Масла BP
Официальный сайт: http://www.bp.com/en_gb/lubricants/united-kingdom.html
119368 / 15805A Visco 7000 0W-40 1L
119369 / 15805B Visco 7000 0W-40 4L
117528 / 15804F Visco 7000 0W-40 60L
117386 / 15804E Visco 7000 0W-40 208L
14F697 / 15571C Visco 5000 5W-30 1L
14F69B / 15571D Visco 5000 5W-30 4L
14F69C / 15570F Visco 5000 5W-30 60L
14EE20 / 15571A Visco 5000 5W-30 208L
114496 / 15805F Visco 5000 5W-40 1L
114502 / 15806A Visco 5000 5W-40 4L
108963 / 15805E Visco 5000 5W-40 60L
108959 / 15805D Visco 5000 5W-40 208L
14DF28 / 15870C Visco 3000 Diesel 10W-40 1L
14DF29 / 15870D Visco 3000 Diesel 10W-40 4L
119777 / 15870B Visco 3000 Diesel 10W-40 60L
119634 / 15870A Visco 3000 Diesel 10W-40 208L
14F6E7 / 157F38 Visco 3000 A3/B4 10W-40 1L
14F6E4 / 157F36 Visco 3000 A3/B4 10W-40 4L
14F6E2 / 157F35 Visco 3000 A3/B4 10W-40 20L
14F6E6 / 157F37 Visco 3000 A3/B4 10W-40 60L
14F6E1 / 157F34 Visco 3000 A3/B4 10W-40 208L
14FA23 / 156DA8 Visco 2000 A3/B3 15W-40 1L
14FA26 / 156DAA Visco 2000 A3/B3 15W-40 5L
14FA20 Visco 2000 A3/B3 15W-40 60L
14FA1D / 156DA6 Visco 2000 A3/B3 15W-40 208L
15267A / 1550F9 Vanellus Max 5W-30 208L
15267C / 1550F6 Vanellus Max 5W-30 20L
15267D / 1550F3 Vanellus Max 5W-30 5L
1525F6 / 1552B1 Vanellus Max Eco 10W-40 208L
1525F7 / 1552B0 Vanellus Max Eco 10W-40 20L
1527F6 / 1553CE Vanellus Max 10W-40 208L
1527F8 / 1553CD Vanellus Max 10W-40 20L
1527FB Vanellus Max 10W-40 5L
1525F0 / 1554FF Vanellus Multi A 10W-40 208L
1525EF / 1554FD Vanellus Multi A 10W-40 20L
1525F2 / 1554FA Vanellus Multi A 10W-40 5L
1525EB / 1552EB Vanellus Multi A 15W-40 208L
1525EA / 1552DB Vanellus Multi A 15W-40 20L
14E2AF Vanellus Multigrade 15W-40 208L
14E2B0 Vanellus Multigrade 15W-40 20L
15282A / 15552B Vanellus Multi 15W-40 208L
15282B / 15551C Vanellus Multi 15W-40 20L
15260C / 15549E Vanellus Mono 10W 208L
15269D / 154FE2 Vanellus Mono 30 208L
14342B Autran DX III 1L
1434A7 Autran DX III 20L
107042 Autran DX III 208L
14340E Autran MBX 1L
116163 / 15646C Autran MBX 20L
107068 Autran MBX 208L
119040 Autran MM-SP III 20L
119041 Autran MM-SP III 208L
117141 Autran 4 10 208L
114801 Autran 4 30 208L
14340A Energear SGX 75W-90 1L
116282 Energear SGX 75W-90 20L
108549 Energear SGX 75W-90 208L
14340D / 1557FC Energear HT 75W-90 1L
152B37 / 1557FD Energear HT 75W-90 20L
112212 / 1557FE Energear HT 75W-90 208L
14342A Energear HT 80W-90 1L
116204 Energear HT 80W-90 20L
107544 Energear HT 80W-90 208L
112224 Energear HT 85W-140 208L
1433FC / 15573C Energear EP 80W-90 1L
116100 / 15573B Energear EP 80W-90 20L
107481 / 15573A Energear EP 80W-90 208L
14973D / 15554C Energear EP 80W 208L
14340C Energear Limslip 90 1L
110198 / 1557F8 Energear Limslip 90 208L
1433FE / 155D2A Energear Hypo 80W-90 1L
116106 / 155D1A Energear Hypo 80W-90 20L
107520 / 155D1C Energear Hypo 80W-90 208L
107527 Energear Hypo 85W-140 208L
116107 Energear Hypo 85W-140 20L
107534 / 1556ED Energear Hypo 90 208L
116108 Energear Hypo 90 20L
119622 / 1556F7 Energear SHX-M 75W-90 208L
119624 / 1556FA Energear SHX-M 75W-90 20L
14B5E2 / 154FC7 Energear SHX-LS 75W-90 208L
109101 Energrease ZS 00 15KG
109107 Energrease ZS 00 50KG
135603 Brake Fluid DOT 4 0.5L
BP Visco 7000 0W-40 CleanGuard свежее
BP Visco 5000 5W-40 свежее
BP VISCO 3000 10W-40 свежее
BP Visco 7000 0W-40 LL-04 C3 отработка на BMW 525D после 10100км
BP Visco 7000 0W-40 отработка на Fiat Linea после 7000км
BP Visco 7000 0W-40 C3 отработка + Liqui Moly Oil Additive на Mitsubishi Outlander XL после 4500км
BP Visco 5000 5W-40 на Лада Калина (Учебка) после 12000км и 1200м.ч
BP Visco 7000 0W-40 LL-04 C3 отработка на VW Tiguan после 8300км
Добрый день, а можно где-то рассмотреть параметры вр 3000 10w40, в анализах там крайне убогая фотка, на которой ничего не видно, в этой теме перекинули более крупную, однако опять же, ничего не видно. Если есть более четка, или просто словесно, что там по щелочному, кол. Фосфора/цинка, вязкость. Буду очень благодарен.)
28 минут назад, Lobshter сказал:
15лет его лил ) в один и тот-же двиг. Щелочное низкое, поэтому менять желательно каждые 5-6ткм. В 2003г состав был -кряк+минералка 1гр. 50%. C 2010г состав поменялся - полностью кряк. Cейчас не знаю какой состав, тк 2года как перешел на менее вязкое масло.
Изменено пользователем Vasya-
Vasya-, спасибо за картинку. Какое-то слишком необычно хорошее масло для "дешевой полусиньки".) Я теперь понял, почему его все хвалят.)
 Выбираю на лето между этим и зик х7 дизель. Одно с золой 1,5 и море противоизноски и моющих, второе данное вр, с густой базой, хорошей противоизноской, с залой примерно 1, но низким щелочным.)
Могу еще сказать что за 15лет двигатель на нем чистый, но я и менял каждые 5ткм.
Ну я расчитываю на интервал в 10к, вот и задаюсь вопросом, что важнее, база или присадки?)
5 часов назад, Lobshter сказал:
Я лил Зик 5-30 Дизель в лач несколько раз по 5 ткм, ничего он не намыл. Поэтому больше не придерживаюсь теории, что лучше дешевле, не чаще, чем дороже и реже. Лучше синтетики с ПАО, ГТЛ и эстерами ничего нет, ИМХО, и менять средне- 7,5-10 ткм.
4 часа назад, zheleznodorozhnik сказал:
А зик 5w30 от дизеля только название, обычное масло, рядовое А3. ПАО и тд денег стоят, у меня на 10к и некоторые  кряки выхаживали спокойно, и все блестело от них, только сейчас цены из-за курса вверх стартанули, вот решено поиск возобновить.)
5 часов назад, zheleznodorozhnik сказал:
Мне кажется в этой теории один минус, более дешевое масло может не выдержать краскосрочную нагрузку. В отсечку газанешь где нибудь и будет задир. Мне кажется дорогое масло и нужно чтобы именно не подвело при нагрузках
Изменено пользователем Alickaps
18 минут назад, Alickaps сказал:
Описка. Дешевле, не НО чаще.
28 минут назад, Alickaps сказал:
Данное утверждение легко подписать 20 и некоторую 30 вязкость, но к 40 это почти не относиться (есть конечно откровенное говно).
Тут обсуждалось масло BP 10w40, судя по ноак, у него очень густая качественная база, я думаю оно почти любую нагрузку выдержит.)
Lobshter ага, мне казалось нагрузку держит именно синтетика а не вязкость).
9 минут назад, Alickaps сказал:
То есть, вжаривать на 0w20 на фул синтетике на турбомоторе куда безопаснее, чем на качественной смеси густой 3 группы 10w40?)
Дополню, я имею ввиду гражданские авто, до 100-120лс с литра, при условии обычной эксплуатации с отжигами переодически-постоянными.
Изменено пользователем Lobshter
Lobshter я в этом не особо, поэтому простые предположения. Сейчас кстати смотрю торкона про s-oil он там как раз говорит про полимерный загуститель его там мало, поэтому лучше при пиковых нагрузках.
Про вязкость я имелл ввиду то что мне кажется именно синтетика 5/40 лучше чем полу 10/40 просто потому что синтетика выше качеством. Но это мнение просто на основании роликов с ютуба.
3 минуты назад, Alickaps сказал:
Данное 10w40 от ВР, по сути,  гидрокрекинг, на густых базовых маслах и минимальным количеством загустителя (ноак у этого масла как у отличной синтетики- 7), так что, по моему мнению, может довольно смело конкурировать с более дорогими 5w40 (в плане отжига)
Масла 10w30, 10w40, 15w40, при хорошем качестве, держат пиковые нагрузки лучше, чем из братья 0/5w, но все зависит от конкретных масел.
Lobshter я понял спасибо.
