Масла BP
Официальный сайт: http://www.bp.com/en_gb/lubricants/united-kingdom.html
119368 / 15805A Visco 7000 0W-40 1L
119369 / 15805B Visco 7000 0W-40 4L
117528 / 15804F Visco 7000 0W-40 60L
117386 / 15804E Visco 7000 0W-40 208L
14F697 / 15571C Visco 5000 5W-30 1L
14F69B / 15571D Visco 5000 5W-30 4L
14F69C / 15570F Visco 5000 5W-30 60L
14EE20 / 15571A Visco 5000 5W-30 208L
114496 / 15805F Visco 5000 5W-40 1L
114502 / 15806A Visco 5000 5W-40 4L
108963 / 15805E Visco 5000 5W-40 60L
108959 / 15805D Visco 5000 5W-40 208L
14DF28 / 15870C Visco 3000 Diesel 10W-40 1L
14DF29 / 15870D Visco 3000 Diesel 10W-40 4L
119777 / 15870B Visco 3000 Diesel 10W-40 60L
119634 / 15870A Visco 3000 Diesel 10W-40 208L
14F6E7 / 157F38 Visco 3000 A3/B4 10W-40 1L
14F6E4 / 157F36 Visco 3000 A3/B4 10W-40 4L
14F6E2 / 157F35 Visco 3000 A3/B4 10W-40 20L
14F6E6 / 157F37 Visco 3000 A3/B4 10W-40 60L
14F6E1 / 157F34 Visco 3000 A3/B4 10W-40 208L
14FA23 / 156DA8 Visco 2000 A3/B3 15W-40 1L
14FA26 / 156DAA Visco 2000 A3/B3 15W-40 5L
14FA20 Visco 2000 A3/B3 15W-40 60L
14FA1D / 156DA6 Visco 2000 A3/B3 15W-40 208L
15267A / 1550F9 Vanellus Max 5W-30 208L
15267C / 1550F6 Vanellus Max 5W-30 20L
15267D / 1550F3 Vanellus Max 5W-30 5L
1525F6 / 1552B1 Vanellus Max Eco 10W-40 208L
1525F7 / 1552B0 Vanellus Max Eco 10W-40 20L
1527F6 / 1553CE Vanellus Max 10W-40 208L
1527F8 / 1553CD Vanellus Max 10W-40 20L
1527FB Vanellus Max 10W-40 5L
1525F0 / 1554FF Vanellus Multi A 10W-40 208L
1525EF / 1554FD Vanellus Multi A 10W-40 20L
1525F2 / 1554FA Vanellus Multi A 10W-40 5L
1525EB / 1552EB Vanellus Multi A 15W-40 208L
1525EA / 1552DB Vanellus Multi A 15W-40 20L
14E2AF Vanellus Multigrade 15W-40 208L
14E2B0 Vanellus Multigrade 15W-40 20L
15282A / 15552B Vanellus Multi 15W-40 208L
15282B / 15551C Vanellus Multi 15W-40 20L
15260C / 15549E Vanellus Mono 10W 208L
15269D / 154FE2 Vanellus Mono 30 208L
14342B Autran DX III 1L
1434A7 Autran DX III 20L
107042 Autran DX III 208L
14340E Autran MBX 1L
116163 / 15646C Autran MBX 20L
107068 Autran MBX 208L
119040 Autran MM-SP III 20L
119041 Autran MM-SP III 208L
117141 Autran 4 10 208L
114801 Autran 4 30 208L
14340A Energear SGX 75W-90 1L
116282 Energear SGX 75W-90 20L
108549 Energear SGX 75W-90 208L
14340D / 1557FC Energear HT 75W-90 1L
152B37 / 1557FD Energear HT 75W-90 20L
112212 / 1557FE Energear HT 75W-90 208L
14342A Energear HT 80W-90 1L
116204 Energear HT 80W-90 20L
107544 Energear HT 80W-90 208L
112224 Energear HT 85W-140 208L
1433FC / 15573C Energear EP 80W-90 1L
116100 / 15573B Energear EP 80W-90 20L
107481 / 15573A Energear EP 80W-90 208L
14973D / 15554C Energear EP 80W 208L
14340C Energear Limslip 90 1L
110198 / 1557F8 Energear Limslip 90 208L
1433FE / 155D2A Energear Hypo 80W-90 1L
116106 / 155D1A Energear Hypo 80W-90 20L
107520 / 155D1C Energear Hypo 80W-90 208L
107527 Energear Hypo 85W-140 208L
116107 Energear Hypo 85W-140 20L
107534 / 1556ED Energear Hypo 90 208L
116108 Energear Hypo 90 20L
119622 / 1556F7 Energear SHX-M 75W-90 208L
119624 / 1556FA Energear SHX-M 75W-90 20L
14B5E2 / 154FC7 Energear SHX-LS 75W-90 208L
109101 Energrease ZS 00 15KG
109107 Energrease ZS 00 50KG
135603 Brake Fluid DOT 4 0.5L
BP Visco 7000 0W-40 CleanGuard свежее
BP Visco 5000 5W-40 свежее
BP VISCO 3000 10W-40 свежее
BP Visco 7000 0W-40 LL-04 C3 отработка на BMW 525D после 10100км
BP Visco 7000 0W-40 отработка на Fiat Linea после 7000км
BP Visco 7000 0W-40 C3 отработка + Liqui Moly Oil Additive на Mitsubishi Outlander XL после 4500км
BP Visco 5000 5W-40 на Лада Калина (Учебка) после 12000км и 1200м.ч
BP Visco 7000 0W-40 LL-04 C3 отработка на VW Tiguan после 8300км
@SE_AL, или 2008 или 2010. Вот отличия ACEA 2010 от ACEA 2008:
@мин, а какая связь между европейским ОЕМ производителем и американской API? Какой им смысл отстегивать, если их основной рынок 0w-40\5w-40 в Европе? За лицензию будешь платить не только за тесты, но и с объема проданного масла.
Хорошо если не указан год к А3/В3 и по умолчанию это последняя действующая редакция. Как объяснить наличие в рознице масла соответствующих редакциям А3/В3-02,А3/В3-04?
дык продается ещё "7000 Turbo Diesel 0W40" без С3 и тбн 10,6
откуда информация по ТБН?
У кого-нибудь есть опыт эксплуатации этого масла на бензиновом движке?
Прошлая зима была относительной теплой в столице Казахстана - Астане. Лил ВР 7000 0-40, что хорошо - всегда заводился. Темнело быстро и мотор загаживался. Машина Тойота Камри 2000 5S-FE. Машину продал, теперь езжу на РАВ4 2006 2AZ-FE, прошлой зимой машина замерзла (кондесат в баке). На эту зиму залил опять ВР 7000 0-40, маслом доволен, единственно чуток угорает на трассе, но может и сам двигатель виноват. В общем недавно был мороз -40, машина стояла, не заводилась, примерно 12 часов, на ветру. Утром крутил стартером секунд 7, машина завелась! Чувствовалось, что масло не мешает, мотор крутится стартером бодро. Рекомендую!
какие были интервалы замены?
Лирическое вступление:
Мной были куплены в розничной сети 20 (+1) литрушек для проведения "тестов" на подвижность при отрицательных температурах и последующего анализа свежего масла. Выбиралось по принципу - самые распространенные в городе Казань по SAE 5w-40. Почему столько, а не меньше. На мой взгляд, когда благодаря усилиям пиарастов-мракетологов зрение сужается до периферического и глаза покупателя уже ничего не различает более 2-3 этикеток, оптимальнось выбора становится существенно ниже. А когда потенциальных кандидатов на покупку становится больше, выбирать на самом деле становится легче. Легче определить кому в каком регионе стоит обратить внимание на продукт, который более всего подойдет по его климатическим условиям, по его толщине кошелька или его широте души. По хорошему, кандидатов должно рассматриваться до 30 одновременно. Но такая задача мне в одиночку не под силу. Поэтому, кто решит поддержать проект большой солянки - деньги переводить на кошелек торкона. Один я буду делать анализы намного дольше. Но сделаю их всё равно. Один или за компанию.
Основная часть:
В первую очередь мне нужно было добиться наибольшей повторяемости по результатам, обеспечив равные условия для "издевательств" над маслами. Было замечено, что есть ощутимая разница по температурам в зависимости от глубины установки масел в камере. Самые низкие температуры были у задней стенки, самая высокая у дверцы. Электронный термометр был проверен двумя спиртовыми. В заключении, для обеспечения равных условий решил ставить наборы поодиночке, установив сзади ограничитель с датчиком термометра. Что хочу отметить. Для того, чтобы более-менее приблизиться к объективной картине - нужна серия тестов. 1-2 градуса уже меняет картину по подвижности. Одиночное опрокидывание может дать ложную картину. Для масел с SAE 5w-40 заметил характерный порог в -27 С, ниже которого лидера могут догнать или обогнать аутсайдеры. Например Addinol Mv 0546 с Ravenol VSi до -27 С имеют одинаковую подвижность, ниже уже заметны отличия.
Пара слов по поводу парафинизации. 18 масел к -25 имели одинаковую картину по помутнению с учетом цвета товарного масла, приобретаемого благодаря пакету присадок. Оставшиеся два масла теряли прозрачность с каждым градусом вниз. Но по скорости они отличались. Если Роснефть максимум, имеющее самый скромный пакет присадок и 2008 год выпуска резко теряло прозрачность, уже на один градус ниже. То Ликви моли Синтойл хай тек при -26 в середине образовывалось облачко с хвостом, обращенным вниз. По краям масло оставалось более прозрачным. В -27 становилось полумутным и в -28 мутнело совсем. До -27 градусов Синтойл хай тек был абсолютным лидером, далее его стали нагонять ТНК, Вальволайн и Шелл. В -31 Вальволайн шел вровень, а ТНК уже опережал. Прямой зависимости, подвижности масел от степени парафинизации (прозрачности) установить не удалось.
Не удалось установить зависимость подвижности масла и относительно заявленного пурпойнта. По Роснефти данных нет, по Тебойлу данные устаревшие. Учитывать изменения в рецептурах не всегда есть возможность из-за отсутствия данных. Большая часть производителей указывают температуру замерзания реальную, даже если она -36 (-37), другие используют этот параметр как дополнительный крючок для выуживания денег из кошелька.
Отследить взаимосвязь более точно можно будет только после лабораторных анализов, включающих CCS и PP "свежего" масла. Заметил, что масла с пакетом уровня качества MB-229.5 имеют более светлый оттенок, нежели родня по DI c MB-229.3. Скорее всего это связано с особенностями в рецептуре по депрессантам и загустителю.
Результаты решил разбить на несколько больших групп по результатам всей серии. Разница между ними минимальная. Отловлен один явный аутсайдер, продувший в плане подвижности всем и при всех температурах. Им оказался продукт от Газпрома G-Energy F Synt 5w-40. Такое впечатление, что это на самом деле 10w-40. Это не значит, что его нельзя заливать вообще. Но стоит обращать внимание на него, либо когда относительно тепло, либо живущим на юге и юго-западе.
В этом ролике смонтировал только результаты при диапазоне температур от -28 до -31. Но по всем 20-ти маслам. Первый блин комом, в будущем сделаю поправки и по камере с фотоаппаратом и с монтажом.
http://www.youtube.com/watch?v=xgMvsckK1PI
Здесь уже полная картина. Обращайте внимание на температуры. Сравнивать можно только внутри одного набора. Относительно.
Таблица результатов:
01 LM Liqui Moly Syntoil High Tech 5w-40
01 TM TNK Magnum Ultratec 5w-40*
01 VS Valvoline SynPower 5w-40
01 SH Shell Helix Ultra 5w-40
02 Lukoil Luxe 5w-40*
02 Teboil Gold S 5w-40
02 ZIC XQ 5w-40*
02 Mannol Elite 5w-40*
02 BP Visco 5w-40
03 ELF Excellium NF 5w-40
03 Ravenol VSi 5w-40*
03 Neste City Standart 5w-40
03 Esso Ultron 5w-40
03 Mobil Super X1 3000 5w-40
04 Agip Tecsint 5w-40
04 Rosneft Maximum 5w-40*
04 Motul X-cess 8100**
04 Total Quartz 5w-40
04 Addinol MV 0546 5w-40
05 G-Energy F Synt 5w-40*
Для тех, кому важно наличие фольги под крышкой в качестве пилюли для самоуспокоения, пометил их аштериксом. Например 5w-40* в конце класса вязкости по SAE. Чемпионом по "тяжести откручивания" крышки оказался Zic XQ.
** - у канистры Мотуль носик выдвижной с пластиковой пломбой.
Ну и в заключении сводная таблица участников:
Изменено пользователем Dmitriy67
Synpower я так понимаю облажался? :D
да не наговаривай), очень достойно выглядит, один из лучших,..кстати ВР тоже молодцом..)
По БП не сомневался
В отсутсвие Фукса переходил с PC SS на BP 0W40 по 5000 пробега
к маслу претензий нет ...
в магазинах появилось виско 5000 5w30, полнозольник с 229,5 и остальными рюшками)
цена примено 1200 за 4л, имхо неплохо
Подскажите ТТХ на Visco 7000 0w40. Чтото не могу найти нигде. Ни вязкость при 100, ни щелочное, ни HTHS.....
Мы пришли к выводу в теме про castrol что ВР 0-40 = тот же арал 0-40 по физ.хим. свойствам все сходиться. Еще и про арал кину для интереса глянешь :rolleyes:
BP_VISCO_0W_40.pdf
BP_VISCO_0W_40_MSDS.pdf
Изменено пользователем mikong
@Silence, а ТУТ не пробовал смотреть или религия не позволяет? :D
P.S. опередил.
Изменено пользователем konung
вот
glis.pdf
спасибо за ссылки. Но виско С3, а кастрол полнозольник какбэ.
Не ты не понял. Сначала разговор был о том что старый ВР 7000 (который был полнозольник) это тот же edge! А сейчас оно льется из одной бочки что и арал супертроник.
