30 ноября 200718 г Закреплён Масла BP Официальный сайт: http://www.bp.com/en_gb/lubricants/united-kingdom.html Артикульные коды для заказа в интернет магазинах: 119368 / 15805A Visco 7000 0W-40 1L 119369 / 15805B Visco 7000 0W-40 4L 117528 / 15804F Visco 7000 0W-40 60L 117386 / 15804E Visco 7000 0W-40 208L 14F697 / 15571C Visco 5000 5W-30 1L 14F69B / 15571D Visco 5000 5W-30 4L 14F69C / 15570F Visco 5000 5W-30 60L 14EE20 / 15571A Visco 5000 5W-30 208L 114496 / 15805F Visco 5000 5W-40 1L 114502 / 15806A Visco 5000 5W-40 4L 108963 / 15805E Visco 5000 5W-40 60L 108959 / 15805D Visco 5000 5W-40 208L 14DF28 / 15870C Visco 3000 Diesel 10W-40 1L 14DF29 / 15870D Visco 3000 Diesel 10W-40 4L 119777 / 15870B Visco 3000 Diesel 10W-40 60L 119634 / 15870A Visco 3000 Diesel 10W-40 208L 14F6E7 / 157F38 Visco 3000 A3/B4 10W-40 1L 14F6E4 / 157F36 Visco 3000 A3/B4 10W-40 4L 14F6E2 / 157F35 Visco 3000 A3/B4 10W-40 20L 14F6E6 / 157F37 Visco 3000 A3/B4 10W-40 60L 14F6E1 / 157F34 Visco 3000 A3/B4 10W-40 208L 14FA23 / 156DA8 Visco 2000 A3/B3 15W-40 1L 14FA26 / 156DAA Visco 2000 A3/B3 15W-40 5L 14FA20 Visco 2000 A3/B3 15W-40 60L 14FA1D / 156DA6 Visco 2000 A3/B3 15W-40 208L 15267A / 1550F9 Vanellus Max 5W-30 208L 15267C / 1550F6 Vanellus Max 5W-30 20L 15267D / 1550F3 Vanellus Max 5W-30 5L 1525F6 / 1552B1 Vanellus Max Eco 10W-40 208L 1525F7 / 1552B0 Vanellus Max Eco 10W-40 20L 1527F6 / 1553CE Vanellus Max 10W-40 208L 1527F8 / 1553CD Vanellus Max 10W-40 20L 1527FB Vanellus Max 10W-40 5L 1525F0 / 1554FF Vanellus Multi A 10W-40 208L 1525EF / 1554FD Vanellus Multi A 10W-40 20L 1525F2 / 1554FA Vanellus Multi A 10W-40 5L 1525EB / 1552EB Vanellus Multi A 15W-40 208L 1525EA / 1552DB Vanellus Multi A 15W-40 20L 14E2AF Vanellus Multigrade 15W-40 208L 14E2B0 Vanellus Multigrade 15W-40 20L 15282A / 15552B Vanellus Multi 15W-40 208L 15282B / 15551C Vanellus Multi 15W-40 20L 15260C / 15549E Vanellus Mono 10W 208L 15269D / 154FE2 Vanellus Mono 30 208L 14342B Autran DX III 1L 1434A7 Autran DX III 20L 107042 Autran DX III 208L 14340E Autran MBX 1L 116163 / 15646C Autran MBX 20L 107068 Autran MBX 208L 119040 Autran MM-SP III 20L 119041 Autran MM-SP III 208L 117141 Autran 4 10 208L 114801 Autran 4 30 208L 14340A Energear SGX 75W-90 1L 116282 Energear SGX 75W-90 20L 108549 Energear SGX 75W-90 208L 14340D / 1557FC Energear HT 75W-90 1L 152B37 / 1557FD Energear HT 75W-90 20L 112212 / 1557FE Energear HT 75W-90 208L 14342A Energear HT 80W-90 1L 116204 Energear HT 80W-90 20L 107544 Energear HT 80W-90 208L 112224 Energear HT 85W-140 208L 1433FC / 15573C Energear EP 80W-90 1L 116100 / 15573B Energear EP 80W-90 20L 107481 / 15573A Energear EP 80W-90 208L 14973D / 15554C Energear EP 80W 208L 14340C Energear Limslip 90 1L 110198 / 1557F8 Energear Limslip 90 208L 1433FE / 155D2A Energear Hypo 80W-90 1L 116106 / 155D1A Energear Hypo 80W-90 20L 107520 / 155D1C Energear Hypo 80W-90 208L 107527 Energear Hypo 85W-140 208L 116107 Energear Hypo 85W-140 20L 107534 / 1556ED Energear Hypo 90 208L 116108 Energear Hypo 90 20L 119622 / 1556F7 Energear SHX-M 75W-90 208L 119624 / 1556FA Energear SHX-M 75W-90 20L 14B5E2 / 154FC7 Energear SHX-LS 75W-90 208L 109101 Energrease ZS 00 15KG 109107 Energrease ZS 00 50KG 135603 Brake Fluid DOT 4 0.5L Лабораторные анализы - Свежие - VOA oil-club.ru BP Visco 7000 0W-40 CleanGuard свежее BP Visco 5000 5W-40 свежее BP VISCO 3000 10W-40 свежее Лабораторные анализы - Отработки - UOA oil-club.ru BP Visco 7000 0W-40 LL-04 C3 отработка на BMW 525D после 10100км BP Visco 7000 0W-40 отработка на Fiat Linea после 7000км BP Visco 7000 0W-40 C3 отработка + Liqui Moly Oil Additive на Mitsubishi Outlander XL после 4500км BP Visco 5000 5W-40 на Лада Калина (Учебка) после 12000км и 1200м.ч BP Visco 7000 0W-40 LL-04 C3 отработка на VW Tiguan после 8300км
28 ноября 20187 г В 01.07.2017 в 08:45, vital_xbc сказал: Visco 3000 удивительно хорошая полусинтетика с жирным пакетом (тут вам и молибден и бор и ZDDP как для дизеля), разве что кальция маловато (отчего щелочное низкое), из-за минералки в базе высокое кислотное и много серы. Цена правда как у хорошего гидрокряка... Разве сейчас Visco 3000 это не 2+3 группы масел ?
28 ноября 20187 г Проехал на Visco 3000 150 тыс км , 14 лет только его и заливал. Недавно менял прокладки клапанных крышек -идеальная чистота. Менял поначалу -3-4года каждые 7тыс км, затем стал менять каждые 5-6 тыс. В основном езжу по городу, по трассе редко. В этом году виско 3000 исчезло из прилавков у нас, а через пару месяцев снова появилось но уже SN со штрих-кодом 480 -филипины. Подумал -че за хрень и не стал брать, залил Кастрол магнетик , посмотрю как покажет. - летом сменю наверно на Виско 5000, так как оно осталось по прежнему со штрих-кодом 42 -германия. На банках BE02 -бельгия, -на обеих.
7 декабря 20187 г Мдаа, не дождался лета, слил этот хренов кастрол магнетик уже через 3 дня)) и залил Виско 5000. C магнетиком двиг начал дымить конкретно, подумал уже что кольца запали . двигатель начал грубо работать и в заливной горловине по углу хрень черная и вязкая, хотя когда заливал горловина была чистейшая. Хотя по коду на галограмме проверил через их сайт - оригинальное масло. В общем никакого Кастрола больше. Изменено 7 декабря 20187 г пользователем Vasya-
8 декабря 20187 г Ага. БП как залил и дыма не стало , ну светлый пар при прогреве, но без едкого кумаря -не знаю как выразится.
8 декабря 20187 г Сейчас уже думаю , в его оправдание, что может это какие присадки в нем выгорали, а поуглу горловины хрень типа черных чернил -легко тряпочкой вытерлась, -может оно отмыло старые какие отложения изнутри. Не знаю что и думать
26 июля 20197 г Проехал на Visco 5000 5w40 5000 км. Горловина которую протер перед заливкой , блестит. На щупе умеренно потемнело -прозрачное. Виско 3000 за такой -же пробег было более темное. Единственное как только перешел с Виско 3000 на Виско 5000, то сразу-же при утреннем запуске лампа давления масла стала дольше гаснуть. на Виско 3000 гасла уже в процессе прокрутки стартером, а здесь через 2-3сек после запуска. Теперь думаю то-ли из-за фильтра NITTO -не держит дренажный клапан, уже несколько человек жаловались на дренажный клапан этого фильтра. То-ли масло жидкое . При замене масла сменю фильтр на другой, тогда и прояснится. Изменено 26 июля 20197 г пользователем Vasya-
13 декабря 20196 г Кто знает, чем-то отличаются масла Виско 5000 5w40 4л c разными артикулами > 4027720090 /114502 / 15806C ,?????? . может на разных заводах льют ? Изменено 13 декабря 20196 г пользователем Vasya-
21 апреля 20206 г Здравствуйте! Задался вопросом, почему российский сайт BP не указывает о продаже моторных масел под маркой BP на территории РФ? Сайт перенаправляет на Castrol, который мне не интересен. В магазинах нашего города эти масла продаются активно. На этикетке на русском языке указан дистрибьютор "Сетра Лубрикантс" и все необходимые данные, но сайт ООО "Сетра Лубрикантс" не существует. В какую сторону копать? Было бы не логично руссифицировать упаковку масел, не ввозимых в РФ официально.
21 апреля 20206 г ООО "Сетра Лубрикантс , то-бишь Кастрол и завозит его в россию, все дистрибьюторы кастрола продают это масло. А вот почему его нет на сайте Кастрол, этот вопрос наверно лучше задать представителю Кастрол на форуме. > Изменено 21 апреля 20206 г пользователем Vasya-
