Shell Helix Ultra ECT C2/C3 0W-30 (API SN; VW 504/507; MB 229.52/229.51/229,31; Porsche C30)
Shell Helix Ultra ECT C2-C3 0W-30 photo1.JPGShell Helix Ultra ECT C2-C3 0W-30 photo2.JPG
Спецификации: ACEA C2/C3; API SN; VW 504/507; MB 229.52, 229.51, 229,31; Porsche C30
Техническая документация: Helix_Ultra_ECT_C2_C3_0W-30_(TDS-rus).pdf
550042353 Shell Helix Ultra ECT C2/C3 0W-30 4л
550042390 Shell Helix Ultra ECT C2/C3 0W-30 1л
550046358 Shell Helix Ultra ECT C2/C3 0W-30 1л
550046375  Shell Helix Ultra ECT C2/C3 0W-30 4л
550046305 Shell Helix Ultra ECT C2/C3 0W-30 1 л. (made in Germany);
550046306 Shell Helix Ultra ECT C2/C3 0W-30 4 л. (made in Germany);
пр-во - ЮВА, Турция, ЕС.
550046641 - Shell Helix Ultra ECT C2/C3 0W-30 1л
550046440 - Shell Helix Ultra ECT C2/C3 0W-30 1л
550052527 - Shell Helix Ultra ECT C2/C3 0W-30 1л
550052662 - Shell Helix Ultra ECT C2/C3 0W-30 1л
550042351 - Shell Helix Ultra ECT C2/C3 0W-30 1л
550046405 -  Shell Helix Ultra ECT C2/C3 0W-30 4л
550053030 - Shell Helix Ultra ECT C2/C3 0W-30 4л
550068840 - Shell Helix Ultra ECT C2/C3 0W-30 4л
550046307 - Shell Helix Ultra ECT C2/C3 0W-30 5л
550042371 - Shell Helix Ultra ECT C2/C3 0W-30 5л
Shell Helix Ultra ECT C2/C3 0W-30 Made in Germany УРЦ
Shell Helix Ultra ECT C2/C3 0W-30 Made in Germany МИЦ
Shell Helix Ultra ECT C2/C3 0W-30 made in Germany 2023
Shell Helix Ultra ECT C2/C3 0W-30 свежее 2020
Shell Helix Ultra ECT С2/C3 0W-30 свежее
Shell Helix Ultra ECT C2/C3 0W-30 отработка на Nissan Qashqai J11 MR20DD после 2617км (100мч)
Shell Helix Ultra ECT C2/C3 0W-30 отработка на Audi A5 (F5) после 2034км
Shell Helix Ultra ECT C2/C3 0W-30 отработка на VW Tiguan 2 после 15000 км
Shell Helix Ultra ECT C2/C3 0W-30 отработка на Volkswagen POLO после 7365км
Shell Helix Ultra ECT C2/C3 0W-30 отработка на Volkswagen Touareg FL после 8500км
Shell Helix Ultra ECT C2/C3 0W-30 отработка на Skoda Octavia A7 после 12000 км
Shell Helix Ultra ECT C2/C3 0W-30 отработка на Mercedes ML350 после 10000км
Shell Helix Ultra ECT C2/C3 0W-30 отработка на Octavia 2.0 TDI после 3000км
Shell Helix Ultra ECT С2/С3 0W-30 отработка на Peugeot 308 после 4500км
Взял у самого Озона литрушки по 793р. Вес канистр 897г. Германия. Импортер МинералАгро-Волга. Собственно это и сподвигло к покупке. От этого же импортера покупал мобил 5в30 из соседней ветки форума который разобран по косточкам.
Сравнил со канистрами 22года от финикса и белорусов отличий много по этикетке - русского языка стало меньше, на лицевой убрали надпись carbon neutral. Но придраться особо не к чему все пахнет оригиналом )
Где сейчас в Москве купить это масло не подделку? Ранее здесь рекламировалась Аллея - у них его нет, так же нет в МПО Авангард, где не раз брал. Скоро уже на замену ехать, а где купить - непонятно. Масло есть в сетевых магазинах Би-Би. Никто не брал там?
ООО "Органикдез" тут представляли анализы, ввозимых ими масел Шелл, вот вроде они на озоне
Спасибо! 5л. канистры есть. Придется 2шт. брать, литрух нет у них.
Коллеги, доброго дня!
Что на сегодня по покупке этого маслица? Где надежнее?
Спасибо!
На озоне у самого озона и у Финикса.
Добрый вечер, дорогие формучане! Уже 2 года как использую это масло, купил тогда сразу с запасом. Но запас иссякли, теперь не знаю, где взять, чтобы быть уверенным, что не подделка. Заметил, что оно продается в Леруа. Никто не покупал его там? Подскажите, где и у какого поставщика лучше купить, чтобы не попасть на подделку?
Здравствуйте. Подскажите, пожалуйста, чем данное масло Shell HELIX ULTRA ECT C2/C3 0W-30 отличается от Shell HELIX ULTRA PROFESSIONAL AV-L 0W-30?
Понимаю, что обсуждаемое в этой теме масло имеет еще допуски MB 229.52/229.51/229,31; Porsche C30 помимо 504/507.
Учитывая, что здесь в теме 66 страницы, а по AV-L всего 7, получается это масло наиболее популярно. Вопрос, почему?
Спасибо!
1 час назад, Recluse сказал:
Спасибо!
Эти масла практически близнецы братья. На форуме есть лабораторные тесты обоих масел, можете сравнить как по вязкости так и по пакету присадок, +- одинаково. У Шелла все масла с названием Professional главным образом предназначены для официальных сервисных центров, в основном разливаются в бочки. Обычные для розницы, потому то в обсуждении обычное встречается чаще. Сейчас в связи с отсутствием официальных поставок всё перемешалось, что смогли купить и завести по параллельному импорту по лучшей цене то и завезли. Так что с точки Вас как потребителя можете смело лить одно и другое.
прошу добавить артикулы в шапку. пр-во - ЮВА, Турция, ЕС.
Немцы на канистрах снизу не пишут дату изготовления?
9412d29d-ee43-47b9-a278-7c5d1eddf15f.jpg43944593-5d34-4df6-a315-5adadfc5a66a.jpgIMG-20241015-WA0025.jpegIMG-20241015-WA0023.jpeg
Два вопроса.
1. А если это масло в серой канистре, это паль, или просто старые партии распродают?
2. Ранее заливал на зиму Castrol 0w30 a3/b4, сейчас хочу попробовать залить  этот Shell, разница между ними чувствительна для обычного бензинового, чугунного, не турбированного двигателя?
Изменено пользователем Kornelius
Kornelius с такими вопоосами лейте лучок. Это проще и понятнее.
17.10.2024 в 15:42, Carbonmlc сказал:
В разных странах бывают разные канистры. Например такие как производились у нас в Торжке не производились больше нигде.
Масло это для Вашего двигателя подойдёт вполне. Собственно туда производитель изначально и рекомендовал лить среднезольное масло 5w30 с допуском VW 504/ 507, но в какой-то момент в России они испугались не качественного топлива и решили что лучше в наших условиях рекомендовать VW 502/ 505 то есть А3 В4 полнозольное. Эксклюзивный договор на поставку масел и технических жидкостей у ВАГа был с Castrol, а у Castrol не было масла А3 В4 в вязкости 5w30, но было 0w30 соответственно оно и было выбрано.
Если хотите попробовать Shell то у Вас есть выбор из VW 504/ 507 в вязкости 5w30 и 0w30 ( и не бойтесь на зиму лить 5w30, у Шелл вся линейка Ультра на GTL там температура замерзания далеко ниже -50 ).
При этом даже линейка HX8 идёт с очень хорошими низкотемпературными характеристиками, например:
Изменено пользователем makdi067
