18 декабря 202518 дек Закреплён 1) Ford Bronco Sport 1.5 20212) Задний дифференциал RDU3) Морозы бывают до (-30С) крайне редко, в основном -10/-154) Аналогов никаких нет, будто бы5) Мануал требует Motorcraft SAE 75W Disconnect Rear Drive Unit Fluid, артикул XY-75W-QL, API GL-5 Motorcraft® SAE 75W Disconnect Rear Drive Unit Fluid is specifically formulated for Ford disconnect rear drive units with a low offset hypoid gear Developed with a lower viscosity to improve axle efficiency and fuel economy Motorcraft® SAE 75W Disconnect Rear Drive Unit Fluid is formulated with synthetic base stocks, friction modifiers, antiwear and extreme pressure additives to provide gear protection and smooth clutch operation Use only in Ford Disconnect Rear Drive Units DO NOT use in conventional high-offset hypoid gear axles where SAE 75W-85, 75W-90, 80W-90 or 75W-140 is recommended
