Масла BP
Официальный сайт: http://www.bp.com/en_gb/lubricants/united-kingdom.html
119368 / 15805A Visco 7000 0W-40 1L
119369 / 15805B Visco 7000 0W-40 4L
117528 / 15804F Visco 7000 0W-40 60L
117386 / 15804E Visco 7000 0W-40 208L
14F697 / 15571C Visco 5000 5W-30 1L
14F69B / 15571D Visco 5000 5W-30 4L
14F69C / 15570F Visco 5000 5W-30 60L
14EE20 / 15571A Visco 5000 5W-30 208L
114496 / 15805F Visco 5000 5W-40 1L
114502 / 15806A Visco 5000 5W-40 4L
108963 / 15805E Visco 5000 5W-40 60L
108959 / 15805D Visco 5000 5W-40 208L
14DF28 / 15870C Visco 3000 Diesel 10W-40 1L
14DF29 / 15870D Visco 3000 Diesel 10W-40 4L
119777 / 15870B Visco 3000 Diesel 10W-40 60L
119634 / 15870A Visco 3000 Diesel 10W-40 208L
14F6E7 / 157F38 Visco 3000 A3/B4 10W-40 1L
14F6E4 / 157F36 Visco 3000 A3/B4 10W-40 4L
14F6E2 / 157F35 Visco 3000 A3/B4 10W-40 20L
14F6E6 / 157F37 Visco 3000 A3/B4 10W-40 60L
14F6E1 / 157F34 Visco 3000 A3/B4 10W-40 208L
14FA23 / 156DA8 Visco 2000 A3/B3 15W-40 1L
14FA26 / 156DAA Visco 2000 A3/B3 15W-40 5L
14FA20 Visco 2000 A3/B3 15W-40 60L
14FA1D / 156DA6 Visco 2000 A3/B3 15W-40 208L
15267A / 1550F9 Vanellus Max 5W-30 208L
15267C / 1550F6 Vanellus Max 5W-30 20L
15267D / 1550F3 Vanellus Max 5W-30 5L
1525F6 / 1552B1 Vanellus Max Eco 10W-40 208L
1525F7 / 1552B0 Vanellus Max Eco 10W-40 20L
1527F6 / 1553CE Vanellus Max 10W-40 208L
1527F8 / 1553CD Vanellus Max 10W-40 20L
1527FB Vanellus Max 10W-40 5L
1525F0 / 1554FF Vanellus Multi A 10W-40 208L
1525EF / 1554FD Vanellus Multi A 10W-40 20L
1525F2 / 1554FA Vanellus Multi A 10W-40 5L
1525EB / 1552EB Vanellus Multi A 15W-40 208L
1525EA / 1552DB Vanellus Multi A 15W-40 20L
14E2AF Vanellus Multigrade 15W-40 208L
14E2B0 Vanellus Multigrade 15W-40 20L
15282A / 15552B Vanellus Multi 15W-40 208L
15282B / 15551C Vanellus Multi 15W-40 20L
15260C / 15549E Vanellus Mono 10W 208L
15269D / 154FE2 Vanellus Mono 30 208L
14342B Autran DX III 1L
1434A7 Autran DX III 20L
107042 Autran DX III 208L
14340E Autran MBX 1L
116163 / 15646C Autran MBX 20L
107068 Autran MBX 208L
119040 Autran MM-SP III 20L
119041 Autran MM-SP III 208L
117141 Autran 4 10 208L
114801 Autran 4 30 208L
14340A Energear SGX 75W-90 1L
116282 Energear SGX 75W-90 20L
108549 Energear SGX 75W-90 208L
14340D / 1557FC Energear HT 75W-90 1L
152B37 / 1557FD Energear HT 75W-90 20L
112212 / 1557FE Energear HT 75W-90 208L
14342A Energear HT 80W-90 1L
116204 Energear HT 80W-90 20L
107544 Energear HT 80W-90 208L
112224 Energear HT 85W-140 208L
1433FC / 15573C Energear EP 80W-90 1L
116100 / 15573B Energear EP 80W-90 20L
107481 / 15573A Energear EP 80W-90 208L
14973D / 15554C Energear EP 80W 208L
14340C Energear Limslip 90 1L
110198 / 1557F8 Energear Limslip 90 208L
1433FE / 155D2A Energear Hypo 80W-90 1L
116106 / 155D1A Energear Hypo 80W-90 20L
107520 / 155D1C Energear Hypo 80W-90 208L
107527 Energear Hypo 85W-140 208L
116107 Energear Hypo 85W-140 20L
107534 / 1556ED Energear Hypo 90 208L
116108 Energear Hypo 90 20L
119622 / 1556F7 Energear SHX-M 75W-90 208L
119624 / 1556FA Energear SHX-M 75W-90 20L
14B5E2 / 154FC7 Energear SHX-LS 75W-90 208L
109101 Energrease ZS 00 15KG
109107 Energrease ZS 00 50KG
135603 Brake Fluid DOT 4 0.5L
BP Visco 7000 0W-40 CleanGuard свежее
BP Visco 5000 5W-40 свежее
BP VISCO 3000 10W-40 свежее
BP Visco 7000 0W-40 LL-04 C3 отработка на BMW 525D после 10100км
BP Visco 7000 0W-40 отработка на Fiat Linea после 7000км
BP Visco 7000 0W-40 C3 отработка + Liqui Moly Oil Additive на Mitsubishi Outlander XL после 4500км
BP Visco 5000 5W-40 на Лада Калина (Учебка) после 12000км и 1200м.ч
BP Visco 7000 0W-40 LL-04 C3 отработка на VW Tiguan после 8300км
Доброго дня. Завтра на ТО-2. Могу взять отработку, масло BP Visco 7000 0W-40, пробежал на нем 8100км. Что спрашиваю, на днях был анализ от Alehandro, и на подходе от veles158.
@Tig66, от veles уже тоже есть. искать в том же разделе.
Отправил на анализ отработку. Что хочу отметить, действительно, как уже писали, при разгоне до отсечки, звук движка более глухой, может действительно работает молибден. Но вот, что еще, на защитной мембране в заливной горловине, серовато-коричневый налет, как пленка, если раньше при доливе масла все смывалось, то при последнем доливе, после отбора на анализ, ничего не смылось, протер, легко снимается, мембрану не снимал, посветил фонарем, отложений нет. Проблем с запуском не было.
За 8300 пробега (на масле BP)) потребовалось долить 450 грамм, что считаю, на фоне масложора ваговских движков (не у всех правда) очень хорошим результатом, вообще с начала эксплуатации доливаю не более литра на 15000, при том, что люблю покрутить движок. Комп показывал максимальную температуру масла 108 градусов, это на скорости за 130 и выше, стоит сбросить до 90-100 и темпер. Уже 98-101.
что то на официальном сайте отсутствует информация о BP visco 5000 5w30
ЭТО КАК ?
А можно смешивать старое А3 BP Visco 7000 и новое С3?
А то есть 4,5 литра нового и 1л старого.
@urman, думаю да, старый ВР = Castrol EDGE 0-40 (ПАО полнозольник, правда старый) на выходе получишь такой себе мид сапс.
ну зольность меня не особо волнует. вопрос в смешиваемости ПАО... хотя не думаю, что у одного производителя они какие-то несовместимые... база одна скорее всего...
сегодня меняю BP VISCO 7000 0w-40 после 400мч города + 90мч трассы. Чем дольше ездил, тем больше казалось, что тише работает, особенно после прогревов.
не сравнивали случайно с Мобил 1 0w-40 ?
нет, к сожалению, ибо разные масла совсем
BP Visco 5000 5W40 теперь соответствует допускам API SN, BMW LL-01, MB 229.5. При этом цена осталась на том же уровне (1200р за 4л).
Если есть у кого-то возможность сбросте фото, где водно дату фасовки на канистре и на етикетке!
спасибо.
:unsure:
Вчера видел в магазине масло Visco 5000 5W-30 за очень привлекательную цену.
Что известно об этом масле? Можно ли его использовать как летний вариант с частотой смены в 7500 км?
Мотор просит GM-LL-A-025. Он у него есть.
