3 ноября 20206 г Популярное сообщение Закреплён Quote Engine: TB48DE, Petrol 4.8 liters Type of oil used: Shell Helix Ultra I 5W-40 Type of car: Nissan Patrol manufacturing year: 2015 Transmission type: Automatic Transmission Total kilos on the odometer: 175 thousand kilometers Distance traveled on oil: It is not known exactly But almost 7,500 km The presence of deposits in the engine: There are no deposits Operation period: March 16 - September 20, before the Pandemic and during the full and partial Lockdown, temperature range from +20 to +50 ° C Oil service life: 6 months and 4 days Fuel Type: 65% 91 Octane gasoline (Mid-March, and months: April-July-August to mid-September) 35% 95 Octane (May and June) Driving modes: The maximum speed reached is 130 kilometers per hour95% in the city5% outside the cityFrequent short tripsLong and frequent engine idle periods, up to 25 minutes of waiting inside the carlittle off-roading, not that hard on the engine. Oil Filter Type: like what the dealership sells, from MAHLE Air Filter Condition: new Status of the fuel filter: New Injectors condition: It was disassembled and cleaned with an external device before changing the previous oil Spark plugs state: old Oil volume: Total 6.8 liters according to the catalog of the car filled with 6.8 liters. Oil sample withdrawal method: thought the drain hole The oil used before this oil: could be a Shell Helix Ultra 1 5W-40 Engine Flush: Not used Additives to oil: Not added. Additives to fuel: Not added. Here is the fresh analysis VOA: as you noticed the alkaline number were estimated based on ASTM D2896 and Molybdenum 23ppm whereas the VOA Molybdenum was less than 1ppm Изменено 3 ноября 20206 г пользователем Abadi55z
3 ноября 20206 г Abadi55z вы не ошиблись? Март 2016 - сентябрь 2020? Изменено 3 ноября 20206 г пользователем Skif_tlt
3 ноября 20206 г Автор 2 минуты назад, Skif_tlt сказал: Abadi55z вы не ошиблись? Март 2016 - сентябрь 2020? 16th of March till 20th of September Цитата Oil service life: 6 months and 4 days
3 ноября 20206 г Abadi55z почему измерили отработку методом ASTM 2896? Изменено 3 ноября 20206 г пользователем Евген 48
3 ноября 20206 г Автор Только что, Евген 48 сказал: Abadi55z почему измерили отработку методом ASTM 2896? I don't know why, most laboratories here test the waste oil by this method.
3 ноября 20206 г 2 минуты назад, Abadi55z сказал: I don't know why, most laboratories here test the waste oil by this method. Если есть возможность, спросите, почему не ASTM 4739.
3 ноября 20206 г Автор 7 минут назад, Евген 48 сказал: Если есть возможность, спросите, почему не ASTM 4739. Yes I had a little chat with the guy who is responsible for the analysis, and from what I remember he said this is the same method and there are no differences between ASTM 4739 and ASTM 2896. and I was like
3 ноября 20206 г 3 часа назад, Abadi55z сказал: Yes I had a little chat with the guy who is responsible for the analysis, and from what I remember he said this is the same method and there are no differences between ASTM 4739 and ASTM 2896. If he said so he is an irresponsible person
3 ноября 20206 г Автор 10 минут назад, Dimmy сказал: If he said so he is an irresponsible person Probably right, from your own perspective can we say ASTM D4739 is always less than the ASTM D2896 by 1 to 1.5 units. Is that right for the worked out oil? In this situation can we say the correct TBN should be around 6.96 - 6.46?
3 ноября 20206 г Abadi55z возможно, но всё равно надо измерять, а не гадать на пальцах, в любом случае масло рабочее. perhaps, but you still need to measure, and not guess on your fingers, in any case, the oil is working.
3 ноября 20206 г 31 минуту назад, Abadi55z сказал: from your own perspective can we say ASTM D4739 is always less than the ASTM D2896 by 1 to 1.5 units. Is that right for the worked out oil? It works only with virgin oils. If we use the D4739 and D2896 methods for the used oil the difference may be bigger. In your case 8 by D2896 may correspond to 7, 6 and even 5 by D4739. The oxidation of the motor oil makes the relation between TBN by different methods quite unpredictable. Изменено 3 ноября 20206 г пользователем Dimmy
3 ноября 20206 г 33 минуты назад, Abadi55z сказал: In this situation can we say the correct TBN should be around 6.96 - 6.46? Possible but not for sure.
3 ноября 20206 г As for Molybdenum. Actually, I think there should be no Mo in this Ultra I 5W-40. But in your UOA there is some, though twice lower than might be expected. Qiute strange. I don't know what to think. If you are absolutely sure that the previous oil was also Ultra I and the UOA is the same oil that your VOA - then it may be explained by the presence of Mo in Ultra I 5W-40. But why the Lab did not see Mo in the VOA and did it in UOA? The Lab is the same, isn't it?
