Масло для Subaru Forester SJG
Subaru Forester, 13г, правый, кузов SJG
Пихло FA20 Turbo (2.0)
По мануалу объем вместе с фильтром 5,1л, 5w30 класса SN/GF-5
Обитание г.Находка
Эксплуатация в основном это короткие пробеги, так как все по близости, но и частенько получает под хвост
Интервал у меня всегда один 5000км
Сейчас залито ELF EVOLUTION FULL-TECH MSX 5W-30, поищу конечно в выходные такое, но всегда должна быть альтернатива )
4 часа назад, Алексей125rus. сказал:
По мануалу для FA20DIT 5w30/40,нулёвки запрещены.
Прямо так и написано? Ладно, теплые зимы в Приморье, в Якутии при -40то же больше вреда будет от 0/30, чем пользы от 5/30?
8 часов назад, Алексей125rus. сказал:
Точно?...такое написано в мануале?
6 часов назад, biguxa сказал:
9.3.4 Turbocharged, Direct Injected FA series Engines
 The FA20 DIT was introduced in the 2014 Forester XT and replaced the EJ25 in the 2015 WRX. Direct injection is new to Subaru and carries with it a couple potential problems highlighted by other manufacturers, namely fuel dilution of the oil and carbon deposits on intake valves. Early UOA results in FA20 DIT engines indicate fuel dilution is a substantial problem, and Subaru's shortening of the change interval from 7,500 to 6,000 miles for 2015 provides some evidence they're aware of the problem. No reports of carbon buildup have surfaced as of the time of writing, but it is a problem owners should watch. The engines are still fairly new, but the incidence of spun bearings in the FA turbo engines appears substantially less than their EJ series forbears, so the necessity of using thicker oil in these engines seems less than in the EJ. The FA20 DIT already uses a thicker oil than its naturally aspirated brother, the FA20 (5w30 vs 0w20). The potential for carbon deposits, though may make a low-SAPS European oil (ACEA C3 or C4) a good choice, with the extra HT/HS safety margin coming as a bonus.
 Normal Street Driving
 Synthetic API RC/ILSAC 5w30 has proven suitable for FA turbo engines on the street.
 Heavy Use
 Subaru does not specify heavier oil for heavy use in the FA20 DIT, but stepping up to a Heavy Duty 30 grade or 40 grade oil for heavy use will provide some margin of safety. Doing so poses some risk of denial of a warranty claim.
 Modified Engines
 Owners of modified cars are wise to use HD 30 grade oils at a minimum for street use. Modified cars receiving heavy use should have a high capacity oil cooler installed in addition to the use of HD oil. For occasional heavy use, modified cars can get away with shear stable HD 40 grade oil conforming to ACEA A3/B4, or a combination of E7 or E9 and a gasoline specification like API SM.
Это только для FA20 DIT, установленного в Forester.
 Объем моторного масла:
 Полная замена масла - 5,4 Qts (5,1 литра) - обратите внимание, что при использовании вторичного фильтра большего размера вам может потребоваться больше масла.
 Dip Stick от низкого до полного - 1,1 Qts (1,0 л)
 Тип и сорт масла:
 ТОЛЬКО 5W30 Synthetic можно использовать для замены масла.
 -5W30 или 5W40 Synthetic или обычное масло можно использовать для доливки, но при следующей замене масла используйте ТОЛЬКО синтетическое масло 5W30.
 -0W20 или 5W20 НЕ подходят для замены масла.
 Приемлемыми сортами масла являются ILSAC GF-4, GF-5 или классификация API SM или SN.
11 часов назад, skorp777 сказал:
5w30 много масел, лей хорошую синтетику, и нечего не будет в -40,ну если овощить  то может и можно ,а зачем тогда нужна машина с таким двигателя ездить на 2т оборотах
Вот ещё с яп.мануала
SUBARU MOTOR OIL ECO 0W-20 (ターボ車は使用不可) 0W-20 SUBARU MOTOR OIL SN 0W-20 (ターボ車は使用不可) 0W-20 (SN) SUBARU MOTOR OIL SM 0W-20 (ターボ車は使用不可) 0W-20 (SM) SUBARU MOTOR OIL SN 5W-30 5W-30 (SN) SUBARU MOTOR OIL SM 5W-30 5W-30 (SM) SUBARU Castrol SLX Professional SM 5W-40 5W-40 (SM) SUBARU elf
35 минут назад, Алексей125rus. сказал:
Гениально
44 минуты назад, Алексей125rus. сказал:
для начала нужно изучить мат.часть и понять отличие 0w от 5w
1 час назад, Алексей125rus. сказал:
Тип и сорт масла:
Это перевод корявый...здесь не написано про вязкость ТОЛЬКО 5-30..... (т.к. дальше и 5-40 упоминается), имеется ввиду ТОЛЬКО Synthetic (синтетическое)......
По ихнему тип - это Synthetic или обычное масло
По ихнему сорт - это ILSAC GF-4, GF-5 или классификация API SM или SN.
Запрета на 0-30 не просматривается.....
В чём разница 5-30 и 0-30 (при прочих равных, например ILSAC GF-5)?...
А почему (при прочих равных) на 0-30 только "овощить" на 2т .оборотах, а на 5-30 можно не "овощить"?...
18 часов назад, biguxa сказал:
Есть русские мануалы  там 5w30 рек., а 5w40 можно на доливку. Короче по допускам A5,A3,GF5. О ни какой нулёвки и речи нет
21 час назад, biguxa сказал:
Если хочешь нулёвки то 0w40,вот у меня на этом двс температура масла 5w30 ,летом 118 гр зимой до 102 гр доходит. Это не городская езда. Есть мануал там рекомендации 5-30/40 а там сам решай ,режим езды, город, трасса, и на масле не экономить. Я меняю 3.5-4 т.к это 100 мот.часов  выходит.
22 часа назад, Oleg_is_250 сказал:
Мат.часть изучена,профессия  такая.
41 минуту назад, Алексей125rus. сказал:
Ни чё не понял....
Почему можно 5-30, а 0-30 нельзя (у них же так сказать "рабочая вязкость" одинаковая),..... но вдруг можно 0-40.....а зачем в зиму 40-ку, если в лето идет 30-ка?
Изменено пользователем biguxa
