 Autran 4 10 208L 114801 Autran 4 30 208L 14340A Energear SGX 75W-90 1L 116282 Energear SGX 75W-90 20L 108549 Energear SGX 75W-90 208L 14340D / 1557FC Energear HT 75W-90 1L 152B37 / 1557FD Energear HT 75W-90 20L 112212 / 1557FE Energear HT 75W-90 208L 14342A Energear HT 80W-90 1L 116204 Energear HT 80W-90 20L 107544 Energear HT 80W-90 208L 112224 Energear HT 85W-140 208L 1433FC / 15573C Energear EP 80W-90 1L 116100 / 15573B Energear EP 80W-90 20L 107481 / 15573A Energear EP 80W-90 208L 14973D / 15554C Energear EP 80W 208L 14340C Energear Limslip 90 1L 110198 / 1557F8 Energear Limslip 90 208L 1433FE / 155D2A Energear Hypo 80W-90 1L 116106 / 155D1A Energear Hypo 80W-90 20L 107520 / 155D1C Energear Hypo 80W-90 208L 107527 Energear Hypo 85W-140 208L 116107 Energear Hypo 85W-140 20L 107534 / 1556ED Energear Hypo 90 208L 116108 Energear Hypo 90 20L 119622 / 1556F7 Energear SHX-M 75W-90 208L 119624 / 1556FA Energear SHX-M 75W-90 20L 14B5E2 / 154FC7 Energear SHX-LS 75W-90 208L 109101 Energrease ZS 00 15KG 109107 Energrease ZS 00 50KG 135603 Brake Fluid DOT 4 0.5L Лабораторные анализы - Свежие - VOA oil-club.ru BP Visco 7000 0W-40 CleanGuard свежее BP Visco 5000 5W-40 свежее BP VISCO 3000 10W-40 свежее Лабораторные анализы - Отработки - UOA oil-club.ru BP Visco 7000 0W-40 LL-04 C3 отработка на BMW 525D после 10100км BP Visco 7000 0W-40 отработка на Fiat Linea после 7000км BP Visco 7000 0W-40 C3 отработка + Liqui Moly Oil Additive на Mitsubishi Outlander XL после 4500км BP Visco 5000 5W-40 на Лада Калина (Учебка) после 12000км и 1200м.ч BP Visco 7000 0W-40 LL-04 C3 отработка на VW Tiguan после 8300км
17 сентября 201016 г тоже залил bp visco 7000. Mark II скажи у тебя на канистре была защитная фольга? У меня просто крышка с кольцом и все. Залил это масло потому что по тестам замерзаемость у него очень низкая, а зимой это и надо. К тому же цена не высокая - 1500 руб. примерно у нас, покупаешь фильтр и замена бесплатная.
17 сентября 201016 г Delone757 покупал года 4 назад, фольги не было. Оборотная наклейка была англо-русско-украинская.
18 сентября 201016 г Братцы, может у кого нибудь есть MSDS Visco 7000? Или как оно в сравнение с SynPower 0W-40?
18 сентября 201016 г вот что-то нашел по bp visco 7000, гланьте братцы кто соображает Visco_7000_0W_40.pdf
18 сентября 201016 г вот что-то нашел по bp visco 7000, гланьте братцы кто соображает Да простят коллеги мой польский... Синповер 0-40 Виско Вязкость при 100 °C, мм2/с 13.3 / 12.45 Вязкость при 40 °C, мм2/с 73 / 75.75 Индекс вязкости 183/171 Вязкость, мПа.с –35°C <6600 / 5850 Температура застывания, °C -54/-60 Сдается, что Виско пожиже будет. В теории. Но пока в морозилку дома два пробника не забросишь, будешь до последнего сомневаться.
18 сентября 201016 г mds не забыть потом слегка встряхнуть... Жидкомолевцы говорили, что возможно по ряду масел (не только их) эффект, когда масло вроде не течет на сильном морозе, но при легком встряхивании сразу оживает: за счет такого рода борьбы присадки-полимера с парафинизацией.
18 сентября 201016 г Прошлой зимой Виско 7000 морозили уже: http://www.autoclub72.ru/forum/index.php?s...ost&p=32472
19 сентября 201016 г Да простят коллеги мой польский... Синповер 0-40 Виско Вязкость при 100 °C, мм2/с 13.3 / 12.45 Вязкость при 40 °C, мм2/с 73 / 75.75 Индекс вязкости 183/171 Вязкость, мПа.с –35°C <6600 / 5850 Температура застывания, °C -54/-60 Сдается, что Виско пожиже будет. В теории. Но пока в морозилку дома два пробника не забросишь, будешь до последнего сомневаться. в морозилку кидал.. жидкое.. ну и markii более точные тесты проводил. Там в пдф файле еще и TBN показатели есть и температура вспышки..
19 сентября 201016 г Конечно BP 0W40 будет жиже Synpower 0W40. Обратите внимание на щелочное число BP 6.4. Это очень маленькое щелочное число, присадки уменьшили что бы сделать масло малозольным, изза современных катализаторов и допусков ACEA C2 и С3. Тоесть моющие свойства у этого масла посредственные. Присадок положено меньше, базового масла больше. Именно изза этого и достигается приемущество перед Synpower в котором присадок больше, а самого базового масла меньше - соответсвенно и характеристики чуть хуже. На 6 градусов цельсия. Зато у Synpower моющие свойства, нейтрализация говенного бензина, богатый пакет противоизносных присадок. Щелочное у него 10.4 markII правильно делает что льет в своих условиях и в свой лексус с каталиком BP. А остальным с простыми движками и катализаторами я бы посоветовал Synpower 0W40. Или просто менять раз в 5 тыс км. Такой режим прощает почти все огрехи масла. Вот вам и Clean Guard с щелочным 6.4 как у азиатов.
19 сентября 201016 г Zamok To Torcon по Visco помести тоже в "Архив документации ..." пусть будет. ага добавил BP в наш архив.
19 сентября 201016 г Валволайн на ПАО?, а то щелочное может быть ниже еще и потому что сама база более стабильная и меньше дает окислов...
19 сентября 201016 г Vitek74 однозначно ПАО. Большой кусок присадок, большой кусок полимерки потому что это 0W40 там базе остается немного места - и при этом температура -54. Это Toyota 0W20 с температурой -50 может позволить себе быть кряком, полимерки мало, присадок там немного - щелочное 5. Базе больше места.
