VOA Pennasol Super Pace 5w-40 API SN
Hi,
A VOA of Pennasol Super Pace 5w-40 API SN, HC (MSDS says 40-75%) based on recycled base
Изменено пользователем miniac007
Very high TBN and very high TAN = 4.2 :unsure:
Flashpoint 220C (in TDS 232C)
Viscosity is normal.
Recycled base? In TDS has not info about this.
http://www.pennasol.de/fileadmin/downloads/pennasol/motorenoel/en/pi/150099_PEN_PI_SUPER_PACE_SAE_5W-40_EN_V3.pdf
same MSDS
http://www.pennasol.de/fileadmin/downloads/pennasol/motorenoel/en/sdb/150099_PEN_SDB_SUPER_PACE_SAE_5W-40_EN_V1.pdf
High TAN means usually recycled base and Pennasol is a part of a factory specialized in recycling used oil: http://www.avista-oil.com/en.html ...
So 99% sure there is recycled hydrocraked base in it :)
May be, but I think they write it on the bottle... :)
You see VHVI recycled oil? Usually recycled oil - it is a Group 1 or Group 2 Mineral oil.
Sorry for my bad English...
Avista is doing what they call upcycling, which means they use used oil as crude oil to reffine new base oil:
http://www.avista-oil.com/en/technology/processes.html
This new base oil can be hydrocracked to produce HC base.
You have the whole process in this 32 pages document: http://www.docstoc.com/docs/81581377/AVISTA-OIL-Group-AVISTA-OIL-Group-Kernsolvat-Re-raffinated
I think they use it in all mineral/HC oil they sell. On all the Pennasol oil I have tested, I have a TAN>4
Note: Motor Gold are the same oils as Pennasol with just different names
There are some on BITOG but no TAN...
This UOA with low TAN: http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=3002339
Better thing to be sure, ask directly Pennasol :)
Here you can read page 11: As shown in Table 3, the TAN of the used engine oil is measured to be 4.5 mg (KOH)/g (sample) which is much higher than the TAN of the base oils [0.02 mg (KOH)/g (sample)]. This is due to the presence of organic, inorganic, heavy metal salts, ammonia slots, resin, water and corrosive materials which result from the oxidation process that occurred at elevated temperatures in the engine
www.mdpi.com/1996-1073/6/2/1023/pdf
Ребята, если я правильно понял, на этом масле можно проехать тысяч 7 (11,5-4,2), подсчет конечно дилетантский, 50% город, 50% трасса, просто сейчас залито именно такое масло.
протоколы испытаний тоже без TAN ссылка, я что-то не пойму о чем miniac007 говорит, то ли они от времени в банках окисляются, то ли после розлива с высоким TAN идут?
Изменено пользователем ss333
say what?
масло как масло, не хуже мобила и прочих с такой основой и допусками. Дешевле намного
Он говорит, что база здесь из переработанной отработки. А высокое кислотное из-за содержания продуктов окисления и прочей грязи, которая была в моторе.
