Масла Chevron
Масла Chevron
Официальный сайт: http://www.chevronlubricants.com/
Артикулы коды для заказа в инетмагазинах
Вариант № 1
223501482 - Chevron Havoline Motor Oil 0W-20 0,946L
076568796280 - Chevron Havoline Motor Oil 5W-20 0,946L
223393721 - Chevron Havoline Motor Oil 5W-20", 0.946L
223502482 - Chevron Havoline ProDS Full Synthetic 5W-20, 0.946L
223503482 - Havoline ProDS Full Synthetic 5W-30, 0.946L
223394485 - Chevron Havoline Motor Oil 5W-30, 4.73L
223394533 - Chevron Havoline Motor Oil 5W-30, 4.73L
076568796297 - Chevron Havoline Motor Oil 5W-30 0,946L
223726482 -  Chevron Havoline ProDS Full Synthetic 5W-40, 0.946L
223504482 - Chevron Havoline ProDS Euro Full Synthetic 5W-40, 0.946L
223395533 - Chevron Havoline Motor Oil 10W-30, 4.73L
223395481 - Chevron Havoline Motor Oil 10W-30, 0.946L
223396485 - Chevron Havoline Motor Oil 10W-40, 4.73L
223396481 - Chevron Havoline Motor Oil 10W-40, 0.946L
220135721 Chevron Supreme Motor Oil SAE 5W-20 946mL
220013533 Chevron Supreme Motor Oil SAE 5W-30 3,78L
220013553 Chevron Supreme Motor Oil SAE 5W-30 4,83L
220013429 Chevron Supreme Motor Oil SAE 5W-30 3,78L
220013719 Chevron Supreme Motor Oil SAE 5W-30 946mL
220155719 Chevron Supreme Motor Oil SAE 10W-30 946mL
220155533 Chevron Supreme Motor Oil SAE 10W-30 4,83L
220059533 Chevron Supreme Motor Oil SAE 10W-40 4,83L
220059429 Chevron Supreme Motor Oil SAE 10W-40 3,78L
220059719 Chevron Supreme Motor Oil SAE 10W-40 946mL
220060719 Chevron Supreme Motor Oil SAE 20W-50 946mL
220060533 Chevron Supreme Motor Oil SAE 20W-50 3,78L
257001388 - Chevron Delo 400 Syn XSP 5W-30 3,785 л
257001448 - Chevron Delo 400 Syn XSP 5W-30 18,9 л
257001981 - Chevron Delo 400 Syn XSP 5W-30 208 л
235195389 CHEVRON DELO 400 Synthetic SAE 0W-30 3,78L
271210339 CHEVRON DELO 400 LE Synthetic SAE 5W-30 3,78L
271210448 CHEVRON DELO 400 LE Synthetic SAE 5W-30 19L
271207448 CHEVRON DELO 400 LE Synthetic SAE 5W-40 19L
271207339 CHEVRON DELO 400 LE Synthetic SAE 5W-40 3,78L
222210339 CHEVRON DELO 400 LE 10W-30 3,78L
222210448 CHEVRON DELO 400 LE 10W-30 19L
222220721 CHEVRON DELO 400 LE 15W-40 946 mL
222220463 CHEVRON DELO 400 LE 15W-40 3,78L
222220478 CHEVRON DELO 400 LE 15W-40 9,946L
222220448 CHEVRON DELO 400 LE 15W-40 19L
224615463 CHEVRON DELO 400 SD SAE 15W-30 3,78L
224615448 CHEVRON DELO 400 SD SAE 15W-30 19L
235101448 CHEVRON DELO 400 Multigrade SAE 15W-40 19L
235101339 CHEVRON DELO 400 Multigrade SAE 15W-40 3,78L
235101721 CHEVRON DELO 400 Multigrade SAE 15W-40 946mL
271220722 CHEVRON DELO 400 XLE Synthetic Blend SAE 10W-30 946mL
271220448 CHEVRON DELO 400 XLE Synthetic Blend SAE 10W-30 19L
271220339 CHEVRON DELO 400 XLE Synthetic Blend SAE 10W-30 3,78L
Вариант №2
235101721           CHEVRON  DELO ® 400  15W-40 CI-4 plus       0.946л.
01020013           CHEVRON  DELO ® 400  15W-40 CI-4 plus       3.785л.
01020012           CHEVRON  DELO ® 400  15W-40 CI-4 plus      18.9л.
235101981           CHEVRON  DELO ® 400  15W-40 CI-4 plus      208л.
01020012           CHEVRON  DELO ® 400 SD 15W-30 CJ-4 plus      18.9л.
01020011           CHEVRON  DELO ® 400 SD 15W-30 CJ-4 plus      208л.
01020013           CHEVRON  DELO ® 400 SD 15W-30 CJ-4 plus   3.785л.
235105339           CHEVRON  Delo®     400 MGX SAE 15W-40         3.785л.
235105428           CHEVRON  Delo®     400 MGX SAE 15W-40       18.9л.
235105981           CHEVRON  Delo®     400 MGX SAE 15W-40       208л.
8888880           CHEVRON DELO XLD  MULTIGRADE SEMI SYNTHETIC 10W-40     20л.
8888881           CHEVRON DELO XLD  MULTIGRADE SEMI SYNTHETIC 10W-40    208л.
271201448           CHEVRON URSA  SUPERPLUS  EC 15W-40    18.9л.
271201981           CHEVRON URSA  SUPERPLUS  EC 15W-40    208л.
222210448           DELO 400 LE 10W-30  18.9л.
222210981           DELO 400 LE 10W-30  208л.
222210339           DELO 400 LE 10W-30  3.785л.
01020048           DELO 400 LE 15W-40  0,946л.
222220448           DELO 400 LE 15W-40  18.9л.
222220981           DELO 400 LE 15W-40  208л.
222220463           DELO 400 LE 15W-40  3.785л.
271210448           DELO 400 LE SYNTHETIC 5W-30  18.9л.
271210981           DELO 400 LE SYNTHETIC 5W-30  208л.
271210339           DELO 400 LE SYNTHETIC 5W-30  3.785л.
271207448           DELO 400 LE SYNTHETIC 5W-40  18.9л.
271207981           DELO 400 LE SYNTHETIC 5W-40  208л.
271207339           DELO 400 LE SYNTHETIC 5W-40  3.785л.
235101721           DELO 400 MULTIGRADE 15W-40  0.946л.
235101448           DELO 400 MULTIGRADE 15W-40  18.9л.
235101981           DELO 400 MULTIGRADE 15W-40  208л.
235101339           DELO 400 MULTIGRADE 15W-40  3.785л.
01020051           DELO 400 SAE 10W  18.9л.
235109981           DELO 400 SAE 10W  208л.
01020051           DELO 400 SAE 40  18.9л.
235195351           DELO 400 SYNTHETIC 0W-30  0.946л.
235195448           DELO 400 SYNTHETIC 0W-30  18.9л.
235195981           DELO 400 SYNTHETIC 0W-30  208л.
235195389           DELO 400 SYNTHETIC 0W-30  3.785л.
01020047           DELO 400 XLE  Synblend 10W-30  18.9л.
01020007           DELO 400 XLE  Synblend 10W-30  208л.
01020048           DELO 400 XLE  Synblend 10W-30  3.785л.
254591542           CHEVRON BLACK PEARL GREASE  EP 2     397г
255659642           CHEVRON MOLY GREASE        EP NLGI 1     397г
01020290           CHEVRON MOLY GREASE        EP NLGI 1    182кг
255660642           CHEVRON MOLY GREASE        EP NLGI 2     397г
01020295           CHEVRON MOLY GREASE        EP NLGI 2    182кг
255660451           CHEVRON MOLY GREASE        EP NLGI 2   15.9кг
274509451           CHEVRON MULTIFAK                EP 00   15.9кг
01020303           CHEVRON MULTIFAK                EP 1     397г
01020302           CHEVRON MULTIFAK                EP 1   15.9кг
274503642           CHEVRON MULTIFAK                EP 2     397г
274503451           CHEVRON MULTIFAK                EP 2   15.9кг
01020218           CHEVRON RPM ARCTIC GREASE        EP NLGI 1    397г
01020218           CHEVRON RYKOTAC  GREASE        EP     397г
254504642           CHEVRON SRI GREASE        NLGI 2     397г
277111642           CHEVRON STARPLEX                EP 2     397г
250186642           CHEVRON ULTI-PLEX GREASE   EP NLGI 1     397г
250185642           CHEVRON ULTI-PLEX GREASE   EP NLGI 2     397г
250188642           CHEVRON ULTI-PLEX GREASE SYNT EP   1.5   397г
01020250           CHEVRON ULTRA-DUTY         EP NLGI 0     397г
238012642           CHEVRON ULTRA-DUTY         EP NLGI 1     397г
238011642           CHEVRON ULTRA-DUTY         EP NLGI 2     397г
235212451           DELO GREASE EP NLGI 00  15.9кг.
01020218           DELO GREASE EP NLGI 1  397г.
235208451           DELO GREASE EP NLGI 2  15.9кг.
235208642           DELO GREASE EP NLGI 2  397г.
01020218           DELO GREASE ESI  397г.
222206642           DELO HEAVY DUTY  EP 2  397г.
222231451           DELO HEAVY DUTY MOLY 3%  EP 2  15,9кг.
01020205           CHEVRON 2 CYCLE OIL             TC-W3     18,9л
01020204           CHEVRON 2 CYCLE OIL             TC-W3  0.946л
01020151           CHEVRON SUPREME 100% SYNTHETIC   5/20  0.946л
01020151           CHEVRON SUPREME 100% SYNTHETIC   5/30  0.946л
01020158           CHEVRON SUPREME 100% SYNTHETIC   5/40  0.946л
01020152           CHEVRON SUPREME 100% SYNTHETIC  10/30  0.946л
01020123           CHEVRON SUPREME HI MI MOTOR OIL         5/30  0.946л
01020123           CHEVRON SUPREME HI MI MOTOR OIL       10/30  0.946л
01020123           CHEVRON SUPREME HI MI MOTOR OIL       10/40  0.946л
01020142           CHEVRON SUPREME MOTOR OIL          30  0.946л
01020103           CHEVRON SUPREME MOTOR OIL        5/20  0.946л
01020103           CHEVRON SUPREME MOTOR OIL        5/30  0.946л
01020102           CHEVRON SUPREME MOTOR OIL        5/30  3.785л
01020113           CHEVRON SUPREME MOTOR OIL       10/30  0.946л
01020111           CHEVRON SUPREME MOTOR OIL       10/30  208л.
01020112           CHEVRON SUPREME MOTOR OIL       10/30  3.785л
01020122           CHEVRON SUPREME MOTOR OIL       10/30  4,73 л
01020123           CHEVRON SUPREME MOTOR OIL       10/40  0.946л
01020122           CHEVRON SUPREME MOTOR OIL       10/40  3.785л
01020122           CHEVRON SUPREME MOTOR OIL       10/40  4,73 л
01020133           CHEVRON SUPREME MOTOR OIL       20/50  0.946л
01020132           CHEVRON SUPREME MOTOR OIL       20/50  3.785л
01020132           CHEVRON SUPREME MOTOR OIL       20/50  4,73 л
01020152           CHEVRON SUPREME SYNTHETIC BLEND M/O   5/30  0.946л
01020152           CHEVRON SUPREME SYNTHETIC BLEND M/O 10/30  0.946л
SAIC-GM Full Synthetic 0W-20 Chevron-Tianjin Made in China
SAIC-GM Full Synthetic 5W-30 Chevron-Tianjin Made in China
Chevron Delo 400 Syn XSP 5W-30 API CK-4
Chevron Delo LE 400 5W-40
Chevron Delo LE 400 5W-30
Chevron Havoline ProDS 0W-20 API SN Dexos1 Gen2
Лабораторные анализы - Отработки - UOAoil-club.ru
Chevron Havoline ProDS 0W-20 API SN Dexos1 Gen2 отработка на Toyota Rav4 после 9460км
Chevron Delo 400LE Synthetic 5W-40 отработка на Dodge Ram 2500 после 8200 км.
Chevron Delo 400 XLE Synblend 10W-30 CJ-4 отработка на Ford Focus ST после 8000 км.
Chevron Delo 400 LE Synthetic 5W-40 отработка на Dodge Ram после 16790 км.
На официальной странице петролюба http://petrolube.ru/index.php?fuseaction=c...g&mod_id=62 написано, что Chevron Supreme Motor Oil 10W-40 содержит дисульфид молибдена - откуда инфа?(на канистре ничего нет)
Я пару лет назад этих строк на петролюбе испугался и не стал лить Chevron залил вальволайн :diablo: Оказалось что нет там никакого десульфида молибдена, покрайнеймере сейчас. Molybdenium как во всех маслах в составе конечно есть - но это не в качестве присадки. Aluminium, boron, iron итд, Тоесть химические элементы которые постоянно содержатся в масле в небольшом количестве.
Спасибо за разъяснение - я тоже испугался:diablo:
проехал 2000 км - пока даже не потемнело(до этого shell и хадо темнели довольно сильно) - это хорошо?
borts ты наверное после зимы путаешься, зимой масло сильнее темнеет, летом медленно. Хотя у вас в Азове зима не суровая.
Тут в базе отличия имхо. Хотел щелочное сравнить, Shell не удосужился даже щелочное число обозначить своего Shell Helix Plus 10W40.
По крайней мере это не повод сливать Шеврон и переходить на другой бренд. Горловина у тебя сфоткана, продолжай ездить и сравнивай реальное состояние с фоткой, если появятся отложения - тогда уже будем делать выводы.
Вообще потемнение масел стараюсь упускать - слишком субьективный параметр и зависит от многих сторонних факторов...
да вот летом заливал хадо(перед шевроном) - потемнело до состояния жжёного дерева...
Даташиты на масла Chevron
https://www.cbest.chevron.com/msdsServer/co...ginPage=true%22
Вдруг кому интересно будет из чего какое масло состоит.
Вот что залил Chevron Supreme 5W30 технология ISOSYN
API SM ILSAC GF-4 Минералка второй группы. Highly Refined Mineral Oil
625р за галон - 3.8 литров.
Масло на цвет какое то мутноватое желтое с зеленым отливом. Пахнет как все масла без резких запахов.
Что понравилось - однозначно тише работает чем Neste City Pro 5W40 :clapping: Вообщем узнается родное двигателю американо-азиатское масло :good: А возможно и меньшая вязкость сьиграла роль.
По Chevron Supreme 5W30 Isosyn. Сегодня покатался по магазинам и послушал.
В общем последствия того что я сменил вязкость с 14 при 100С Neste, на 10 при 100С Chevron. А может последствия того, что я поменял бренд и вязкость здесь не причем. Двигатель тише работает на ХХ! Меньше посторонних звуков и звонов. Громкий изначально 3s-fe стал "тикать".
torcon , отличный выбор, коллега ! :clapping::good:
Тоже при следующей смене масла залью Шеврон 5-30, послушаем как будет работать движок.
Не доверяйте своему слуху, запишите на диктофон\видеокамеру звук двигателя при одинаковой температуре и сравните.
Renat, не ленись, запиши пока не сменил масло.
torcon беднота одолела что на такие масла перешёл? :clapping:
Javen тут слуху доверять не нужно что бы понять :clapping: Разница очень существенна... С другой стороны документально это подтвердить для остальных не мешало бы... Тут я свалял дурака, не ожидал просто на перед что будет такая существенная разница.
Zver просто экономической целесообразности нет, я сейчас буду менять масло через каждую 1000км что бы промыть двигатель пятиминутками Liqui-moly, смысл мне покупать Valvoline Synpower по 2000р? :good: Хотя есть и финансовая сторона, на самом деле стало влом платить 1800р за канистру. Запросто перейду на Шеврон или Петроканаду - если в течении времени на себе удостоверюсь что это масло стоит лить. Всмысле поведение, угар, потение, замерзаемость итд. В общем если понравиться.
Javen учтем на будущее, запишу на фотик у него вроде качество записи неплохое.
За завтра еще 1 тыс. км намотаю и буду менять!
