Масла Febi
Масло Febi
32941 - Febi Engine Oil Longlife 5W-30 1L
32947 - Febi Engine Oil Longlife Plus 5W-30 5L
32921 - Febi 20W-50 1L
32922 - Febi 20W-50 5L
32923 - Febi 20W-50 25L
32924 - Febi 20W-50 60L
38408 - Febi 20W-50 200L
32925 - Febi 15W-40 1L
32926 - Febi 15W-40 4L
32927 - Febi 15W-40 5L
32928 - Febi 15W-40 25L
32929 - Febi 15W-40 60L
32930 - Febi 15W-40 200L
32931 - Febi     10W-40    1
32932 - Febi     10W-40    4
32933 - Febi     10W-40    5
32934 - Febi     10W-40    60
32935 - Febi     10W-40    200
32936 - Febi     5W-40    1
32937 - Febi     5W-40    4
32938 - Febi     5W-40    5
32939 - Febi     5W-40    60
32940 - Febi     5W-40    200
32941 - Febi     5W-30 Longlife    1
32942 - Febi     5W-30 Longlife    4
32943 - Febi     5W-30 Longlife    5
32944 - Febi     5W-30 Longlife    60
39336 - Febi     5W-30 Longlife    200
32945 - Febi     5W-30 Longlife Plus    1
32946 - Febi     5W-30 Longlife Plus    4
32947 - Febi     5W-30 Longlife Plus    5
32948 - Febi     5W-30 Longlife Plus    60
39337 - Febi     5W-30 Longlife Plus    200
34052 - Febi     10W-40 Truck Longlife Plus    200
48416 - Febi     5W-30 Longlife EU6    205
101140 - Febi     0W-40    1
101141 - Febi     0W-40    4
101142 - Febi     0W-40    5
101143 - Febi     0W-40    60
101144 - Febi     0W-40    200
105840 - Febi     10W-40 Truck Special Longlife    5
34047 - Febi     10W-40 Truck Special Longlife    20
34048 - Febi     10W-40 Truck Special Longlife    60
34049 - Febi     10W-40 Truck Special Longlife    200
101150 - Febi     5W-30 HC-FO    1
101151 - Febi     5W-30 HC-FO    4
101152 - Febi     5W-30 HC-FO    5
101153 - Febi     5W-30 HC-FO    60
101154 - Febi     5W-30 HC-FO    200
108350 - Febi     5W-20 HC E-FO    1
108351 - Febi     5W-20 HC E-FO    4
108352 - Febi     5W-20 HC E-FO    5
108360 - Febi     5W-30 HC C4    1
108361 - Febi     5W-30 HC C4    4
108362 - Febi     5W-30 HC C4    5
Febi Long Life Plus 5W-30 API SN
Febi SAE 5W-30 Longlife
Febi SAE 10W-40 Truck Special Longlife
Febi SAE 0W-40
Febi SAE 5W-40
Febi Longlife Plus 5W-30
Febi Long Life HC-FO 5W-30
Febi 39070
Febi Zentralhydraulikol
Лабораторные анализы - Отработки - UOA
FEBI Longlife Plus 5W-30 отработка на VW Passat B8 2.0 TDI после 11 326км
FEBI Longlife Plus 5W-30 отработка на VW Touareg после 13 000км
FEBI Longlife Plus 5W-30 отработка на VW Touareg после 9006км
Febi Loglife Plus 5W-30 отработка на Volkswagen Touareg после 8700км
Febi Long Life HC-FO 5W-30 отработка на TOYOTA VERSO  после 8000 км
Febi SAE 0W-40 отработка на Skoda Yeti после 6760км
28.08.2021 в 00:45, GerasimMumu сказал:
Кто может подсказать, сколько литрушек в картонной упаковке, 6,8,12?
Я как-то брал масло меньше коробки, так прислали в коробке. Потом брал то же масло в размере коробки, прислали в пленке со скотчем.
8 минут назад, SL1 сказал:
На сайте Феби - есть данные сколько канистр масла в фабричной упаковке. Например...
1578105064_Opera_2021-12-02_200737_partsfinder.bilsteingroup_com.thumb.png.2fe38ba759406f00e86424cbd8001047.png
Изменено пользователем SIRIUS
Может быть этот у всех масел с таким составом такой эффект, но мне он понравился. Febi 5w30 Longlife (C3+505). По сравнению с VAG 5w40, мой атмосферник конечно же чуть тише работает, можно сказать, что почти что урчит, как котёнок. Но я чувствую, что это не предел, мягкости можно ещё добавить. Думал, что такой эффект будет только на свежем масле. А нет, 2500 км со средней 22км/ч - приятная работа ДВС сохранилась.
Далее на очереди Лукойл (C3+505), сравним.
2 часа назад, GerasimMumu сказал:
На VAG SAE 5W-30  работа ещё лучше чем на этом Феби 5W40 , даже расход топлива снижается на 3% .
1 час назад, Hanval Rus сказал:
:sarcastic:
Несмотря на редкость данного масла, после единократного использования сразу понял что это масло и есть масло которое хочет мой пожилой мотор. Сразу изчезли вибрации и дизеление. До этого лил эльф, мотрио и лукойл силно угорают и после 5 т. Км р мотор работал как трактор. Здесь же даже после 8000 все идеально! И это за вполне одекватные деньги! Кстати SWAG c ариткулом 15932937 это тоже масло 5w40 api sn/cf
В пользу того,что для Febi масло производится на мощностях Rowe, говорит и маркировка дат производства,срока хранения  и номера партии. На канистрах Febi они идентичны с Rowe.
1410095977_FebiSAE5W-30Longlifephoto3.thumb.jpeg.7e8781c62b5807e57d08acdd9b32cbea.jpeg
Изменено пользователем bvv83
Взял данное Febi 5W-30 Longlife. Буду тестить.
Кстати, канистра фирмы Mauzer, качественно выполнен и наклейки качественно приклеены. НА оборотной стороне наклейка с книжкой.  Купил в Автодоке.
Изменено пользователем ILGIZ_717
Giga и в правду, с таким намёком "осторожность" отталкивает от заливки.
Хотя на прошлой таре всё точно также, только акцент не такой явный.
Изменено пользователем GerasimMumu
Теперь могу написать на собственном опыте - для корейцев масло Febi 5W-30 LL отличное масло. Использовал в Удмуртии в Ижевске.
Уже две тысячи км. катаюсь на febi 0w20 508.00
Из приятных дополнений к крайне приятной цене в 30$ (1200грн) за 5л абсолютно официального масла, очень приятная работа мотора. Работает мягче чем на предыдущем havoline 0w20 на старой 2022г рецептуре полностью ПАО. Прям очень нравится масло хотя ещё рано делать какие либо выводы, ближе к моменту замены на пробеге в 10ткм будет окончательно понятно.
IMG_20240624_230641_506.jpgIMG_20240624_230641_111.jpgIMG_20240624_230621_621.jpgIMG_20240624_230641_302.jpg
Узнавал в представительстве. Это обязательный знак по нормам РФ. Поэтому внизу и написали что только для РФ, так как больше нигде нет такого требования в нанесении этого знака
