14 июня 20179 г Закреплён AR6400-D Professional PEA Concentrate For Diesel and Biofuel Blended Diesel DESCRIPTION: AR6400-D is a fuel additive blended from the latest high-strength polyetheramines and PIBSA/PIBSI detergents that quickly and safely removes gum, varnish and carbon deposits from the fuel system and engine. Advanced combustion modification chemistry then maximizes combustion performance to help remove post combustion hydrocarbon build-up whilst rapidly reducing harmful exhaust emissions. AR6400-D quickly restores lost engine performance and fuel economy in addition to unique properties that help protect surfaces from further deposit build-up. Molecule by molecule deposits are safely removed from the diesel injectors and combustion area thus improving combustion efficiency and enabling emission control systems such as the DPF to operate more efficiently. AR6400-D is suitable for all diesel engines running on pump, bunkered or bio-diesel blended fuel. Features/Benefits: Cleans harmful deposits and prevents future accumulation Restores fuel efficiency Restores fuel economy Restores power and performance Smoothes rough idling Lowers harmful exhaust emissions Lubricates and protects the fuel system HISTORY: The first family of dispersant/detergents were amines with a polyisobutylene (PIB) tail. The PIB tail gave good solubility and the amine group provided surface activity that lifted deposits from the metal surface. However the PIB tail, as a polymer, gave the undesirable effect of stickiness so the PIB amine had to be combined with a fluidizer to ensure that it flowed through the combustion region of the engine and did not build up any residues. The fluidizer was typically a polyolefin epoxide. The next generation of chemistries combined the fluidizer with the polymeric amine. These are called polyetheramines or PEA. Polyetheramines do not require the addition of a fluidizer and the oxygen content provides enhanced surface activity. PIB amines are still widely used in gasoline and perform well. However, PEA’s offer improved combustion chamber cleaning efficiency but is considerably more expensive. There is an abundance of supply of PIB amines unlike with PEA; hence the treatment cost is significantly higher. Therefore, PEA’s are not widely found in low cost cleaners or are found in reduced quantities. AR6400-D contains the highest safe amount of PEA and accompanying chemistry to safely remove deposits. USAGE INSTRUCTIONS Add the correct amount of AR6400-D to the fuel tank first and then fill up with fuel immediately afterwards. Treatment ratio is 1:100 > 1:200. A single 14.5oz bottle will treat between 12 to 22 gallons of fuel depending upon carbon buildup. Use every 5000 miles or use once and follow up regularly with Archoil AR6200 Fuel Modification Complex. PACKAGING 14.5oz/430ml bottle В Европе есть. Упоминается здесь
14 июня 20179 г РЕА по данным msds содержится 30-50%. Однако в составе имеется ферроцен, т.е. для бензинок не айс. MSDS-AR6400-PEA.pdf
14 июня 20179 г Автор на 430 мл - это много или мало, или достаточно чтобы что-то нежелательное произошло?
14 июня 20179 г на 430 мл - это много или мало, или достаточно чтобы что-то нежелательное произошло? Да фиг его знает. Тут надо пересчитывать эти 1% не к 0,43л, а на объём бака. Допустим, для простоты, примем, что бак на 43 л., тогда концентрация получается 1:10 000 Рекомендации по применению ферроцена советуют использовать его в соотношении 200гр+- (160-300) на 1 тонну бензина. Тогда выходит соотношение 1:5000. И это при тонне, а в литрах разница будет ещё больше - допустим 1:6000 Хм-м, получается, что относительно безопасно.
14 июня 20179 г Автор м-м, получается, что относительно безопасно. Там же зеленые-экологи, все жестко, причем "химикат" и продукты его горения попадают в атмосферу. получается что "да", без явного воздействия.
