Масла Febi
Масло Febi
32941 - Febi Engine Oil Longlife 5W-30 1L
32947 - Febi Engine Oil Longlife Plus 5W-30 5L
32921 - Febi 20W-50 1L
32922 - Febi 20W-50 5L
32923 - Febi 20W-50 25L
32924 - Febi 20W-50 60L
38408 - Febi 20W-50 200L
32925 - Febi 15W-40 1L
32926 - Febi 15W-40 4L
32927 - Febi 15W-40 5L
32928 - Febi 15W-40 25L
32929 - Febi 15W-40 60L
32930 - Febi 15W-40 200L
32931 - Febi     10W-40    1
32932 - Febi     10W-40    4
32933 - Febi     10W-40    5
32934 - Febi     10W-40    60
32935 - Febi     10W-40    200
32936 - Febi     5W-40    1
32937 - Febi     5W-40    4
32938 - Febi     5W-40    5
32939 - Febi     5W-40    60
32940 - Febi     5W-40    200
32941 - Febi     5W-30 Longlife    1
32942 - Febi     5W-30 Longlife    4
32943 - Febi     5W-30 Longlife    5
32944 - Febi     5W-30 Longlife    60
39336 - Febi     5W-30 Longlife    200
32945 - Febi     5W-30 Longlife Plus    1
32946 - Febi     5W-30 Longlife Plus    4
32947 - Febi     5W-30 Longlife Plus    5
32948 - Febi     5W-30 Longlife Plus    60
39337 - Febi     5W-30 Longlife Plus    200
34052 - Febi     10W-40 Truck Longlife Plus    200
48416 - Febi     5W-30 Longlife EU6    205
101140 - Febi     0W-40    1
101141 - Febi     0W-40    4
101142 - Febi     0W-40    5
101143 - Febi     0W-40    60
101144 - Febi     0W-40    200
105840 - Febi     10W-40 Truck Special Longlife    5
34047 - Febi     10W-40 Truck Special Longlife    20
34048 - Febi     10W-40 Truck Special Longlife    60
34049 - Febi     10W-40 Truck Special Longlife    200
101150 - Febi     5W-30 HC-FO    1
101151 - Febi     5W-30 HC-FO    4
101152 - Febi     5W-30 HC-FO    5
101153 - Febi     5W-30 HC-FO    60
101154 - Febi     5W-30 HC-FO    200
108350 - Febi     5W-20 HC E-FO    1
108351 - Febi     5W-20 HC E-FO    4
108352 - Febi     5W-20 HC E-FO    5
108360 - Febi     5W-30 HC C4    1
108361 - Febi     5W-30 HC C4    4
108362 - Febi     5W-30 HC C4    5
Febi Long Life Plus 5W-30 API SN
Febi SAE 5W-30 Longlife
Febi SAE 10W-40 Truck Special Longlife
Febi SAE 0W-40
Febi SAE 5W-40
Febi Longlife Plus 5W-30
Febi Long Life HC-FO 5W-30
Febi 39070
Febi Zentralhydraulikol
Лабораторные анализы - Отработки - UOA
FEBI Longlife Plus 5W-30 отработка на VW Touareg после 13 000км
FEBI Longlife Plus 5W-30 отработка на VW Touareg после 9006км
Febi Loglife Plus 5W-30 отработка на Volkswagen Touareg после 8700км
Febi Long Life HC-FO 5W-30 отработка на TOYOTA VERSO  после 8000 км
Febi SAE 0W-40 отработка на Skoda Yeti после 6760км
По любому даже мешает не сам, как ACdelco только наклейка этикеток наверное.
т.е. продукт достойный внимания.кто-нибудь нашел пасопрта на них..всё облазил smile287.gif
Если интересует мнение обывателя , то при выборе масла, общался с продавцом магазина, которые сами возят их из Германии, Феби, Арал и Вольф какой то. Ну в общем он и подсказал мне залить Арал и не париться. Но с Аралом у меня своя зимняя инстория, и нашел своё масло в другом месте. Вольф не рассматривается. Конретно про феби было сказано что давление в жару настолько падает, что машина сигнализирует миганием контрольки...Еще он сказал , что внутри какое то корейское масло. Но не уточнил. А поанчалу я тоже хотел клюнуть на дешевое немецкое масло ))))))))) да и по запчастям можно сделать вывод. Феби ставишь - год, полтора, Лемфердер поставил и забыл...это на мерседесе.
veles158 верно говорит. Самые отстойные запчасти, это феби. Хотя иногда в их коробках попадаются и приличные железки, но в подавляющем большинстве случаев феби и рувилле - полный отстой, причем при средней цене. Не думаю, что с маслом у этой фирмы политика другая.
До сих пор не могу понять почему у них такие дешёвые антифризы и спец жидкости... очень подозрительно!
По запчастям для меня лично Феби уже давно в черном списке.
Не ну за свои деньги у них не плохие запчасти, но лучше взять побрендовей что либо.
По запчастям под одним и темже номером может прийти запчасть сделанная в разных местах :(
@шансонье, Упаковщик он и есть упаковщик, причем не раскрывает что льет, в отличии к примеру от Картечника, где тот официально расписывает, каких производителей лампы, антифризы, масла пакует и какие при этом маркировки плюс на жижи все TDS, MSDS выложены.
И что , FEBI совсем плохое? Ни у кого нет опыта применения, или отзывов об этом масле?
Вот нашел официальные документы по этому маслу.
32938.moe.ru.pdf
Изменено пользователем almik11
Диванные теоретики. Жидкости Фэби поставляются на конвеер Мерседеса, и ПЕРЕКРЫВАЮТ требования МБ.
