Nitto 4M-117 (Mitsubishi Delica, Eclipse, Galant, Lancer, Outlander, Pajero)
Nitto 4M-117 Made in Japan
Применяемость:
Mitsubishi Aspire, EA1A, EC7A, EA7A, EC1A
Mitsubishi Bravo, U41V, U42V
Mitsubishi Carisma, DA2A
Mitsubishi Chariot Grandis, N84W
Mitsubishi Chariot, N48W, N34W, N43W, N44W, N33W
Mitsubishi Colt, Z27A, Z26A, Z25A, Z24A, Z28A, Z24W, Z23W, Z23A, Z22A, Z21A
Mitsubishi Delica Space Gear, PD4W, PC4W, PB4W, PA4W, PA3V
Mitsubishi Delica Star Wagon, P23V, P24W, P07V, P17V, P06V, P27V, P04W, P03V, P02V, P13V, P03W, P01V, P12V
Mitsubishi Delica Truck, L036P, L063P, P02T, P13T
Mitsubishi Delica, CV5W
Mitsubishi Diamante, F34A, F12A
Mitsubishi Dingo, CQ5A, CQ2A, CQ1A
Mitsubishi Dion, CR5W, CR6W
Mitsubishi Eclipse Spyder, D38A
Mitsubishi Eclipse, D32A, D27A, D22A
Mitsubishi Emeraude, E52A, E72A, E54A, E64A, E53A
Mitsubishi Eterna Sava, E39A, E32A, E37A, E35A, E33A
Mitsubishi Eterna, E35A, E39A, E64A, E52A, E33A, E72A, E54A, E53A
Mitsubishi FTO, DE3A, DE2A
Mitsubishi Galant Fortis, CY4A
Mitsubishi Galant Sigma, E12A, E19A
Mitsubishi Galant, EC7A, EA7A, EC1A, EA1A, E72A, E53A, E64A, E54A, E32A, E31A, E52A, E33A, E35A, E38A, E37A, E39A
Mitsubishi Grandis, NA4W
Mitsubishi Lancer Cedia, CS6A, CS2W, CS2V, CS5W, CS2A, CS5A
Mitsubishi Lancer Evolution, CY4A
Mitsubishi Lancer, CE9A, C37W, C12W, CK2A, CK1A, CC3A, CM2A, C72A, CC4A, CM5A, CA4A, CA3A, CK4A, CS2V, CA2A, CK6A, CA1A, CS2A, CB6A, C12V, CS6A, CS5A, CD9A, C11V, C32V, CJ4A, CS5W, CJ2A, CJ1A, C62A, CB1A, CD5A, C61A, CL2A, CB4A, CB3A, CS2W, CD3A, CB2A
Mitsubishi Legnum, EC4W, EA1W, EC5W, EC7W, EA7W, EA5W, EA4W, EC1W
Mitsubishi Libero, CB2V, CB4W, CD5W, CD2V, CB2W, CB1V, CB5W
Mitsubishi Mirage, CJ2A, CD9A, CJ1A, CJ4A, CB6A, CB3A, CB4A, CD5A, CB1A, CD3A, CB2A, C51A, CL2A, C72A, C52A, C11V, C12V, C32V, CK4A, CA4A, CK2A, CM5A, CE9A, CC4A, CA1A, CK6A, CA3A, CC3A, CA2A, C82A, C61A, CM2A, CK1A, C62A, C37W, C12W
Mitsubishi Outlander, CW4W, CW5W, CW6W
Mitsubishi Pajero iO, H67W, H77W, H76W, H66W, H61W, H72W, H62W, H71W
Mitsubishi Pajero, V21W
Mitsubishi RVR, GA3W, GA4W, N23WG, N21WG, N21W, N11W, N23W, N13W
Mitsubishi Sigma, F12A
Nissan Vanette
Экспертизы масляного фильтра Nitto 4M-117:
Nitto 4M-117 - пилил Ex-Gubkin
Nitto 4M-117 Made in Japan пилил torcon
Nitto 4M-117 Made in Japan пилил Ermito
1 час назад, Olejik сказал:
дренажный клапан срывало и он стоял как попало при снятии фильтра
«Резиновый» противодренажный? Или перепускной металлический?
29 минут назад, Thought сказал:
Резиновый, тот что сверху, рыжего цвета.
То ли поджимная пластина слабая, не удерживает. То ли в целом конструкция такая.
2 часа назад, Olejik сказал:
Интересно. Фоток нет?
Thought скорее всего нет, либо если и есть, то на старом телефоне где-то. Очень давно было, с тех пор и не ставил их.
Можно нагуглить, были случаи не только у меня со 113 фильтром, возможно даже тут на форуме и были.
 Клапан немного смещается из центра, но не рвётся
Изменено пользователем Olejik
07.10.2026 в 17:49, mxt33 сказал:
Я имел ввиду, что появилась натертость на плоскости, к которой фильтр прижимается. На фотографии выдели стрелочками. К тому как фильтрует вопросов нет :)
Обратил внимание на посадочную поверхность на своем авто:
тоже царапанная.
Стоял фильтр Vic затянутый на 3/4. Визуально кромка фильтра касалась.
Установил Mann, там все с зазором:
Подозреваю, что все из за формы прокладки: у Mann - прямоугольная, ее не продавить, японских фильтров форма округлая. Да и торчит на mann прокладка сильнее
Изменено пользователем Thought
8 часов назад, Thought сказал:
тоже царапанная.
Сейчас тоже посмотрел запасы. На Vic C 415 и Nitto 4m-117 круглая резинка мягкая и легко продавливается. А вот Hengst H97W05 в этот раз с плоской - ее действительно так не продавить. Просто оригинальный фильтр был с круглой, потом два Hengstа были с круглой. А потом, вот прочитав отзывы и топ фильтров, закупил Нитто. Сейчас поставил Vic, следующим наверно поставлю Hengst с плоской :)
Для оценки наличия зазора между внешней кромкой фильтра и посадочной поверхностью предлагаю не хитрый расчет.
Шаг резьбы 1,5 мм, то есть за один оборот фильтр должен сжать прокладку и приблизиться к посадочной поверхности на 1,5 мм. По инструкции мы должны сделать 3/4 оборота, то есть прокладка должна поджаться на 1,5х(3/4)=1,125 мм
За счет незначительных деформаций, зазоров там будет чуть меньше, около 1 мм как раз.
mxt33 чтоб не царапать поверхность выбирайте фильтры у которых прокладка торчит за кромку более чем на 1,3 мм.
Посмотрел фильтры из наличия с резьбой М20х1,5. Прокладка торчит за внешнюю кромку:
Vic C-225 Vic, C-224, C-809, -1,1 мм,
Nitto 4HM-113 Nitto,  4ND-111, 4ND-110 - 1,2 мм,
Nitto 4M-117 - 1,3 мм,
W 610/3 Mann, W 67/1 Mann - 1,4 мм
Получается, что 4M-117 Nitto как раз таки не должен был царапать поверхность, там же прокладка более толстая. Это наверное от других фильтров осталось.
Хотя, расчет расчетом. Пробовать нужно
51 минуту назад, Thought сказал:
Хотя, расчет расчетом. Пробовать нужное
До Нитто там была небольшая царапка в 1 месте, а вот после нитто поцарапалось все по кругу. После замены предпоследнего было около половины, а последний все добил. Имхо, ржавая кромка помогла в этом. Надо было, конечно вести фотодневник, но да ладно. В следующий раз самостоятельно масло буду менять наверно не скоро (если не забью на 4 ТО у дилера =). Можно будет попробовать примерить фильтры, как они сидят в реальности.
mxt33 , есть сервисмены дебилы, фильтры инструментом дотягивают. Соответственно , они прожать могут любую прокладку. За ними смотреть надо, чтоб быть в чем-то уверенным. А так, по фото ваша ржавая кромка фильтра целая, без следов соприкосновения. Так что хз.
42 минуты назад, Сергей Николаевич сказал:
После ТО у дилера я всегда откручивал фильтры рукой. Единственный раз, когда я не смог открутить, это первый фильтр, который поставили на заводе. После 2.4к пробега я не смог, купил ключ-чашечку. Воспользовался один раз, и  с тех пор он просто лежит в запасе :)
Как доберусь, сделаю замеры на фильтре и натертой плоскости и вернусь. В целом это просто мелочь, не протрется же там до дыр )
57 минут назад, mxt33 сказал:
Главное чтоб герметично было. А то скачем с размера на размер. И на том диаметре где у одного фильтра кромка (и царапины на поверхности от нее), у другого может быть прокладка
