Oil for Volkswagen Passat B8 2.0 TDI 110kW DFGA
Hello, I want your advice for oil to my car.
Volkswagen Passat B8 2.0 TDI 2018 110kW DFGA DPF 7speed DSG EURO6
Motor: Diesel with DPF filter, 2.0 TDI DFGA 110kW
Oil capacity: 4,7l
Country: Slovakia, max -20°C
Routes: 60% outside the city, 25% city driving, 15% highway
Interval: 5-7000km
Euro 6 with DPF
Most favorite oil brands in Slovakia: Mobil1, Shell, Valvoline, Ravenol
Type of oil: norm VW 507.00
In Slovakia VW accept oil change after 30 000km/ 2 years!!
Car have oil changes at:
29 000km OEM VW 0W-30 (maybe Shell ECT C2/C3 or AV-L) 9/2018
59 000km OEM VW 0W-30 6/2019
87 0000km OEM VW 0W-30 5/2020
124 000km (37 000km with 1 oil !!!!!!) OEM VW 0W-30 2/2021
Then i bought car at 127 000km.
I have changed oil 5 times afer 3000km ( because last oil change was after 37 000km!)
My changes:
128 000km 11/2021 Ravenol VMP
131 000km 2/2022 Ravenol VMP
135 000km 4/2022 Ravenol VMP
138 000km 6/2022 Ravenol VMP
141 000km 9/2022 Ravenol VMP
I want your advice, which oil will be best for me, I have used Ravenol VMP, it is most expensive here, but it have best reputaion.
I have at home Mobil 1 ESP 5W-30 5l, Shell ECT C2/C3 0W-30 5l and OEM VW 0W-30.
Do you recommend anything else?
Here have best reputation Ravenol, Amsoil, Redline, Mobil...
ДФГА , ZIC TOP LS 5w-30 :good2:
Изменено пользователем ProstoFilya
Выходим на широкий международный уровень?
Mobil 1 ESP Formula 5w30
Масло Aral Super Tronic LongLife III 5w30
FUCHS TITAN GT1 PRO C3 5W-30
SHELL Helix HX8 ECT 5w30
Valvoline SynPower XL-III C3 5w30
Все масла проверенного качества. Просто меняйте его каждые 7-8000 км или 300 моточасов.
Ivaylo Dimov  появилась информация, что болгарам нельзя общаться с русскими под угрозой увольнения с работы, так ли это?
7 часов назад, dfga сказал:
:up:
Сергей Васильевич
Это ложь, и меня это тоже не смущает, мое начальство любит Россию
dfga here Ravenol doesn’t have best (and good) reputation))
So, it seems to me, Mobil 1 ESP 5w30 would be best one for u engine
Ok so your advice is, that best oil for me is Mobil 1 ESP 5W-30?
Hello.
In mobil1 oil recommendation it gives me only mobil 1 esp 0W-30, not 5W-30.
Which is better?
5 минут назад, dfga сказал:
Hello.
Which is better?
dfga The Rav... ol oil is prohibited to discuss on forum. Read the forum rules. There is no point to use 0W oil in Slovakia due to soft warm weather. Some time it uses low viscosity stuff with huge amount of thickener.
Ok thank you, I will ho for 5W-30 ESP M1
Hello.
I am back after 4 years.
Can you recommend me oil?
VW 507.00
Ideal 0W-30 (better for short drives?).
This year I cleaned oil pan and for first time I tried BG EPR flush.
Here is picture with history of oil changes:
dfga , у вас не доступен переводчик ? зачем на Российском форуме писать на Английском :unknw:
- короткие поездки это сколько километров ? поддон был сильно грязный ?
Цитата
Здравствуйте. Я вернулся спустя 4 года. Можете ли вы порекомендовать мне масло? VW 507.00 Идеально подходит 0W-30 (лучше для коротких поездок?). В этом году я почистил масляный поддон и впервые попробовал промывку BG EPR. Вот фотография с историей замены масла:
