Масла Hyundai / KIA OEM
05200-00140 - Hyundai Kia Eco Premium Diesel C2 0W-30 1L
05200-00640 - Hyundai Kia Eco Premium Diesel C2 0W-30 6L
05100-00171 - Hyundai Mega Turbo Syn 0W-30 API SN, ACEA C2 1L
05100-00471 - Hyundai Mega Turbo Syn 0W-30 API SN, ACEA C2 4L
05100-00161 - Hyundai New Premium Gasoline Engine Oil 0W-20 API SN ACEA C2 1L
05100-00461 - Hyundai New Premium Gasoline Engine Oil 0W-20 API SN ACEA C2 4L
05200-00110 - HYUNDAI CLASSIC GOLD DIESEL 10W-30 1L
05200-00410 - HYUNDAI CLASSIC GOLD DIESEL 10W-30 4L
05200-484A0 - HYUNDAI COMMERCIAL DIESEL 10W-40 4L
05200-00120 - HYUNDAI PREMIUM DPF DIESEL 5W-30 1L
05100-00121 - HYUNDAI PREMIUM GASOLINE 5W-20 1L
05100-00421 - HYUNDAI PREMIUM GASOLINE 5W-20 4L
05100-00151 - HYUNDAI PREMIUM LF GASOLINE 5W-20 1L
05100-00451 - HYUNDAI PREMIUM LF GASOLINE 5W-20 4L
05200-00411 - HYUNDAI PREMIUM LS DIESEL 5W-30 4L
05200-00111 - HYUNDAI PREMIUM LS DIESEL 5W-30 1L
05200-00100 - HYUNDAI PREMIUM PC DIESEL 10W-30 1L
05200-00400 - HYUNDAI PREMIUM PC DIESEL 10W-30 4L
05100-00110 - HYUNDAI SUPER EXTRA GASOLINE 5W-30 1L
05100-00410 - HYUNDAI SUPER EXTRA GASOLINE 5W-30 4L
05100-00141 - HYUNDAI TURBO SYN 5W-30 1L
05100-00441 - HYUNDAI TURBO SYN 5W-30 4L
05200-00610 - HYUNDAI CLASSIC GOLD DIESEL 10W-30 6L
05200-486A0 - HYUNDAI COMMERCIAL DIESEL 10W-40 6L
05100-00121 HYUNDAI PREMIUM GASOLINE 5W-20 SL/GF-3 1L
05100-00321 HYUNDAI PREMIUM GASOLINE 5W-20 SL/GF-3 3L
Перевод кем произведено оригинальное масло:
Hyundai-Kia Premium LF Gasoline 5W-20 2024
Hyundai-Kia New Premium Plus 0W-20 (анализ с корейского форума)
Hyundai Turbo Syn 5W-30 05100-00441 new
Kia Mega Turbo Syn 0W-30 API SN, ACEA C2 05100-00171
Hyundai New Premium Gasoline Engine Oil 0W-20 API SN ACEA C2 05100-00161
Hyundai-Kia Turbo Syn 5W-30 05100-00441
Hyundai Kia Ecо Premium Diesel 0W-30
Hyundai 05100-00451 (05100-00151) Premium LF Gasoline 5w-20
Hyundai Premium Gasoline Engine Oil 5W-20
Hyundai-Kia Premuim DPF Diesel 5W-30 ACEA C3
Hyundai Kia Premium LS Diesel 5W-30 05200-00111
Hyundai Turbo Syn 5W-30 отработка на Kia Sportage после 9781км
KIA Mega Turbo Syn 0W-30 отработка на Mitsubishi Outlander XL после 8000 км
Kia Mega Turbo Syn 0W-30 API SN, ACEA C2 отработка на Mitsubishi Montero Sport после 7000-7300км
KIA Mega Turbo Syn 0W-30 отработка на Kia Rio после 2745км
KIA Mega Turbo Syn 0W-30 отработка на Toyota Land Сruiser Prado после 5646км
KIA Mega Turbo Syn 0W-30 ACEA C2 API SN отработка на KIA ceed CD после 6023км
Hyundai New Premium Gasoline Engine Oil 0W-20 API SN ACEA C2 0W-20 отработка на Hyundai Creta после 0-200-4200км
Hyundai Premium LF Gasoline 5w-20 отработка на Hyundai Creta после 7 000 км
Hyundai Premium LF Gasoline 5w-20 отработка на Hyundai Solaris после 5500 км.
Hyundai Kia Premium LS Diesel 5W-30 отработка на KIA Sorento после 5520 км.
Hyundai 20 05100-00451 Premium LF Gasoline 5W-20 отработка на KIA Rio после 6345 км.
С новья лью Hyundai 05100-00451 ( 05100-00151) Premium LF Gasoline 5W-20 киа рио 4 акпп 2018г, пробег 19т.км все отлично, но есть один ньюанс, на горячию на ХХ при выключенном климате и музыки, закрытых окнах слышиться какое то раздражающие слух тарахтение двигателя с металлическим оттенком, особенно когда на улице нет шума, например ночью. С наружи этого тарахтения не слышно, двигатель работает тихо, слышен только треск форсунок и шелест навесного. Может это из-за этого масла или так треск форсунок проникает в салон в искаженном виде или что-то с двигателем или так и должно быть?
torcon Simext  нефтянка таких анализов не делает, может плотность и кв при 40 сделать, и еще газовую хроматограмму, но для этого перенастраивать надо,
Simext  у меня тоже на холодную громковато было, забей, если нравится езди, можешь другое масло попробовать, в этой же вязкости
6 часов назад, Serega сказал:
Всё тоже самое один в один как ты описал.масла илсаки разные,и на А5 есть этот звук.вообще очень много тем про этот звук.мнения разные есть.Но походу это перекладка.Меньше всего было его слышно на лук глид 5/30.думаю после А5 попробовать 40ку.как говорится послушать
Если бы это была перекладка, ее бы с наружы тоже было слышно, это тарахтения похоже по такту на работу форсунок, быть может моторный щит и шумоизоляция так его искажают в салоне, акустический эффект типо. Был сегодня у ОД по поводу этого, тоже сказали что кроме работы форсунок ничего не слышим.
Изменено пользователем Simext
Ребят! на H/K Premium LF Gasoline 5w-20 пробег 5100 км и 155м\ч, но 14 месяц пошел, стоит поменять, или дождаться 200м\ч?
Изменено пользователем Watson™
HYUNDAI MOBIS
NEW PREMIUM PLUS GASOLINE ENGINE OIL 0W-20
Маловязкое моторное масло нового поколения плюс
API SN+ SAE 0W-20
1L 05100 - 00181
4L 05100 - 00481
Dumus Возможно, новое бензиново-моторное масло Hyundai Kia Motors для бензиновых двигателей.
Новый бензиновый двигатель соответствует новейшей спецификации API и ACEA C5.
Возможно, эти трент.
Вот купил про запас сегодня LF 5w20 1L 4шт, на всех четырех одинаковый батч-код, это нормально?
В 26.05.2019 в 15:05, Serega сказал:
А как на счет версии что это клапана, из-за отсутсивия гидрокомпенсаторов. Или плохо отрегалированных с завода. Интересно на форуме у кого нибудь есть новый двигатель каппа 1.4 с гидриками, узнать бы есть у них это тарахтение, что бы проверить гипотезу
В 18.07.2019 в 01:12, Simext сказал:
Есть такой;). Могу записать звук работы двигателя. Если очень надо.
В 16.07.2019 в 17:40, Simext сказал:
Да. Бач-код на партию идет.
Брал оригинальную ATF SP-III 2 шт. по 4л, код был одинаковый(тоже производства мичанг)
