Amsoil Signature Series Synthetic 0W-20 отработка на Hyundai Creta после 0-200км-6000км
jimptsog ответил в теме пользователя Евген48 в Лабораторные анализы отработок - Бензиновые двигателиI have put the Amsoil 0w20 oil once in the Honda Civic 2006 model 1.800 cc for 9000 km and 1 year,, and it burned 300 grams. The next year I put Amsoil 5w20. With this oil I have done 7000 km so far and it has burned 600 grams so far. I can't understand why it has burned oil with the 5w20. But I have decided to use the Amsoil 0w20 next time. I read on your forum that many times it is recommended to change the oil at 7500 km for multiple oils. I wanted to ask, if the car runs on natural gas (CNG), can the oil change interval be extended? Does the oil last more km? Is there any discussion about the endurance of the oil when the engine burns natural gas (CNG) ? Let me inform you that my Honda Civic has been converted and it burns natural gas (CNG). Now it has a total of 151,000 km. 60,000 km have been done with natural gas (CNG) .
Mobil1 ESP LV 0W-30 свежее
Your English is very good. You can answer me in Russian. I will translate and understand. I look at the flash point for shell helix ultra a5b5 0w30. Is 242 C ASTM D92 . Is this measurement with the cap open ? file:///C:/Users/user/Downloads/GPCDOC_Local_TDS_United_Kingdom_Shell_Helix_Ultra_A5_B5_0W-30_(SL_A5_B5)_(en-GB)_TDS.pdf
- Mobil1 ESP LV 0W-30 свежее
Amsoil Signature Series 0W-20 отработка на Honda Civic после 9821км
jimptsog ответил в теме пользователя anatoleech в Лабораторные анализы отработок - Бензиновые двигателиHi from Greece !! I have same car with R18A2 engine. Yesterday I bought this oil amsoil signature serius 0w20. I will put it on for the first time. Now I have oil motul eco-lite 0w20. Do you continue to put the amsoil oil?
Help for the 50400 oil specification.
Hi..I am from Greece. I have Vw polo 1.0 tgi CNG 14,000km. At the moment the engine has oil Castrol edge profesional long life III 5w30. I am reading the forum these days. I am trying to understand the tests and the analyzes that have been done. You have all done an incredible job. Well done. I want to change the oils and I am between three oils. To continue with the Castor 5w30 oil that has titanium 25-30 ? To put the oil of mobil 1 ESP 0w30 which has molybdenum 80 and oxidation 40.9 ? Or to put the new oil VW longlife III FE 0W30 ? That oil for Europe is in cooperation with the Shell, and it is the same oil Shell Ultra ECT C2/C3 0w30 but it does not have molybdenum. What would you do in my position? Is it better for the oil to have titanium, molybdenum or to have neither? Привет .. Я из Греции. У меня Vw polo 1.0 tgi CNG 14000км. На данный момент в двигателе стоит масло Castrol edge profesional long life III 5w30. Я сейчас читаю форум. Я пытаюсь понять тесты и анализы, которые были сделаны. Вы все проделали невероятную работу. Отличная работа. Я хочу поменять масла, а я между тремя маслами. Чтобы продолжить масло Castor 5w30 с титаном 25-30? Ставить масло mobil 1 ESP 0w30 с молибденом 80 и степенью окисления 40.9? Или поставить новое масло VW longlife III FE 0W30? Это масло для Европы производится в сотрудничестве с Shell, и это то же масло Shell Ultra ECT C2 / C3 0w30, но без молибдена. Что бы вы сделали на моем месте? Что лучше, если в масле есть титан, молибден или ни того, ни другого?
jimptsog ответил в теме пользователя Евген48 в Лабораторные анализы отработок - Бензиновые двигателиHello . What is the ultimate answer to reducing TBN for amsoil SS 0w20 ? I read 34 pages and thought I would find an answer at the end. A year has passed. Now we have March 2021. There is no answer; In the end, the company is lying about ΤBN 12.5?
jimptsog ответил в теме пользователя Евген48 в Лабораторные анализы отработок - Бензиновые двигателиHello . What is the final answer of the company Amsoil for the reduction of TBN for amsoil SS 0w20 ? Read 34 pages and I thought I would find an answer at the end. You have asked an email to the Amsoil company. A year has passed. Now we have March 2021. There is no answer?
From Greece !! Oil for civic 1,8 2006 and vw polo tgi (cng)
I want to write something else that happened this winter. When I start the engine the Vw polo 2019 model, in the morning, the engine has 1400 rpm. In summer + 20, + 30 C and in winter with normal temperatures for Greece, -2.0, +2 C, the engine has 1400 rpm when I start. This winter in one day it was -9 C in the morning. I start the engine at the pole and noticed that the engine was 1200 rpm. Why is this happening? Why was the engine 200 rpm less? Were the oils frozen? It also had a different, louder noise when the engine started the morning at -9 C. The oil I have on the Vw polo is castrol edge longlife III 5w30.
Do you think that I do not need to change the oil in a few months because I do short trips? And for the second car, Vw polo, in the dealership and warranty ratio, they want the 50400 specification. I will have a problem with the warranty if I put oil without the 50400 specification. Вы думаете, что мне не нужно менять масло через несколько месяцев из-за коротких поездок? А для второй машины, Polo, в соотношении дилерского центра и гарантии они хотят спецификацию 50400. У меня будут проблемы с гарантией, если я поставлю масло без спецификации 50400.
Пришлось писать по-русски ? Привет из Греции. Я очень рад, что нашел этот хороший форум. Я читал вам несколько дней и был впечатлен этой информацией. Я читал ее анализы по маслам, но многого не понимаю. У меня две машины: Honda civic 1,8 2006 с двигателем gode R18A2, я переоборудован на природный газ (CNG) и vw polo 1,0 tgi (CNG). Сивик меня очень смутил какое масло на него наносить. Хонда заявляет, что мы должны поставить Motul eco-lite 0w-20. Но здесь, в Греции, все очень странно. Одни ставили 10w-40, другие ставили 5w-40, третьи ставили 5w-30. И очень немногие поставили 0w-20. Последние 6-7 лет ставлю 0w-20. Которые я раньше ставил 5w-40 и 5w-30. Я не знал, что Хонда сказала поставить 0w-20. Обе машины совершают короткие поездки на 0,3 км утром, чтобы поехать на работу, я и моя жена, ребенок в школе. Двигатель работает около 10 минут и выключается. И 3 км в полдень, чтобы вернуться домой в полдень мне. И еще 3 км жена забирает ребенка из школы в полдень. И на одной из двух машин мы совершаем поездки, когда можем. Хонда делает 6000-7000 км в год. Vw Polo проезжает около 8000-9000 км в год. Я положил Castrol edge longlife III 5w-30 в поло, но я нашел этот сайт, на котором говорится, что Castrol прекратил сотрудничество с актерским составом и теперь сотрудничает с Shell. И 5w-30 заменяет его на 0w-30. См. Ссылку. Температуры у нас в городе Лариса -10, зимой -5, но несколько дней. А летом до +35, +38. В моем городе не очень много трафика. Мой дом находится за пределами центра. Пожалуйста, помогите мне!! Какое масло выбрать для этих автомобилей? Нужно ли чаще менять масла? В 6 месяцев? Или через 1 год? Honda civic с motul eco-lite 0w-20, по моим оценкам, сжигает около 400 грамм на 7000-8000 км. Vw polo с Castrol edge longlife III 5w30 50400 сжигает около 300 граммов примерно на 8000 км.
Hello from Greece. I am very happy that I found this nice forum. I have been reading to you for a few days and I have been impressed by the information. I read her analyzes on oils but I do not understand many things. I have two cars, the Honda civic 1,8 2006 engine gode R18A2 and I have converted to natural gas(CNG) and the vw polo 1,0 tgi (CNG) . Civic has confused me a lot what oil to put on it. Honda states that we must put Motul eco-lite 0w-20. But here in Greece things are very strange. Some put 10w-40, others put 5w-40, others put 5w-30. And very few put 0w-20. In the last 6-7 years I put 0w-20. Which I used to put 5w-40 and 5w-30. I did not know that Honda said to put 0w-20. Both cars make short trips .3 km in the morning to go to work me and my wife the child at school. The engine runs for about 10 minutes and turns off. And 3 km at noon to return home at noon me. And another 3 km my wife to pick up the child from school at noon. And with one of the two cars we make some trips when we can. Honda makes 6000-7000 km per year. Vw Polo makes about 8000-9000 km a year. I put Castrol edge longlife III 5w-30 in the polo, but I found this site that states that the Castrol stopped cooperating with the cast and now has cooperation with the Shell. And 5w-30 replaces it with 0w-30. See the link. The temperatures we have in my city Larissa are -10, -5 in winter, but for a few days. And in the summer up to + 35, + 38. In my city we do not have too much traffic. My house is outside the center. Please help me!! What oil should I choose for these cars? Do I need to change the oils more often? At 6 months? Or in 1 year? Honda civic with motul eco-lite 0w-20 I estimate that it burns about 400 grams at 7000-8000 km. The Vw polo with Castrol edge longlife III 5w30 50400 burns about 300 grams at about 8000 km. https://vagdrive.com/threads/vsjo-ob-originalnyx-motornyx-maslax-volkswagen.1218/?fbclid=IwAR1UYhfem_4-Z8tlZy76TT0u9o37cK1RhqzSSf2QdId_34o0usxqylUJ67g
