badsykes
Пользователи
  • Зарегистрирован
  • Посещение
  1. I want to thank Dimmy for advices.
  2. Sorry i misunderstood you a little Dimmy.. "Badsykes, I think that advanced API diesel classes (CH-4, CI-4) speak for themselves. Don't forget such oils are different from common SM/CF or SN/CF. Besides, the diesel class goes first. If you prefer better heavy duty protection Lukoil Avantgarde Professional is for you." From this line i understood to stay away from Avantgarde Ultra because is more for diesel and not for my gasoline.So after this i looked at the others Truck oils and i felt the same so i ruled them out. To be clear YES i do seek heavy duty engine oil..Now you made it clear that except the Profesional i can use the Avantgarde Ultra.. I want also to replace Gearbox oil and Transfer Box oil..In the Car book it says that both of them (gear and transfer boxes) need the same oil like the engine..Can i use Avantgarde Ultra here too or i need something else?
  3. The Profesional line is still very diesel oriented oil.. http://lukoil-lubricants.com/products/commerce/motoroils/00231/ The avantgarde extra says something about gasoline but not sure again: http://lukoil-lubricants.com/products/commerce/motoroils/00156/ The only option would be to go with Luxe line semi synth..
  4. Itseasy: I was thinking of better protection for heavy duty stuff but i may be wrong...I read that avantgard is for mixed fleets..I did feel that this oil is more for diesel engines.. thanks
  5. Hello I am new to the forum in search for some advice..I don't know russian at all so i use google translate so i may ask some stupid questions because of that.. I own an Opel Frontera 2.0i (1996, x20se engine) gasoline and i want to replace the Castrol Magnatec 10w40 with something suited for winter days (-20 C).Also the Lukoil Avantgarde 5w40 seems the only semi synthetic with this rating on my market..The reason i choose a part-synthetic oil is that i am afraid of leaks. I use the car off-road for steep hills and muddy stuff so the engine is put under pressure. thanks
