20 октября 201610 г Закреплён Масляный фильтр Purflux LS285 Применяемость: CHRYSLER Voyager IV 3.8 142KW(193PS/HP) Wrangler 3.8 146KW(199PS/HP) FORD Courier 1.3 44KW(60PS/HP) Courier 1.3i 44KW(60PS/HP) Escort III 1.1 40/43KW(55/59PS/HP) Escort III 1.1 37KW(50PS/HP) Escort III 1.3 48/51KW(66/69PS/HP) Escort III 1.3 51KW(70PS/HP) Escort III 1.6 71KW(97PS/HP) Escort III 1.6 58KW(79PS/HP) Escort IV 1.3 44KW(60PS/HP) Escort IV 1.3 51KW(70PS/HP) Escort IV 1.4 54/55KW(73/75PS/HP) Escort IV 1.6 75KW(102PS/HP) Escort IV 1.6 66KW(90PS/HP) Escort IV 1.6 58KW(79PS/HP) Escort IV1.6i Cat. 66KW(90PS/HP) Escort RS 1.6 Turbo 97KW(132PS/HP) Escort RS 1.6i 85KW(115PS/HP) Escort V 1.3 44KW(60PS/HP) Escort V 1.3i 44KW(60PS/HP) Escort V 1.4i 52KW(71PS/HP) Escort V 1.6 66KW(90PS/HP) Escort V 1.6i 77/79KW(105/108PS/HP) Escort VI 1.4i CFi (Single Point Injection) 52KW(71PS/HP) Escort VI 1.4i EFi (Multipoint Injection) 55KW(74PS/HP) Escort VI 1.4i, Cat. 55KW(75PS/HP) Escort XR3 1.6 71KW(96PS/HP) Escort XR3i 1.6 75KW(102PS/HP) Escort XR3i 1.6, Cabrio 77KW(105PS/HP) Fiesta I 1.0 29KW(40PS/HP) Fiesta I 1.1 39KW(53PS/HP) Fiesta I 1.3 49KW(66PS/HP) Fiesta II 1.0 33KW(45PS/HP) Fiesta II 1.1 37KW(50PS/HP) Fiesta II 1.3 51KW(69PS/HP) Fiesta II 1.4 54/55KW(73/75PS/HP) Fiesta II XR2 1.6 70/71KW(95/97PS/HP) Fiesta III XR2i 1.6i 76KW(103PS/HP) Fiesta III XR2i 1.6i 81KW(110PS/HP) Fiesta III 1.0 33KW(45PS/HP) Fiesta III 1.1i 37KW(50PS/HP) Fiesta III 1.1i 40KW(55PS/HP) Fiesta III 1.3 44KW(60PS/HP) Fiesta III 1.3i 44KW(60PS/HP) Fiesta III 1.4i 52/54KW(71/73PS/HP) Fiesta IV 1.0i 48KW(65PS/HP) Fiesta IV 1.0i 38KW(52PS/HP) Fiesta IV 1.3i 37/44KW(50/60PS/HP) Fiesta IV 1.4 Cfi 66KW(90PS/HP) Fiesta XR2 62KW(84PS/HP) Ka I 1.0i 48KW(65PS/HP) Ka I 1.0i 38KW(52PS/HP) Ka I 1.3i 44KW(60PS/HP) -->09/02 Ka I 1.3i 37KW(50PS/HP) Orion 1.3 51KW(69PS/HP) Orion 1.3 44KW(60PS/HP) Orion 1.3i Orion 1.4 54/55KW(73/75PS/HP) Orion 1.4i 52KW(71PS/HP) Orion 1.4i, 1.4i Cat. 52KW(72PS/HP) Orion 1.6 66KW(90PS/HP) Orion 1.6 58KW(79PS/HP) Orion 1.6i 75KW(102PS/HP) Orion 1.6i 16V 77/79KW(105/108PS/HP) Orion 1.6i, 1.6i Cat. 77KW(105PS/HP) Sierra 1.6 53/55KW(72/75PS/HP) Sierra 1.6i 59KW(80PS/HP) Sierra 1.8 64/66KW(87/90PS/HP) Sierra 1.8i 59/64KW(80/87PS/HP) Sierra Sapphire 1.6 59KW(80PS/HP) Sierra Sapphire 1.6i Sierra Sapphire 1.8 66KW(90PS/HP) FORD USA Belina Corcel, Corcel GT Fiesta 1.3, 1.6 LADA Granta 1.6 72KW(98PS/HP) Granta 1.6 64KW(85PS/HP) Granta 1.6 60KW(80PS/HP) Kalina 1.6 72KW(98PS/HP) Kalina 1.6 78KW(106PS/HP) Kalina 1.6 64KW(87PS/HP) Priora 1.6 72KW(98PS/HP) Priora 1.6 60KW(82PS/HP) Priora 1.6 64KW(87PS/HP) Priora 1.6 LPG 71KW(95PS/HP) MAZDA 121 1.2i 16V 55KW(75PS/HP) 10/97--> 121 1.3 37/44KW(50/60PS/HP) RENAULT Alpine 1600 75KW(102PS/HP) Alpine A 310 V6 110KW(150PS/HP) -->06/84 Fuego Turbo 97KW(132PS/HP) -->06/84 Fuego TX, GTX 81KW(110PS/HP) -->06/84 Jeep CJ7 Standard, Renegade, Laredo 62KW(85PS/HP) -->06/84 Master I 2.0 58KW(80PS/HP) R14 GTS, TS 51KW(70PS/HP) R14 L, TL, GTL 43KW(58PS/HP) R18 Turbo 92KW(125PS/HP) -->06/84 R18 TX, GTX 76KW(104PS/HP) -->06/84 R20 LS, TS, TX 76/85KW(104/116PS/HP) R25 GTX 92KW(126PS/HP) -->06/84 R25 TS, GTS 76KW(103PS/HP) -->06/84 R25 V6 Inj. 104KW(141PS/HP) -->06/84 R30 TS, Automatic 94KW(128PS/HP) R30 TX, Automatic 104KW(142PS/HP) Trafic I 2.0 63KW(86PS/HP) -->06/84 TOYOTA 4 Runner 2.4 82KW(112PS/HP) Runner 3.4i 136KW(185PS/HP) VOLVO 340 1.4, DL 46/47/51/53KW(63/64/69/72PS/HP) -->06/84 343, 345 1.4, L, DL, GL 51KW(70PS/HP) 55 1.1 33/40KW(45/54PS/HP) 66 1.1 33KW(45PS/HP) 66 1.3 42KW(57PS/HP) Экспертизы масляных фильтров:
14 января 20197 г Интересный вопрос. Смотрел распил такого фильтра на Драйве. Там экспериментатор насчитал всего 10дм2 фильтрующего материала. Он срезал бумагу по герметику, и разложив получившийся материала померил. Но в характеристиках даны ах 15 дм2. Как это мерили?
20 января 20197 г Автор В 14.01.2019 в 20:59, KolaDOOMer сказал: всего 10дм2 Даже это не "всего", а очень неплохой результат. У Mann W914/2 по паспорту - 1038см2, а по замерам ~825-880см2. У Mahle OC384 намерили ~996см2. Изменено 20 января 20197 г пользователем TDream
21 января 20197 г Вот мне интересно, как это измеряют. Просто тупо берут площадь бумаги которая идет на фильтр? Кстати, на драйве измеритель в W914/2 - намерил тоже 10дм2
16 апреля 20197 г Диаметр отверстия перепускного клапана 12,6мм Площадь получается 1,247см2, усилие начала открывания на весах- 2,5кг Давление посчиталось - 2кГ/сМ2 Изменено 16 апреля 20197 г пользователем AliBaba
30 марта 20206 г 16.04.2019 в 11:00, AliBaba сказал: Диаметр отверстия перепускного клапана 12,6мм Площадь получается 1,247см2, усилие начала открывания на весах- 2,5кг Давление посчиталось - 2кГ/сМ2 То наверное вы на полный ход продавили, нужно посмотреть как только приоткрывается клапан.
18 октября 20215 г 30.03.2020 в 20:28, Максим Л. сказал: удалил Изменено 18 октября 20215 г пользователем AliBaba
6 мая 20233 г Что можно добавить? Объем фильтра около 300 мл, а аналогичных, к примеру для ВАЗ, почти в два раза больше. Кто привык наливать масло чОтко по объему, с данным фильтром будет перелив примерно на 200-300мл. Это можно учитывать при замене.
25 мая 20233 г 06.05.2023 в 14:31, Юрбан сказал: 200 мл это ни о чем. Масло доливают до "нормы" после запуска двигателя. ну если знаешь сколько и наливаешь до MAX. то будет перелив на 200-300мл. Выше МАХ на пару миллиметров. А если не знаешь сколько лить, так и об чем разговор?
