28 сентября 20224 г Закреплён Hello, I want your advice for oil to my car. Volkswagen Passat B8 2.0 TDI 2018 110kW DFGA DPF 7speed DSG EURO6 Motor: Diesel with DPF filter, 2.0 TDI DFGA 110kW Oil capacity: 4,7l Country: Slovakia, max -20°C Routes: 60% outside the city, 25% city driving, 15% highway Interval: 5-7000km Euro 6 with DPF Most favorite oil brands in Slovakia: Mobil1, Shell, Valvoline, Ravenol Type of oil: norm VW 507.00 In Slovakia VW accept oil change after 30 000km/ 2 years!! Car have oil changes at: 29 000km OEM VW 0W-30 (maybe Shell ECT C2/C3 or AV-L) 9/2018 59 000km OEM VW 0W-30 6/2019 87 0000km OEM VW 0W-30 5/2020 124 000km (37 000km with 1 oil !!!!!!) OEM VW 0W-30 2/2021 Then i bought car at 127 000km. I have changed oil 5 times afer 3000km ( because last oil change was after 37 000km!) My changes: 128 000km 11/2021 Ravenol VMP 131 000km 2/2022 Ravenol VMP 135 000km 4/2022 Ravenol VMP 138 000km 6/2022 Ravenol VMP 141 000km 9/2022 Ravenol VMP I want your advice, which oil will be best for me, I have used Ravenol VMP, it is most expensive here, but it have best reputaion. I have at home Mobil 1 ESP 5W-30 5l, Shell ECT C2/C3 0W-30 5l and OEM VW 0W-30. Do you recommend anything else? Here have best reputation Ravenol, Amsoil, Redline, Mobil...
20 октября20 окт Why not to use 5W30 instead? It is cheaper and contains less thickener. Winters in Slovakia are soft, for —20*C 5w30 is enough. Почему бы не использовать 5w30? Зимы в Европе мягкие, а в 5w30 меньше загустителя и оно дешевле.
20 октября20 окт dfga The Ravenol Brand is prohibited to discuss hear due to forum polices (no comments). The rest of brands Amsoil, Redline, Mobil are OK. For -20C 5W-30 also OK, MOL Essence Longlife 5W-30, for example. There is information suggesting that Valvoline Restore and Protect contains OSP (oil-soluble polyalkylene glycols), which provide a cleaning effect due to their low aniline point. Изменено 20 октября20 окт пользователем SL1
20 октября20 окт Автор До сих пор я заливал в основном 5W-30. До работы мне 500 метров, и иногда нужно что-то перевезти или съездить в магазин, в основном в течение недели поездки короткие. Только на выходных мы куда-то ездим за город, в среднем за выходные набегает даже 200 км. Поэтому я думал, не лучше ли для этих коротких поездок перейти на 0W-30? Сейчас я впервые пробую Mobil 1 ESP 0W-30, и двигателю оно подходит, к тому же наступает зима. Спасибо. Изменено 20 октября20 окт пользователем SL1
20 октября20 окт 53 минуты назад, dfga сказал: Поэтому я думал, не лучше ли для этих коротких поездок перейти на 0W-30? Сейчас я впервые пробую Mobil 1 ESP 0W-30, и двигателю оно подходит, к тому же наступает зима. Попробуйте (если есть желание) ..вы же специально подняли этот вопрос через 4 года ? и какая t зимой у вас? - лучше,хуже или одинаковый загуститель в Mobil 1 ESP 5W-30 подскажут наверное кто разбирается ?
20 октября20 окт Автор В Словакии, где я живу, зимой обычно до -5, ночью максимум -10. Исключительно редко бывает до -20 несколько дней. У Mobil 1 ESP 0W-30, говорят, старая рецептура?
20 октября20 окт 1 час назад, dfga сказал: Поэтому я думал, не лучше ли для этих коротких поездок перейти на 0W-30? Liqui Moly Top Tec 4210 0w-30.
20 октября20 окт 4 hours ago, dfga said: Should I switch over to 0W-30? На английском: Spoiler It depends. Cold weather, short trips, traffic jams, prolonged engine idling are considered a "usage in harsh conditions" by car manufacturers. "Harsh conditions" lead to more engine wear, increased fuel consumption, and accelerated oil degradation. In such cases It is recommended to make oil changes more often, do some occasional highway driving, and to use the least viscosity allowed by the car manufacturer in user manual. And that's really it. In your case, the problem is that your engine has no time to warm up properly during a short trip. Even if coolant temp gauge says that you can go, your oil is still cold and thick, which is not ideal. Unfortunately, reduction of winter number (5W -> 0W) can give random results, depending on manufacturer. You should watch for "Kinematic viscosity at 40°C, or KV40" metric instead. It shows thickness of oil when it's relatively cold, which is more accurate, in my opinion. For example, ZIC Zero 0W-30's KV40 is 59.28, Sintec Premium 0W-30's KV40 is 68.83, 5W-30's is 73.62. As you can see, the difference between ZIC 0W and Sintec 0W is bigger, than between Sintec 0W and 5W. So, the answer is: "You should stay at 5W-30 for the time being, and shorten your oil change intervals". It should be noted, that the bigger the difference between winter viscosity and main viscosity, the less thermally durable the oil is, making it susceptible to evaporation and engine oil consumption, especially in turbocharged engines. 0W-30 is fine, 5W-30 is good, 10W-30 is better, 15W-30 is best, but such viscosity does not exist. Try both 0W-30 and 5W-30, and if you'll find no difference - stay at 5W-30. https://www.youtube.com/watch?v=48pviPLgaPQ На русском (через Google Translate): Spoiler Всё зависит от обстоятельств. Холодная погода, короткие поездки, пробки и длительная работа двигателя на холостых оборотах — всё это автопроизводители классифицируют как «эксплуатацию в тяжёлых условиях». Такие условия приводят к повышенному износу двигателя, увеличенному расходу топлива и ускоренному старению моторного масла. В подобных ситуациях рекомендуется чаще менять масло, периодически совершать поездки по трассе, а также использовать масло с минимально допустимым уровнем вязкости, предусмотренным руководством по эксплуатации автомобиля. Вот, собственно, и всё. В вашем случае проблема заключается в том, что во время коротких поездок двигатель просто не успевает как следует прогреться. Даже если указатель температуры охлаждающей жидкости показывает, что можно ехать, масло остаётся холодным и густым, что далеко от идеала. К сожалению, переход на другой «зимний» индекс (например, с 5W на 0W) не всегда даёт предсказуемый результат — всё зависит от конкретного производителя. Лучше ориентироваться на показатель «кинематическая вязкость при 40°C» (KV40). На мой взгляд, этот параметр точнее отражает густоту масла в относительно холодном состоянии. Например, у ZIC Zero 0W-30 показатель KV40 составляет 59,28, у Sintec Premium 0W-30 — 68,83, а у масла класса 5W-30 — 73,62. Как видите, разница между ZIC 0W и Sintec 0W даже больше, чем между Sintec 0W и 5W. Таким образом, мой совет: пока оставайтесь на вязкости 5W-30, но сократите интервалы замены масла. Стоит также учесть, что чем больше разрыв между «зимним» и «основным» индексами вязкости, тем ниже термическая стабильность масла. Это делает его более склонным к испарению и «угару» (повышенному расходу), что особенно актуально для турбированных двигателей. 0W-30 — приемлемый вариант, 5W-30 — хороший, 10W-30 — ещё лучше, а 15W-30 было бы идеальным, но такой вязкости, по сути, не существует. Попробуйте и 0W-30, и 5W-30; если разницы не заметите — оставайтесь на 5W-30. https://www.youtube.com/watch?v=48pviPLgaPQ Изменено 20 октября20 окт пользователем Kilowatt
20 октября20 окт dfga It just occurred to me... You should try ZIC Zero 0W-30 API SQ. They added more molybdenum in comparison with API SP composition. Molybdenum reduces engine wear in cold weather and improves fuel economy. Plus, it's has low KV40, which is significant in temperatures below -15°C. And it meets VW 507 requirements. https://zicoil.ru/products/zero/zic-zero-30-0w-30.html Part number 162676.
20 октября20 окт 5 часов назад, dfga сказал: Исключительно редко бывает до -20 несколько дней. Veľká Fatra? 1 час назад, dfga сказал: Как думаешь, из-за санкций будет проблема купить у нас российское масло? Зачем? Лейте первокласные Mobil, Castrol, Shell, Aral, Rowe, Avia, Fuchs, тот же Mol.
20 октября20 окт Автор В общем, пока остаюсь на Mobil 1 ESP 0W-30. Ничего получше найти не получается. А про запрещенную марку VSW тут говорить нельзя.
20 октября20 окт 18 минут назад, dfga сказал: А про запрещенную марку VSW тут говорить нельзя. в Правилах форума написано : 13) Запрещено обсуждение масел Totachi, Ravenol. Без комментариев!
29 октября29 окт 29 минут назад, evgeniy1988 сказал: А что на счет оригинального масла VW? Или не стоит денег? А что в оригинальном масле особенного ? А такое например чем не устраивает : Или другой вариант нужен ? : Изменено 29 октября29 окт пользователем apologize
29 октября29 окт dfga вы и так льете отличное масло Mobil 1 ESP 0W-30! Castrol EDGE Professional LL III 0W-30 ZIC Zero 30 0W-30 Большего и не нужно.
