Масла Chevron
Масла Chevron
Официальный сайт: http://www.chevronlubricants.com/
Артикулы коды для заказа в инетмагазинах
Вариант № 1
223501482 - Chevron Havoline Motor Oil 0W-20 0,946L
076568796280 - Chevron Havoline Motor Oil 5W-20 0,946L
223393721 - Chevron Havoline Motor Oil 5W-20", 0.946L
223502482 - Chevron Havoline ProDS Full Synthetic 5W-20, 0.946L
223503482 - Havoline ProDS Full Synthetic 5W-30, 0.946L
223394485 - Chevron Havoline Motor Oil 5W-30, 4.73L
223394533 - Chevron Havoline Motor Oil 5W-30, 4.73L
076568796297 - Chevron Havoline Motor Oil 5W-30 0,946L
223726482 -  Chevron Havoline ProDS Full Synthetic 5W-40, 0.946L
223504482 - Chevron Havoline ProDS Euro Full Synthetic 5W-40, 0.946L
223395533 - Chevron Havoline Motor Oil 10W-30, 4.73L
223395481 - Chevron Havoline Motor Oil 10W-30, 0.946L
223396485 - Chevron Havoline Motor Oil 10W-40, 4.73L
223396481 - Chevron Havoline Motor Oil 10W-40, 0.946L
220135721 Chevron Supreme Motor Oil SAE 5W-20 946mL
220013533 Chevron Supreme Motor Oil SAE 5W-30 3,78L
220013553 Chevron Supreme Motor Oil SAE 5W-30 4,83L
220013429 Chevron Supreme Motor Oil SAE 5W-30 3,78L
220013719 Chevron Supreme Motor Oil SAE 5W-30 946mL
220155719 Chevron Supreme Motor Oil SAE 10W-30 946mL
220155533 Chevron Supreme Motor Oil SAE 10W-30 4,83L
220059533 Chevron Supreme Motor Oil SAE 10W-40 4,83L
220059429 Chevron Supreme Motor Oil SAE 10W-40 3,78L
220059719 Chevron Supreme Motor Oil SAE 10W-40 946mL
220060719 Chevron Supreme Motor Oil SAE 20W-50 946mL
220060533 Chevron Supreme Motor Oil SAE 20W-50 3,78L
257001388 - Chevron Delo 400 Syn XSP 5W-30 3,785 л
257001448 - Chevron Delo 400 Syn XSP 5W-30 18,9 л
257001981 - Chevron Delo 400 Syn XSP 5W-30 208 л
235195389 CHEVRON DELO 400 Synthetic SAE 0W-30 3,78L
271210339 CHEVRON DELO 400 LE Synthetic SAE 5W-30 3,78L
271210448 CHEVRON DELO 400 LE Synthetic SAE 5W-30 19L
271207448 CHEVRON DELO 400 LE Synthetic SAE 5W-40 19L
271207339 CHEVRON DELO 400 LE Synthetic SAE 5W-40 3,78L
222210339 CHEVRON DELO 400 LE 10W-30 3,78L
222210448 CHEVRON DELO 400 LE 10W-30 19L
222220721 CHEVRON DELO 400 LE 15W-40 946 mL
222220463 CHEVRON DELO 400 LE 15W-40 3,78L
222220478 CHEVRON DELO 400 LE 15W-40 9,946L
222220448 CHEVRON DELO 400 LE 15W-40 19L
224615463 CHEVRON DELO 400 SD SAE 15W-30 3,78L
224615448 CHEVRON DELO 400 SD SAE 15W-30 19L
235101448 CHEVRON DELO 400 Multigrade SAE 15W-40 19L
235101339 CHEVRON DELO 400 Multigrade SAE 15W-40 3,78L
235101721 CHEVRON DELO 400 Multigrade SAE 15W-40 946mL
271220722 CHEVRON DELO 400 XLE Synthetic Blend SAE 10W-30 946mL
271220448 CHEVRON DELO 400 XLE Synthetic Blend SAE 10W-30 19L
271220339 CHEVRON DELO 400 XLE Synthetic Blend SAE 10W-30 3,78L
Вариант №2
235101721           CHEVRON  DELO ® 400  15W-40 CI-4 plus       0.946л.
01020013           CHEVRON  DELO ® 400  15W-40 CI-4 plus       3.785л.
01020012           CHEVRON  DELO ® 400  15W-40 CI-4 plus      18.9л.
235101981           CHEVRON  DELO ® 400  15W-40 CI-4 plus      208л.
01020012           CHEVRON  DELO ® 400 SD 15W-30 CJ-4 plus      18.9л.
01020011           CHEVRON  DELO ® 400 SD 15W-30 CJ-4 plus      208л.
01020013           CHEVRON  DELO ® 400 SD 15W-30 CJ-4 plus   3.785л.
235105339           CHEVRON  Delo®     400 MGX SAE 15W-40         3.785л.
235105428           CHEVRON  Delo®     400 MGX SAE 15W-40       18.9л.
235105981           CHEVRON  Delo®     400 MGX SAE 15W-40       208л.
8888880           CHEVRON DELO XLD  MULTIGRADE SEMI SYNTHETIC 10W-40     20л.
8888881           CHEVRON DELO XLD  MULTIGRADE SEMI SYNTHETIC 10W-40    208л.
271201448           CHEVRON URSA  SUPERPLUS  EC 15W-40    18.9л.
271201981           CHEVRON URSA  SUPERPLUS  EC 15W-40    208л.
222210448           DELO 400 LE 10W-30  18.9л.
222210981           DELO 400 LE 10W-30  208л.
222210339           DELO 400 LE 10W-30  3.785л.
01020048           DELO 400 LE 15W-40  0,946л.
222220448           DELO 400 LE 15W-40  18.9л.
222220981           DELO 400 LE 15W-40  208л.
222220463           DELO 400 LE 15W-40  3.785л.
271210448           DELO 400 LE SYNTHETIC 5W-30  18.9л.
271210981           DELO 400 LE SYNTHETIC 5W-30  208л.
271210339           DELO 400 LE SYNTHETIC 5W-30  3.785л.
271207448           DELO 400 LE SYNTHETIC 5W-40  18.9л.
271207981           DELO 400 LE SYNTHETIC 5W-40  208л.
271207339           DELO 400 LE SYNTHETIC 5W-40  3.785л.
235101721           DELO 400 MULTIGRADE 15W-40  0.946л.
235101448           DELO 400 MULTIGRADE 15W-40  18.9л.
235101981           DELO 400 MULTIGRADE 15W-40  208л.
235101339           DELO 400 MULTIGRADE 15W-40  3.785л.
01020051           DELO 400 SAE 10W  18.9л.
235109981           DELO 400 SAE 10W  208л.
01020051           DELO 400 SAE 40  18.9л.
235195351           DELO 400 SYNTHETIC 0W-30  0.946л.
235195448           DELO 400 SYNTHETIC 0W-30  18.9л.
235195981           DELO 400 SYNTHETIC 0W-30  208л.
235195389           DELO 400 SYNTHETIC 0W-30  3.785л.
01020047           DELO 400 XLE  Synblend 10W-30  18.9л.
01020007           DELO 400 XLE  Synblend 10W-30  208л.
01020048           DELO 400 XLE  Synblend 10W-30  3.785л.
254591542           CHEVRON BLACK PEARL GREASE  EP 2     397г
255659642           CHEVRON MOLY GREASE        EP NLGI 1     397г
01020290           CHEVRON MOLY GREASE        EP NLGI 1    182кг
255660642           CHEVRON MOLY GREASE        EP NLGI 2     397г
01020295           CHEVRON MOLY GREASE        EP NLGI 2    182кг
255660451           CHEVRON MOLY GREASE        EP NLGI 2   15.9кг
274509451           CHEVRON MULTIFAK                EP 00   15.9кг
01020303           CHEVRON MULTIFAK                EP 1     397г
01020302           CHEVRON MULTIFAK                EP 1   15.9кг
274503642           CHEVRON MULTIFAK                EP 2     397г
274503451           CHEVRON MULTIFAK                EP 2   15.9кг
01020218           CHEVRON RPM ARCTIC GREASE        EP NLGI 1    397г
01020218           CHEVRON RYKOTAC  GREASE        EP     397г
254504642           CHEVRON SRI GREASE        NLGI 2     397г
277111642           CHEVRON STARPLEX                EP 2     397г
250186642           CHEVRON ULTI-PLEX GREASE   EP NLGI 1     397г
250185642           CHEVRON ULTI-PLEX GREASE   EP NLGI 2     397г
250188642           CHEVRON ULTI-PLEX GREASE SYNT EP   1.5   397г
01020250           CHEVRON ULTRA-DUTY         EP NLGI 0     397г
238012642           CHEVRON ULTRA-DUTY         EP NLGI 1     397г
238011642           CHEVRON ULTRA-DUTY         EP NLGI 2     397г
235212451           DELO GREASE EP NLGI 00  15.9кг.
01020218           DELO GREASE EP NLGI 1  397г.
235208451           DELO GREASE EP NLGI 2  15.9кг.
235208642           DELO GREASE EP NLGI 2  397г.
01020218           DELO GREASE ESI  397г.
222206642           DELO HEAVY DUTY  EP 2  397г.
222231451           DELO HEAVY DUTY MOLY 3%  EP 2  15,9кг.
01020205           CHEVRON 2 CYCLE OIL             TC-W3     18,9л
01020204           CHEVRON 2 CYCLE OIL             TC-W3  0.946л
01020151           CHEVRON SUPREME 100% SYNTHETIC   5/20  0.946л
01020151           CHEVRON SUPREME 100% SYNTHETIC   5/30  0.946л
01020158           CHEVRON SUPREME 100% SYNTHETIC   5/40  0.946л
01020152           CHEVRON SUPREME 100% SYNTHETIC  10/30  0.946л
01020123           CHEVRON SUPREME HI MI MOTOR OIL         5/30  0.946л
01020123           CHEVRON SUPREME HI MI MOTOR OIL       10/30  0.946л
01020123           CHEVRON SUPREME HI MI MOTOR OIL       10/40  0.946л
01020142           CHEVRON SUPREME MOTOR OIL          30  0.946л
01020103           CHEVRON SUPREME MOTOR OIL        5/20  0.946л
01020103           CHEVRON SUPREME MOTOR OIL        5/30  0.946л
01020102           CHEVRON SUPREME MOTOR OIL        5/30  3.785л
01020113           CHEVRON SUPREME MOTOR OIL       10/30  0.946л
01020111           CHEVRON SUPREME MOTOR OIL       10/30  208л.
01020112           CHEVRON SUPREME MOTOR OIL       10/30  3.785л
01020122           CHEVRON SUPREME MOTOR OIL       10/30  4,73 л
01020123           CHEVRON SUPREME MOTOR OIL       10/40  0.946л
01020122           CHEVRON SUPREME MOTOR OIL       10/40  3.785л
01020122           CHEVRON SUPREME MOTOR OIL       10/40  4,73 л
01020133           CHEVRON SUPREME MOTOR OIL       20/50  0.946л
01020132           CHEVRON SUPREME MOTOR OIL       20/50  3.785л
01020132           CHEVRON SUPREME MOTOR OIL       20/50  4,73 л
01020152           CHEVRON SUPREME SYNTHETIC BLEND M/O   5/30  0.946л
01020152           CHEVRON SUPREME SYNTHETIC BLEND M/O 10/30  0.946л
SAIC-GM Full Synthetic 0W-20 Chevron-Tianjin Made in China
SAIC-GM Full Synthetic 5W-30 Chevron-Tianjin Made in China
Chevron Delo 400 Syn XSP 5W-30 API CK-4
Chevron Delo LE 400 5W-40
Chevron Delo LE 400 5W-30
Chevron Havoline ProDS 0W-20 API SN Dexos1 Gen2
Лабораторные анализы - Отработки - UOAoil-club.ru
Chevron Havoline ProDS 0W-20 API SN Dexos1 Gen2 отработка на Toyota Rav4 после 9460км
Chevron Delo 400LE Synthetic 5W-40 отработка на Dodge Ram 2500 после 8200 км.
Chevron Delo 400 XLE Synblend 10W-30 CJ-4 отработка на Ford Focus ST после 8000 км.
Chevron Delo 400 LE Synthetic 5W-40 отработка на Dodge Ram после 16790 км.
, ключевое слово откатал в Питере - где зимой слякоть и грязь как у нас в конце марта...
В радиусе километров пятидесяти от СПб на северном направлении можешь легко словить от -20С до -30С...
Едещь с дачи зимой и видишь как при подъезде к городу поднимается температура воздуха на дисплее
Нет никаких ошибок?
Chevron Delo LE 400 5W-40 свежее
CCS -30C - 5 877
Это входит в SAE 5W-40
а это замерял отдельно
MRV -35C - 30 407 (норматив 60 000)
CCS -35C - 11 874 (норматив 6 200)
, а на ролике видел его? Вот такой вот контроль качества значит... :D
Давай я тебя тоже потроллю немного...
Народ святых производителей нет! Ravenol, Yacco, Mobil, Татнефть, Amtecol, Meguin, Лукойл, Orlen - я половины не назвал еще! Сколько их еще будет мама дорогая...
Если Delo 400 LE 5W-40 не показало такой результат который идет после 11 минут 9 секунд
http://www.youtube.com/watch?v=-SIbPvwkybU#t=659
значит все в порядке
Святых нет, но у кого то все в пределах статистической погрешности - а у кого то два локтя по карте плюс минус..
@sirantony, нет плюсов они стоят одинаково. Петра во всем лучше.
Вот ссылки на один и тот же известный магазин
Петра
Шеврон
При чем мне думается, что цена на Петру старая, до подорожания.
@sirantony, что вы меня все ссылками кормите то юлмарт то еще что нибудь?
Я тебе говорю про свою дислокацию Тюмень. Напиши ЛС нашему оф преду ES он тебе скажет сколько у него стоит Petro-Canada Supreme 5W-30 и я тебе гарантирую Chevron Supreme 5W-30 в наших магазинах или у офпредов, ты дешевле чем PC не найдешь...
Chevron Supreme 5W-30 и Petro-Canada Supreme 5W-30 - всегда шли рядом по цене - 600р за галлон. Сейчас доллар ростет, кто то сменил ценник, а кто то хочет просто избавится от залежалого товара который не продается годами (это касается шеврона у нас) - поэтому смотреть сейчас, "а я видел там дешевле, а там дороже, а тут одинаково" - смысла мало.
Говоря твоими словами можно тоже самое заявить про те два масла которые превысили CCS. Но двойные стандарты - да - они такие...
@torcon, Тогда надо хотя бы попытаться быть объективным. При чем тогда цены в Тюмени? Я пишу про цены в своем городе, а ты меня пытаешься убедить на основании своих цен. В Питере Шеврон дешевле Петры. В Тюмени наоборот. В Питере Шеврон есть и пользуется спросом в определенных кругах (владельцы американских авто, особенно старых). В Тюмени наоборот.Давай на этом и остановимся.
@sirantony, ну тогда и не говори за всех - ты же заявил это! Я оспорил! У нас она дешевле шеврона. И она лучше шеврона - это факт. Разница что ты привел 20р это смешно - это не разница - это знак равно. :) А если ты узнаешь отпускные цены на масла в твоем Санкт-Петербурге в Компании Петролюб - petrolube.ru оф пред и шеврона и петроканады - то будем предметнее разговаривать, а не заявлять образно. Наш ES там и берет Petro-canada - которая с перевозкой здесь получается дешевле Шеврона. Про Питер уж подавно говорить не буду - пока конкретики не будет.
@torcon, Хорошо,завтра узнаю цену у них.
Узнал. У этого продавца Шеврон дороже.
В розницу кварта Шеврона 208р, литр Петры 201р Галлон Шеврона 900р, 4л Петры 785р
Не знаю было уже или нет....
12.02.2014 Chevron получила премию в области смазочных материалов
Объединенная команда, состоящая из Chevron Lubricants, Chevron Oronite и Chevron Energy Technology, получила одну из самых престижных премий в автомобильной индустрии, вручаемых Сообществом Автомобильных Инженеров (Society of Automotive Engineers, SAE) за исследование в области Автомобильных Смазочных материалов. Официальное награждение состоится в апреле 2014 в Детройте.
Организация SAE International включает в себя более чем 138 000 участников из различных областей – автомобильной (производство легковых автомобилей), коммерческих и специальных транспортных средств, а также космической отрасли. SAE International – крупнейший издатель стандартов промышленности и исследований смазочных материалов. Победители этой престижной награды выбираются независимым жюри, состоящим из экспертов автомобильной отрасли.
Данная премия является признанием новаторской работы команды Chevron и ее прорыва в исследованиях в области разработки моторных масел. В настоящее время Chevron Lubricants владеет такими брендами, как Texaco и Caltex.
«Нам нужно начинать думать о моторных маслах совершенно по-новому», сказал James McGeehan, представитель Chevron, который инициировал проект и возглавил исследовательскую группу. «Результаты парадигмы в технологии дизельных двигателей – это разработка совершенно новой формулы моторного масла с нулевым процентом фосфора и сульфатной золы, ниже 0,4 %».
Согласно McGeehan, новая формула моторного масла с ультранизким содержанием золы и нулевым содержанием фосфора может послужить основным условием, которое изменит правила игры в мировом производстве смазочных материалов. С 2014 года все новые дизельные двигатели в Северной Америке, Европе и Японии будут обязаны оборудоваться сажевым фильтром, с целью сокращения вредных выбросов. Из-за расхода моторного масла, эти фильтры накапливают зольные отложения, прежде всего, металлов входящих в состав пакета присадок, образующиеся при сгорании моторного масла, и должны периодически подвергаться очистки, что требует кратковременного выведения из эксплуатации транспортного средства, и увеличивает затраты на его обслуживание. Низкозольное моторное масло может существенно снизить, а, в конечном счете, даже аннулировать это требование по техническому обслуживанию.
McGeehan так же добавил: «В результате ходовых испытаний, приведенных в нашем исследовании, новая формула моторного масла показала выдающиеся результаты по минимизации износа и контроля вязкости в условиях увеличенного интервала замены. Мы убедились, что новая формула моторного масла уменьшает количество зольных отложений в сажевых фильтрах на 78 %, значительно увеличивая интервалы обслуживания».
«Низкая зольность, отсутствие фосфора в маслах расширяют возможности производителей (ОЕМ) дизельных двигателей, а так же возможности применения иных видов топлив, включая бензин и природный газ. Наша новая разработка может изменить мышление целой отрасли промышленности».
