Масла Areol
Масла Areol
Официальный сайт:  http://www.areollub.com/
Нарвался на просторах интернета на такое вот масло под названием Areol, производится типа в Нидерландах.
каталог http://armtek.by/wp-content/uploads/2017/10/Katalog-masel-AREOL.pdf
продвигается белорусским Armtek
5W30AR015 - Areol Max Protect F 5W-30 1L
5W30AR016 - Areol Max Protect F 5W-30 4L
5W30AR017 - Areol Max Protect F 5W-30 5L
5W30AR044 - Areol Max Protect F 5W-30 20L
5W30AR045 - Areol Max Protect F 5W-30 60L
5W30AR046 - Areol Max Protect F 5W-30 205L
5W40AR011 - Areol Max Protect 5W-40 1L
5W40AR010 - Areol Max Protect 5W-40 4L
5W40AR009 - Areol Max Protect 5W-40 5L
5W40AR038 - Areol Max Protect 5W-40 20L
5W40AR039 - Areol Max Protect 5W-40 60L
5W40AR040 - Areol Max Protect 5W-40 205L
10W40AR002 - Areol Max Protect 10W-40 1L
10W40AR003 - Areol Max Protect 10W-40 4L
10W40AR001 - Areol Max Protect 10W-40 5L
10W40AR032 - Areol Max Protect 10W-40 20L
10W40AR033 - Areol Max Protect 10W-40 60L
10W40AR034 - Areol Max Protect 10W-40 205L
5W40AR060 - Areol Eco Protect 5W-40 1L
5W40AR061 - Areol Eco Protect 5W-40 4L
5W40AR062 - Areol Eco Protect 5W-40 5L
5W40AR063 - Areol Eco Protect 5W-40 20L
5W40AR064 - Areol Eco Protect 5W-40 60L
5W40AR065 - Areol Eco Protect 5W-40 205L
5W30AR018 - Areol Eco Protect 5W-30 1L
5W30AR019 - Areol Eco Protect 5W-30 4L
5W30AR020 - Areol Eco Protect 5W-30 5L
5W30AR047 - Areol Eco Protect 5W-30 20L
5W30AR048 - Areol Eco Protect 5W-30 60L
5W30AR049 - Areol Eco Protect 5W-30 205L
0W20AR068 - Areol Eco Energy DX1 0W-20 5L
0W20AR067 - Areol Eco Energy DX1 0W-20 4L
0W20AR066 - Areol Eco Energy DX1 0W-20 1L
0W30AR057 - Max Protect 0W-30 1L ACEA A3/B4
0W30AR058 - Max Protect 0W-30 4L ACEA A3/B4
0W30AR059 - Max Protect 0W-30 5L ACEA A3/B4
5W30AR074 - Areol ECO Energy DX1 5W-30 5L
5W30AR073 - Areol ECO Energy DX1 5W-30 4L
5W30AR072 - Areol ECO Energy DX1 5W-30 1L
5W30AR006 AREOL ECO Protect Z 5W-30 (5L) масло моторное! синт.\ ACEA C3, API SN, MB 229.51/229.52, VW 502.00
5W30AR007 AREOL ECO Protect Z 5W-30 (1L) масло моторное! синт.\ ACEA C3, API SN, MB 229.51/229.52, VW 502.00
5W30AR008 AREOL ECO Protect Z 5W-30 (4L) масло моторное! синт.\ ACEA C3, API SN, MB 229.51/229.52, VW 502.00
5W30AR012 AREOL Max Protect LL 5W-30 (1L) масло моторное! синт.\ ACEA A3/B4, API SN/CF, MB 229.3/226.5
5W30AR013 AREOL Max Protect LL 5W-30 (4L) масло моторное! синт.\ ACEA A3/B4, API SN/CF, MB 229.3/226.5
5W30AR014 AREOL Max Protect LL 5W-30 (5L) масло моторное! синт.\ ACEA A3/B4, API SN/CF, MB 229.3/226.5
5W30AR018 AREOL ECO Protect 5W-30 (1L) масло моторное! синт.\ ACEA C3, API SN, VW 504.00/507.00, MB 229.51
5W30AR019 AREOL ECO Protect 5W-30 (4L) масло моторное! синт.\ ACEA C3, API SN, VW 504.00/507.00, MB 229.51
5W30AR020 AREOL ECO Protect 5W-30 (5L) масло моторное! синт.\ ACEA C3, API SN, VW 504.00/507.00, MB 229.51
Грузовая Программа:
10W40AR004 AREOL Trans Truck 10W-40 (20L) масло моторное! полусинт.\ ACEA A3/B4/E7, API CI-4/SL, MB 228.3/229.1
10W40AR005 AREOL Trans Truck 10W-40 (205L) масло моторное! полусинт.\ACEA A3/B4/E7, API CI-4/SL, MB 228.3/229.1
10W40AR025 AREOL Trans Truck ECO 10W-40 (20L) масло моторное! синт.\ACEA E6/E7, API CI-4, Volvo VDS-3,MAN M3477
10W40AR026 AREOL Trans Truck ECO 10W-40 (205L) масло моторное! синт.\ACEA E6/E7, API CI-4,Volvo VDS-3,MAN M3477
Areol Eco Energy DX1 5W-30 API SP
Areol Max Protect 5W-40 API SN
Areol Trans Truck 10W-40 API CI-4
Areol Max Protect 0W-30
Areol Eco Protect C2 5W-30
Areol Eco Energy DX1 0W-20 API SP
Areol Eco Protect 5W-30 2022
Areol EcoProtect 5W-30 канистра март 2018 года
Areol Max Protect LL 5W-30
Areol Eco Energy DX1 0W-20  отработка на Toyota Rav4 после 9300км
4 минуты назад, tutish сказал:
Видел и что вас смущает?
А вас?
По моему в ролике всё чётко расписано, не?!
Нет. В ролике были искажены данные обще принятого стандарта вязкости SAE 300 и на этом были построены не верные выводы.
tutish ну давайте перейдем в тему анализа, и вы нам расскажите где у этого масла взять А3!
12 минут назад, tutish сказал:
Стоп, не переводите стрелки. По SAE данные искажены, согласны?
А вам кто то лично что то предъявляет, собственно вы кто, представитель, дистрик?
В словах "почти 20", не является выражением "это 20", в чём проблема?!
Мне никто ничего не предъявляет. Я просто честный человек. Этого достаточно.
Проблема в том, что в этом ролике за счет искажения данных дается не верная информация. Не понятно только для чего.
Не совсем понятен вопрос про А3. Что вас смущает? Все показатели, представленные в ролике соответствуют этой спецификации.
15 минут назад, tutish сказал:
Я вам дал тему, расскажите автору ролику про свои мысли, я их уже понял.
17 минут назад, tutish сказал:
Параметр HTHS при 150С не соответствует допуску А3. Вывод делается на основании вязкости при 100С. Для соответствия допуску А3 вязкость масла 0-30 должна быть в районе 12сСт при 100С.
1 час назад, tutish сказал:
Благодарю за понимание.
Не, не, не, а кто будет
1 час назад, avignon сказал:
искать, а, я что ли:sarcastic:
Увидел ананлиз масла, и решил отписать. Продвигает его Армтек наш, беларусский, если на точке продажи спросить что залить- покажут на него пальцем, скажут не дорогое и из Европы. Два раза работал на мероприятиях Армтека, полуофицальных, где так же был представитель этого бренда. Рассказывал и показывал графики про уровень качества и цены. Посыл был в том, что качество у них на уровне Мобила, а цены на уровне бюджетного Лукойла (это было их деление в презентации, по этой же презентации у Лукойла качество было низкое, как и цена.
 Отзывы по этому маслу- ВСЕ говорят, что масло нормальное, но менять надо в 2 раза чаще. Так было сказано мне и работниками Армтека, и представителями магазинов, что продают это масло, а так же половину отзывов на беларусских интернет-ресурсах. Так же довольно часто можно прочитать, что масло не держит вязкость, и сливается водой (впрочем, по анализу оно не держит вязкость с завода). Самый главный бонус, которым он отчасти держит клиентов- это тара 5л. Ни у Лукойла, ни у Зика нет 5л тары.
Р.S. Знакомый залил эту жижу 5w40 в Мерседес 2012 1,8 турбобенз. Не хотел тратиться на масло, так как мерс был на продаже. Откатал 6к, ничего не подливал, так и продал.
3 часа назад, tutish сказал:
Ещё раз, если кто то не читает тему.
Вязкость у этого масла слишком низкая, она конечно проходит стандарт SAE как тридцатка, но это не ACEA A3/B4. Это масло не будет удовлетворять HTHS > 3,5.
Друзья это мои слова, за свои слова могу ответить. К Areol отношусь с симпатией за их дешевый ценник и содержимое, прошу меня не зачислять в антипиарщики и не строить конспирологии. Что вижу то говорю...
Вот анализы масел 0W-30 стандарта ACEA A3/B4
Вы видите там где то масло с вязкостью 9.9?
Вот тех. документация на ваше масло
Вы видите там где то вязкость 9,9?
Если попытаться отнекаться, то да можно ухватиться за последний аргумент - SAE J300 где указано что SAE 30 должна быть от 9,3 до 12,5.
Но у вас не просто SAE 0W-30, у нее есть и другие стандарты например ACEA A3/B4 где HTHS > 3.5. А так же спецификации немецких компаний, где все это тоже перечислено.
Не путайте пожалуйста причинно следственную связь. Если вы объективные люди, Вам нужно валить вину не на того, кто показал вам неточность продукта, а писать на завод и спрашивать с них, почему они такое масло сделали. Я то тут причем? Или нам теперь масла не тестировать?
