Масла Aral
Масла Aral
Официальный сайт: http://www.aral-lubricants.com
Каталог масел: https://www.aral-lubricants.de/en/lubricants/aral-engine-oils/engine-oils-for-passenger-cars
Первый вариант кодов
Aral SuperTronic SAE 0W-40 1l - 20458
Aral SuperTronic SAE 0W-40 4l - 20459
Aral SuperTronic SAE 0W-40 60l - 10451
Aral SuperTronic SAE 0W-40 208l - 20450
Aral SuperTronic G SAE 0W-30  1l - 10382
Aral SuperTronic G SAE 0W-30 4l - 10383
Aral SuperTronic G SAE 0W-30 208l – 10385
Aral SuperTronic Longlife II SAE 0W-30 60l – 10321
Aral SuperTronic E SAE 0W-30 1l – 10508
Aral SuperTronic Longlife III SAE 5W-30 1l  - 20478
Aral SuperTronic Longlife III SAE 5W-30 4l - 20479
Aral SuperTronic Longlife III SAE 5W-30 60l - 10471
Aral SuperTronic Longlife III SAE 5W-30 208l – 20470
Aral HighTronic С SAE 5W-30 1l - 10589
Aral HighTronic С SAE 5W-30 4l – 10584
Aral HighTronic G SAE 5W-30 1l - 21387
Aral HighTronic G SAE 5W-30 4l - 21384
Aral HighTronic G SAE 5W-30 60l - 21381
Aral HighTronic G SAE 5W-30 208l  - 21380
Aral HighTronic J SAE 5W-30 1l - 20198
Aral HighTronic J SAE 5W-30 4l - 20194
Aral HighTronic J SAE 5W-30 60l - 20191
Aral HighTronic J SAE 5W-30 208l – 20190
Aral HighTronic R SAE 5W-30 1l - 16008
Aral HighTronic R SAE 5W-30 4l – 16004
Aral HighTronic F SAE 5W-30 1l - 10332
Aral HighTronic F SAE 5W-30 60l - 3692
Aral HighTronic F SAE 5W-30 208l – 10333
Aral ECOTronic F SAE 5W-20 1l - 25097
Aral ECOTronic F SAE 5W-20 4l – 25094
Aral MegaTronic SAE 10W-60 1l - 24927
Aral MegaTronic SAE 10W-60 4l – 10228
Aral HighTronic SAE 5W-40 1l - 20637
Aral HighTronic SAE 5W-40 4l - 20634
Aral HighTronic SAE 5W-40 5l - 20635
Aral HighTronic SAE 5W-40 20l - 20633
Aral HighTronic SAE 5W-40 60l - 20631
Aral HighTronic SAE 5W-40 208l – 20632
Aral HighTronic М SAE 5W-40 1l - 21407
Aral HighTronic М SAE 5W-40 4l - 21404
Aral HighTronic М SAE 5W-40 60l - 21401
Aral HighTronic М SAE 5W-40 208l – 21400
Aral BlueTronic SAE 10W-40 1l - 20488
Aral BlueTronic SAE 10W-40 4l - 20484
Aral BlueTronic SAE 10W-40 5l – 20485
Aral BlueTronic SAE 10W-40 20l - 10487
Aral BlueTronic SAE 10W-40 60l - 10481
Aral BlueTronic SAE 10W-40 208l -  20480
Aral SuperTurboral SAE 5W-30 4l - 11488
Aral SuperTurboral SAE 5W-30 20l - 11482
Aral SuperTurboral SAE 5W-30 208l – 11489
Aral SuperTurboral LA SAE 5W-30 20l - 20353
Aral SuperTurboral LA SAE 5W-30 60l - 20351
Aral SuperTurboral LA SAE 5W-30 208l – 20350
Aral MegaTurboral SAE 10W-40 5l - 10625
Aral MegaTurboral SAE 10W-40 20l - 13932
Aral MegaTurboral SAE 10W-40 60l - 13931
Aral MegaTurboral SAE 10W-40 208l – 23930
Aral MegaTurboral LA SAE 10W-40 20l - 13962
Aral MegaTurboral LA SAE 10W-40 208l – 13961
MegaTurboral VR SAE 10W-40 20l – 20203
MegaTurboral S SAE 10W-40 208l – 20131
Aral  Turboral SAE 10W-40 1l - 21197
Aral  Turboral SAE 10W-40 5l - 22004
Aral  Turboral SAE 10W-40 20l - 22003
Aral  Turboral SAE 10W-40 60l - 22001
Aral  Turboral SAE 10W-40 208l – 22000
Aral Turboral SAE 15W-40 5l - 22014
Aral Turboral SAE 15W-40 20l - 11281
Aral Turboral SAE 15W-40 208l – 22119
Aral Getriebeöl EP SYNTH. SAE 75W-90 1l – 25467
Aral Getriebeöl EP 85W-90 1l – 15108
Aral  Getriebeöl  EP Plus 80W-90 20l - 15452
Aral  Getriebeöl  EP Plus 80W-90 60l - 15454
Aral  Getriebeöl  EP Plus 80W-90 208l – 25450
Aral Getriebeöl HYP 85W-90 1l - 14257
Aral Getriebeöl HYP 85W-90 20l – 14303
Aral Getriebeöl BS LSX SAE 75W-140 20l – 26342
Aral Getriebeöl ATF 22 1l - 15973
Aral Getriebeöl ATF 22 20l – 15968
Aral Getriebeöl ATF 22 208l – 15970
Aral Getriebeöl ATF 55 1l - 15928
Aral Getriebeöl ATF 55 20l – 15922
Aral Getriebeöl ATF J 1l - 56638
Aral Getriebeöl ATF J 20l -  56633
Aral Getriebeöl ATF E-S 1l – 15878
Aral Antifreeze Extra 1l – 90829
Aral Antifreeze Silikatfrei 1l - 90839
Второй вариант кодов:
4003116106259 Моторное масло ARAL MegaTurboral SAE 10W-40 (5л)
4003116204597 Моторное масло ARAL SuperTronic SAE 0W-40 (4л)
4003116204849 Моторное масло ARAL BlueTronic SAE 10W-40 (4л)
4003116204887 Моторное масло ARAL BlueTronic SAE 10W-40 (1л)
4003116212745 Моторное масло ARAL Plus Turboral SAE 15W-40 (4л)
4003116103326 Моторное масло ARAL HighTronic F SAE 5W-30 (1л)
4003116220047 Моторное масло ARAL Turboral SAE 10W-40 (5л)
4003116220078 Моторное масло ARAL Turboral SAE 10W-40 (1л)
4003116220146 Моторное масло ARAL Turboral SAE 15W-40 (5л)
4008177991288 Моторное масло ARAL Turboral SAE 10W-40 (20л)
4003116105894 Моторное масло ARAL HighTronic C SAE 5W-30 (1л)
4003116114889 Моторное масло ARAL SuperTurboral SAE 5W-30 (4л)
4003116142578 Трансмиссионное масло ARAL Getriebeol Hyp SAE 85W-90 (1л)
4003116151082 Трансмиссионное масло ARAL Getriebeol EP SAE 85W-90 (1л)
4003116158784 Трансмиссионное масло ARAL Getriebeol ATF E-S (1л)
4003116159286 Трансмиссионное масло ARAL Getriebeol ATF 55 (1л)
4003116159736 Трансмиссионное масло ARAL Getriebeol ATF 22 (1л)
4003116160084 Моторное масло ARAL HighTronic R SAE 5W-30 (1л)
4003116201985 Моторное масло ARAL HighTronic J SAE 5W-30 (1л)
4003116213971 Моторное масло ARAL HighTronic M SAE 5W-30 (1л)
4003116566381 Трансмиссионное масло ARAL Getriebeol ATF J (1л)
4003116908297 Антифриз концентрированный бесцветный ARAL Antifreeze Extra (1л)
4003116908396 Антифриз концентрированный красный ARAL Antifreeze Silikatfrei (1л)
2200000013262 Моторное масло ARAL Extra Turboral SAE 10W-40 (20л)
2200000013682 Моторное масло ARAL SuperTurboral SAE 5W-30 (20л)
4008177965005 Гидравлическое масло ARAL Vitam DE 32 (20л)
4008177990809 Моторное масло ARAL Turboral SAE 15W-40 (20л)
4008177990175 Моторное масло ARAL MegaTurboral SAE 10W-40 (208л)
2200000013279 Моторное масло ARAL Extra Turboral SAE 10W-40 (60л)
2200000013330 Моторное масло ARAL MultiTurboral SAE 15W-40 (60л)
2200000013248 Моторное масло ARAL BlueTronic SAE 10W-40 (60л)
4008177991271 Моторное масло ARAL Turboral SAE 10W-40 (60л)
2200000013286 Моторное масло ARAL HighTronic SAE 5W-40 (60л)
4003116249246 Моторное масло ARAL MegaTronic SAE 10W-60 (4л)
4003116249277 Моторное масло ARAL MegaTronic SAE 10W-60 (1л)
4008177990182 Моторное масло ARAL Turboral SAE 10W-40 (208л)
4008177943706 Трансмиссионное масло ARAL Getriebeol Hyp Synth. SAE 75W-90 (60л)
4008177959646 Трансмиссионное масло ARAL Getriebeol EP Plus SAE 80W-90 (60л)
4008177964312 Трансмиссионное масло ARAL Getriebeol ATF J (20л)
4008177978890 Трансмиссионное масло ARAL Getriebeol ATF 55 (60л)
4008177990076 Моторное масло ARAL HighTronic SAE 5W-40 (208 л)
4008177990083 Моторное масло ARAL BlueTronic SAE 10W-40 (208л)
4008177990199 Моторное масло ARAL Turboral SAE 15W-40 (208л)
14AF79 BlueTronic 10W-40     20 Liter
154FE6 BlueTronic 10W-40     4 Liter
1529FA BlueTronic 10W-40     5 Liter
14955C BlueTronic 10W-40     60 Liter
14F736 BlueTronic 10W-40    1 Liter
14F738 BlueTronic 10W-40    208 Liter
15318F EcoTronic F 5W-20     1 Liter
15318C EcoTronic F 5W-20     208 Liter
15570E EcoTronic F 5W-20     4 Liter
15318D EcoTronic F 5W-20     60 Liter
1505B4 HighTronic 5W-40 1 Liter
151C11 HighTronic 5W-40 208 Liter
1505B1 HighTronic 5W-40 20 Liter
154FE7 HighTronic 5W-40 4 Liter
1505B2 HighTronic 5W-40 60 Liter
1529F9 HighTronic 5W-40     5 Liter
15B618 HighTronic C 5W-30     1 Liter
154F51 HighTronic C 5W-30     208 Liter
15563C HighTronic C 5W-30  4 Liter
15563B HighTronic C 5W-30     60 Liter
1552A0 HighTronic F  5W-30    1 Liter
15529D HighTronic F 5W-30    208 Liter
1552A2 HighTronic F 5W-30     4 Liter
15529F HighTronic F 5W-30     60 Liter
14FEEE HighTronic G 5W-30     1 Liter
14FEEC HighTronic G 5W-30     208 Liter
155EA7 HighTronic G 5W-30     4 Liter
14FEED HighTronic G 5W-30     60 Liter
14F90C HighTronic J  5W-30       60 Liter
14F90D HighTronic J  5W-30      208 Liter
151CED HighTronic J  5W-30     1 Liter
1555F7 HighTronic J 5W-30     4 Liter
150B6A HighTronic M 5W-40     1 Liter
150B6B HighTronic M 5W-40     208 Liter
154FE8 HighTronic M 5W-40     4 Liter
150B6C HighTronic M 5W-40     60 Liter
14F898 HighTronic R 5W-30       60 Liter
14F899 HighTronic R 5W-30      208 Liter
151CEE HighTronic R 5W-30     1 Liter
1555F2 HighTronic R 5W-30     4 Liter
154FAC MegaTronic 10W-60     1 Liter
15BC4F MegaTurboral 10W-40     208 Liter
15BC45 MegaTurboral 10W-40     20 Liter
15B6C8 MegaTurboral 10W-40     5 Liter
15BC50 MegaTurboral 10W-40 60 Liter
15BD3D MegaTurboral LA 10W-40     208 Liter
15BD3B MegaTurboral LA 10W-40     20 Liter
15AB04 MegaTurboral LA 10W-40     60 Liter
15BD42 MegaTurboral LA 10W-40   4 Liter
15567F MegaTurboral S 10W-40     208 Liter
15555A MegaTurboral S3 10W-40     208 Liter
15555B MegaTurboral S3 10W-40     60 Liter
1557B4 MegaTurboral VR 10W-40     208 Liter
1557B5 MegaTurboral VR 10W-40     20 Liter
1557B6 MegaTurboral VR 10W-40     60 Liter
151CA2 SuperTronic 0W-40 (Low SAPS)     208 Liter
14AF3B SuperTronic 0W-40 (Low SAPS)     20 Liter
14950C SuperTronic 0W-40 (Low SAPS)     60 Liter
14F800 SuperTronic 0W-40 (Low SAPS)    1 Liter
154FED SuperTronic 0W-40 (Low SAPS)    4 Liter
151CA3 SuperTronic E 0W-30     208 Liter
154FEE SuperTronic E 0W-30   4 Liter
149A1B SuperTronic E 0W-30     60 Liter
14F802 SuperTronic E 0W-30    1 Liter
15A8B0 SuperTronic G 0W-40     208 Liter
15A8AF SuperTronic G 0W-40     60 Liter
15A8AD SuperTronic G 0W-40    4 Liter
15A8AE SuperTronic G 0W-40    1 Liter
15135C SuperTronic Longlife III 5W-30     208 Liter
14AF40 SuperTronic LongLife III 5W-30     20 Liter
152A0E SuperTronic Longlife III 5W-30     5 Liter
14954B SuperTronic LongLife III 5W-30     60 Liter
14F7FD SuperTronic LongLife III 5W-30    1 Liter
15503C SuperTronic LongLife III 5W-30   4 Liter
15B6B5 SuperTronic LL IV FE 0W20 1 Liter
15B6B7 SuperTronic LL IV FE 0W20 208 Liter
15B6B6 SuperTronic LL IV FE 0W20 60 Liter
1556AA SuperTurboral  5W-30    208 Liter
1556A9 SuperTurboral  5W-30    20 Liter
1556AD SuperTurboral 5W-30     4 Liter
1556AC SuperTurboral 5W-30     60 Liter
15870F SuperTurboral LA 5W-30     208 Liter
15870E SuperTurboral LA 5W-30     20 Liter
15871F SuperTurboral LA 5W-30     4 Liter
15871A SuperTurboral LA 5W-30     60 Liter
15BCCA Turboral 10W-40      1 Liter
15BCD3 Turboral 10W-40      208 Liter
15BCD2 Turboral 10W-40      20 Liter
15BCD5 Turboral 10W-40      5 Liter
15BCD4 Turboral 10W-40      60 Liter
15BC5E Turboral 15W-40       20 Liter
15BC64 Turboral 15W-40       60 Liter
15BC61 Turboral 15W-40      208 Liter
15554B Turboral 15W-40      5 Liter
15B6C6 Turboral 15W-40     1 Liter
15569F Turboral 20W-20     208 Liter
15569E Turboral 20W-20     20 Liter
15BBD3 Turboral 20W-50     1 Liter
15BBD2    Turboral 20W-50     208 Liter
15BBD1    Turboral 20W-50     20 Liter
15BBD4 Turboral 20W-50     5 Liter
Aral Super Tronic Longlife III 5W-30
Aral HighTronic 5W-40 API SL
Aral High Tronic 5W-40
Aral SuperTronic 0W-40
Aral SuperTronic G 0W-30
Aral SuperSynth 0W-40
Аral Ep Synth 75w-90 API GL-4/5
Aral Getriebeöle EP Synth 75W-90 API GL-4+
Aral Supertronic G 0W-30 отработка на Lada Granta после 4400км.
Аral Supеr Trоnic 0w-40 отработка на Lеxus после 11300км
А фиг его знает. Судя по тому что у арала по старым продуктам куча мсдс-тдс-ов это скорее всего либо новый продукт, либо рецептура не менялась
Вот и я не понял. Хотя я не спец, ну судя по aral.ua и их таблице сравнения с SuperTronic 0W-40 это масло стремиться к допуску VW504 с условностями.
Изменено пользователем GAn77
 про кольца не могу ничего сказать, да и с чего бы им залечь при на такой базе и с таким коротким интервалом замены... расход масла при моём режиме почти не заметный до замены, но единственное на что грешу, это надо проверить маслопомойку на предмет её перемерзнаия в сильный мороз, тк маслопомойка была всегда горячей если потрогать после поездки, а последние разы что трогал холодная.... теоретически он могла перемерзать и газы могли скапливаться... но думаю это маловероятно .... просто сильно часто двигатель в сильные морозы не прогревался до полной температуры пока доеду до работы, почти не грел на ХХ , а только в движении, а при сильном морозе порой 20км проедешь пока стрелка до уровня доползёт, а было даже что стрелка падала на ходу до половины....
я на зиму прорези для вентиляции в защите картера заклеил скотчем. Если защиты нету, как вариант можно обклеить картер спленом или подобным материалом, чтобы не охлаждался в движении.
ну у меня открыт только картер, как и на других авто.. а радиатор полностью закрываю сразу с начала зимы, утеплитель под капот и тд, не первый год на севере... просто Д4 зимой без нагрузки не греется нифига.... да в -37 с ветром 15, да на ходу.... приходится коробку на 4ю 5ю передачу в мануал ставить чтобы хоть оборотами греть.... при этом печка жарит на ура, в -37 на климает 22С стоит, она кстати тоже хорошо мотор выстужает
ну для полноты картины и картер надо закрыть :)
@Nordman, давно надо прислать это масло на анализ. Так не скажешь - очень много от состояния машины зависит... клапан егр, забитость каталиков, кольца, колпачки, бензин, да все короче куда пальцем не ткни может быть виновато в саже.
уже только новое Арал смогу...
ЕГР нет у меня, каталики и лямды на Е4 сразу отрабатывает чек, колпачки на 100тык на этих моторах ещё никто не менял, это не срок.... судя по выносу масла через систему вентиляции-газы в картер не прут как сумашедшие - порядка 100гр на 10тык... состояние маслосъемных трудно оценить ибо машина зимой тошнит на 1500об, а не ездит, считай постоянный ХХ, что в движении, что на стоянке...
согласен, для этого мотора видимо это необходимость....
Заливал в свои авто: Марк 2 Кволис 5s-fe 2.2 и Соарер 2jz-Ge 3.0. масла Aral High Tronic 5-40 в летне-зимний период, затем летом 10-40 Блютроник, летом 2012 г., проблем не было, все как обычно.
Пробеги большие на обоих авто за 300 000 км., режимы город 80% трасса 20 % (300 км).
Новосибирск.
парни, а есть отзывы о Aral HighTronic M 5W-40 ?
Aral SuperSynth 0W-40 - никто не подскажет номер для заказа масла через exist и ему подобные?
Aral OIL2227 Масло моторное синтетическое "SuperTronic 0W-40", 1л
Aral OIL2228 Масло моторное синтетическое "SuperTronic 0W-40", 4л
катаю Арал последние 3 года. наверное в первую очередь из-за его цены SuperTronic (LL-04) 0w40 - 6eur за литр при покупке в интернете с доставкой по европе. немцы на форумах сами смеются, что дешевле только воды налить. Но на оригинальной заправке оно почти 15 евро стоит. Вот лежит у меня последняя литрушка, нужно на тест прислать вам.
Изменено пользователем samches
только что сравнил щиты Aral SuperSynth 0W-40 и Castrol ЭДЖ 0W-40 - циферка в циферку :) есть ли смысл покупать какоето одно из этих масел и надеяться, что в канистре первого или второго будет все таки немного качественнее продукт или они полностью идентичны не только характеристиками но и качеством?
Этикеточка, этикеточка. Она все расскажет. Есть у кастрола EDGE многонациональное, на обороте в три слоя на разных языках о нем рассказано, а есть русско-украинский вариант. Второе - спецпродукт для нашего рынка, его брать не стоит...
Вот, напримерpost-2513-0-44354100-1362135674_thumb.jpg, далее post-2513-0-63744300-1362135805_thumb.jpg, это я так думаю, настоящий Кастрол, который продается по Европе. А вот post-2513-0-19995500-1362135986_thumb.jpg, соответственно на обороте только английский, русский и украинскийpost-2513-0-31947200-1362136021_thumb.jpg
А вот Аралpost-2513-0-58042000-1362135818_thumb.jpg, внутри post-2513-0-68653200-1362135825_thumb.jpg
Изменено пользователем RuuS
Лихо по этикетке определить спецпродукт... :facepalm:
ЗЫ посмотрите на битоге как нибудь анализы Кастрола Эдж (есесно без руского перевода), так я вам открою тайну, он такой же как наш (спецпродукт с русским переводом) Вы только никому об этом не говорите :D
