30 ноября 200718 г Закреплён Масла BP Официальный сайт: http://www.bp.com/en_gb/lubricants/united-kingdom.html Артикульные коды для заказа в интернет магазинах: 119368 / 15805A Visco 7000 0W-40 1L 119369 / 15805B Visco 7000 0W-40 4L 117528 / 15804F Visco 7000 0W-40 60L 117386 / 15804E Visco 7000 0W-40 208L 14F697 / 15571C Visco 5000 5W-30 1L 14F69B / 15571D Visco 5000 5W-30 4L 14F69C / 15570F Visco 5000 5W-30 60L 14EE20 / 15571A Visco 5000 5W-30 208L 114496 / 15805F Visco 5000 5W-40 1L 114502 / 15806A Visco 5000 5W-40 4L 108963 / 15805E Visco 5000 5W-40 60L 108959 / 15805D Visco 5000 5W-40 208L 14DF28 / 15870C Visco 3000 Diesel 10W-40 1L 14DF29 / 15870D Visco 3000 Diesel 10W-40 4L 119777 / 15870B Visco 3000 Diesel 10W-40 60L 119634 / 15870A Visco 3000 Diesel 10W-40 208L 14F6E7 / 157F38 Visco 3000 A3/B4 10W-40 1L 14F6E4 / 157F36 Visco 3000 A3/B4 10W-40 4L 14F6E2 / 157F35 Visco 3000 A3/B4 10W-40 20L 14F6E6 / 157F37 Visco 3000 A3/B4 10W-40 60L 14F6E1 / 157F34 Visco 3000 A3/B4 10W-40 208L 14FA23 / 156DA8 Visco 2000 A3/B3 15W-40 1L 14FA26 / 156DAA Visco 2000 A3/B3 15W-40 5L 14FA20 Visco 2000 A3/B3 15W-40 60L 14FA1D / 156DA6 Visco 2000 A3/B3 15W-40 208L 15267A / 1550F9 Vanellus Max 5W-30 208L 15267C / 1550F6 Vanellus Max 5W-30 20L 15267D / 1550F3 Vanellus Max 5W-30 5L 1525F6 / 1552B1 Vanellus Max Eco 10W-40 208L 1525F7 / 1552B0 Vanellus Max Eco 10W-40 20L 1527F6 / 1553CE Vanellus Max 10W-40 208L 1527F8 / 1553CD Vanellus Max 10W-40 20L 1527FB Vanellus Max 10W-40 5L 1525F0 / 1554FF Vanellus Multi A 10W-40 208L 1525EF / 1554FD Vanellus Multi A 10W-40 20L 1525F2 / 1554FA Vanellus Multi A 10W-40 5L 1525EB / 1552EB Vanellus Multi A 15W-40 208L 1525EA / 1552DB Vanellus Multi A 15W-40 20L 14E2AF Vanellus Multigrade 15W-40 208L 14E2B0 Vanellus Multigrade 15W-40 20L 15282A / 15552B Vanellus Multi 15W-40 208L 15282B / 15551C Vanellus Multi 15W-40 20L 15260C / 15549E Vanellus Mono 10W 208L 15269D / 154FE2 Vanellus Mono 30 208L 14342B Autran DX III 1L 1434A7 Autran DX III 20L 107042 Autran DX III 208L 14340E Autran MBX 1L 116163 / 15646C Autran MBX 20L 107068 Autran MBX 208L 119040 Autran MM-SP III 20L 119041 Autran MM-SP III 208L 117141 Autran 4 10 208L 114801 Autran 4 30 208L 14340A Energear SGX 75W-90 1L 116282 Energear SGX 75W-90 20L 108549 Energear SGX 75W-90 208L 14340D / 1557FC Energear HT 75W-90 1L 152B37 / 1557FD Energear HT 75W-90 20L 112212 / 1557FE Energear HT 75W-90 208L 14342A Energear HT 80W-90 1L 116204 Energear HT 80W-90 20L 107544 Energear HT 80W-90 208L 112224 Energear HT 85W-140 208L 1433FC / 15573C Energear EP 80W-90 1L 116100 / 15573B Energear EP 80W-90 20L 107481 / 15573A Energear EP 80W-90 208L 14973D / 15554C Energear EP 80W 208L 14340C Energear Limslip 90 1L 110198 / 1557F8 Energear Limslip 90 208L 1433FE / 155D2A Energear Hypo 80W-90 1L 116106 / 155D1A Energear Hypo 80W-90 20L 107520 / 155D1C Energear Hypo 80W-90 208L 107527 Energear Hypo 85W-140 208L 116107 Energear Hypo 85W-140 20L 107534 / 1556ED Energear Hypo 90 208L 116108 Energear Hypo 90 20L 119622 / 1556F7 Energear SHX-M 75W-90 208L 119624 / 1556FA Energear SHX-M 75W-90 20L 14B5E2 / 154FC7 Energear SHX-LS 75W-90 208L 109101 Energrease ZS 00 15KG 109107 Energrease ZS 00 50KG 135603 Brake Fluid DOT 4 0.5L Лабораторные анализы - Свежие - VOA oil-club.ru BP Visco 7000 0W-40 CleanGuard свежее BP Visco 5000 5W-40 свежее BP VISCO 3000 10W-40 свежее Лабораторные анализы - Отработки - UOA oil-club.ru BP Visco 7000 0W-40 LL-04 C3 отработка на BMW 525D после 10100км BP Visco 7000 0W-40 отработка на Fiat Linea после 7000км BP Visco 7000 0W-40 C3 отработка + Liqui Moly Oil Additive на Mitsubishi Outlander XL после 4500км BP Visco 5000 5W-40 на Лада Калина (Учебка) после 12000км и 1200м.ч BP Visco 7000 0W-40 LL-04 C3 отработка на VW Tiguan после 8300км
17 августа 201214 г вот это и плохо Ну так сейчас почти все кряк.. @megranny Не переживайте, если на канистре стоит С2 С3 то А3\В4 можно не указывать, оно там есть автоматом! с той лишь разницей, что C2 C3 это лоу сапс, а просто А3 - нет ))
17 августа 201214 г с той лишь разницей, что C2 C3 это лоу сапс, а просто А3 - нет )) Не в том дело.Допуск С3 перекрывает по всем параметрам А3\В4 вот его и не пишут.Даже если и написано А3\В4 С2 С3 это все равно не делает его полнозольником
17 августа 201214 г Не в том дело.Допуск С3 перекрывает по всем параметрам А3\В4 вот его и не пишут.Даже если и написано А3\В4 С2 С3 это все равно не делает его полнозольником Вооот, но ключевое отличие - щелочное, а это важно :drinks:
17 августа 201214 г Да все правильно, но нейтрализация плохого топлива у А3\В4 поболее будет :drinks:
17 августа 201214 г Вооот, но ключевое отличие - щелочное, а это важно :drinks: Как бы согласен, да щелочное хотелось бы побольше, полнозольное получше бы было ... НО! Посмотрел характеристики того что Субару предлагает лить в свои движки, а именно Subaru SM 5W30 (K0215Y0271). Т.е. то под чем Субару подписалось - мол это самое то .. http://www.japanoil-ural.ru/index.php?mod=3&idtov=26 И что мы видим ? : 1 Плотность при 20 С, кг/куб.м; ГОСТ 3900-85; = 849 2 Вязкость кинематическая при 40 С, сСт; ГОСТ 33-2000; = 57,63 3 Вязкость кинематическая при 100 С, сСт; ГОСТ 33-2000; = 10,36 4 Индекс вязкости; ГОСТ 25371-97; = 170,3 5 Щелочное число, мг КОН/г; ГОСТ 11362-96; = 6,23 6 Температура вспышки, С; ГОСТ 4333-87; = 220 7 Температура потери текучести, С; ГОСТ 20287-91; = -38 8 Зольность сульфатная, %; ГОСТ 12417-94; = 0,89 Похоже Субару за лоу-сапс . Так что ИМХО BP 7000 0W40 C3 - это то что доктор ( раскосый ) для Субы прописал.
17 августа 201214 г Ну так это больше для европы рекомендация.Давай еще про тойоту и мицубиси поговорим.
17 августа 201214 г ...Посмотрел характеристики того что Субару предлагает лить в свои движки, а именно Subaru SM 5W30 (K0215Y0271). Т.е. то под чем Субару подписалось - мол это самое то .. ... Пользовал я это масло года три-четыре на предыдущих Субах,думая,что оно как минимум полусинтетика,а оно минералкой оказалось.Хотя очень неплохое и не горит,может и дальше бы его пользовал,да негуманный ценник стал 2тыр за 4л.
18 августа 201214 г Похоже Субару за лоу-сапс . Так что ИМХО BP 7000 0W40 C3 - это то что доктор ( раскосый ) для Субы прописал. Просто это типичное американо-азиатское масло, необходимые свойства достигаются базовыми маслами.Количество присадок - минимально, отсюда и щелочное невысокое. Дешевый азиатский кряк, они все такие. Изменено 18 августа 201214 г пользователем veles158
18 августа 201214 г Дешевый азиатский кряк, они все такие. Вот только у нас это кряк совсем не дешев. Но вообще я привел это пример только что бы показать - раз яппы считают что низкощелочное масло можно лить, то и нам С3 лить можно. А тем более с укороченным до 7-8 тыс интервалом.
27 августа 201214 г читал на форуме, что есть где-то анализ Виско 7000. ткните носом пожалуйста! спасибо!
27 августа 201214 г читал на форуме, что есть где-то анализ Виско 7000. ткните носом пожалуйста! спасибо! http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=239062&page=1 Изменено 27 августа 201214 г пользователем mikong
27 августа 201214 г http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=239062&page=1 :drinks: а свежего масла нет?
27 августа 201214 г из свежего есть результаты прожарки http://bmwservice.livejournal.com/27699.html Изменено 27 августа 201214 г пользователем slider88
27 августа 201214 г а свежего масла нет? Не нового С3 не видал, недавно встречал старый тест еще А3-го, но это ж динозавр уже Изменено 27 августа 201214 г пользователем mikong
29 августа 201214 г Ну что ж товарисчи эксперты, залил сегодня вискарика сутра по раньше и погнал в Харьков по делам (180 км. в одну сторону). Показалось стал немного порезче отклик на газ, и на ХХ потише стала работать машина, но я думаю это скорей всего из-за свежего масла и HTHS поменьше чем у x-cess. Будим юзать, интересно понаблюдать за угаром и системой Clean Guard мотыль оставил после себя чистоту http://www.oil-club.ru/forum/topic/40-promivka-dvigatelja-pjatiminutka-moet/page__st__645 тут есть фото, поэтому есть с чем сравнивать.
