Sanja83
Пользователи
  • Зарегистрирован
  • Посещение
  1. Sanja83 ответил в теме пользователя Finik в Топливо и АЗС
    Ну вот пришел и ответ от Neste ) Hello Aleks, Nice that you have found our Neste MY product. Neste have tested MY renewable diesel for more than 15 years in our own research center in Finland and also with several parties around the world. According to cetane number there have been possitive feedback for high number. Most cases high cetane number helps with cold startability, emissions and engine noise. We have not seen negative side of high cetane in diesel engines. And that´s why we can say that Neste MY renewable diesel can be used in 100% blend in diesel engines. There is no need to make any blend with fossil fuels. But also be aware that if needed you can also blend Neste MY with standard Futura diesel in any blend ration if neste MY is not available in the station where you are going to fill your tank. And about Lubricating components Neste MY have same kind of chemical componets that fossil diesel. So also same kind of lubricity additives are added to the diesel before it´s released to the market. Due to feedstock and production process, neste my is sulphur free fuel sulphur content less than 1 mg/kg. Compared fossil diesel where sulphur level is max 10 mg/kg. One good informative paper is ACEA "world wide fuel charter" that document is general for diesel and gasoline fuels. But you can find some information about cetene number from that book.
  2. Если сравнивать его с Castrol EDGE 5W-30 ll , по составу они стали одинаковыми? Подскажите пожалуйста, знающие люди! Долго выбирал, на чем остановится, покупал пару канистр Castrol, так и лежат дома! А в итоге залил Mobil 1 ESP 5W-30 2023 года! Вот теперь думаю что залил тот же гидрокрекинг, ведь Mobil по составу превосходил Кастрол-а!
  3. Вот, покупал канистру 5 л Mobil 1 ESP 5W-30 у оф дилера Lexus в Таллинне! Заметил что дата производства стирается пальцем! А дата производства самой канистры на дне - вообще еле видно! Производство Франция
  4. Sanja83 ответил в теме пользователя Finik в Топливо и АЗС
    На каждом Neste продают! Отправил им письмо, процитирую тут! «Здравствуйте! Подскажите пожалуйста! Где я могу подробнее посмотреть про топливо Neste MY diesel? В паспорте на странице производителя не указана эта информация! А именно - смазывающая составляющее, цетановое число, сера ! Цетановое число указано в районе 70 единиц только в описании продукта но не в документе! Не повредит ли дизельному двигателю автомобиля постоянная заправка этим топливом в чистом виде, не смешивая с другим дизелем? Или все же его лучше смешивать с другим дизелем, допустим 50 на 50 % ? Меня беспокоит цетановое число на отметке свыше в 70 единиц! Слышал что такое цетановое число плохо скажется для дизельного двигателя! Не оставит ли нагар в моторе и как себя будет чувствовать топливный насос? Спасибо» в итоге документ нашел! )
  5. Sanja83 ответил в теме пользователя Finik в Топливо и АЗС
    Расход ни больше ни меньше по сравнению с обычным дизелем! Во всяком случае мне так показалось! Вот высокий цетан меня и беспокоит! Но в то же время мне нравится как работает мотор, отклик педали газа в разы лучше! А вот показатели Circle K - бывшее название Statoil , где я уже лет 20 машину и заправлял! Там цетан 51 )
  6. Sanja83 ответил в теме пользователя Finik в Топливо и АЗС
    Вот, нашел на их финском сайте! Цетан 70, смазывающее 400 Neste MY.pdf
  7. Sanja83 ответил в теме пользователя Finik в Топливо и АЗС
    Пишут что без серы! А вот по поводу смазывающей информации не нашел!
  8. Sanja83 ответил в теме пользователя Finik в Топливо и АЗС
    Взято у них на веб странице https://www.neste.ee/sites/neste.ee/files/13898_neste_renewable_diesel_neste_renewable_diesel_100_neste_my_renewable_diesel_02.02.2023_rus.pdf
  9. Sanja83 ответил в теме пользователя Finik в Топливо и АЗС
    Всем привет! Как относитесь к этому топливу, стоит ли доверять? https://www.nestemy.ee/ru/ Пошел 3-ий бак! Мотор работает тише, динамика как будто лучше, разгон бодрее! Расход не заметил, использую родной доп отопитель, раньше от другого диз топлива был запах, сейчас его не чувствую! Заливаю в Škoda Octavia 2016 г, дизель, 2.0 135 kw, сажевый родной на месте! Производитель пишет что цетановое 70! Где то вычитал что слишком высокое цетановое число вредит мотору! Топливо прозрачное как вода, ничем не пахнет! Не содержит FAME - RME! Расписано от производителя красиво! Но че то стремно заливать в долгосрочной перспективе!
