Масла Chevron
Масла Chevron
Официальный сайт: http://www.chevronlubricants.com/
Артикулы коды для заказа в инетмагазинах
Вариант № 1
223501482 - Chevron Havoline Motor Oil 0W-20 0,946L
076568796280 - Chevron Havoline Motor Oil 5W-20 0,946L
223393721 - Chevron Havoline Motor Oil 5W-20", 0.946L
223502482 - Chevron Havoline ProDS Full Synthetic 5W-20, 0.946L
223503482 - Havoline ProDS Full Synthetic 5W-30, 0.946L
223394485 - Chevron Havoline Motor Oil 5W-30, 4.73L
223394533 - Chevron Havoline Motor Oil 5W-30, 4.73L
076568796297 - Chevron Havoline Motor Oil 5W-30 0,946L
223726482 -  Chevron Havoline ProDS Full Synthetic 5W-40, 0.946L
223504482 - Chevron Havoline ProDS Euro Full Synthetic 5W-40, 0.946L
223395533 - Chevron Havoline Motor Oil 10W-30, 4.73L
223395481 - Chevron Havoline Motor Oil 10W-30, 0.946L
223396485 - Chevron Havoline Motor Oil 10W-40, 4.73L
223396481 - Chevron Havoline Motor Oil 10W-40, 0.946L
220135721 Chevron Supreme Motor Oil SAE 5W-20 946mL
220013533 Chevron Supreme Motor Oil SAE 5W-30 3,78L
220013553 Chevron Supreme Motor Oil SAE 5W-30 4,83L
220013429 Chevron Supreme Motor Oil SAE 5W-30 3,78L
220013719 Chevron Supreme Motor Oil SAE 5W-30 946mL
220155719 Chevron Supreme Motor Oil SAE 10W-30 946mL
220155533 Chevron Supreme Motor Oil SAE 10W-30 4,83L
220059533 Chevron Supreme Motor Oil SAE 10W-40 4,83L
220059429 Chevron Supreme Motor Oil SAE 10W-40 3,78L
220059719 Chevron Supreme Motor Oil SAE 10W-40 946mL
220060719 Chevron Supreme Motor Oil SAE 20W-50 946mL
220060533 Chevron Supreme Motor Oil SAE 20W-50 3,78L
257001388 - Chevron Delo 400 Syn XSP 5W-30 3,785 л
257001448 - Chevron Delo 400 Syn XSP 5W-30 18,9 л
257001981 - Chevron Delo 400 Syn XSP 5W-30 208 л
235195389 CHEVRON DELO 400 Synthetic SAE 0W-30 3,78L
271210339 CHEVRON DELO 400 LE Synthetic SAE 5W-30 3,78L
271210448 CHEVRON DELO 400 LE Synthetic SAE 5W-30 19L
271207448 CHEVRON DELO 400 LE Synthetic SAE 5W-40 19L
271207339 CHEVRON DELO 400 LE Synthetic SAE 5W-40 3,78L
222210339 CHEVRON DELO 400 LE 10W-30 3,78L
222210448 CHEVRON DELO 400 LE 10W-30 19L
222220721 CHEVRON DELO 400 LE 15W-40 946 mL
222220463 CHEVRON DELO 400 LE 15W-40 3,78L
222220478 CHEVRON DELO 400 LE 15W-40 9,946L
222220448 CHEVRON DELO 400 LE 15W-40 19L
224615463 CHEVRON DELO 400 SD SAE 15W-30 3,78L
224615448 CHEVRON DELO 400 SD SAE 15W-30 19L
235101448 CHEVRON DELO 400 Multigrade SAE 15W-40 19L
235101339 CHEVRON DELO 400 Multigrade SAE 15W-40 3,78L
235101721 CHEVRON DELO 400 Multigrade SAE 15W-40 946mL
271220722 CHEVRON DELO 400 XLE Synthetic Blend SAE 10W-30 946mL
271220448 CHEVRON DELO 400 XLE Synthetic Blend SAE 10W-30 19L
271220339 CHEVRON DELO 400 XLE Synthetic Blend SAE 10W-30 3,78L
Вариант №2
235101721           CHEVRON  DELO ® 400  15W-40 CI-4 plus       0.946л.
01020013           CHEVRON  DELO ® 400  15W-40 CI-4 plus       3.785л.
01020012           CHEVRON  DELO ® 400  15W-40 CI-4 plus      18.9л.
235101981           CHEVRON  DELO ® 400  15W-40 CI-4 plus      208л.
01020012           CHEVRON  DELO ® 400 SD 15W-30 CJ-4 plus      18.9л.
01020011           CHEVRON  DELO ® 400 SD 15W-30 CJ-4 plus      208л.
01020013           CHEVRON  DELO ® 400 SD 15W-30 CJ-4 plus   3.785л.
235105339           CHEVRON  Delo®     400 MGX SAE 15W-40         3.785л.
235105428           CHEVRON  Delo®     400 MGX SAE 15W-40       18.9л.
235105981           CHEVRON  Delo®     400 MGX SAE 15W-40       208л.
8888880           CHEVRON DELO XLD  MULTIGRADE SEMI SYNTHETIC 10W-40     20л.
8888881           CHEVRON DELO XLD  MULTIGRADE SEMI SYNTHETIC 10W-40    208л.
271201448           CHEVRON URSA  SUPERPLUS  EC 15W-40    18.9л.
271201981           CHEVRON URSA  SUPERPLUS  EC 15W-40    208л.
222210448           DELO 400 LE 10W-30  18.9л.
222210981           DELO 400 LE 10W-30  208л.
222210339           DELO 400 LE 10W-30  3.785л.
01020048           DELO 400 LE 15W-40  0,946л.
222220448           DELO 400 LE 15W-40  18.9л.
222220981           DELO 400 LE 15W-40  208л.
222220463           DELO 400 LE 15W-40  3.785л.
271210448           DELO 400 LE SYNTHETIC 5W-30  18.9л.
271210981           DELO 400 LE SYNTHETIC 5W-30  208л.
271210339           DELO 400 LE SYNTHETIC 5W-30  3.785л.
271207448           DELO 400 LE SYNTHETIC 5W-40  18.9л.
271207981           DELO 400 LE SYNTHETIC 5W-40  208л.
271207339           DELO 400 LE SYNTHETIC 5W-40  3.785л.
235101721           DELO 400 MULTIGRADE 15W-40  0.946л.
235101448           DELO 400 MULTIGRADE 15W-40  18.9л.
235101981           DELO 400 MULTIGRADE 15W-40  208л.
235101339           DELO 400 MULTIGRADE 15W-40  3.785л.
01020051           DELO 400 SAE 10W  18.9л.
235109981           DELO 400 SAE 10W  208л.
01020051           DELO 400 SAE 40  18.9л.
235195351           DELO 400 SYNTHETIC 0W-30  0.946л.
235195448           DELO 400 SYNTHETIC 0W-30  18.9л.
235195981           DELO 400 SYNTHETIC 0W-30  208л.
235195389           DELO 400 SYNTHETIC 0W-30  3.785л.
01020047           DELO 400 XLE  Synblend 10W-30  18.9л.
01020007           DELO 400 XLE  Synblend 10W-30  208л.
01020048           DELO 400 XLE  Synblend 10W-30  3.785л.
254591542           CHEVRON BLACK PEARL GREASE  EP 2     397г
255659642           CHEVRON MOLY GREASE        EP NLGI 1     397г
01020290           CHEVRON MOLY GREASE        EP NLGI 1    182кг
255660642           CHEVRON MOLY GREASE        EP NLGI 2     397г
01020295           CHEVRON MOLY GREASE        EP NLGI 2    182кг
255660451           CHEVRON MOLY GREASE        EP NLGI 2   15.9кг
274509451           CHEVRON MULTIFAK                EP 00   15.9кг
01020303           CHEVRON MULTIFAK                EP 1     397г
01020302           CHEVRON MULTIFAK                EP 1   15.9кг
274503642           CHEVRON MULTIFAK                EP 2     397г
274503451           CHEVRON MULTIFAK                EP 2   15.9кг
01020218           CHEVRON RPM ARCTIC GREASE        EP NLGI 1    397г
01020218           CHEVRON RYKOTAC  GREASE        EP     397г
254504642           CHEVRON SRI GREASE        NLGI 2     397г
277111642           CHEVRON STARPLEX                EP 2     397г
250186642           CHEVRON ULTI-PLEX GREASE   EP NLGI 1     397г
250185642           CHEVRON ULTI-PLEX GREASE   EP NLGI 2     397г
250188642           CHEVRON ULTI-PLEX GREASE SYNT EP   1.5   397г
01020250           CHEVRON ULTRA-DUTY         EP NLGI 0     397г
238012642           CHEVRON ULTRA-DUTY         EP NLGI 1     397г
238011642           CHEVRON ULTRA-DUTY         EP NLGI 2     397г
235212451           DELO GREASE EP NLGI 00  15.9кг.
01020218           DELO GREASE EP NLGI 1  397г.
235208451           DELO GREASE EP NLGI 2  15.9кг.
235208642           DELO GREASE EP NLGI 2  397г.
01020218           DELO GREASE ESI  397г.
222206642           DELO HEAVY DUTY  EP 2  397г.
222231451           DELO HEAVY DUTY MOLY 3%  EP 2  15,9кг.
01020205           CHEVRON 2 CYCLE OIL             TC-W3     18,9л
01020204           CHEVRON 2 CYCLE OIL             TC-W3  0.946л
01020151           CHEVRON SUPREME 100% SYNTHETIC   5/20  0.946л
01020151           CHEVRON SUPREME 100% SYNTHETIC   5/30  0.946л
01020158           CHEVRON SUPREME 100% SYNTHETIC   5/40  0.946л
01020152           CHEVRON SUPREME 100% SYNTHETIC  10/30  0.946л
01020123           CHEVRON SUPREME HI MI MOTOR OIL         5/30  0.946л
01020123           CHEVRON SUPREME HI MI MOTOR OIL       10/30  0.946л
01020123           CHEVRON SUPREME HI MI MOTOR OIL       10/40  0.946л
01020142           CHEVRON SUPREME MOTOR OIL          30  0.946л
01020103           CHEVRON SUPREME MOTOR OIL        5/20  0.946л
01020103           CHEVRON SUPREME MOTOR OIL        5/30  0.946л
01020102           CHEVRON SUPREME MOTOR OIL        5/30  3.785л
01020113           CHEVRON SUPREME MOTOR OIL       10/30  0.946л
01020111           CHEVRON SUPREME MOTOR OIL       10/30  208л.
01020112           CHEVRON SUPREME MOTOR OIL       10/30  3.785л
01020122           CHEVRON SUPREME MOTOR OIL       10/30  4,73 л
01020123           CHEVRON SUPREME MOTOR OIL       10/40  0.946л
01020122           CHEVRON SUPREME MOTOR OIL       10/40  3.785л
01020122           CHEVRON SUPREME MOTOR OIL       10/40  4,73 л
01020133           CHEVRON SUPREME MOTOR OIL       20/50  0.946л
01020132           CHEVRON SUPREME MOTOR OIL       20/50  3.785л
01020132           CHEVRON SUPREME MOTOR OIL       20/50  4,73 л
01020152           CHEVRON SUPREME SYNTHETIC BLEND M/O   5/30  0.946л
01020152           CHEVRON SUPREME SYNTHETIC BLEND M/O 10/30  0.946л
SAIC-GM Full Synthetic 0W-20 Chevron-Tianjin Made in China
SAIC-GM Full Synthetic 5W-30 Chevron-Tianjin Made in China
Chevron Delo 400 Syn XSP 5W-30 API CK-4
Chevron Delo LE 400 5W-40
Chevron Delo LE 400 5W-30
Chevron Havoline ProDS 0W-20 API SN Dexos1 Gen2
Лабораторные анализы - Отработки - UOAoil-club.ru
Chevron Havoline ProDS 0W-20 API SN Dexos1 Gen2 отработка на Toyota Rav4 после 9460км
Chevron Delo 400LE Synthetic 5W-40 отработка на Dodge Ram 2500 после 8200 км.
Chevron Delo 400 XLE Synblend 10W-30 CJ-4 отработка на Ford Focus ST после 8000 км.
Chevron Delo 400 LE Synthetic 5W-40 отработка на Dodge Ram после 16790 км.
8 часов назад, ss333 сказал:
13 часов назад, SL1 сказал:
то он говорил, что группа II в моторном масле имеет не только преимущества перед I, но и недостатки. При перекате, перегреве и т.п. она больше подвержена образованию sludge, если я правильно помню, желируется в сгустках. Применять ее как базу PCMO в чистом виде не так уж и хорошо. Возможно, это тоже аргумент за смесь I+III (I+II+).
Этот момент не уловил в его постах, а если и прочел, мог не придать данному посту нужное внимание:unknw:, на битоге встречал пост, где SonofJoe ратовал за II группу, как идеал базы, или я, так смог прочесть в гуглопереводе, или хотел именно так, читать пост:unknw:, внутрене для себя, начинаю понемногу считать, что 2гр. - это золотая середина
Каждому свое. Вопрос цены. Гр.3 всяко лучше, чем гр.2. Смеси могут быть 1+3, 2+3, 1+2, цена и позиционирование соответствующие. Есть очень хорошая минералка, особенно моноградная и авиационная, но это для теплых регионов.
II хороша тем, что в ней нет ни чего лишнего, только нейтральные парафины. Этим же она и плоха, т.к. у парафинов хуже смазывающая и моющая способность по сравнению с гр. 1 и 3. Есть проблема желирования при перекатах. Многое решают присадки.
14 минут назад, SL1 сказал:
Не совсем так. Смазывающая способность падает с ростом номера группы. То есть, самая хорошая смазывающая способность у минералки - у первой группы. У II хуже, у III ещё хуже, у IV совсем швах. То же самое и с растворяющей способностью. Именно поэтому пакеты присадок поставляются замешанные в минералке.
3 hours ago, Dumus said:
Вы правда считаете, что например эстеры смазывают хуже чем минералка?
Зависит от полярности (NPI) эстера.
Высокополярные эстеры не хуже сочетания "гр.II + противоизносный пакет".
PS
А вообще - важна готовая композиция масла (как тут принято говорить "крепкая база"
- это совсем бестолково в "отрыве" от пакета).
Ну и вопрос целесообразности в каждом случае.
1 час назад, GVA сказал:
5 часов назад, Dumus сказал:
PS
Если уж на то пошло, то есть высокомолекулярные эстеры, которые свойства эстеров не проявляют, т.к. доминируют другие группы в молекуле. А есть mPAO которое по всем параметрам намного лучше гр III и II.
Изменено пользователем SL1
10 часов назад, SL1 сказал:
Здесь встретил:  из не оф. источника:unknw:, цитата: "В частности, парафины обладают хорошей стабильностью к окислению, однако при низких температурах она сводится «на нет». Нафтеновые кислоты при высокой температуре образуют в масле осадок. Ароматические углеводороды отрицательно влияют на окислительную стабильность, а также смазывающую способность. Кроме этого, они образуют лаковые отложения."
Можно ли, ваш источник, текстов прочесть, для уточнений или, дополнить ваш пост:unknw:
Изменено пользователем ss333
1 час назад, ss333 сказал:
Насчет недостатков гр. II, в том числе по сравнению с гр.III, у SAE20 было. Остальное на уровне обыденных очевидных истин. Почитайте про отличия гр. III (изопарафинов) от II (линейных парфинов).
1 час назад, SL1 сказал:
Ищу плюсы во 2й гр.:unknw:, в ней должны быть плюсы,  как есть и минусы в  III гр, переходный период, от начитки минеральных тем:pardon:, поделитесь ссылками, если есть по парафинам, по их классификации от гугления, не удалось напасть на стоящий материал:pardon:
Данная картинка подстегнула на думы о 2й  группе:
22 минуты назад, ss333 сказал:
Искать плюсы между методами очистки нефти , это как тянуть резину , математика проста , чем чище база тем выше ИВ , в тоже время чем она чище = тем она более пустая , лучше очишина от парафинов , выше трение , меньше защита от износа , но в тоже время более низкая температура потери текучести у более чистой базы без парафинов , кроме того метод очистки , рафинирование или гидрокрекинг отличается по остатку серы , при очтстке нефти методом рафинирования серы остаётся более 0.3% = 3000ррм , при методе гидрокрекинг серы менее 0.3% = 3000ррм , сера с одной стороны является противоизноской как ZDDP , с другой стороны при поподании конденсата в картер + температура = кислота , что приводит к более быстрому старению самого масла , его разрушения и образования отложений внутри двигателя , в камере сгорания и на кольцах поршней
ss333  Здесь такие обсуждения, наверное оффтоп.
На форуме есть соответствующие темы по маслам, можно там посмотреть. А вообще, почитайте книжки в google books. Lubricants and Lubrication, Theo Mang, Wilfried Dresel рекомендую.
18 часов назад, ss333 сказал:
Именно ароматика и даёт лучшую смазывающую способность минералке. И именно она ухудшает окислительную стабильность. Индустрия выбрала стабильность.
05.06.2020 в 11:11, Dumus сказал:
Texacoman Вы правда считаете, что например эстеры смазывают хуже чем минералка?
Я честно сказать "вещал" только о I, II, III, IV группе.
Изменено пользователем Texacoman
22 минуты назад, Александр-34rus сказал:
Texacoman  подскажите пожалуйста,а какие масла у шеврона на 2 группе?
А кто ж его знает? Это коммерческая тайна. Можно только догадываться, например, по их буклетам в которых они предлагают свою вторую группу покупателям.
Но... возможны варианты ))
1 час назад, Texacoman сказал:
может от рынков сбыта/пр-ва (георафически) зависят варианты:unknw:
