From Greece !! Oil for civic 1,8 2006 and vw polo tgi (cng)
Hello from Greece. I am very happy that I found this nice forum. I have been reading to you for a few days and I have been impressed by the information. I read her analyzes on oils but I do not understand many things.
I have two cars, the Honda civic 1,8 2006 engine gode R18A2 and  I have converted to natural gas(CNG) and the vw polo 1,0 tgi (CNG) .
Civic has confused me a lot what oil to put on it. Honda states that we must put Motul eco-lite 0w-20. But here in Greece things are very strange. Some put 10w-40, others put 5w-40, others put 5w-30. And very few put 0w-20. In the last 6-7 years I put 0w-20. Which I used to put 5w-40 and 5w-30. I did not know that Honda said to put 0w-20.
Both cars make short trips .3 km in the morning to go to work me and my wife the child at school. The engine runs for about 10 minutes and turns off. And 3 km at noon to return home at noon me. And another 3 km my wife to pick up the child from school at noon. And with one of the two cars we make some trips when we can.
Honda makes 6000-7000 km per year. Vw Polo makes about 8000-9000 km a year.
I put Castrol edge longlife III 5w-30 in the polo, but I found this site that states that the Castrol stopped cooperating with the cast and now has cooperation with the Shell. And 5w-30 replaces it with 0w-30. See the link.
The temperatures we have in my city Larissa are -10, -5 in winter, but for a few days. And in the summer up to + 35, + 38.
In my city we do not have too much traffic. My house is outside the center.
Please help me!! What oil should I choose for these cars? Do I need to change the oils more often? At 6 months? Or in 1 year?  Honda civic with motul eco-lite 0w-20 I estimate that it burns about 400 grams at 7000-8000 km. The Vw polo with Castrol edge longlife III 5w30 50400 burns about 300 grams at about 8000 km.
https://vagdrive.com/threads/vsjo-ob-originalnyx-motornyx-maslax-volkswagen.1218/?fbclid=IwAR1UYhfem_4-Z8tlZy76TT0u9o37cK1RhqzSSf2QdId_34o0usxqylUJ67g
Пришлось писать по-русски ?
Привет из Греции. Я очень рад, что нашел этот хороший форум. Я читал вам несколько дней и был впечатлен этой информацией. Я читал ее анализы по маслам, но многого не понимаю.
У меня две машины: Honda civic 1,8 2006 с двигателем gode R18A2, я переоборудован на природный газ (CNG) и vw polo 1,0 tgi (CNG).
Сивик меня очень смутил какое масло на него наносить. Хонда заявляет, что мы должны поставить Motul eco-lite 0w-20. Но здесь, в Греции, все очень странно. Одни ставили 10w-40, другие ставили 5w-40, третьи ставили 5w-30. И очень немногие поставили 0w-20. Последние 6-7 лет ставлю 0w-20. Которые я раньше ставил 5w-40 и 5w-30. Я не знал, что Хонда сказала поставить 0w-20.
Обе машины совершают короткие поездки на 0,3 км утром, чтобы поехать на работу, я и моя жена, ребенок в школе. Двигатель работает около 10 минут и выключается. И 3 км в полдень, чтобы вернуться домой в полдень мне. И еще 3 км жена забирает ребенка из школы в полдень. И на одной из двух машин мы совершаем поездки, когда можем.
Хонда делает 6000-7000 км в год. Vw Polo проезжает около 8000-9000 км в год.
Я положил Castrol edge longlife III 5w-30 в поло, но я нашел этот сайт, на котором говорится, что Castrol прекратил сотрудничество с актерским составом и теперь сотрудничает с Shell. И 5w-30 заменяет его на 0w-30. См. Ссылку.
Температуры у нас в городе Лариса -10, зимой -5, но несколько дней. А летом до +35, +38.
В моем городе не очень много трафика. Мой дом находится за пределами центра.
Пожалуйста, помогите мне!! Какое масло выбрать для этих автомобилей? Нужно ли чаще менять масла? В 6 месяцев? Или через 1 год? Honda civic с motul eco-lite 0w-20, по моим оценкам, сжигает около 400 грамм на 7000-8000 км. Vw polo с Castrol edge longlife III 5w30 50400 сжигает около 300 граммов примерно на 8000 км.
Do you think that I do not need to change the oil in a few months because I do short trips? And for the second car, Vw polo, in the dealership and warranty ratio, they want the 50400 specification. I will have a problem with the warranty if I put oil without the 50400 specification.
Вы думаете, что мне не нужно менять масло через несколько месяцев из-за коротких поездок? А для второй машины, Polo, в соотношении дилерского центра и гарантии они хотят спецификацию 50400. У меня будут проблемы с гарантией, если я поставлю масло без спецификации 50400.
Then for Polo:
https://erwin.volkswagen.de/erwin/downloadStaticFile/volkswagen/files/oil/step_50400_50700.pdf
The choice is yours.
Change every 1 year or 8 000-10 000 km. Regardless of short trips. This is my opinion.
@jimptsog, hi
U can easy use 5-20 ilsac. Or even 0-20.
i dont see any sense to use higher viscosity. Especially for honda.
For example - shell 0-20, quaker state 5-20, idemitsu zepro 0-20, castrol edge supercar 0-20 a1.
Have a look at analyses, therere no wear.
Of course, u can use 5-30 ilsac also, but oil in your engines even doubtly finaly gets to its sae.
If u worried abt warranty, continue use their oil. Imho.
I want to write something else that happened this winter. When I start the engine the Vw polo 2019 model, in the morning, the engine has 1400 rpm. In summer + 20, + 30 C and in winter with normal temperatures for Greece, -2.0, +2 C, the engine has 1400 rpm when I start. This winter in one day it was -9 C in the morning. I start the engine at the pole and noticed that the engine  was 1200 rpm. Why is this happening? Why was the engine 200 rpm less? Were the oils frozen? It also had a different, louder noise when the engine started the morning at -9 C.
The oil I have on the Vw polo is castrol edge longlife III 5w30.
Изменено пользователем jimptsog
That depends on various factors. If rpms stable (not jumping up'n'down) and no any unusual vibration, so theres nothing to worry about)
@SAE20, cud u advice anythng?
Изменено пользователем Dimitreska190388
