Масло K1 Lube (Корея)
Официальный сайт: https://www.k1lube.com/
Сайт импортёра в РФ : https://k1lube.ru/
Видео: https://www.youtube.com/channel/UC6Ij3XQRUZyJ1yWrrBGE9rQ
TDS :   https://disk.yandex.ru/client/disk/TDS K1 Lube
8801471215014    K0512AL1W1    K1 Lube GX SP 0W-20_1L (1L*12)
8801471215076    K051244TW1    K1 Lube GX SP 0W-20_4LT (4LT*4)
8801471215212    K2512AL1W1    K1 Lube GX SP 5W-20_1L (1L*12)
8801471215311    K3512AL1W1    K1 Lube GX SP 5W-30_1L (1L*12)
8801471215373    K351244TW1    K1 Lube GX SP 5W-30_4LT (4LT*4)
8801471215342    K3512440W1    K1 Lube GX SP 5W-30_4L (4L*4)
8801471215359    K3512350W1    K1 Lube GX SP 5W-30_5L (5L*3)
8801471215410    K4512AL1W1    K1 Lube GX SP 5W-40_1L (1L*12)
8801471215472    K451244TW1    K1 Lube GX SP 5W-40_4LT (4LT*4)
8801471215441    K4512440W1    K1 Lube GX SP 5W-40_4L (4L*4)
8801471215458    K4512350W1    K1 Lube GX SP 5W-40_5L (5L*3)
8801471215717    K7512AL1W1    K1 Lube GX SP 10W-40_1L (1L*12)
8801471215779    K751244TW1    K1 Lube GX SP 10W-40_4LT (4LT*4)
8801471215748    K7512440W1    K1 Lube GX SP 10W-40_4L (4L*4)
8801471215755    K7512350W1    K1 Lube GX SP 10W-40_5L (5L*3)
8801471206111    K1602AL1W1    K1 Lube HD CI-4 10W-40_1L (1L*12)
8801471206173    K160244TW1    K1 Lube HD CI-4 10W-40_4LT (4LT*4)
8801471206142    K1602440W1    K1 Lube HD CI-4 10W-40_4L (4L*4)
8801471206159    K1602350W1    K1 Lube HD CI-4 10W-40_5L (5L*3)
8801471206166    K1602360W1    K1 Lube HD CI-4 10W-40_6L (6L*3)
8801471206197    K1602P20W1    K1 Lube HD CI-4 10W-40_20L
8801471206210    K2602AL1W1    K1 Lube HD CI-4 15W-40_1L (1L*12)
8801471206272    K260244TW1    K1 Lube HD CI-4 15W-40_4LT (4LT*4)
8801471206241    K2602440W1    K1 Lube HD CI-4 15W-40_4L (4L*4)
8801471206258    K2602350W1    K1 Lube HD CI-4 15W-40_5L (5L*3)
8801471206265    K2602360W1    K1 Lube HD CI-4 15W-40_6L (6L*3)
8801471206296    K2602P20W1    K1 Lube HD CI-4 15W-40_20L
8801471564167    K3745360W1    K1 Lube HD CH-4 15W-40_6L (6L*3)
8801471200119    K1002AL1W1    K1 Lube HD CF-4 15W-40_1L (1L*12)
8801471200140    K1002440W1    K1 Lube HD CF-4 15W-40_4L (4L*4)
8801471200157    K1002350W1    K1 Lube HD CF-4 15W-40_5L (5L*3)
8801471200164    K1002360W1    K1 Lube HD CF-4 15W-40_6L (6L*3)
8801471200195    K1002P20W1    K1 Lube HD CF-4 15W-40_20L
8801471250916    K9052AL1W1    K1 Lube ATF DX-III_1L (1L*12)
8801471250978    K905244TW1    K1 Lube ATF DX-III_4LT (4LT*4)
8801471252415    K4252AL1W1    K1 Lube ATF DX-VI_1L (1L*12)
8801471252477    K425244TW1    K1 Lube ATF DX-VI_4LT (4LT*4)
8801471251814    K8152AL1W1    K1 Lube ATF Multi_1L (1L*12)
8801471251876    K815244TW1    K1 Lube ATF Multi_4LT (4LT*4)
8801471251913    K9152AL1W1    K1 Lube CVTF_1L (1L*12)
8801471251975    K915244TW1    K1 Lube CVTF_4LT (4LT*4)
8801471252019    K0252AL1W1    K1 Lube DCTF_1L (1L*12)
8801471252071    K025244TW1    K1 Lube DCTF_4LT (4LT*4)
8801471296211    K2692AL1W1    K1 Lube Gear GL-5 75W-90_1L (1L*12)
8801471296242    K2692440W1    K1 Lube Gear GL-5 75W-90_4L (4L*4)
8801471296297    K2692P20W1    K1 Lube Gear GL-5 75W-90_20L
8801471298314    K3892AL1W1    K1 Lube Gear GL-5 80W-90_1L (1L*12)
8801471298345    K3892440W1    K1 Lube Gear GL-5 80W-90_4L (4L*4)
8801471298390    K3892P20W1    K1 Lube Gear GL-5 80W-90_20L
8801471298413    K4892AL1W1    K1 Lube Gear GL-5 85W-140_1L (1L*12)
8801471298444    K4892440W1    K1 Lube Gear GL-5 85W-140_4L (4L*4)
8801471298499    K4892P20W1    K1 Lube Gear GL-5 85W-140_20L
8801471366396    K3663P20W1    K1 Lube Hydraulic HL-46_20L
8801471366495    K4663P20W1    K1 Lube Hydraulic HL-68_20L
8801471368598    K5863P20W1    K1 Lube Hydraulic HM-46_20L
8801471368697    K6863P20W1    K1 Lube Hydraulic HM-68_20L
(пока нет)
Изменено пользователем Informed
Я так понимаю, замена Kixx. Потому как у нас Kixx-а нет от слова совсем. Все подборы масляные выдают именно это. У меня еще 1.5 литра 5w20 FE осталось. Как думаете - мешать можно?
21 минуту назад, Jaxon сказал:
У нас на озоне такой ситуации нет, достаточно разных вязкостей.
45 минут назад, Master Yoda сказал:
Я конкретно при кикс. Его у нас нет. Вместо него К1.
Сейчас глянул озон, цена конь там.
Изменено пользователем Jaxon
1 час назад, Jaxon сказал:
Вы тему с начала почитайте, тут не много страниц. Просто, еще одна корейская контора. Возможно, решили сэкономить на таре и разливают в старую киксовскую, плюс узнаваемость и закос.
Изменено пользователем SL1
31.01.2026 в 11:34, SL1 сказал:
Читал. Более того, держал в руках литрушку и сравнивал с моей старой. Даже продаван сказал, что полная замена Кикса.
3 минуты назад, Jaxon сказал:
Вот  "Продаванам" Меньше всего верить нужно
Изменено пользователем Александр. К.
2 минуты назад, Jaxon сказал:
Они много чего говорят и даже мамой клясться могут:)
Кикс масло не уникальное, проблем заменить другим брендом нет, но это не кикс.
2 часа назад, SL1 сказал:
Согласен, что не уникальное. Но я как раз Кикс искал. У меня еще 1,5 литра осталось.
Представитель бренда как-то быстро пропал. На пол года хватило всего)
K1 LUBE Масло трансмиссионное Gear 75W-90 1л Полусинтетика. Есть ли где температура застывания? не могу найти.
Rupor
Screenshot_2026-06-24-06-48-43-96_820b80da67ca34a12f493dfc8307f092.thumb.jpg.0b0b69a8b6b5f0011d137f275faa689e.jpg
04.06.2026 в 12:43, Rupor сказал:
под рукой есть анализ для 75w-90
armspecial 80w90 же по документам. Только кисель какой то. Что то из разряда 85w110/140 .
CCCP[Ne0] да, не тот отправил :(
07.11.2025 в 17:44, Евген48 сказал:
Взял на покатать.
Цена на ВБ 1400р
Дата март 2025г
Наконец-то улетело на заливку в Рафик на зиму.
