Масла Taif
Официальный сайт: http://taif-lubricants.ru/index.html
TAIF Allegro 0w-20 API SP, ILSAC GF-6 1л - 211001
TAIF Allegro 0w-20 4л - 211002
TAIF Allegro 0w-20 20л - 211003
TAIF Allegro 0w-20 205л - 21104
TAIF Allegro 5w-20 API SP, ILSAC GF-6 1л - 211005
TAIF Allegro 5w-20 4л - 211006
TAIF Allegro 5w-20 20л - 211007
TAIF Allegro 5w-20 205л - 211008
TAIF Allegro 5w-30 API SP, ILSAC GF-6 1л - 211009
TAIF Allegro 5w-30 4л - 211010
TAIF Allegro 5w-30 20л - 211011
TAIF Allegro 5w-30 205л - 211012
TAIF Tanto 0w-20 API SN, ILSAC GF-5 1л - 211033
TAIF Tanto 0w-20 4л - 211034
TAIF Tanto 0w-20 20л - 211035
TAIF Tanto 0w-20 205л - 211036
TAIF Tanto 10w-30 API SN, ILSAC GF-5 1л - 211045
TAIF Tanto 10w-30 4л - 211046
TAIF Tanto 10w-30 20 - 211047
TAIF Tanto 10w-30 205 - 211048
TAIF Tanto 5w-20 API SN, ILSAC GF-5 1л - 211037
TAIF Tanto 5w-20 4л - 211038
TAIF Tanto 5w-20 20л - 211039
TAIF Tanto 5w-20 205л - 211040
TAIF Tanto 5w-30 1л - 211041
TAIF Tanto 5w-30 4л - 211042
TAIF Tanto 5w-30 20л - 211043
TAIF Tanto 5w-30 205л - 211044
TAIF Vite 5w-30 ACEA C3, API SN, VW 504 00/507 00, MB 229.51 1л - 211013
TAIF Vite 5w-30 4л - 211014
TAIF Vite 5w-30 20л - 211015
TAIF Vite 5w-30 205л - 211016
TAIF Etude 5w-40 API SL/CF 1л - 211069
TAIF Etude 5w-40 4л - 211070
TAIF Etude 5w-40 20л - 21071
TAIF Etude 5w-40 205л - 211072
TAIF Etude 10w-40 SL/CF 1л - 211073
TAIF Etude 10w-40 4л - 211074
TAIF Etude 10w-40 20л - 211075
TAIF Etude 10w-40 205л - 211076
TAIF Vivace 5w-40 API SN/CF, MB 229.5 1л - 211025
TAIF Vivace 5w-40 4л - 211026
TAIF Vivace 5w-40 20л - 211027
TAIF Vivace 5w-40 205л - 211028
TAIF Vivace 0w-40 API SN/CF 1л - 211021
TAIF Vivace 0w-40 4л - 211022
TAIF Vivace 0w-40 20л - 211023
TAIF Vivace 0w-40 205л - 211024
Taif Vite C3 5W-30 2025
Taif Forte 5W-30 A5/B5 2024
Taif Vivace 5W-40 API SN 2024
Taif Allegro 5W-30 API SP 2023
Taif Vivace 0W-40 API SN 2023
Taif Tanto 0W-20 API SN
Taif Tirata 10W-40
Taif Vite C3 5W-30
Taif Allegro 0W-20 API SP
Taif Tirata 10W-40 свежее Shear Stability Test and HTHS
Taif Shift CVTF
Taif Shift PAO 75W-90 API GL-4/5
Лабораторные анализы - Отработки - UOA
Taif Allegro 5W-30 отработка на Mazda CX-5 после 7500км
В теме присутствует официальный представитель TAIF Lubricants. Если у Вас есть какие то вопросы по маслам Taif, вы можете их задать @taif_lubricants. Прошу любить и жаловать :)
Taif Allegro 5w20 кто-нибудь эксплуатировал? Паспорт завода изготовителя можно скинуть любой, если есть.
19.12.2025 в 14:52, Misha6112008 сказал:
В наших то краях на зиму лучше 0w-20.
@taif_lubricants, в Taif Allegro 5W-30 API SP (анализ от 2023г.) пропали дисперсанты. В 2021 был бор, а нынче - тютю...:unknw:. Просьба вернуть
Цитата
...предотвращают образование отложений, сохраняя чистоту двигателя...
Без дисперсантов крупицы будут налипать.
1 час назад, Archimedes сказал:
Эфиры ДОТФ моют двигатель изнутри, изучите.
5 часов назад, Archimedes сказал:
Куда?:Rulezz_alcoman1:
6 часов назад, Дмитрий Иванович сказал:
Everywhere
Archimedes разве это так работает?
10 часов назад, Misha6112008 сказал:
Спасибо за рекомендацию.
Изучил всё, что нашлось:
- ДОТФ свойства моющие увеличивают;
- Фото двигателей и отзывы после отработок говорят о повышение чистоты поверхностей двигателя и чистоты самой отработки после многоразового использования.
Интересовала конкретно диспергирующая (измельчать и удерживать) составляющая мытья. Потому что нигде о ней не указано. Пишут лишь "моет лучше". И здесь в масле бор просто убрали под 0. В других отечественных маслах аналогично после 2022 тоже убирали молибден и бор. От того и был мой запрос.
Засим вопрос решён:)
Всем привет! С новым годом!
Езжу на Taif C3.С момента появления оф магазина на OZON,беру там. Но тут дошёл слух что кто-то, где-то, когда-то..купил у официалов масло на OZON,а внутри оказалась дешёвое фуфло.Типа на складах OZON что-то мутили с ним. В принципе правдоподобно,поскольку вытащить крышку с канистры не срывая пломбу,вполне возможно.
Слышал кто-нибудь что-то об этом?
SergApat это покупатели делают. Сливают нормальное масло, заливают отработку и возвращают в ПВЗ, а оттуда на склад. Владелец магазина на это не может повлиять, так что следите за состоянием упаковки при приобретении.
Дмитрий Иванович Так частично о том и речь.
Сам лично пробовал. Пробка не опечатана,подсовываешь линейку и она от канистры отстёгивается. Слил-залил,пробку-горловину назад вставил и всё никаких следов.
А эти фантики типа "честный знак".На садоводе рулонами продаются на любой товар.
Если бы пломба была прилеплена одним краем на канистру,перекрывая пробку и другим краем опять на канистру,а еще такая, которая при отклеивании, повреждается и назад не клеится,с голограммой. Было бы спокойнее как-то.
SergApat разумные вещи говорите, напишите им на почту, может, что-то предпримут.
1 час назад, SergApat сказал:
Предпочтительнее подмена масла Rolf Ultra, чем этот татарский Таиф. До подмены Таифа и Такаямы ещё никто не додумался.
Всем привет. Я катаю 5w-20 в 6b31 уже 80к в пересменку с 5w-30, примерно в соотношении 70/30 по времени. 5w-30 после 4000 км начинает угарать. На 5w-20 нет угара. Катаю и зимой и летом. Замена раз в 7500 км. Решил остановится на 5w-20. Паспорт партии прилагаю.
23.10.2022 №1294 (п.22210103) TAIF ALLEGRO 5W-20 (4л).pdf
Изменено пользователем Latest_Jedi
Раз уж о Taif, то в дополнение к моторному маслу, откатал около 80к в АКПП shift atf dx vi и в диффе с раздаткой shift pao 75w-90, 2 замены.
на shift pao 75w-90 муфта издавала странные звуки. Залил позавчера Amsoil Severe Gear 75w-90, звуки пропали. Думаю ПАО не очень подходит, нужно лить видимо shift gl-5, или shift LS. Попробую через 45к.
Паспорта партий, которые эксплуатировал.
17.01.2024 № 56 (п.24800502) SHIFT ATF DX VI (20 л.).pdf 14.09.2023 № 1338 (п.23309403) SHIFT GL-4.GL-5 PAO 75W-90 (1 л.).pdf 06.10.2021 №347 (п.21803503) TAIF SHIFT ATF DX VI (4л).pdf
