Mahle Knecht OC90 (Opel, Daewoo, Chevrolet)
Масляный фильтр Mahle Knecht OC90
Применяемость:
Opel Ascona C 1,6 (16N) , 1,6i (C16LZ), 1,6i (C16NZ), 1,6i (E16NZ), 1,6 (16SV), 1,6 (16SH), 1,8i (C18NE), 1,8i (18SE), 1,8i (18E), 1,8 (E18NV), 2,0i (20NE), 2,0i (C20NE), 2,0i (20SEH)
Opel Calibra A 2,0i (C20NE), 2,0i 16V (X20XEV), 2,0i Turbo 16V (C20LET), 2,5i 24V (C25XE), 2,5i 24V (X25XE)
Opel Vectra A 1,4 (14NV) , 1,6 (16SV), 1,6i (E16NZ), 1,6i (C16NZ), 1,6i (X16SZ)
Opel Frontera A 2,2i 16V (X22XE)
Opel Frontera B 2,2i 16V (X22SE) , 2,2i 16V (Y22SE)
Opel Sintra 2,2i 16V (X22XE)
Daewoo Lanos (KLAT) 1,5i (A15SMS), 1,6i 16V (A16DMS)
Daewoo Assol 1,5i (A15SMS), 1,6i 16V (A16DMS)
Daewoo Espero (KLEJ) 2,0i (C20LE), 2,0i (C20LZ)
Daewoo Leganza (KLAV) 1,8i D-Tec, 2,0i C20SEL D-Tec , 2,0i E-Tec
Daewoo Nubira / Wagon (KLAJ) 1,6i 16V (A16DMS), 1,8i D-Tec (KLAJ)
Daewoo Nexia 1,5i (G15MF), Prince 1,8i (C18LE), 2,0i (C20LE) Espero (KLEJ) 1,8i (C18LE) , Super Saloon 2,0i (C20LE)
Chevrolet Blazer Елабуга 2,2i (C22NE)
Chevrolet Blazer (S10) 2,2i G TBi
Opel Omega B / Caravan 2,0i (20SE), 2,0i (X20SE), 2,2i 16V (Y22XE) , 2,2i 16V (Z22XE), 2,0i 16V (X20XEV)
Opel Zafira 2,0i Turbo 16V (Z20LET)
Opel Astra F/ Cabrio / Caravan 1,4i 16V (X14XE) , 2,0i 16V (X20XEV)
Opel Astra G / купе / Caravan 1,4i 16V (X14XE) , 1,4i 16V (Z14XE), 1,6i 16V (Z16SE), 1,6i (X16SZR) (C16SEL), (X16XEL), 2,0i 16V (X20XEV), 2,0i Turbo 16V (Z20LET), 2,2i 16V (C22SEL)
Opel Kadett E / CC / Caravan1,8i (18E) , 1,8i (18SE) масляный фильтр Opel
Calibra A (включая полный привод) 2,0i (C20NE), 2,0i 16V (C20XE)
Opel Frontera A Sport 2,0i (X20SE)
Opel Vectra B / СС / Caravan 1,6i (X16SZR), 1,6i 16V (X16XEL) , 2,0i 16V (X20XEV) , 2,0i 16V (C20SEL), 2,2i 16V (C22SEL)
Opel Vectra A / Caravan 2,0i 16V (20XE) , 2,0i 16V (C20XE)
Chevrolet Aveo (T200) 1,4i 16V (F14D3)
Chevrolet Lacetti (J200) 1,4i 16V (F14D3) , 1,6i 16V (F16D3) , 1,8i 16V (T18SED)
Chevrolet Evanda (V200) 2,0i 16V
Daewoo Nexia (N100) 1,5i 16V (A15MF)
Opel Antara 2,4i 16V (Z24XE)
Chevrolet Captiva (C100) 2,4i 16V (Z24SED)
Экспертизы масляных фильтров:
Mahle Kneсht OC 90 Made in Austria - пилил torcon
Mahle OC90 Made in China - видео француз
Kneсht OC 90 Made in Austria за спонсирование экспертизы спасибо форумчанину Yurij
Куплен через emex.ru поставщик VSAU по цене 198р.
Применение:
Opel Ascona C 1,6 (16N) , 1,6i (C16LZ), 1,6i (C16NZ), 1,6i (E16NZ), 1,6 (16SV), 1,6 (16SH), 1,8i (C18NE), 1,8i (18SE), 1,8i (18E), 1,8 (E18NV), 2,0i (20NE), 2,0i (C20NE), 2,0i (20SEH)[/size]
Opel Calibra A 2,0i (C20NE), 2,0i 16V (X20XEV), 2,0i Turbo 16V (C20LET), 2,5i 24V (C25XE), 2,5i 24V (X25XE)[/size]
Opel Vectra A 1,4 (14NV) , 1,6 (16SV), 1,6i (E16NZ), 1,6i (C16NZ), 1,6i (X16SZ)[/size]
Opel Frontera A 2,2i 16V (X22XE) [/size]
Opel Frontera B 2,2i 16V (X22SE) , 2,2i 16V (Y22SE)[/size]
Opel Sintra 2,2i 16V (X22XE) [/size]
Daewoo Lanos (KLAT) 1,5i (A15SMS), 1,6i 16V (A16DMS)[/size]
Daewoo Assol 1,5i (A15SMS), 1,6i 16V (A16DMS)[/size]
Daewoo Espero (KLEJ) 2,0i (C20LE), 2,0i (C20LZ)[/size]
Daewoo Leganza (KLAV) 1,8i D-Tec, 2,0i C20SEL D-Tec , 2,0i E-Tec[/size]
Daewoo Nubira / Wagon (KLAJ) 1,6i 16V (A16DMS), 1,8i D-Tec (KLAJ)[/size]
Daewoo Nexia 1,5i (G15MF), Prince 1,8i (C18LE), 2,0i (C20LE) Espero (KLEJ) 1,8i (C18LE) , Super Saloon 2,0i (C20LE) [/size]
Chevrolet Blazer Елабуга 2,2i (C22NE) [/size]
Chevrolet Blazer (S10) 2,2i G TBi [/size]
Opel Omega B / Caravan 2,0i (20SE), 2,0i (X20SE), 2,2i 16V (Y22XE) , 2,2i 16V (Z22XE), 2,0i 16V (X20XEV)[/size]
Opel Zafira 2,0i Turbo 16V (Z20LET) [/size]
Opel Astra F/ Cabrio / Caravan 1,4i 16V (X14XE) , 2,0i 16V (X20XEV)[/size]
Opel Astra G / купе / Caravan 1,4i 16V (X14XE) , 1,4i 16V (Z14XE), 1,6i 16V (Z16SE), 1,6i (X16SZR) (C16SEL), (X16XEL), 2,0i 16V (X20XEV), 2,0i Turbo 16V (Z20LET), 2,2i 16V (C22SEL)[/size]
Opel Kadett E / CC / Caravan1,8i (18E) , 1,8i (18SE) масляный фильтр Opel[/size]
Calibra A (включая полный привод) 2,0i (C20NE), 2,0i 16V (C20XE) [/size]
Opel Frontera A Sport 2,0i (X20SE) [/size]
Opel Vectra B / СС / Caravan 1,6i (X16SZR), 1,6i 16V (X16XEL) , 2,0i 16V (X20XEV) , 2,0i 16V (C20SEL), 2,2i 16V (C22SEL)[/size]
Opel Vectra A / Caravan 2,0i 16V (20XE) , 2,0i 16V (C20XE) [/size]
Daewoo Lanos (KLAT) 1,5i (A15SMS), 1,6i 16V (A16DMS) [/size]
Chevrolet Aveo (T200) 1,4i 16V (F14D3) [/size]
Chevrolet Lacetti (J200) 1,4i 16V (F14D3) , 1,6i 16V (F16D3) , 1,8i 16V (T18SED)[/size]
Chevrolet Evanda (V200) 2,0i 16V [/size]
Daewoo Nexia (N100) 1,5i 16V (A15MF) [/size]
Opel Antara 2,4i 16V (Z24XE) [/size]
Chevrolet Captiva (C100) 2,4i 16V (Z24SED) [/size]
Общий видеообзор:
Полиграфия замечательная, все четко, не придерешься. На дне красуется Made in Austria
Печать на корпусе фильтра
Резьба нарезана хитрая, каждый виток резьбы имеет канавку. Резьба какая то не свежая и не явная, нарезана не так четко как на Mahle который будет чуть ниже.
Прижимное резиновое кольцо квадратного сечения, заусенцев нет .
Пружина которая прижимает катушку в корпусе фильтра.
Фильтрующий материал средней толщины, на изгиб не рвется. Уложен часто.
Там где просвет - не пугаемся, это место спайки фильтрующего материала - норма. У фильтра отсутствует перепускной клапан - так предусмотрено конструкцией двигателя.
Вид изнутри - все красиво - излишков герметика нет.
Внутри корпуса немного краски - но в целом норм.
Полезная площадь фильтрации: Площадь фильтрующего материала 213смx4см=852см2
Вывод: Kneсht OC 90 не плохой фильтр, по аккуратности на 4 с плюсом, по технологиям прост  - ничего особого. Фильтрующий материал не сомневаюсь хороший но на том же Mahle Longlife OC 405/3 - он лучше. В общем фильтр крепкий хорошист.
Имеет УФ маркировку.
Имеется увеличенный аналог OC93
Всем привет. Купил ос90 чёрный фильтр. Вроде не подделка. Вопрос в другом. Этот фильтр не имеет обратного клапана. Можно ли такой фильтр ставить на опель мотор z18xe?Я ставлю обычно манн, но иногда ставил  джи эм.
А кто нибудь в курсе , сейчас в коробке OC90 тоже Китай , как и у других кнехтов/мале?
Распилен фильтр масляный Mahle OC 90. Спонсор мероприятия, наш уважаемый соклубник Yurij
Изменено пользователем француз
2 часа назад, француз сказал:
Распилен фильтр масляный BIG GB-1240.
Почему биг, если это мале?
Честно говоря я ожидал в синей упаковке. да и оранжевая отличается от того что ранее было, сравните с первым сообщением. всегда такие приходили. где заказывали? если емекс, то укажите код поставщика.
Спасибо за обзор, ожидаю следующих.
Изменено пользователем Yurij
Yurij Мои извинения, заголовок исправил. Было уже поздно, хотелось в кроватку.
Фильтра заказываю в разных оптовых конторах, с которыми давно работаю. Это не секрет, просто в розницу они не работаают.
Начиная с прошлого года с упаковками пошла полная чехарда. Но если честно я больше верю оранжевой. Пока по моим прикидкам, то что в "апельсине", это свое производство. А в синей, это заказ на стороне. В какой упаковке фильтр придет, я не знаю. Могу гарантировать только одно, Knecht-Mahle заказываю у ребят, которые раньше были их дилерами и кое какую инсайдерскую информацию они мне выдают.
Поставил бы я данный фильтр на свою машину? Однозначно ДА. Хотя меня очень смущает "опелевский изыск" без байпасного клапана. Но это вопрос не к фильтру, а к конструкции.
француз, что касается двух разных штрих-кодов на коробках Mahle, то это действительно интересный момент. На австрийских фильтрах код один. А вот на китайских и индонезийских - два, причём один начинается с 400 (отсыл к головному офису компании в Германии), а вторые одинаковые по начальным цифрам, хотя страны производства разные.
Изменено пользователем Dimmy
Dimmy Один из людей на Ютубе сказал следующее.
Цитата: Один штрих-код EAN - европейский, второй UPC - американский стандарт. Вероятно для продаж по всему миру наносят сразу два - так дешевле коробочки печатать. Конец цитаты.
Но почему ни у кого кроме Mahle, этого нет?
1 час назад, француз сказал:
Ну может хоть кто-нибудь историю бренда почитает?)). Раньше это были два разных производителя, Кнехт (оранжевая упаковка) и Мале (синяя упаковка). Потом Мале поглотил Кнехт и все изделия приобрели бренд Мале, но линии и заводы Кнехт по прежнему на упаковках оранжевого цвета указывают основной бренд (Мале) и дополнительный (Кнехт) и к стране производства это не имеет отношения)).
Andrey_74 Про историю знаем, чай не совсем уж темнота беспросветная :boredom:.
Давным давно в Питер на семинар приезжал инженер Кнехта и сказал следующее. Мале поглотила Кнехт, НО, с возможностью и производить фильтры под своим флагом и когда Мале делает партию на заводах Кнехта печатать на коробочках свой логотип и оставить узнаваемую цветовую гамму (апельсин). И это мы наблюдаем до сих пор на оранжевых фильтрах. Когда произошло слияние у Кнехта вроде бы было 4 завода по всему миру.
Поэтому я и считаю, что в апельсине, это четко свое производство. А в синих бог знает где. На самом деле таких примеров в запчастях масса.
Вроде бы вы написали то же самое, что и я )).
По поводу бог знает где. Брал в Автодоке с небольшой разницей во времени фильтры OC195. Первый пораньше пришел в синей коробке, типа чисто Мале, второй попозже пришел в оранжевой Кнехт/Мале. Фильтры внутри абсолютно до мелких деталей и надписей одинаковые и конечно оба Китай, т.е. близнецы, хотя коробки, т.е. линии должны быть разные. Это как в старом анекдоте про этикетку на бутылку вина, какую хочешь, такую и приклеим, так и здесь с коробками похоже.
Andrey_74 Про одно и тоже согласен. Я немножко в раздрае сейчас. Не судите строго.
После истории с Мале 593/3, я все таки больше верю "апельсину". Это свои заводы, вне зависимости от их расположения. А вот синька, как мне кажется может быть как с родного завода (ваш пример), так и от стороннего производства. В ближайшее время на распиле будет еще один Мале, поглядим. Хотя противореча самому себе, фильтры мале с буковкой А из индонезии, делаются на мощностях Сакуры, но идут в "апельсине".
